I've modified my call to coulditbe() to always use assuming real to prevent false positives.
Now I find it gives internal error Error, (in type/complex) too many levels of recursion which can not even be trapped when the thing I am checking happened to have complex I in it. (This is done in code).
So I modied the code to only do this check if there is no complex in the expression being checked.
But I think Maple should not generate such error in first place. This indicates some internal problem in Maple, correct?
Here is worksheet. (ps. updated, wrong worksheet for somereason was uploaded).
`The "Physics Updates" version in the MapleCloud is 1792 and is the same as the version installed in this computer, created 2024, August 22, 12:6 hours Pacific Time.`
libname;
the_residual:=-1/4*I*x^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)*6^(1/2)-1/4*x^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)*2^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)-x^(1/2);
try
    coulditbe(the_residual=0) assuming real;
catch:
   print("error");
end try;
-((1/4)*I)*x^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)*6^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)-(1/4)*x^(1/2)*2^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)-x^(1/2)
try
    if not has(the_residual,I) then
       print("by passing, since residual is complex");
    fi;
catch:
   print("error");
end try;
Download internal_error_too_many_Levels_from_coulditbe_august_23_2024.mw
while i am writing code for loop with if condition i am having problem kindly help me out i am sharing fileburgers_type_method.mw
Are there any tools in Maple that allow you to find real roots of complex integral equations?
I have attached examples of such equations.
Unfortunately, I can't solve them.
Best regards.
Test.mw
Hello community,
I recently became a Maple Ambassador and  I would like to ask about some portals that were mentioned to me. Are these portals on mapleprimes and how can I access them?
I was thinking that I could also create a LinkedIn group, so that I could present there the activities I will do at the university, the online workshops I will do in the future or upload material from student projects.
Best Regards,
Athanasios Paraskevopoulos
HI, I saw an example in Maplesim where the speed of the Unwinder roller is modeled as a feedback control from the dancer's position, the radius of the Unwinder roller, to maintain a constant speed of the web.
I was wondering how the Unwinder roller radius (m) was divided by the target constant web speed (Lamp signal (m/s)) and added from the dancer's angle to achieve feedback control of the Unwinder roller.
Studying the attached documentDuffing Equation from the University of Colorado, I tried to plot the Duffing equation in three different ways. My worksheet is attached.
But I didn't get the desired result as you can see below. Any suggestion on how to fix my problem?
Download Example.mw
This ode has solution when solving for the IC by hand. But Maple gives new error I did not see before when asking it to solve the ode with IC.
No error if asked to solve the ODE without the IC.
Is this new error in dsolve? I have no earlier Maple versions to check. Below is worksheet. Solving for the IC by hand gives the solution which odetest verified.
`The "Physics Updates" version in the MapleCloud is 1789 and is the same as the version installed in this computer, created 2024, August 10, 8:50 hours Pacific Time.`
ode := diff(y(x), x) = sqrt(2)*sqrt(-(y(x) - 6)*(2*y(x) - 3))/(-y(x) + 6);
IC:=y(0)=3;
diff(y(x), x) = 2^(1/2)*(-(y(x)-6)*(2*y(x)-3))^(1/2)/(-y(x)+6)
y(0) = 3
sol:=dsolve(ode);
x-(1/4)*(-4*y(x)^2+30*y(x)-36)^(1/2)-(9/8)*arcsin((4/9)*y(x)-5/3)+c__1 = 0
sol_with_IC:=dsolve([ode,IC]); #why this error??
