https://aws.amazon.com/getting-started/projects/deploy-elastic-hpc-cluster/
is it possible to use maple on high performance clusters?
i can only think to use c program to call cmaple with MPI in linux to use high performance clusters.
is there any other official method to do this?
if i upload my maple 2015 version to amazon for this computing, will it used up all license in this first chance of installation leading to that i can not install maple 2015 linux version to other machine?
https://docs.aws.amazon.com/AWSEC2/latest/WindowsGuide/ConfigWindowsHPC.html#ComputeNode
which virtual machine should i install the maple 12? on one virtual machine or all compute nodes?
how many compute nodes are need to compute dsolve 100,000 systems which may or may not have solution in maple 12?
Hello Maple experts;
I am not able to understand why Maple 2019 can solve Laplace PDE in 2D Catersian on semi-infinite domain, when the infinity is along the Y direction, but not along the X direction, since the solution method is exactly the same.
Here is the code
#right one, Maple can not solve
pde := diff(u(x, y), x$2)+diff(u(x, y), y$2) = 0:
bc_left_edge := u(0, y) = 0:
bc_bottom_edge:= u(x, 0) = 0:
bc_top_edge:= u(x, 1) = A:
bc:=bc_left_edge ,bc_top_edge,bc_bottom_edge:
sol:=pdsolve([pde, bc],HINT = boundedseries(x = infinity)) assuming x>0,y>0;
#left one, Maple can solve
bc_right_edge:= u(1, y) = A:
bc:=bc_left_edge ,bc_right_edge,bc_bottom_edge:
sol:=pdsolve([pde, bc],HINT = boundedseries(y = infinity)) assuming x>0,y>0;
Here is screen shot.
Maple can solve both cases if I remove the HINT. But the solution it gives is not as simple as using the HINT and contains unknown constants (_C5) that is why I use the HINT.
But the main question is, since both problems are exactly the same, why Maple can solve one and not the other when using the HINT? Is there something I am doing wrong?
Maple 2019 on windows 10 and Physics cloud version 333.
Suggestions for a Maple program entering the coordinates of three points and giving the equation of the circle passing through these three points, non-aligned?
What is the default subinterval set in approximate int in Student[MultivariateCalculus] package? How can I change the subinterval number. Thank you.
How to draw graph when the matrix and the position is given in cartesius coordinate?
For example, I have this matrix and the following coordinate
Matrix(9, 9, [[0, 0, 1, 0, 1, 1, 1, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 1], [0, 0, 0, 1, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 1, 0]])
#Coordinate
[40, 40], [22, 22], [36, 26], [21, 45], [45, 35], [55, 20], [55, 45], [26, 59], [55, 65]
For sure, we can use Graph package
GT := GraphTheory;
G := GT:-Graph(X);
GT:-DrawGraph(G):
How to assign the coordinate such that I get the result of drawing in cartesius ?
Thank you anyway
which Maple command gives the exact value of factorial (1/2)?   ``(1/2)!``
This is a minor issue, but I noticed using Maple 2019, with Physics cloud version 331 that it prints on the screen some results from internal computation on some calls to pdsolve
I have a ":" at the end of each command, so no output should go to the screen. In Maple 2018 this does not happen.
pde := a*diff(w(x,y),x) +  b*arctan(lambda*y)*diff(w(x,y),y) =  a*arctan(mu*x)^m+arctan(beta*y)^k:
sol := pdsolve(pde,w(x,y)):
#another example
pde := a*diff(w(x,y),x) +  b*arccot(lambda*y)*diff(w(x,y),y) =  a*arccot(mu*x)^m+arccot(beta*y)^k:
sol:=pdsolve(pde,w(x,y)):
Running the above on Maple 2019 and Maple 2018, here is screen shot. Notice the output in Maple 2019
In Maple 2019
Hello everyone!
