For display only purposes, to get the Latex looking better, I replace the constant of integrations Maple using which is _C1, _C2., etc... to c[1],c[2],.....
This is something I do at the very end of computation, just before I get the Latex of the expression.
The way I do this now, is not good. .And I am asking if there is a better way to do this replacement. In Mathematica, I can do this using a patterm where I tell it to replace  C?  by c[?] where ? means anything.
Is it possible to do something like this in Maple? Here is an example
sol:=dsolve(diff(x(t),t$3) = x(t));
This gives solution as
And just before ask for the Latex of this, I change it to
This is done using a function. Please see worksheet below.
The problem with the current solution is that I do not know how many _C there are, so I assumed 10 as worst case, which works for my case. But I prefer a more general solution, may be using pattern in the subs command?
replace_all_C:=proc(expr::anything)
local n,N,c;
local new_expr;
local max_count :=10; #worst case, since do not know how many
    new_expr:=expr;
    for n from 1 to max_count do
        N:=convert(n,string);
        new_expr:=subs( :-parse(cat("_C",N))=:-parse(cat("c[",N,"]")),new_expr);
    return new_expr;
tmp:=replace_all_C(sol)
x(t) = _C1*exp(t)+_C2*exp(-(1/2)*t)*sin((1/2)*3^(1/2)*t)+_C3*exp(-(1/2)*t)*cos((1/2)*3^(1/2)*t)
x(t) = c[1]*exp(t)+c[2]*exp(-(1/2)*t)*sin((1/2)*3^(1/2)*t)+c[3]*exp(-(1/2)*t)*cos((1/2)*3^(1/2)*t)
Download q.mw
And now I get the latex of tmp in the above, instead of sol which looks better.
Can anyone help with plotting the logistic map as a function in Maple
Logistic map x_(n+1)=f(x_n); f(x_n)=r*X(1-x) with the following values:
r=2.0; x(1)=0.3 f=r.*x.*(1-x)
Please help? Thanks.
I created some simple maple 9 code to do some z->w mappings long time ago, on my web page:
https://ingalidakis.com/math/ComplexMaps.html
Upon revising my webpage, I've stumbled upon a page for comformal mappings, by David Bau:
http://davidbau.com/conformal/#exp(z)
Here's the current version of my code in Maple 18:
rrestart;
NULL;
xMax := 1;
yMax := 1;
N := 10;
step := abs(xMax)/N;
GL := proc (x, y) options operator, arrow; x+I*y end proc;
f := sin;
G := {};
for k from -N+1 to N+1 do
G := `union`(G, {complexplot(f(GL(x, (k-1)*step)), x = -xMax .. xMax, color = brown)});
G := `union`(G, {complexplot(f(GL((k-1)*step, y)), y = -yMax .. yMax, color = brown)})
display(G, scaling = constrained);
The code is pretty simple: I am simply scanning the 1x1 unit square complex grid and create a complex plot of it on the w-plane, by passing it through whatever function is at: f:=x.
Does anyone have any idea why the grid lines on the w-plane do not agree with Bau's grid lines mapping of the w-plane? To try it for exp for example, input "exp(z)" in Bau's home page.
The difference is quite noticeable, especially on exp and log, where the orientation of the w-grid on the left and right half-planes, seem to be opposite of what my code displays.
The reason may be Mathematical, but from what I see from the description on Bau's page, there's no difference on the identity function, so I am clueless.
Many thanks in advance
Any idea why the result of the FirstChild function of the attached file is
_XML_Text("\n  ")
Test.zip
I also miss a more complete example on Maple Help for writing, reading and processing xml files.
W := proc ()
      global rf;
     rf := add(xx[ii]^2-nn, ii = 1 .. nn);
    return rf ;
Optimization:-Minimize(W(), nn = 1 .. 5, seq(xx[ii] = 1 .. 10, ii = 1 .. nn));
Error, (in W) unable to execute add
Please solve
A triangle ABC with fixed B and C vertex is considered in the plane, A being variable so that b+c remains constant and equal to a given length L.
We call P, T, T' the points of contact of the exinscrit circle in the angle B with the sides BC, AB and AC respectively.
Show that P is fixed and is one of the vertex of the ellipse described by point A. What are the locus of T and T'? How to animate the drawing when A move ? Thank you.
