I am porting some code I have  from Mathematica to Maple.
In Mathematica, there is a command https://reference.wolfram.com/language/ref/CopyDirectory.html  which copies directory tree (i.e. the directory and everything below it) to a new location on the file system.
I looked at FileTools, and the Copy command there only works on files, not Directories.
"An exception is raised if source is a directory."
There must be a command in Maple to do this basic operation, but I am not able to find it. I googled.
Note: I do not want to rename the directory, but to copy it.
I could ofcourse work around this by writing code or calling system, but I would expect Maple to have a command for this somewhere.
I want to solve a highly nonlinear equation in one variable. The equation includes some undetermined parameters. The running time is long in serial programming. Can I help me to execute the following command in parallel? I know that the ‘solve’ command is not thread-safe.
solve(Eq1, beta);
 Let me know solve the problem, if the number of equations is larger than one, as below:
solve({eq1,eq2,eq3},{beta1,beta2,beta3});
Best wishes
Will Chebyshev differential equation always give  the series solution or not.?
Chebyshev differential equation have variable coefficient,Can we solve it without using any series solution method.
A question about the alias command: Can the abbreviation u[k] of the function call u[k](x, y) be implemented by the alias command, so that the type of u[k] is a function for any integer K?
example:
alias(F[k]=F[k](x));
output:F[k].
whattype(F[k]);
output:function
whattype(F[1]);
output:indexed
I want f[k] to be a function for any integer K. how to implement it? If there are experts to see this question to help answer, will be very grateful!
i want to make a costomized procedure to calculate laplace transform.please guide me why wont MAPLE calculate the limit?  I will use this procedure to make another integral transform so I can not use built-in Laplace Transform commands.
maple.mw
How to plot graphs on the xyz axes? Can somebody tell me step by step
How to evaluate the integration when x=[-infinity , +infinity]?
integration_24sep.mw
I am trying to solve a set of ODEs with dsolve. There are 26 equations of my ODEs, but the problem is a multiple point bvp. So the range is divided into three region. In order to use dsolve, I transform the three subregion's coordinate into 0 to 1. Meanwhile, the ODEs are different in three regions, respectively. So, there are 26×3 equations in total. And according to the paper I want to replicate, it says the response is unstable,so parameter continuation is used. Similar to the paper, an additional equation is added(eq1_27 in code), also an additional condition is added(about lambda). When the lambda is less then 0.11, the dsolve works, but for other values it doesn't work. Could anyone help me?
Sorry for the tedious programming code, I am new to Maple.
I would like to write an automated code, this means that I would like not to copy and paste anything.
4.22647099771398*exp(-0.0104163888375266*t) - 4.22647099771398*exp(-2.00033505979518*t)
I have this as my last result and would like to use the value of the exponential function (0.0104163888375266 and 2.00033505979518) without having to manually copy and paste it into the next function.
How can i do this?
Thank you in advice for your help! :)
I am trying to create a simulation of a UR5e, I have added a spring dampening systen in order to simulate the imput of external forces and torques. However I get a strange error for which I could not find an awnser for on the web.
The closest was
https://www.mapleprimes.com/questions/203860-Compile-Maplesim-Model-To-Ccode
However it is quite old and not entirely a match.
I get the following output
More information
Maplesim 2020
64 bit version
Windows 10
RAM - 16 GB
Do anybody know a solution for this?
Mvh
Eric Ragnarsson
Its easy to calculate a potential function for a vectorfield
But now by hand in 2D Input mode ..a struggle
Doing your homework in 2D Input mode is something totally different then the structurized explanations done in Maple input for lessons by an instructor.
Partiel differentation with respect to what variable, is not notated in 2D mode, so a serie of them showing up in the document says nothing.and reexecuting them a couple of times doubles the output if you have used a inline notation.
Basic idea here f-> f ' -> F(f ') = f  and handling variables x,y, and z for integrating/differentation
with(Student:-VectorCalculus)
BasisFormat(true)
v := VectorField(`<,>`(x, y, z))
Vector(3, {(1) = x, (2) = y, (3) = z})
Student:-VectorCalculus:-ScalarPotential(v); "_noterminate"
(1/2)*x^2+(1/2)*y^2+(1/2)*z^2
Thats easy to use the ScalarPotential for a manual exercise
Example 2: finding a Potential function
Show that F = [exp(x)*cos(y)+y*z, x*z-exp(x)*sin(y), x*y+z] is conversative and find a potential function for it.