Error, (in dsolve) when calling 'series/RootOf'. Received: 'unable to compute series'
#lets solve for the IC by hand:
eq:=eval(sol,[y(x)=3,x=0])
-(1/4)*18^(1/2)+(9/8)*arcsin(1/3)+c__1 = 0
C_sol:=PDEtools:-Solve(eq,_C1);
c__1 = (3/4)*2^(1/2)-(9/8)*arcsin(1/3)
my_new_sol:=eval(sol,C_sol)
x-(1/4)*(-4*y(x)^2+30*y(x)-36)^(1/2)-(9/8)*arcsin((4/9)*y(x)-5/3)+(3/4)*2^(1/2)-(9/8)*arcsin(1/3) = 0
odetest(my_new_sol,[ode,IC])
[0, 0]
Download internal_error_when_unable_to_find_solution_august_22_2024.mw
i have solution of ODE but again i want take derivative from solution function F then i want take reciprocal of derivative
if F'=G then i want 1/F'=1/G like that i want all solution by list and if possible don't give the parameter a sequence  it will be better
thanks for any help
K := diff(G(xi), xi $ 2) = -lambda*diff(G(xi), xi) - mu;
                d                    / d        \
          K := ----- G(xi) = -lambda |---- G(xi)| - mu
                   2                 \ dxi      /
                dxi
V:= [seq](-1..1, 1/2);
                          [    -1     1   ]
                     V := [-1, --, 0, -, 1]
                          [    2      2   ]
interface(rtablesize= nops(V)^3):
DataFrame(
    <seq(seq(<a | b | rhs(dsolve(eval(K, [lambda,mu]=~ [a,b])))>, a= V), b= V)>,
    columns= [lambda, mu, F]
loading
Dear Expert Users,
I am still struggling with my transition from Mathcad 15 to Maple. Would someone be so kind to look at the attached worksheet and how I can obtain the desired result? Thanks in advance. The data used in the example come from TestFleck.xlsx
QuestionPrimes.mw TestFleck.xlsx
my odetest must give me zero everything is true but still not simplify the function with power include 1/n  not do cancelation even
test_sol_for_PDE.mw
EDIT: Thanks for the help i used the restore backup feature. I made my anti virus not react to maple since i thought that might work, so far no more problems. Else this is a fix if anybody else has this problem.
Hi, so my maple freezes during simple tasks, such as trying to type something, or somtimes copying and inerting the results from a previous equation, the feature where you mark something and drag the answer to somewhere else also does this. When this happens, maple completely freezes and i'm forced to close the app with taksmanager, where i lose everything i have worked on, sometimes for the past hour because i didn't save every minute which is basically not something you can do.
Is there any fix for this or anything i can do to prevent this, cause it really sucks.
I'm on a windows 11 with maple 2024
i have  written summation with  two  loops at the end and the result should be start from uNew[1][1] since values of i is starting from 1 but in the result i am getting uNew[0][1] why? for understanding of question i am attaching my file kindly help me sort out the problemautomatic_differentiation.mw
most of my equation when i wanna solve it is give me something like thus equation and it take a lot time to calculate and i don't get any answer after 1 hour past and still searching for finding parameter how i can do in fast way or maybe if exist  can i use mathematica or matlab is better for calculating this or not ?
F-P.mw
I am preparing some examples to start the year in the differential equations lesson. And I was wondering if there is any other way to represent the equilibrium points than the following which I found and then plotted using pointplot.
alpha := 0.4e-1; beta := 0.8e-2; sys := {diff(g(t), t) = -.25*g(t)+beta*p(t)*g(t), diff(p(t), t) = .7*p(t)*(1-(1/100)*p(t))-alpha*p(t)*g(t)}; ics := {g(0) = 5, p(0) = 20}
sol := dsolve(`union`(sys, ics), {g(t), p(t)}, numeric, range = 0 .. 50); with(plots); plots:-display(plots:-odeplot(sol, [t, p(t)], 0 .. 50, color = blue, legend = ["p(t)"]), plots:-odeplot(sol, [t, g(t)], 0 .. 50, color = red, legend = ["gt)"]), labels = ["t", "Population"], title = "Population Dynamics")
eqns := {.7*p(t)*(1-(1/100)*p(t))-alpha*p(t)*g(t) = 0, -.25*g(t)+beta*p(t)*g(t) = 0}; eq_points := solve(eqns, {g(t), p(t)}); eq_points
{g(t) = 0., p(t) = 0.}, {g(t) = 0., p(t) = 100.}, {g(t) = 12.03125000, p(t) = 31.25000000}
eqpoints := pointplot([[0, 0], [100, 0], [31.25000000, 12.03125000]], color = [red], symbol = diamond, symbolsize = 15)
phaseplot := odeplot(sol, [p(t), g(t)], 0 .. 35, color = green, thickness = 2)
with(DEtools); vectorfield_plot := dfieldplot([diff(p(t), t) = .7*p(t)*(1-(1/100)*p(t))-alpha*p(t)*g(t), diff(g(t), t) = -.25*g(t)+beta*p(t)*g(t)], [p(t), g(t)], t = 0 .. 35, p = 0 .. 150, g = 0 .. 30, arrows = small, color = blue, axes = boxed)
display([vectorfield_plot, phaseplot, eqpoints])
Download aquarium.mw
First 83 84 85 86 87 88 89 Last Page 85 of 2430