Hello! Sorry if this question was already asked, I just can't find my answer and I don't really know how to form the question since I'm new to using Maple. My question is: How can I find a point on a plot I did in Maple? When I use the cursor position(from when I click Probe info) I can never align it right enough for me to not get a decimal answer. For instance, I can't figure out the y-value for when x=2 because the closest I can get to 2 is like 2.1 which isn't exact enough for me.
This is a very basic question and apologize for not being able to figure it out myself.     I would like to define a function that I can evaluate with a complicated argument.    For example for a simple function, the following works well
f:=x->x^2+x^3;
This allows me to plot f(x) or f(exp(-r)), etc.
However the following syntax does not work in the same way.
g:=x->diff(f(x),x);
I can plot g(x) correctly, but g(exp(-r))  cannot be plotted or evaluated.    The error message is
Error, (in g) invalid input: diff received exp(-r), which is not valid for its 2nd argument
Thanks in advance for your suggestions.
Hi guys,
an error appeared in solving a set of equations and plotting the solution, I dont know how to handle it!!
Thanks for your help
Best
problem.mw
please help me
Similar*solution
Similar*solution
eq11 := (10-9*lambda1)*n*diff(f(eta),eta,eta,eta)*(-diff(f(eta),eta,eta))^(n-1)-m*diff(f(eta),eta)^2+M^2*diff(f(eta),eta)+(m*(2*n-1)+1)/(n+1)*f(eta)*diff(f(eta),eta,eta)=0;
(10-9*lambda1)*n*(diff(diff(diff(f(eta), eta), eta), eta))*(-(diff(diff(f(eta), eta), eta)))^(n-1)-m*(diff(f(eta), eta))^2+M^2*(diff(f(eta), eta))+(m*(2*n-1)+1)*f(eta)*(diff(diff(f(eta), eta), eta))/(n+1) = 0
eq21 := (10-9*lambda1)*n*diff(theta(eta),eta,eta)*(-diff(theta(eta),eta))^(n-1)+(m*(2*n-1)+1)/(n+1)*f(eta)*diff(theta(eta),eta)-m*diff(f(eta), eta)*theta(eta)=0;
(10-9*lambda1)*n*(diff(diff(theta(eta), eta), eta))*(-(diff(theta(eta), eta)))^(n-1)+(m*(2*n-1)+1)*f(eta)*(diff(theta(eta), eta))/(n+1)-m*(diff(f(eta), eta))*theta(eta) = 0
bc21:= f(0)=0, D(f)(0)=1+alpha*(D@@2)(f)(0), D(f)(N)=0, theta(0)=1+b*D(theta)(0), theta(N)=0;
f(0) = 0, (D(f))(0) = 1+alpha*((D@@2)(f))(0), (D(f))(N) = 0, theta(0) = 1+b*(D(theta))(0), theta(N) = 0
n:=1.2: b:=0: M:=0: alpha:=0:
N:=6:
m:=0.8:
A11:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(1.03827200589718e-4)+HFloat(7.543487679217342e-5)*I' when datatype=float[8]
m:=1.2:
A12:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(1.239112373179345e-4)+HFloat(9.002678360924433e-5)*I' when datatype=float[8]
m:=2:
A13:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(5.684098069533373e-5)+HFloat(4.129738980869168e-5)*I' when datatype=float[8]
p1:=odeplot(A11, [[eta,f(eta),color=red,linestyle=2]],0..N):
p2:=odeplot(A12, [[eta,f(eta),color=blue,linestyle=2]],0..N):
p3:=odeplot(A13, [[eta,f(eta),color=green,linestyle=2]],0..N):
display({p1,p2,p3}, axes=boxed,  title=`velerature Profiles:`);
Error, (in plots:-display) expecting plot structures but received: {p1, p2, p3}
for j from 1 to 100*(N-1) do eta[j]:=A11[2,1][j,1] end do:
for j from 1 to 100*(N-1) do vel1[j]:=A11[2,1][j,2] end do:
for j from 1 to 100*(N-1) do vel2[j]:=A12[2,1][j,2] end do:
for j from 1 to 100*(N-1) do vel3[j]:=A13[2,1][j,2] end do:
E1:= <<seq(eta[j], j=1..100*(N-1) )>|<seq(vel1[j], j=1..100*(N-1) )>|<seq(vel2[j], j=1..100*(N-1) )>|<seq(vel3[j], j=1..100*(N-1))>>;
_rtable[18446746174193268126]
#ExportMatrix("F:/D/Drive D/Local/Rashad/Paper 9/vel1.txt", E1, format = rectangular):
