I want to show the animation of the polar equation r=cos(2theta) be plotted from theta=0 to 2pi
Hello,The system of equations is as follows:
I'd like to find all integer solutions in [1,20], when I use isolve ,the results are not good.  Since at least one variable is equal to 0 in evey solution.
{isolve}({a+b+c=a1+b1+c1, a^2+b^2+c^2=(a1)^2+(b1)^2+(c1)^2,a*b*c=2*a1*b1*c1})
 In maple I did not  want to use less efficient for-loop like C programing as following.
#include <math.h>
#include <stdio.h>
void main()
    long int a,b,c,d,e,f;
    for(a=1;a<20;a++)
        for(b=1;b<20;b++)
            for(c=1;c<20;c++)
                for(d=1;d<20;d++)
                    for(e=1;e<20;e++)
                        for(f=1;f<20;f++)
                            if(a+b+c==d+e+f&&a*a+b*b+c*c==d*d+e*e+f*f&&a*b*c==2*d*e*f)                                             printf("a=%d,b=%d,c=%d,d=%d,e=%d,f=%d\n",a,b,c,d,e,f);
a=3,b=5,c=16,d=1,e=8,f=15
a=3,b=5,c=16,d=1,e=15,f=8
a=3,b=5,c=16,d=8,e=1,f=15
a=3,b=5,c=16,d=8,e=15,f=1
a=3,b=5,c=16,d=15,e=1,f=8
a=3,b=5,c=16,d=15,e=8,f=1
a=3,b=16,c=5,d=1,e=8,f=15
a=3,b=16,c=5,d=1,e=15,f=8
a=3,b=16,c=5,d=8,e=1,f=15
a=3,b=16,c=5,d=8,e=15,f=1
a=3,b=16,c=5,d=15,e=1,f=8
a=3,b=16,c=5,d=15,e=8,f=1
a=5,b=3,c=16,d=1,e=8,f=15
a=5,b=3,c=16,d=1,e=15,f=8
a=5,b=3,c=16,d=8,e=1,f=15
a=5,b=3,c=16,d=8,e=15,f=1
a=5,b=3,c=16,d=15,e=1,f=8
a=5,b=3,c=16,d=15,e=8,f=1
a=5,b=16,c=3,d=1,e=8,f=15
a=5,b=16,c=3,d=1,e=15,f=8
a=5,b=16,c=3,d=8,e=1,f=15
a=5,b=16,c=3,d=8,e=15,f=1
a=5,b=16,c=3,d=15,e=1,f=8
a=5,b=16,c=3,d=15,e=8,f=1
a=16,b=3,c=5,d=1,e=8,f=15
a=16,b=3,c=5,d=1,e=15,f=8
a=16,b=3,c=5,d=8,e=1,f=15
a=16,b=3,c=5,d=8,e=15,f=1
a=16,b=3,c=5,d=15,e=1,f=8
a=16,b=3,c=5,d=15,e=8,f=1
a=16,b=5,c=3,d=1,e=8,f=15
a=16,b=5,c=3,d=1,e=15,f=8
a=16,b=5,c=3,d=8,e=1,f=15
a=16,b=5,c=3,d=8,e=15,f=1
a=16,b=5,c=3,d=15,e=1,f=8
a=16,b=5,c=3,d=15,e=8,f=1
Does Maple have more good ways to solve that?
I had to save previous results of a calculation to files as the number of elements is too big for my computer to handle in one go.   Here it is an idea of what I am doing to read the files and perform the calculations.
mainproc:=proc(arg1,arg2,arg3,arg4) ... end proc:
Grid:-Set(mainproc):
Grid:-Set(arg2,arg3,arg4):   #  They don't change ever.
for i from 1 to number_of_files do
   read(...):  # it reads arg1 from a file
   Grid:-Set(arg1):
   ans:=Grid:-Seq(mainproc(arg1[i],arg2,arg3,arg4),i=1..numelems(arg1))):
   Grid:-Wait():
   save ans, ....:
   unassign('arg1'):
   unassign('ans'):
   gc():  # An attempt
The actual code works but, for every step in the loop, the memory used by Maple increases by a certain amount that seems to be mostly related to arg1 (as if arg1 is piling up from iteration to iteration).
I read some of the earlier posts on a similar subject dated 5 to 10 years old.  I wonder if there is something new that can be done to minimize the usage of memory.
Many thanks
Ed
PS. I am aware of tasksize, numcpus and Threads.
I have a simple matrix, 11 rows x 3 columns, with header row.  <<
I multiply column 1 and 2 to get <<0.,0.031,0.218,0.657,1.084,1.095,0.654,0.217>>
Now, I just want to add up these elements, but 'sum' doesn't work 'Sum' doesn't work either. Is there a simpel way to do this?
m1 := `<|>`(`<,>`("# girls", 0, 1, 2, 3, 4, 5, 6, 7, 8), `<,>`("P(x)", 0.4e-2, 0.31e-1, .109, .219, .271, .219, .109, 0.31e-1, 0.4e-2), `<,>`("x*P(x)", 0, 0, 0, 0, 0, 0, 0, 0, 0))
Matrix(%id = 18446745635438952446)
m1[2 .. 9, 3] := `~`[`*`](m1[2 .. 9, 1], m1[2 .. 9, 2])
Vector[column](%id = 18446745635417541318)
"Sum?"
