A complicated programmed task for me
I must analyze this
In this plot there are vertical  walls connected with the step area's , but that its not wanted.
Also the domain is showed by adding 0 in the plot 3d( {0, 'g(x,y)'}, ...) and this distract the plot with the step area's
Its not needed the domain in the plot ( in order to get the 0 value for z )
The 3 axis x,y,z  are not visible in the plot
Seems to be not complete programmed as it just to be.
f:=proc(A,B,T,x,y)
     local n,m,i,j,val;
     n:=nops(A);m:=nops(B);
       for i from 1 to n-1 do
         for j from 1 to m-1 do
         if (A[i]<=x and x<A[i+1]) and
            (B[j]<=y and y< B[j+1]) then val:=T[i,j];
     val;
A:=[0,1,2];B:=[0,1,2];T:=array([[1,2],[1.5,1]]);
A := [0, 1, 2]
B := [0, 1, 2]
array( 1 .. 2, 1 .. 2, [( 2, 1 ) = (1.5), ( 1, 1 ) = (1), ( 2, 2 ) = (1), ( 1, 2 ) = (2)  ] )
g:=(x,y)->f(A,B,T,x,y);
proc (x, y) options operator, arrow; f(A, B, T, x, y) end proc
plot3d({0,'g(x,y)'},x=0..2,y=0..2,axes=normal,
           scaling=constrained,orientation=[-37,75],
           projection=0.8,tickmarks=[3,0,2],
           shading=XYZ,lightmodel='light3');
Download texc_set_4_-task_3_-forumvraag.mw
 I want to find all real roots of   equation x^2 + floor(x) - 10=0
solve(x^2+floor(x)-10,x) assuming x::real
maple tells me:
  RootOf(_Z^2 + floor(_Z) - 10)
allvalues(%)
RootOf(_Z^2 + floor(_Z) - 10, 2.828427125 + 0.*I)
even though  usRealDomain.
use RealDomain in  solve(x^2+floor(x)-10,x) end use
We get nothing!
So I trun to use fsolve.
plot(x^2+floor(x)-10,x=-5..5)
s:=fsolve(x^2+floor(x)-10,{x});
fsolve(x^2+floor(x)-10,x,avoid={s})
                     s := {x = 2.828427125}
                          -3.741657387
I try to use mathematica, it is good:
Solve[x^2 + Floor[x] - 10 == 0, x, Reals]
Could Maple  do that?
In the same spirit of my previous question about converting a Mathapp to a GIF format, ( for educational goal)  Ideas?
Fibonacci.mw
With showstat( )  i can see procedure body
But it is also possible for tools : assistant, math apps, tutors and tasks ?
In library all proc are public.
I'm willing to draw phase portrait for the equation of ode fifth order
u'''''+6(u'u'''+(u'')^2)-u'''(a+2b)=0
where a and b are arbitrary constant not equal to zero and (') represents derivative w.r.t  'x'.
I'm getting no solution for the attached pdf.  Kindly suggest!
Maple Worksheet - Error
pde.mw
Hi dears
Just a simple question: I am trying to restore the coefficients of a polynomial in a vector, respect to a list of variables. For example
f:=a*u[]*u[1]*u[2]+b*u[1]*u[2]+c*v[]*v[1]*u[2]+d*u[]*v[1]*v[2]+d*u[]*v[1]*u[2]+f*u[]*v[];
    f := a u[] u[1] u[2] + c u[2] v[] v[1] + d u[] u[2] v[1] + d u[] v[1] v[2] + b u[1] u[2]+fu[]v[]
collect(f,{u[1],u[2],v[1],v[2]},distributed);
       (a u[] + b) u[1] u[2] + (c v[] + d u[]) u[2] v[1] + d u[] v[1] v[2]+fu[]v[]
in above example I intend to keep (a u[] + b) and (c v[] + d u[]) and d and fu[]v[] in a vector or a varieble. Is there any comments?
