I was applying the Grip Map to the procedure LArip. It apparently finished in less than 5 seconds. But when I wanted to display the results as an Array, this step required minutes. How can this time be reduced? Here is a piece of the code:
n := 8;
r := 2^n;
M := Vector(r, randperm(r) + [-seq(1, i = 1 .. r)], datatype = integer[4]);
LArip := proc(k::integer, r::integer, M::Vector(datatype = integer[4]))
local N, j, t, i, A;
N := Vector(r, 0); A := Vector(r, 0);
i := k - 1;
for j from 0 to r - 1 do
for t from 0 to r - 1 do
N[t + 1] := Occurrences(1, Split(Xor(And(t, i), And(M[t + 1], j)))) mod 2;
A[j + 1] := Occurrences(0, convert(N[], list));
return convert(A, list);
infolevel[Grid:-Map] := 3;
rt := time[real]();
Bb := Grid:-Map(k -> LArip(k, r, M), [$ (1 .. r)]);
GridMapTime := time[real]() - rt;
The worksheet is here:
Magma_GridMap.mw
Thank you for your help.
Hey!
I am using the solve function and I get the following form of the result :
rootsq0 := {z = 9.096986124+3.141592654*I}, {z = 1.138376998+3.141592654*I}, {z = .3074241220+3.141592654*I}, {z = .5854971300+3.141592654*I}, {z = -2.519351300+3.141592654*I}, {z = -5.138371980+3.141592654*I}, {z = -1.759344122+3.141592654*I}, {z = -0.9698634104e-1+3.141592654*I}
I want to convert rootsq0 into a list [9.096986124+3.141592654*I, 1.138376998+3.141592654*I, ...]. So, I would like to remove {} and z=. Any suggestions are welcome! :)
Is it possible to write an equation reduction program that uses only LinearAlgebra.?
restart; with(LinearAlgebra); with(Student[LinearAlgebra]); unprotect(D);
f := proc (x, y) options operator, arrow; 5*x^2+4*y*x+8*y^2+16*x-8*y-16 end proc;
A := coeff(f(x, y), x, 2); B := coeff(coeff(f(x, y), x, 1), y, 1); C := coeff(f(x, y), y, 2); D := coeff(coeff(f(x, y), x, 1), y, 0); E := coeff(coeff(f(x, y), y, 1), x, 0);
F := tcoeff(f(x, y));
MQ:=Matrix([[A,B/2], [B/2,C]]):
Delta := A^2-4*A*C;
ML := `<,>`(D, E);
vp := Eigenvalues(MQ);
Omega := evalm(-`&*`((1/2)*ML, 1/MQ));
M1 := MQ-Eigenvalues(MQ)[1]*IdentityMatrix(2);
M2 := MQ-Eigenvalues(MQ)[2]*IdentityMatrix(2);
D := JordanForm(MQ);
with(linalg);
ma := matrix(2, 2, [A, (1/2)*B, (1/2)*B, C]);
jordan(ma, 'P1'); G := map(normalize, GramSchmidt([col(P1, 1 .. 2)])); P := map(simplify, concat(op(G)));
evalm(`&*`(`&*`(1/P, MQ), P));
nx := [X, Y];
var := [x, y];
x := matrix([seq([nx[i]], i = 1 .. 2)]); y := evalm(`&*`(P, x));
s := seq(var[k] = y[k, 1]+Omega[k], k = 1 .. 2);
eq := unapply(simplify(expand(subs(s, f(x, y)))), X, Y);
alpha := -eq(0, 0);
a := sqrt(alpha/vp[2]); b := sqrt(alpha/vp[1]); c := sqrt(a^2-b^2); print(X^2/a^2+Y^2/b^2 = 1);
This program works;. It is possible to simplify ? Thank you.
eq := 61*x^2 + 1 = y^2;
sols := (isolve(eq) assuming (x::posint, y::posint)):
for sol in sols do
  print(subs(_Z1 = 1, sol));
isolve returns the solution in terms of _Z1, indicating there may be infinite number of solutions?
I think {x = 226153980, y = 1766319049} is the only solution with x::posint, y::posint.
How do I restrict this to only positive integers in the solution?
If you could assist; I am trying to set something like an asymptote or upper limit such that my plot below approaches asymptotically (below y =1 ) from negative infinity:
Download Plotting.mw
Why Float(undefined) appears in calculation integrals
3333.mw
I see this question at here
https://mathematica.stackexchange.com/questions/239874/how-to-reduce-timing-to-find-the-integer-numbers-a-b-c-d-e-f-g-h-k-m-of
How to solve this problem by Maple?
command completion (when hitting the ESC key) in Maple could be made more useful. It does not seem to support type names for example.
What shows up on the command completion window are  possible commands that start with that partial text.
It does not list other known names by Maple, such as type names and other options.
This makes it hard to use in many places, where one have to remember type names exactly instead of the system helping them by listing all possible type names that start with that string.
Is there a way around this? Will Maple next version support smarter and more complete command completion menu?
dear all
I would like to display the error ( tab_err) and plot it.
The code run without any mistakes but there is no table of error dispalyed and can then be plotted
integ_R.mw
Thank you for any help
How to plot Complex vales in 2D?
Z be complex.
rho := 1/4; mu := 1/4; E := sum(Z^k/GAMMA(k*rho+mu), k = 0 .. 5)
I am trying to run this code but this error message is coming up "Error, (in fprintf) number expected for floating point format
". What have I done wrong and how do I correct it.
