I know that you can open the command prompt from within the maple interface, but how do i append instructions for it to execute a .ps1 script please thank you in advance
F := proc(f,x)
    f(x); # invalid.
f := (a,b,c)->a*b*c;
F(f,3);
    = 3*b*c;
How can I just apply 3 to one of the parameters in F without knowing how man(I really want to apply it to the first parameter but it doesn't matter all that much).
I really need to sorty of curry and uncurry a function. I might want to pass an function of arbitrary dimension but only apply a value to one parameter(usually the first).
while I could do somethign like
F(x->f(x,b,c))
this is kinda verbose and requires me to know the parameters of f at the call site, I don't think that is necessary.
Is there any way to extend maple by adding constants, functions, etc that are automatically loaded without having to add a with statement?
While I can use a template there are two issues, I don't really wanna see all the additions and I the template opens as the file and so the filename does not change. If one modifies the template and saves then it ruins the template. (it should open the template but not use the filename)
Anyone with the idea of seq such help please. I am tryong to collect all the series into one case but its only calling the last one.
The link is attached below. Thank you in advance
 seq.mw
As title says, when I enter equation in math mode and switch to text mode and hit "enter" to go to the next line then it gets executed, usually in former versions it didnt execute and was much faster for me to use the program this way.
How do I fix this? I don't want to use shift-F5 all the time to make the text unexecutable, I would like it to be like in the old version prior to 2019.
Now it does this which is really annoying, I dont want it to execute when changing line!
Best regards
Jonas
Hi guys
I want to solve the following differential equation but I can not. please help me in this way
diff(phi((8*R^(3/2)-W)*sqrt(2)/(24*sqrt(M))), W$2)=lambda*phi((8*R^(3/2)-W)*sqrt(2)/(24*sqrt(M)))
with the best regard
How would I make a subset in a set.
For example,
What if I had the sample space {1,2,3,4,5,6,7,8,9,10}.
A = {1,2,3,4}
B={4,5,6,7}
C={8,9,10}
How would I be able to ask C complementary and it would give me the elements that don't belong to C.
William
How to calculate the derivative of modified Bessel fucntion of the first kind and order \alpha, such that \alpha>-1/2?
I need to calculate de general term of the derivative of modified Bessel function of the first kind and order \alpha.
Best regards
I don't understand why Maple does not like my code:
dsol := dsolve({diff(y(t),t) = -y(t), y(0)=1}, numeric):
frame := proc(s)
  odeplot(dsol, [t,y(t)], t=0..s);
animate(frame, [t], t=0..3);
Error, (in plots/animate) invalid range
I know how to get around it (as shown in the attached worksheet) but I am curious to know why the above approach does not work.
Download worksheet: mw.mw
i literally cant figure out how to pay money for this
Worm greeting to all
I use the following to plot two orthogonal vectors display(arrow(1,0), arrow(0,1)) as
  Now, I need to shift these two orthogonal vectors to another point.
Does anyone know how the command PLOT(POLYGONS(...)) fills  polygons?
I'm interested in polygons that are not simple, that is polygons for which 2 different sides without common vertex do not intersect.
Is it possible to change programmatically the permissions of a file without using ssystem?
Such as in ssystem("chmod +x MyFile") for instance
TIA
I'm using dsolve command to solve a differential equation. Using infolevel to 3 will tell me the classification of said DE. However, how can I see the step by step solution? I'm using Maple as a study tool so I do solve manually a DE then I'd like to compare my answer with Maple's. How can I acomplish this? Thanks in advance.
How do I write plot ceil(x) mod 2 properly?
If I write:
plot(ceil(x) mod 2, x = 0 .. 4)
it produces a step pattern and not a square wave. (Only 0 and 1 should be plotted.)
First 653 654 655 656 657 658 659 Last Page 655 of 2433