p1:=odeplot(A11, [[eta,theta(eta), color=red,linestyle=2]],0..N):
p2:=odeplot(A12, [[eta,theta(eta), color=blue,linestyle=2]],0..N):
p3:=odeplot(A13, [[eta,theta(eta), color=green,linestyle=2]],0..N):
display({p1,p2,p3}, axes=boxed,  title=`temperature Profiles:`);
"[[eta,F(eta),(&DifferentialD;)/(&DifferentialD;eta) F(eta),((&DifferentialD;)^2)/(&DifferentialD;eta^2) F(eta),Theta(eta),(&DifferentialD;)/(&DifferentialD;eta) Theta(eta),f(eta),(&DifferentialD;)/(&DifferentialD;eta) f(eta),((&DifferentialD;)^2)/(&DifferentialD;eta^2) f(eta),theta(eta),(&DifferentialD;)/(&DifferentialD;eta) theta(eta)]]"
for j from 1 to 100*(N-1) do temp1[j]:=A11[2,1][j,5] end do:
for j from 1 to 100*(N-1) do temp2[j]:=A12[2,1][j,5] end do:
for j from 1 to 100*(N-1) do temp3[j]:=A13[2,1][j,5] end do:
E2:= <<seq(eta[j], j=1..100*(N-1) )>|<seq(temp1[j], j=1..100*(N-1) )>|<seq(temp2[j], j=1..100*(N-1) )>|<seq(temp3[j], j=1..100*(N-1))>>;
_rtable[18446746174193227646]
#ExportMatrix("F:/D/Drive D/Local/Rashad/Paper 9/temp1.txt", E2, format = rectangular):
Download text.mw
When a real matrix have repeated eigenvalue (i.e. multiplicity >1) and the matrix is not the identity matrix, then it is called defective eigenvalue.
For example if the eigenvalue is repeated 2 times, there will be only one eigevector associated with it.
There is an algorithm to generate another (linearly independent) eigenvector from this same eigenvalue called the defective eigenvalue method.
My question is: Does Maple have support for finding such additional eigenvectors?  The standard Eigenvectors does not seem to do this. Here is an example.
A :=Matrix([[1,-2],[2,5]]);
(eigen_values, eigen_vectors) := LinearAlgebra:-Eigenvectors(A);
By hand, using the defective eigenvalue method it is possible find second eigenvector for this eigenvalue, which is linearly independent of the one returned by Maple. Such as
The method to find these additional eigenvector is described in number of places such as
https://en.wikipedia.org/wiki/Defective_matrix
And the pdf at the bottom show a more detailed example.
I can code this method by hand to find complete set of L.I. eigenvectors for this defective eigenvalue.
But before doing that, I thought to ask if Maple have buildin support for this, such as a single command to do this or some package.
I looked at help for LinearAlgebra and I am still not able to see anything, It only says this:
With an eigenvalue of multiplicity  k>1 , there may be fewer than  k linearly independent eigenvectors. In this case, the matrix is called defective.  By design, the returned matrix always has full column dimension.  Therefore, in the defective case, some of the columns that are returned are zero.  Thus, they are not eigenvectors.  With the option, output=list, only eigenvectors are returned.  For more information, see LinearAlgebra[JordanForm] and LinearAlgebra[SchurForm].
This PDF also describes using Maple, how to do it for one example
https://wps.prenhall.com/wps/media/objects/884/905485/chapt5/proj5.4/proj5-4.pdf
This PDF also describes how to do it by hand without using Maple, starting at end of page 3
http://www.math.utah.edu/~zwick/Classes/Fall2013_2280/Lectures/Lecture23_with_Examples.pdf
It is not too hard to code this method in Maple. But if Maple allready can do it, using some command, it will be better ofcourse.
To practice more in documentmode
Given  f := x^2 + y^2 + z^2 = 1
Asked:
surfacelevel on level 1  and surfacelevel upon wich the point (sqrt(3), 3, -2) is located.
