I created the following worksheet to illustrate my question.
We have two equations. w and w__0 are parameters and we wish to solve for A__1 and A__2.
eq1 := A__1*(w^2-3*w__0^2)+A__2*w__0^2 = 0 = A__1*(w^2-3*w__0^2)+A__2*w__0^2 = 0NULL
eq2 := A__1*w__0^2+A__2*(w^2-w__0^2) = 0 = A__1*w__0^2+A__2*(w^2-w__0^2) = 0NULL
solve({eq1, eq2}, {A__1, A__2}) = {A__1 = 0, A__2 = 0}NULL
Maple says the only solution is the trivial solution.
If we check the determinant of the matrix of the system we see it can be zero for certain values of w given w__0.
M := Matrix([[w^2-3*w__0^2, w__0^2], [w__0^2, w^2-w__0^2]]) = Matrix(%id = 36893488152149895276)NULL
d := LinearAlgebra:-Determinant(M) = w^4-4*w^2*w__0^2+2*w__0^4NULL
solutions := solve(d = 0, w)
(2+2^(1/2))^(1/2)*w__0, -(2+2^(1/2))^(1/2)*w__0, (2-2^(1/2))^(1/2)*w__0, -(2-2^(1/2))^(1/2)*w__0
If w is one of these values then the system of equations is singular and has non-zero solutions.``
For example, subbing the first value above into the equations and solving Maple gives us non-trivial solutions.
solve({subs(w = solutions[1], eq1), subs(w = solutions[1], eq2)}, {A__1, A__2})
{A__1 = -(1+2^(1/2))*A__2, A__2 = A__2}
Why didn't Maple give us any indication that there could be non-zero solutions in the first call to solve?
For context, the system of equations comes from a calculation involving coupled oscillators.
I had a system of differential equations, guessed at a solution, plugged it in and got the equations shown in the worksheet. The guess isn't a correct solution in general, but it is a solution if w is one of the values computed in the worksheet (the values of the variable "solutions").
Download solve-nonzero-solutions.mw
hw8.mw
I am struggling to find the answer how to force maple to give finakl answer and not some expression. Actually i am trying to solve for a
i have a generator function but in out come i have phi(p_1,p_2,p_3, so on )=** result is clear but this p_1 and p_2 in not shown i want to be shown in my outcome
generate_solution.mw
It happens from time to time that context menus do not appear. Normally, they appear at mouse-over (i.e. when the cursor is moved over an menu item).
Example: Right-click on input line
A Maple restart is required to get the normal behaviour back.
Recently I noticed that repeatedly clicking at different location on the menu item make the contex menus appear again.
This can be workarround if a restart is not acceptable.
It seems that the new Java IDE, which was introduced with Maple 2021, is more susceptible to this phenomen.
All on Windows 10.
Since this behaviour is rare I could not identify a clear pattern which system state or event could be responsible for the appearance of this phenomen.
I would be interested if someone else has observed it and found another solution how to get the menus back without restarting Maple.
Any idea why calling solve(eqs,unknowns) gives Error, (in is/internal) type does not exist when the unknowns are in a set, but the error goes away when the unknowns are in a list? Is this expected or is this a bug?
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1779 and is the same as the version installed in this computer, created 2024, July 25, 8:56 hours Pacific Time.`
eqs:={0 = ln(2)+ln(-a*sech(1/2*2^(1/2)*b)^2), 1 = -tanh(1/2*2^(1/2)*b)*a^(1/2)*2^(1/2)};
unknown:={a, b};
{0 = ln(2)+ln(-a*sech((1/2)*2^(1/2)*b)^2), 1 = -tanh((1/2)*2^(1/2)*b)*a^(1/2)*2^(1/2)}
{a, b}
solve(eqs,unknown)
Error, (in is/internal) type `a` does not exist
solve(eqs,unknown)
eqs:=[0 = ln(2)+ln(-a*sech(1/2*2^(1/2)*b)^2), 1 = -tanh(1/2*2^(1/2)*b)*a^(1/2)*2^(1/2)];
unknown:={a, b};
[0 = ln(2)+ln(-a*sech((1/2)*2^(1/2)*b)^2), 1 = -tanh((1/2)*2^(1/2)*b)*a^(1/2)*2^(1/2)]
{a, b}
solve(eqs,unknown)
unknown:=[a, b];
[a, b]
solve(eqs,unknown)
Download is_internal_error_from_solve_maple_2024_1.mw
Update
Reported to Maplesoft support.