Vector[column](%id = 18446745635493441398)
"sum?"
Error, (in LinearAlgebra:-Multiply) invalid arguments
Download Untitled_(3).mw
I must do some formula manipulation
Classification of conic sections
restart; with(student):
A*x^2+B*y^2+C*x+D*y+E=0;
A*x^2+B*y^2+C*x+D*y+E = 0
f:= A*x^2+B*y^2+C*x+D*y+E;
completesquare(f, x);
A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y+E
ans:=Student[Precalculus][CompleteSquare]( (4), [y] );
B*(y+(1/2)*D/B)^2+A*x^2+C*x+E-(1/4)*D^2/B
ans1:=Student[Precalculus][CompleteSquare]( (4), [x] );
ans+ans1;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y
B*(y + D/(2*B))^2 + A*x^2 + C*x + 2*E - D^2/(4*B) + A*(x + C/(2*A))^2 - C^2/(4*A) + B*y^2 + D*y = 0;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y = 0
Now i must  get this form A( )^2 +B( )^2 = M
Download vraag_herleiding_conic_sections_formule.mw
Does this condition happen when the character is too long?
Hello everybody,
i am trying to use PDEchangecoords to transform a system of differential equations from Cartesian coordinates to toroidal coordinates. However, when i use a user defined coordinate transform from toroidal to Cartesian, i don't get the initial equations. Please find attached a minimal working environment.
i would highly appreciate your hints and suggestions!
Best regards,
F
question.mw
restart; with(DEtools); addcoords(invToroidal, [xi, eta, phi], [sinh(xi)*cos(phi)/(cosh(xi)-cos(eta)), sinh(xi)*sin(phi)/(cosh(xi)-cos(eta)), sin(eta)/(cosh(xi)-cos(eta))]); PDEchangecoords(diff(f(x, y, z), z), [x, y, z], toroidal, [xi, eta, phi]); PDEchangecoords(%, [xi, eta, phi], invToroidal, [x, y, z]); print("i would expect here to get", diff(f(x, y, z), z))
Download question.mw
Dear Community,
I would like to have an inverse interpolation with a 2D lookup table in MapleSim. The usual 2D lookup interpolation has u1 column values, and u2 row values, and a corresponding   y   table values, i.e. y = f(u1,u2). Now I would like to go the reverse way. Suppose I know y, and u2, and I would like to get u1. How can I implement this in MapleSim? An additional information is, that the 3D surface represented by the f(u1, u2) function is a smooth, slightly curved, monotonically sloping surface, so to any  y  value a unique pair of u1 and u2 values belong.
With my specific data, which are attached in the TestVLP.xlsx file:
  • u2 values are: 1st row, cells 2 .. 14
  • u1 values are  1st column, rows 2 .. 11
  • tabulated values are all the rest, i.e. from cell(2,2) .. cell(11,14)
Now for my case:
  • u2 = 42000.0
  • y   = 94.5614
How much is u1? I know the correct answer from elsewhere, it should be something very close to u1 ~ 85. This  y  value is in the rectangle bordered by columns 7 .. 8  and rows 5 .. 6 in the Excel file.
So my question is how do I correctly implement this in MapleSim? As visible from the attached TestInverse2DInterpolation.msim file I tried to do it with an Inverse Block Constraints component and a horizontally flipped 2D Lookup Table (VLP) and Constants for y and u2, but upon running MapleSim I get an error message that no solution is found, although the solution is relatively easy and straightforward. May I ask you to have a look at it, what can be the problem here, what do I do wrong? I’m using MapleSim 2019.2.
Your kind help is appreciated in advance
best regards
Andras
TestVLP.xlsx
Hello Everyone!
I have one more challenge for you.
How can I find for a Free-Pinned-Pinned-Free (3-span) beam (Picture A below) using the Krylov–Duncan Method (Literature links and references below):
- the matrix of the system?
- the transcendental equation in order to determine the natural frequencies?
- the first three mode shapes?
I tried to do it as you can see from my MAPLE (file below), but I got stuck when I use the command "determinant" and it did not find the transcendental equation.
Krylov_function_free_pinned_pinned_free_beam.mw
Picture_A
References:
https://link.springer.com/content/pdf/10.1007%2F978-1-4419-1047-9_14.pdf
Krylov–Duncan Functions - page 96
You can find that book using the https://libgen.is/
https://www.amazon.com/Formulas-Structural-Dynamics-Tables-Solutions/dp/0071367128
Hello.
I would like to solve numerically highly nonlinear and cumbersome the second order differential equation.