1) x^2 + y^2 + z^2 = 1   : what solid ( a sphere with radius 1)  and  plot
2) surfacelevel (solid sphere)   for point  (sqrt(3), 3, -2) and plot
3) Plot together
Doing this calculation solely with contextpanel..no that's not always possible as it seems by trying to plot a sphere.
a:=0.2; b:=0.2; c:=5.7;
ode1:=diff(x(t),t)=-y(t)-z(t);
ode2:=diff(y(t),t)=x(t)+a*y(t);
ode3:=diff(z(t),t)=b+z(t)*(x(t)-c);
ic1:=x(0)=-0.7;
ic2:=y(0)=-0.7;
ic3:=z(0)=1;
sol:=dsolve({ode1,ode2,ode3,ic1,ic2,ic3},{x(t),y(t),z(t)},numeric,method=classical[rk4],stepsize=0.10,output=listprocedure);
b:=rhs(sol[2]);
c:=rhs(sol[3]);
d:=rhs(sol[4]);
animate (pointplot3d, [ [b(t),c(t),d(t)], symbol=box, color=blue],t=15..100,
background = odeplot(sol, [x(t),y(t),z(t)],t=15..100,numpoints=7000),frames=20);
UPD
And "Error, (in plots/animate) incorrect first argument" BUT if i use classic functions (sin,cos,sqrt) instead of b,c,d - all is well.
For example [sin(t),cos(t),t/10]
For example [b(t),c(t),d(t)]
Using latest Physics, I found case where it is not giving the Latex.
Please see attached worksheet.  This is on windows 10, Maple 2020.1.1
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 804 and is the same as the version installed in this computer, created 2020, September 7, 12:31 hours Pacific Time.`
ode:=diff(y(t),t) = -2*arctan(y(t))/(1+y(t)^2);
diff(y(t), t) = -2*arctan(y(t))/(1+y(t)^2)
sol:=dsolve(ode)
t+Intat((1/2)*(_a^2+1)/arctan(_a), _a = y(t))+_C1 = 0
Physics:-Latex(sol)
Error, (in unknown) invalid range for string subscript
latex(sol)
t+\int ^{y \left( t \right) }\!{\frac {{{\it \_a}}^{2}+1}{2\,\arctan
 \left( {\it \_a} \right) }}{d{\it \_a}}+{\it \_C1}=0
By trial and error, I found that the error was introduced in Physics 797. Since in Physics 796 it did work.
Here is screen shot
Download latex_issue_11.mw
If I call for the metric (27.27) in Stephani et al. in the Physics package, I expected the null tetrad employed to compute say the Weyl scalars would be the one given in conjunction with (27.27) (equation (27.22) in Stephani et al.). But, Weyl[scalars] returned long expressions for each of the five scalars, whereas with respect to the null tetrad in Stephani et al one expects the first two (or last two) scalars to be zero since the null vector k in their tetrad is the multiple pnd of Weyl. e_[nullvectors] and Setup(tetradmetric=null) followed by e_[ ] seem to output the same null tetrad, which does not appear to be that of Stephani et al. I assume this null tetrad is the null tetrad associated to the orthonomral tetrad that e_[ ]  returns if one hasn't used Setup(tetradmetric=null). How does Maple select this default orthonormal tetrad? What is the best way to set the null tetrad of Stephani et al as the null tetrad to compute Weyl[scalars]?
Here is a simpler example. Calling [27, 37, 1]. Stephani et al give the null tetrad in terms of the spacetime coordinates along with the metric in their equaiton (27.37). After using Setup(tetradmetic=null), e_[ ] returns a tetrad that might, I suppose, be that of Stephani et al. in disguise. Specifically, the tetrad vector defining the null congruence should have only a component with respect to the coordinate r, yet the Maple output gives expressions for the components with respct to the u and r coordinates for both the k and l elements of the null tetrad (while the expressions for the complex element m is exactly what one would expect). As in the previous example, all Weyl scalars are given by nontrivial expressions, even though two of them should be zero (since k is a multiple pnd). So is it the case that the experssions in the Maple output where one expects zero are in fact zero in disguise? The experssions are complicated enough that it is not obvious.  I have uploaded the Maple document for these calculations. SKMHH27_37.mw
First 507 508 509 510 511 512 513 Last Page 509 of 2432