Any idea why limit(e,x=0) fail to evaluate but  eval(e,x=0) does in this example?
e:=-tanh(sqrt(2)*(a*x+b))
-tanh(2^(1/2)*(a*x+b))
limit(e,x=0)
limit(-tanh(2^(1/2)*(a*x+b)), x = 0)
eval(e,x=0)
-tanh(b*2^(1/2))
Download limit_problem_maple_2024_1.mw
I tried the above using some other software, and there both evaluate to same result as expected:
In Maple, I found that by removing the sqrt(2) from inside the tanh, then limit now works
e:=-tanh((a*x+b));
limit(e,x=0)
Is this a bug?
Dear all, I have the following issue:
Goal is to calculate saddle, turning point, etc.
As you can see in the code above only in case of a second restart x2 is calculated correctly.
Thanks for help.
I have created a document on my computer that runs normally in Maple 2024.1. However, when I upload this document to MaplePrimes, it shows an error or behaves unexpectedly. The document contains a system of differential equations, which I solved numerically and plotted, but the plots and equilibrium points do not display correctly after uploading.
When I run this code on my local machine, it works perfectly. However, after uploading the document to MaplePrimes, it does not run as expected. What could be causing this issue? Is there a known problem with Maple 2024.1 when uploading documents, or could there be a compatibility issue with MaplePrimes?
Any help or suggestions would be greatly appreciated. Thank you!
This project discusses the predator-prey system, particularly the Lotka-Volterra equations, which model the interaction between two species: prey and predators. Let's solve the Lotka-Volterra equations numerically and visualize the results.
alpha := 1.0; beta := .1; g := 1.5; delta := 0.75e-1; ode1 := diff(x(t), t) = alpha*x(t)-beta*x(t)*y(t); ode2 := diff(y(t), t) = delta*x(t)*y(t)-g*y(t); eq1 := -beta*x*y+alpha*x = 0; eq2 := delta*x*y-g*y = 0; equilibria := solve({eq1, eq2}, {x, y}); print("Equilibrium Points: ", equilibria); initial_conditions := x(0) = 40, y(0) = 9; sol := dsolve({ode1, ode2, initial_conditions}, {x(t), y(t)}, numeric); eq_points := [seq([rhs(eq[1]), rhs(eq[2])], `in`(eq, equilibria))]
[[0., 0.], [20., 10.]]
plots[odeplot](sol, [[t, x(t)], [t, y(t)]], t = 0 .. 100, legend = ["Rabbits", "Wolves"], title = "Prey-Predator Dynamics", labels = ["Time", "Population"])
sol_plot := plots:-odeplot(sol, [[x(t), y(t)]], 0 .. 100, color = "blue"); equilibrium_plot := plots:-pointplot(eq_points, color = "red", symbol = solidcircle, symbolsize = 15); plots:-display([sol_plot, equilibrium_plot], title = "Phase Portrait with Equilibrium Points", labels = ["Rabbits", "Wolves"])
Now, we need to handle a modified version of the Lotka-Volterra equations. These modified equations incorporate logistic growth fot the prey population.