I have the following Maple code:
with(CurveFitting); with(plottools); with(Statistics); A := [[1.364, 0.64765768e-1], [2.05, -.182176113], [2.664, -0.13914542e-1], [2.728, 0.2193938e-1], [4.092, -0.18349139e-1], [4.1, -.312968801], [5.328, -0.1819837e-2], [5.456, -.28840961], [6.15, -.57076866], [7.992, .175022254]];
F := LeastSquares(A, x);
plot([F, A], x = 0 .. 8, legend = ["Метод наименьших квадратов", "Экспериментальные данные"], legendstyle = [font = ["Roman", 15]], labels = ["d, ìì", "ln(I/I_0)"], labelfont = ["Roman", 15], labeldirections = ["horizontal", "vertical"], axesfont = ["ROMAN", "ROMAN", 15], color = [red, blue], style = [line, point], linestyle = [solid], symbolsize = 20, title = "Определение линейного коэффициента поглощения", titlefont = [Roman, bold, 20]);
This produces a plot:
How can I add error bars to the points that are colored in blue?
Thank you in advance for any help!
Having problems with solving PDE with symbolic BCs.
u(x,y,t,M,A);
 M,A,x are constants for this problem.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Code Starts
pde := diff(u(x, y, t), t)-.5*(diff(u(x, y, t), y, y))-A*sin(M*x-t) = 0
bc[1] := u(x, 0, t) = 0
bc[2] := u(x, 10, t) = A*sin(M*x-t)
sys := [pde, bc[1], bc[2]]
pdsolve(sys)
>>>>>>>>>>>>>>>>Code ends
I don't get any solution after this.
Moreover, in the second BC, I would like to change 10 to inifnity.
-(-u*(diff(v, x))+int((diff(v, x))*(diff(u, x)), x)+int((diff(v, x, x))*u, x))  how to simplify this expression to zero by any commands?
Error, module member referencing is not supported in evalhf
What is the solution for this error.
Also when I run job in command prompt I also getting following errors
Warning, the restart command only works at the top level. It cannot be executed within a procedure, or from a file being read by the read statement.
But the same code runs fine in GUI.
Hello everybody and thankyou in advance to answer my question.
I am trying to answer this question:
“Find the solutions for x so that the sine of x degrees be equal to the sine of x radians in the interval [0, Pi].” I wrote this formula to solve it but without success:
solve(sin(x*degree)=sin(x),x) assuming 0<=x<=Pi
I expected a solution like:
{x=0, x=(180*Pi)/(180+Pi)} but not,
I somehow get a numeric solution for the first positive real number within the referred interval with this:
fsolve(sin(x*Pi/180) = sin(x), x, 0 .. Pi);
But if I change the interval for example [0, 3*Pi] I still only get one answer, not the four I spect.
I am struggling with statistical analysis of a dataset. I would appreciate help from the community. Let me describe what I am looking for.
1. The linear regression model that I am trying to use is Y=b1X1 + b2x2 + e. I am interested in estimating b1 and b2 so that the estimated error is the least.
2. I am trying to randomly select 25 percent of observations from the dataset and estimate b1 and b2.
3. The estimated coefficients are used to predict the Y values for the remainder of the 75 percent of the data and calculate the error. The idea is to use a subset to estimate coefficients, and check for the robustness of the estimates.
4. The process is iterated for say 100 times.
5. Each time, I would like to store the statistical results and export them to an excel file.
For some reason, each time I struggle with one or two steps mentioned above. Could anyone help me with the approach?
Thank you,
Omkar
I have a circle equation: F: = x^2+y^2 = 1.
I need to check: x^2+y^2 <= 1.
I tried to get this expression from F like this: lhs(F) <= rhs (F).
The content matches what I need but get: Error, cannot determine if this expression is true or false: x^2+y^2 <= 1.
When I specify just the if x^2+y^2 <= 1 then everything works fine. What am I doing wrong?
New to maple here. Having this problem for evaluating my function. If its relevant it is to solve the Ising model analytically. Whats the problem and how do I fix it? Thanks.
First 716 717 718 719 720 721 722 Last Page 718 of 2433