Thank you and best regards.
Digits:=30:
f:=proc(n)
	-((sin(x[n]))/(2-sin(x[n])))*(2+sin(x[n]-Pi)):
e1:=y[n+1]=h*delta[n]-(1/2)*h^2*(-u^2*sin((1/2)*u)+2*cos((1/2)*u)*u-2*cos(u)*u-4*sin((1/2)*u)+2*sin(u))*f(n)/(u^2*(2*sin((1/2)*u)-sin(u)))+(1/2)*h^2*(u^2*sin((1/2)*u)+2*cos((1/2)*u)*u-4*sin((1/2)*u)+2*sin(u)-2*u)*f(n+1)/(u^2*(2*sin((1/2)*u)-sin(u)))-(1/2)*h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u)))+y[n]:
e2:=h*delta[n+1]=h*delta[n]+h^2*(u*sin((1/2)*u)+cos(u)-1)*f(n)/(u*(2*sin((1/2)*u)-sin(u)))+h^2*(u*sin((1/2)*u)+cos(u)-1)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u))):
e3:=y[n+1/2]=(1/2)*h*delta[n]-(1/8)*h^2*(-u^2*sin((1/2)*u)+4*cos((1/2)*u)*u-4*cos(u)*u-16*sin((1/2)*u)+8*sin(u))*f(n)/(u^2*(2*sin((1/2)*u)-sin(u)))+(1/8)*h^2*(u*sin((1/2)*u)+4*cos((1/2)*u)-4)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-(1/8)*h^2*(u^2*sin(u)+4*cos(u)*u+16*sin((1/2)*u)-8*sin(u)-4*u)*f(n+1/2)/(u^2*(2*sin((1/2)*u)-sin(u)))+y[n]:
e4:=h*delta[n+1/2]=h*delta[n]-(1/2)*h^2*(-u*sin((1/2)*u)+4*cos((1/2)*u)-2*cos(u)-2)*f(n)/(u*(2*sin((1/2)*u)-sin(u)))+(1/2)*h^2*(u*sin((1/2)*u)+4*cos((1/2)*u)-4)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-(1/2)*h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u))):
inx:=0:
ind:=1:
iny:=2:
h:=Pi/4:
n:=0:
omega:=1:
u:=omega*h:
N:=solve(h*p = 8*Pi, p):
c:=1:
for j from 0 to 1 by 1/2 do
	t[j]:=inx+j*h:
vars:=y[n+1/2],y[n+1],delta[n+1/2],delta[n+1]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%6s%15s%15s%16s%15s%15s%15s\n",
	"h","Num.y","Num.z","Ex.y","Ex.z","Error y","Error z");
#eval(<vars>, solve({e||(1..4)},{vars}));
st := time():
for k from 1 to N do
	par1:=x[0]=t[0],x[1/2]=t[1/2],x[1]=t[1]:
	par2:=y[n]=iny,delta[n]=ind:
	res:=eval(<vars>, fsolve(eval({e||(1..4)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		exy:=eval(2+sin(c*h/2)):
		exz:=eval(-sin(c*h/2)+10*epsilon*cos(10*c*h)):
		printf("%6.5f%17.9f%15.9f%15.9f%15.9f %13.5g%15.5g\n",
		h*c,res[i],res[i+2],exy,exz,abs(res[i]-exy),
		abs(res[i+2]-exz)):
		c:=c+1:
	iny:=res[2]:
	ind:=res[4]:
	inx:=t[1]:
		t[j]:=inx + j*h:
How to add a legend to Statistics:-Histogram?
This could be particularly useful to compare histograms, for instance in
S := Statistics:-Sample(Normal(0, 1), 1000):
T := Statistics:-Sample(Normal(1, 1), 1000):
plots:-display(
  Statistics:-Histogram(S, color=gold, transparency=0.3, legend="N(0,1)"),
  Statistics:-Histogram(T, transparency=0.3, legend="N(1,1)")
But doing this generates the error Error, (in Statistics:-Histogram) display does not accept the legend option
And yes indeed, even this command
h := Statistics:-Histogram(S, legend="N(0,1)")
already produces the same error.
After having examined the structure of h and using a way Carl Love gave here How to change the colour inn Statistics:-Sunflower?  I finally obtained the expected plot.
HS := Statistics:-Histogram(S, color=gold, transparency=0.3):
HT := Statistics:-Histogram(T, transparency=0.3):
hs := evalindets([op(HS)], specfunc(COLOUR), c-> (c, LEGEND("N(0,1)")) ):
ht := evalindets([op(HT)], specfunc(COLOUR), c-> (c, LEGEND("N(1,1)")) ):
PLOT(op(hs), op(ht))
But this rather long a way to proceed (Note: it seems that the overrideoption  that acer suggested in this prevous thread doesn't "work" here?)
Do you have any idea if there is a simpler solution?
TIA
AoA....
sir how we solve partial differential equation by Adomian Decomposition method in maple? plz send me maple code..
I have a problem when running the follwoing code using the input proposed.
integ_R.mw
problem : print_table , used as input in  proc
I tried to compute an integral using trapezoidal rule using two differents methods but I get two different results
trap.mw
First 445 446 447 448 449 450 451 Last Page 447 of 2432