Applying the numerical procedure I got an error "Error, (in dsolve) found wrong extra argument(s): range = 0 .. 4*Pi, type = numerical". The similar problem has been described earlier here however I can't realize my problem.
Below is my code
A1 := 8*Pi^3*R^2*n(x)^4*m+(2*Pi*sin((1/2)*x)*m*omega0*p+Pi*sin((1/2)*x)*m*omega0+3*Pi^2*(diff(n(x), x, x)))*n(x)^3+(-2*sin((1/2)*x)^2*m^2*omega0^2*p^2+2*cos((1/2)*x)^2*m^2*omega0^2*p^2-2*sin((1/2)*x)^2*m^2*omega0^2*p+2*cos((1/2)*x)^2*m^2*omega0^2*p)*n(x)^2+(-4*(diff(n(x), x, x))*sin((1/2)*x)^2*m^2*omega0^2*p^2-8*sin((1/2)*x)*(diff(n(x), x))*cos((1/2)*x)*m^2*omega0^2*p^2-4*(diff(n(x), x, x))*sin((1/2)*x)^2*m^2*omega0^2*p-8*sin((1/2)*x)*(diff(n(x), x))*cos((1/2)*x)*m^2*omega0^2*p)*n(x)+8*sin((1/2)*x)^2*(diff(n(x), x))^2*m^2*omega0^2*p^2+8*sin((1/2)*x)^2*(diff(n(x), x))^2*m^2*omega0^2*p;
R := 1; m := 1; p := 10; omega0 := 1000;
A2 := A1;
A3 := dsolve({A2, n(0) = n(4*Pi), (D(n))(0) = (D(n))(4*Pi)}, type = numerical, range = 0 .. 4*Pi):
odeplot(A3);
I appreciate for any help and suggestion.
Help required to plot the real part only in  multiple plots. i have written some codes  please help me to rectify the errors.Thanks in advance
n:=0.75:Eh:=100:mn:=1:t0:=0.2:
a1:=(mn/t0)^((n-1)/(n))*(tb)^(1/n):a3:=Eh/tb:a4:=(Eh)^2:
U1:=(a1/Eh)*(-1+(a3*r/Eh))^(1/n)*(n*a4/(1+n))*(1/a3-(r/Eh))-a1*(-1+(1/tb))^(1/n)*(n/(n+1)*(tb-1)):
plot([Re(seq(eval(U1,tb=j),j in[0.8,0.9,1.0]))],r=0..1,legend = [tb =0.8, tb=0.9,tb =1.0],  labels = ["z ", "U"], labeldirections = ["horizontal", "vertical"],  linestyle = [solid,dash,dot],color = [black, red,green]);
I want to shade the area where the two polar curves overlap. The first curve is r=2 and the other curve is r=2(1-cos(theta)). How do I do this?
I want to find the surface area of this parametric curve revolving around the x-axis. I was able to plot the 2D rendering but I want to show the plot so that I can see the surface area. I suspect that would be the 3D rendering.
x=cos(t), y=2+sin(t), 0<=t<=2pi, x-axis
I see this error once in a while
Error, (in SolveTools:-CancelInverses) assertion failed, simplify should not leak _Z variables out from RootOfs
When I run a long script. Unfortunately, I have not been able to make a small example to reproduce it. So it is random. I've seen it about 5-6 times in the last 2-3 weeks, over 100 runs during this time.
Just wanted to see if anyone saw this before. The strange thing it is random. I can re-run the same script, or restart it from the point where it failed,  with no changes anywhere, and this error do not show up again for days, and suddenly it shows up again.
Must be related how to Maple internal cache memory happened to be arranged at that time. I noticed that a number of things in Maple seem to happen at random times, such as a random hang of the server at different times and places. I could never understand why this happens in Maple.
If there is only one thing Maplesoft could do for the next version, it will be to improve the robustness of its software.
Update March 7, 2024.
FYI, examples giving this error using Maple 2024 using different functions
kernelopts('assertlevel'=2):
ode:=(exp(x)*sin(y(x))-3*x^2)+(exp(x)*cos(y(x))+y(x)^(-2/3)/3)*diff(y(x),x)=0;
DEtools:-odeadvisor(ode,y(x))
exp(x)*sin(y(x))-3*x^2+(exp(x)*cos(y(x))+(1/3)/y(x)^(2/3))*(diff(y(x), x)) = 0
ode:=diff(y(x),x)*y(x)/(1+1/2*sqrt(1+diff(y(x),x)^2))=-x;
dsolve([ode,y(0)=3],y(x))
(diff(y(x), x))*y(x)/(1+(1/2)*(1+(diff(y(x), x))^2)^(1/2)) = -x
Download leak_Z_maple_2024.mw
I have reported this to Mapesoft.
Any chance to get a dataplot with units in one or both axis?
Or is this another thing where units are cause of trouble?
plotunits1.mw
First 534 535 536 537 538 539 540 Last Page 536 of 2433
