Is there a reason that an angle theta from zero to pi/2 (0 to 90 deg) returns as invalid for an animation range?  I am trying to rotate a vector 2D for visualization.  This is build-up towards a 3d rotating vector in an animation.
Here is the code: theta is the arrow tip rotation's location via cos(theta), sin(theta) coordinates in a 2D vector.
animate(arrow, [<cos(theta), sin(theta)>, width = [0.05, relative], view = [-1 .. 2, -1 .. 2], color = "blue"], theta = 0 .. Pi/2)
ErrorMessage:
Error, (in plots/animate) 0 = 0 .. (1/2)*Pi  is an invalid animation range
Thanks In Advance,
Bill
does Maple have a PDE solver? I want to solve the following inhomogeneous case of the heat equation:
diff(u(t,x,y,z),t)=k*Laplacian(u(t,x,y,z))+l*u(t,x,y,z)+m
with boundary conditions u(t,0,y,z)=u(t,L,y,z)=u(t,x,0,z)=u(t,x,L,z)=u(t,x,y,0)=u(t,x,y,L)=0. The initial condition is not fixed, as I want to try different cases. It will probably be some sinusoidal spatial function. I would prefer an analytic solution but I could live with a numerical one. If not in three spatial dimensions then even a solution with one dimension would be useful. I would appreciate any help.
How can this expression sorted in order of the symbol "y"? I want the terms with y locate at the beginnig.
f:=x^2+x^y+1-z
x^2+x^y+1-z
Download sort.mw
As the title, who can help me fix the problem like this
theta:= diff(arctan(y,x)):
W:= piecewise(
         theta>-Pi/2 and theta< -Pi/2+10, 1+A+B*cos(theta),
         theta>-Pi/2+10 and theta< Pi/2-10. 1-A+B*cos(thea));
there always plotout the undefined when acrtan(y,x)=Pi/2,
How can I ignore this undefined or define another value for W when acrtan(y,x)=Pi/2
    Dear Fellows
Hoped everything is fine with you. I plotted some contours for a flow model and i want to generate its dat file. Please help me in this regard. Thanks
Attached is a worksheet containing a simple assignment that gives an "illegal use of an object as a name" error. I created the superscripted name in the following way.
1)  type b.
2) click on the Insert|Typesetting|Superscript  item in the insert menu.
3) enter 1 at the cursor in the superscript position.
4)  the result is a name b with superscript 1, but this symbol does not constitute a valid name for an assignment.
Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
Error, illegal use of an object as a name
"b^1:=2+3;"
Download errorws.mw
How Would I fix that?
I forgot how to display the output ar an array i.e. (r,u(r)) (table of data)
I am sure i will find answers here.
a:=-0.1:alpha:=0.2:
dsys:={diff(u(r),r,r)+((1-alpha)/r+r^(alpha-2))*diff(u(r),r)=a};
res1:=dsolve(dsys union {u(0.05)=0,u(1)=0},numeric);
How we can see steps of Laplace transform calculation?
In a thesis by Md. Mohsin Ali at the University of Ontario, he says that ifactor uses multiple threads and presents a graph of measured results.
I ran ifactor with a 100 digit input and do not see mserver using multiple cores in top.  I do see mserver using 100% of a single core.
Am I missing something?
It would be nice to save various animated Maple images from into GIF images, but without the coordinates and the axes. THe same question in anoehr way: Can we plot the original function without any axes or coordinates?
mapleatha
ifactor(1522605027922533360535618378132637429718068114961380688657908494580122963258952897654000350692006139);
kilobytes used=921, alloc=1200, time=0.09
kilobytes used=1325, alloc=5296, time=0.13
kilobytes used=107733, alloc=9228, time=6.64
Process Maple segmentation fault (core dumped)
No matter what I do from the keyboard, a core dump is not a reasonable response.
This worksheet animates stereographic projection of a grid on a sphere onto the plane the sphere sits on.
Is there a way to display matching colors in corresponding cells in the two grids?
Stereographic_projection.mw
My question is whether any special interest groups exist in the Maple Cloud?  If so, is there a public listing of these groups?
First 417 418 419 420 421 422 423 Last Page 419 of 2432