F := VectorField(`<,>`(exp(x)*cos(y)+y*z, x*z-exp(x)*sin(y), x*y+z))
Vector(3, {(1) = exp(x)*cos(y)+y*z, (2) = x*z-exp(x)*sin(y), (3) = x*y+z})
y*z*x+exp(x)*cos(y)+(1/2)*z^2
ScalarPotential(F)
So "f(x,y,z):=y z x+(e)^x cos(y)+(z^2)/2 + C :"
Now manual
'F' = value(F)
F = (Vector(3, {(1) = exp(x)*cos(y)+y*z, (2) = x*z-exp(x)*sin(y), (3) = x*y+z}))
(exp(x)*cos(y)+y*z)*`#mover(mi("e"),mo("&lowbar;"))`[x]+(x*z-exp(x)*sin(y))*`#mover(mi("e"),mo("&lowbar;"))`[y]+(x*y+z)*`#mover(mi("e"),mo("&lowbar;"))`[z]
F
F
M := exp(x)*cos(y)+y*z; N := x*z-exp(x)*sin(y); P := x*y+z
x*y+z
x
M1 := exp(x)*cos(y)+y*z
exp(x)*cos(y)+y*z
exp(x)*cos(y)+y*z
"(->)"y   ( to z )
NULLNULL
M2 := exp(x)*cos(y)+y*z
exp(x)*cos(y)+y*z
(14)
exp(x)*cos(y)+y*z
(15)
"(->)"-exp(x)*sin(y)+z (to y) NULL
N1 := x*z-exp(x)*sin(y)
x*z-exp(x)*sin(y)
(16)
x*z-exp(x)*sin(y)
(17)
"(->)"x  (to z)
N2 := x*z-exp(x)*sin(y)
x*z-exp(x)*sin(y)
(18)
x*z-exp(x)*sin(y)
(19)
"(->)"-exp(x)*sin(y)+z (to x)
P1 := x*y+z
x*y+z
(20)
x*y+z
(21)
"(->)"x  (to y )
P2 := x*y+z
x*y+z
(22)
x*y+z
(23)
"(->)"y  ( to x )
Test for to be a conservative field
P1=N1 ,  M1=P2, N2=M2
int(F, x).... integrating F  with respect to x ,holding  y and z fixed
Its a vector form F , probably F must be converted to scalar form? (command?)
exp(x)*cos(y)+y*z+x*z-exp(x)*sin(y)+x*y+z
(24)
x*z+(1/2)*x^2*y+(1/2)*x^2*z+y*z*x+exp(x)*cos(y)-exp(x)*sin(y)
(25)
Ok, can integrate to 3 variables now
Now the partial diretives from f
M1 = exp(x)*cos(y)+y*z"(->)"y*z*x+exp(x)*cos(y) + g(y,z) constant of integration of f (the potential function)NULL
So : "f(x,y,z)= "y*z*x+exp(x)*cos(y)NULL + g(y,z) (1) # a total mess as notation here done by me
The logic from this all not yet completely understood and lost oversight , but this equation (1) must be further  integrated/differentiated  to get
y*z*x+exp(x)*cos(y)+(1/2)*z^2+C
Step by step following the text example in Thomas Calculus (page 1075, example 2) in 2 D mode is not going well.
Download thomas_calculus-vb2-blz_1075_-vraag_forum.mw
Is there a way to find what changed in each Physics update? Even if it is just one or two lines short summary? I am not able to find how to do this.
For example, after doing Physics:-Version(latest); and getting a new version, how to find what was fixed/added to new version?
There is a page in help titled "Overview of the Physics Updates" but I am asking about what specific change made in each update and not as general overall description as the above page talks about.
Again, even if the changes are short, it will be nice to know what changed each time.
I can’t block the display of my p and A variables even if I finish my commands with both points.
Ideas? ThanksTrianglesQuelconques.mw
After running the program without any error, no plot obtained.
What is the reason?
Thanks3.mw
First 502 503 504 505 506 507 508 Last Page 504 of 2432