alpha := 1.0; beta := .1; g := 1.5; delta := 0.75e-1; k := 100; ode1 := diff(x(t), t) = alpha*x(t)*(1-x(t)/k)-beta*x(t)*y(t); ode2 := diff(y(t), t) = delta*x(t)*y(t)-g*y(t); eq1 := alpha*x*(1-x/k)-beta*x*y = 0; eq2 := delta*x*y-g*y = 0; equilibria := solve({eq1, eq2}, {x, y}); print("Equilibrium Points: ", equilibria); initial_conditions := x(0) = 40, y(0) = 9; sol := dsolve({ode1, ode2, initial_conditions}, {x(t), y(t)}, numeric); eq_points := [seq([rhs(eq[1]), rhs(eq[2])], `in`(eq, equilibria))]
[[0., 0.], [100., 0.], [20., 8.]]
plots:-odeplot(sol, [[x(t), y(t)]], 0 .. 50, color = "blue"); equilibrium_plot := plots:-pointplot(eq_points, color = "red", symbol = solidcircle, symbolsize = 15); plots:-display([plots:-odeplot(sol, [[x(t), y(t)]], 0 .. 50, color = "blue"), equilibrium_plot], title = "Phase Portrait with Equilibrium Points", labels = ["Rabbits", "Wolves"])
Download predator_prey.mw
I can't combine standard font and Greek symbols in a plot legend. I want to type:
"Limit of X_{i}^{\rho=0} (\alpha\mapsto+\infty)>0"
where I used LaTeX notation to emphasise that I want (1) superscript and subscript of X displayed as aligned exactly on top of each other, (2) rho, alpha, mapsto-style arrow, and infinity typed in their respective symbolic forms.
thanks!
I do not have earlier Maple version to check now. But Maple 2024.1 gives division by zero on this second order ode with missing x. This looks like new problem in Maple. Would someone who have access to earlier version of Maple be able to check if this problem shows there also? I solved this and get y=x+3 as solution which Maple verifies.
ode:=diff(y(x),x$2)=(diff(y(x),x))^3-(diff(y(x),x))^2;
IC:=y(0)=3,D(y)(0)=1;
diff(diff(y(x), x), x) = (diff(y(x), x))^3-(diff(y(x), x))^2
y(0) = 3, (D(y))(0) = 1
dsolve([ode,IC])
Error, (in dsolve) numeric exception: division by zero
sol:=y(x)=3+x;
odetest(sol,[ode,IC])
y(x) = 3+x
[0, 0, 0]
DEtools:-odeadvisor(ode);
[[_2nd_order, _missing_x], [_2nd_order, _reducible, _mu_y_y1]]
infolevel[dsolve]:=5;
5
dsolve([ode,IC])
Methods for second order ODEs:
trying 2nd order Liouville
trying 2nd order WeierstrassP
trying 2nd order JacobiSN
differential order: 2; trying a linearization to 3rd order
--- trying a change of variables {x -> y(x), y(x) -> x}
trying 2nd order ODE linearizable_by_differentiation
trying 2nd order, 2 integrating factors of the form mu(x,y)
trying differential order: 2; missing variables
-> Computing canonical coordinates for the symmetry [0, 1]
-> Rewriting ODE in canonical coordinates by means of differential invariants
Try computing 1 more symmetries for ODE written in canonical coordinates
 -> Computing symmetries using: way = 3
 Found another symmetry:
[1, 0]
[-x+y, 0]
Computing a convenient ordering to use the 3 symmetries available
<- differential order: 2; canonical coordinates successful
<- differential order 2; missing variables successful
dsolve(ode)
[1, 0]
[-x+y, 0]
-> Calling odsolve with the ODE diff(_b(_a) _a) = _b(_a)^3-_b(_a)^2 _b(_a) HINT = [[1 0] [-_a+y -_b*(_b-1)]]
   *** Sublevel 2 ***
   symmetry methods on request
 1st order, trying reduction of order with given symmetries:
[1, 0], [-_a+y, -_b*(_b-1)]
   1st order, trying the canonical coordinates of the invariance group
   <- 1st order, canonical coordinates successful
y(x) = ln(LambertW(-c__1*exp(x-1)))+c__2
Download divide_by_zero_maple_2024_1_august_5_2024.mw
I want to substitute a variable r' =sqrt(x^2 + y^2 + z^2).