Thanks indeed in advence
Here in the above graph we are trying to find the longest distance between two vertices For example now say we consider vertices v_2 and v_4 in the above graph
P_1 , P_2 ,P_3 are different possible path length in the above graph between v_2 and v_4  and it can be seen now the longest distance is 3 as it is the greatest among all lengths between v_2 and v_4
AllPathshortest only does the shortest path
can anyone help in the in general  finding the longest path between two vertices a graph if i give the
graph and the two vertices it should longest distance
here between v_2 and v_4 longest or greatest distance is 3 which should  greatest length of the several different paths between v_ 2 and v_4 itself
it should display that value.
kind help if anyone can
See the following code
u:=Vector(1);
u[1]:=1;
x1:=sum('u[i]^i','i'=1..1);
u[1]:=2;
x2:=sum('u[i]^(i)','i'=1..1);
x3:=sum('u[i]^(i+1)','i'=1..1);
When I run x1=1 and x2=1, but x3=4. But x2 should be 2. I presume this has something to do with the fact that when sum sees u[1] it already thinks it knows what u[1] is, but when it sees u[1]^2 it recalculates.  I realize that "add" would solve the problem here, but I thought for short sums sum called add. Suggestions?
I am working on a series of educational activities on the added value of the GIF format in collaborative work.
How to convert this Math App to animated format , exportable to GIF, keeping all variable values ( Circle area, Polygon area. ) Ideas? In advance Thank you
MathApps.mw
   My question should have a straight forward answer but after considerable searching I am unable to find one that is satisfactory. I am new to Maple.
I am writing an exam question, and I would like to change the parameter values to create different versions of the same question. I begin by defining the parameters and defining the supply schedule:
n:= 10: alpha:= -60: beta:= 20:
Qs:= alpha + beta*P;
The question with text and inserted math appears as follows (after each math expression I use CTRL = to generate an inline expression):
There are n = 10 identical firms. Supply is given by Qs = 20 P - 60. When P := 4 = 4 then quantity supplied is equal to Qs = 20. Calculate the ...
What I want instead is the following:
There are 10 identical firms. Supply is given by Qs = 20 P - 60. When P = 4 then quantity supplied is equal to 20.  Calculate the ...
I want the values highlighted in blue to update if I change the values for n, alpha and beta, and then click the !!! button in the Maple menu. I am okay with moving the "P = 4" out of the question and defining it as a parameter along with n, alpha and beta. However, when I do this Qs evaluates as a value rather than the Qs = 20P - 60 expression.
Thank you very much.
How one can plot a vector (field) defined in Physics[Vectors] package ?
with(Physics[Vectors])
F_:=r _r + phi^2 _phi
I could normally use fieldplot/fieldplot3d from plots package to plot vector fields from VectorCalculus package, but with Physics[Vectors] package, I am not sure how to plot these. Can you show me a way to plot Physics[Vector] vectors?
We have just run into a problem (loss of data), when 2 users have opened the same workbook.
Does Maple support Multiuser access to a workbook, and if not - why isn't there any lock mechanism in place to prevent that?
Should be that i was thinking on the use the arrow operator for a function definition and to use this for graphing this function
It becomes complicated.
the following piecewise-defined function was considered
exc set 4 task 1a
sin(3*x): # x <= 0 .. must be evaluated to true or false for branching to      #other second function
sin(x/3): # otherwise
h:=proc(x)
   if x<=0 then sin(3*x)
   else sin(x/3)
   fi;
maplemint(h);
h(1); #
sin(1/3)
h(1.0);
.3271946968
Strange that this function notation e.g h(1) can be used for a expression ?, while the idea was to use this only for a function defintion with a arrow operator  ( function as a procedure )
Seems to be possible to use the notation e.g : h(1) or h(1.0) if the input parameter is numeric for a expression.
The condition in the if statement must be(can only) evaluated numeric..that seems to be not possible with the arrow operator definition in the procedure.
h(x);
Error, (in h) cannot determine if this expression is true or false: x <= 0
plot('h(x)'); # delay of the evaluation of h(x)
plot(h);
Download exc_set_4_task1.mw
First 536 537 538 539 540 541 542 Last Page 538 of 2433