But how do I change my output so that r' is displayed instead of sqrt(x^2+y^2+z^2)?
E.g. line (5) D(g)(r')x/r' and not D(g)(sqrt(x^2 + y^2 + z^2))*/sqrt(x^2 + y^2 + z^2).
And one more question. How can I make sure that my output in (6) is only the result on the right side and the left side of the equal sign is not displayed?
with(Physics)
__________________________________________________________________
with(Vectors)``
Setup(spacetimeindices = greek, spaceindices = lowercaselatin, su2indices = uppercaselatin, signature = `- - - +`, coordinates = cartesian)
[coordinatesystems = {X}, signature = `- - - +`, spaceindices = lowercaselatin, spacetimeindices = greek, su2indices = uppercaselatin]
diff(r(x), x) := sqrt(x^2+y^2+z^2)
(x^2+y^2+z^2)^(1/2)
g(diff(r(x), x))
g((x^2+y^2+z^2)^(1/2))
diff(g(diff(r(x), x)), x)
(D(g))((x^2+y^2+z^2)^(1/2))*x/(x^2+y^2+z^2)^(1/2)
H := (x*Psigma[1, matrix]+y*Psigma[2, matrix]+z*Psigma[3, matrix]).Vector(2, {1 = 0, 2 = U(diff(r(x), x))})
(x*Physics:-Psigma[1]+y*Physics:-Psigma[2]+z*Physics:-Psigma[3]).Vector[column](%id = 36893490180036880732) = Vector[column](%id = 36893490180036881092)
Download representation_of_code.mw
In the code below, I define an expression, then turn it into a function of omega_d.
Consider the results (5) and (6) below.
I take the derivative of the function relative to omega_d, set the derivative to zero and ask Maple to solve for the critical point (ie, the omega_d at which the derivative is zero).
I get the correct result in (5), ie three different critical points. But when I simplify this result, Maple returns only one of the critical points.
Why?
expr := f/sqrt((`&omega;__0`^2-`&omega;__d`^2)^2+`&gamma;__b`^2*`&omega;__d`^2)
f/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(1/2)
A := unapply(expr, `&omega;__d`)
proc (omega__d) options operator, arrow; f/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(1/2) end proc
diff(A(`&omega;__d`), `&omega;__d`)
-(1/2)*f*(-4*(omega__0^2-omega__d^2)*omega__d+2*gamma__b^2*omega__d)/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(3/2)
simplify(diff(A(`&omega;__d`), `&omega;__d`))
-f*omega__d*(gamma__b^2-2*omega__0^2+2*omega__d^2)/(omega__d^4+(gamma__b^2-2*omega__0^2)*omega__d^2+omega__0^4)^(3/2)
solve(diff(A(`&omega;__d`), `&omega;__d`) = 0, `&omega;__d`)
0, (1/2)*(-2*gamma__b^2+4*omega__0^2)^(1/2), -(1/2)*(-2*gamma__b^2+4*omega__0^2)^(1/2)
simplify(solve(diff(A(`&omega;__d`), `&omega;__d`) = 0, `&omega;__d`))
This was a problem for me just now because I used the command in (6) first and just could not figure out what the heck was going on. I did the calculations by hand to check, and then finally found out it was this simplify command.
Download simplifysolve.mw
Something seems to have changed.  I do not now have Maple 2024.0 to check or earlier Maple's as I have to reinstall windows since my C:\ drive died.
I installed Maple 2024.1 new on windows 10 home edition.
I noticed now when evaluating the current cell, the cursor automatically jumps to next cell, which is what I want and how Maple always worked.
But now the cursor jumps to the end of the command in the next cell. Before, I could swear that not how it worked and it used to jump to the start of the next cell.
This makes it very confusing, as I keep looking for where the cursor is now.
Why was this changed in 2024.1? I looked at option and see nothing to change this.
Here is worksheet and small movie.
This is my display options
x:=1;
y:=3;
z:=4;
4
h:=4;
4
Download cursor_jump_to_end_of_line.mw
Update
I tried to change the cursor size and thickness in windows 10 itself (using settings->Ease of access->Text cursor) and made it much bigger and restarted Maple but this had no effect. Cursor inside Maple remained the same.
I was hoping if there is a way to make the cursor bigger then this will make it easier to see where it jumped to when hitting enter.
It is bad, since the Maple cursor jumps to random places in the next cell. sometimes it jumps to the middle of the code in the next cell when there are more than one line there.
Here is a movie. Notice how it jumped to the start of the second line now in next cell in one case and not to the end of the code.
I can't believe no one at Maplesoft have noticed this and is able to fix it. This is ridiculous behavior. I spend few seconds each time I hit enter looking for where the cursor has landed as I keep looking at start of the next cell and it is not there. I could have 10-20 lines of code in one cell and have too look to find where the cursor is hidden in these 20 lines.
It natural for one to look for where the cursor is when woking and this makes it annoying. Hopefully someone can find a way to tell Maple to bring the old behaviour back where cursor jumps always to the start of the next cell.
local gamma;
gamma
with(Plot)
params := {alpha = 2.5, k = 3, w = 2, beta[3] = 3, beta[4] = 1.7,theta=0,gamma=1};
{alpha = 2.5, gamma = 1, k = 3, theta = 0, w = 2, beta[3] = 3, beta[4] = 1.7}
xi := sqrt(-1/(72*alpha*beta[4]+72*gamma*beta[4]))*(2*alpha*k*t+x)
(-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x)
sol1 := [U(xi), -k*x -(9*alpha*k^2*beta[4] + 2*beta[3]^2)/(9*beta[4])*t + theta];
[U((-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x)), -k*x-(1/9)*(9*alpha*k^2*beta[4]+2*beta[3]^2)*t/beta[4]+theta]
sol2 := eval(sol1, U(xi) = -beta[3]/(3*beta[4]) + beta[3]*sinh(xi)/(6*beta[4]*cosh(xi)) + beta[3]*cosh(xi)/(6*beta[4]*sinh(xi)));
[-(1/3)*beta[3]/beta[4]+(1/6)*beta[3]*sinh((-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x))/(beta[4]*cosh((-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x)))+(1/6)*beta[3]*cosh((-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x))/(beta[4]*sinh((-1/(72*alpha*beta[4]+72*gamma*beta[4]))^(1/2)*(2*alpha*k*t+x))), -k*x-(1/9)*(9*alpha*k^2*beta[4]+2*beta[3]^2)*t/beta[4]+theta]
solnum :=eval(sol2, params);
[-.5882352940+(.2941176471*I)*sin(.7247137946*t+0.4831425297e-1*x)/cos(.7247137946*t+0.4831425297e-1*x)-(.2941176471*I)*cos(.7247137946*t+0.4831425297e-1*x)/sin(.7247137946*t+0.4831425297e-1*x), -3*x-23.67647059*t]
plots:-complexplot3d(solnum, x = -50.. 50, t = -50..50);
Warning, unable to evaluate the function to numeric values in the region; complex values were detected
if there is any other way for graph please share with me
Download complexplot3d.mw
Why doesn't evalf work on the data structures below?
M1 := Matrix([[m__1, m__2]])
Matrix(%id = 36893488151929448556)
M := [M1, M1]
[Matrix(%id = 36893488151929448556), Matrix(%id = 36893488151929448556)]
m__1 := 1; m__2 := 2
M
evalf(M)
[Matrix(%id = 36893488151929440844), Matrix(%id = 36893488151929440964)]
evalf(M[1])
Matrix(%id = 36893488151929437108)
evalf(op(M))
Matrix(%id = 36893488151929432292), Matrix(%id = 36893488151929432412)
evalf(op(M[1]))
1., 2., {(1., 1.) = m__1, (1., 2.) = m__2}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []
Download evalf.mw
First 88 89 90 91 92 93 94 Last Page 90 of 2430
