I would like to generate a ColumnGraph such that the bars are centered over 1, 2, and 3. For example, I have a vector:
x:= Vector([1,2,3]);
When you execute ColumnGraph(x), you a get the first bar centered over 0.375, instead of 1, second bar centered over 1.375, instead of 2, and so on.
Thanks for your help.
I have seen this quite a bit in blocks of code. The `>` symbol seems to appear erratically. I don't know how to specifically reproduce this. Does it mean something? I would post the worksheet but it will not run without the package.
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"NULL
"maple.ini in users"
NULL#  plot  solutions to a system  of DEs
sys := {diff(x(t), t) = y(t), diff(y(t), t) = -x(t) - 1/2*y(t)}
{diff(x(t), t) = y(t), diff(y(t), t) = -x(t)-(1/2)*y(t)}
DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[x(0) = 1, y(0) = 0]])
This is not working, seems to be simple ...
Have made an attempt to create a procedure from these two commands, but no success
Apparently, I need to learn to use a debugger to determine what is wrong, then?
dv_systeemplot:= proc ( DV1,DV2 ,RV1,RV2 )
                 local t, sys,systeemplot;
                 sys := {DV1 , DV2 }:
                 systeemplot:= DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[RV1 , RV2]]);
                 return systeemplot;
proc (DV1, DV2, RV1, RV2) local t, sys, systeemplot; sys := {DV1, DV2}; systeemplot := DEplot(sys, [x(t), y(t)], t = 0 .. 15, [[RV1, RV2]]); return systeemplot end proc
DV1 := diff(x(t), t) = y(t)
DV2 := diff(y(t), t) = -x(t)-(1/2)*y(t)
RV1 := x(0) = 1
x(0) = 1
RV2 := y(0) = 0
y(0) = 0
dv_systeemplot( DV1,DV2 ,RV1,RV2 );
Error, (in DEtools/DEplot/CheckDE) inputs must be ODEs
Ask AI to get some code: never i got the right Maple code ! :)
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"``
systeem := proc(eq1, eq2, beginwaarden)
  local x, y, oplossing;
  x := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t);
  y := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t);
  oplossing := DEplot([x(t), y(t)], t = 0 .. 10, beginwaarden);
  oplossing;
# Definieer de differentiaalvergelijkingen
eq1 := diff(x(t), t) = y(t);
eq2 := diff(y(t), t) = -x(t);
# Geef de beginwaarden op
beginwaarden := [x(0) = 1, y(0) = 0];
# Roep de procedure aan met de differentiaalvergelijkingen en beginwaarden
systeem(eq1, eq2, beginwaarden);
proc (eq1, eq2, beginwaarden) local x, y, oplossing; x := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t); y := unapply(rhs(dsolve({eq1, eq2, beginwaarden}, {x(t), y(t)})), t); oplossing := DEplot([x(t), y(t)], t = 0 .. 10, beginwaarden); oplossing end proc
Error, (in dsolve) invalid input: PDEtools/sdsolve expects its 1st argument, SYS, to be of type Or(set({`<>`, `=`, algebraic}),list({`<>`, `=`, algebraic}),`casesplit/ans`(list,list)), but received {diff(x(t),t) = y(t), diff(y(t),t) = -x(t), [x(0) = 1, y(0) = 0]}
Probably i do need to work with a debugger here?
Download dv_systeem_via_mapleprimes_.mw
If we write
restart: alias(po=pochhammer):
assume(abs(z)<1);  F:=z->sum(po(1,n)^2/po(1/2,n)^2*z^n/(n+1),n=1..infinity);
Then the output of F(z) is a hypergeometric series, and
A=subs(z=4, F(z);
evalf(A)
gives the correct output. But, why do we need to assume that abs(z)<1 if we are evaluating at abs(z)>1?. Observe that if we do not assume it, then the output we get is wrong, why?
I recently watched a video in which the speaker asked the following question: "How many seconds are there in 42 days?".
I think I've done what anyone would do: trying to quickly find an order of magnitude for this number.
But the speaker's answer was both remarkable and obvious when you think of it: "Exactly 10! seconds".
So my question: Given the number 3628800, is there a way to identify it (in the  identify's sense) to 10!  ?
Or maybe some trick to force identify to answer 10! ?
Well , honestly I can't make sense of how to do this.
Interactive can be done step by step , but now generalize via a procedure , but can't get a handle on it
How to get the right procedure ?
" restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ;"
DV := y(x)*(diff(y(x), x)) = exp(x)
opl_1 := dsolve({DV, RV1}, y(x))
y(x) = (1-2*exp(1)+2*exp(x))^(1/2)
opl_2 := dsolve({DV, RV2}, y(x))
y(x) = -(1-2*exp(1)+2*exp(x))^(1/2)
opl := plot({rhs(opl_1), rhs(opl_2)}, x = 0 .. 5, y = -10 .. 10, thickness = 3)
lijnelement := dfieldplot(DV, y(x), x = 0 .. 5, y = -10 .. 10, title = "lijnelementveld met intergaalkromme door (1,1)(1,-1)")
display({opl, lijnelement})
DV, RV1, RV2
y(x)*(diff(y(x), x)) = exp(x), y(1) = 1, y(1) = -1
"restart: with(plots):with(DEtools):with(Student[ODEs]):infolevel[Student]:=3 ; "
DVplot:=proc(DVA,RV1A,RV2A)
          local DV;RV1;RV2;opl_1;opl_2;opl;lijnelement;
          DV:
          RV1:
          RV2:
          opl_1 := dsolve({DV, RV1}, y(x)):
          opl_2 := dsolve({DV, RV2}, y(x)):
          opl:= plot({rhs(opl_1), rhs(opl_2)}, x = 0 .. 5, y = -10 .. 10, thickness = 3):
          lijnelement:=dfieldplot(DV, y(x), x = 0 .. 5, y = -10 .. 10, title = "lijnelementveld met                intergaalkromme door (1,1)(1,-1)"):
          display({opl, lijnelement});
DVA := y(x)*(diff(y(x), x)) = exp(x)
RV1A := y(1) = 1
y(1) = 1
RV2A := y(1) = -1
y(1) = -1
DVplot(DVA, RV1A, RV2A)
Error, (in dsolve) not a system with respect to the unknowns [y(x)]
Download DV_plotten-_procedure.mw
I want to make from a procedure call a single argument function that can be used in function composition.
To illustrate this with a simple example, below the function pow[3] performs a cube operation
pow[3]:=x-> `^`(x,3):
(evalf[4]@pow[3]@sin)(Pi/6)
                             0.1250
To make the use of pow a bit more generic, I though about doing definitions for other powers in a loop with an inline assignement
for i from -1/2 to 5 by 1/2 do (power[i]:=x-> `^`(x,i)) end do;
This does not work because the i in the rigthhand side of power[i]:=x-> `^`(x,i) does not evaluate to the acutal value of the loop counter. I tried eval and evaln without success. How do I get full evaluation of the inline assignement?
How can I find a relation of a, b, c, d, t (a d <> 0) so that the function f(x) = (a x^2 + b x + c)/(d x +t) is a increasing function on the interval (m, n)? I know that, we have the conditions
f'(x) >=0 forall x in (m, n) and -t/d not in (m, n)
I have the following procedure that uses the Lie Derivatives of a vector field to build a set of equations.
LieDerList:=proc(h::symbol,f::list,vars::list)
description "This function returns the system of equations based on the Lie derivative.":
local i,n:=numelems(vars),L:=Array(0..n):
L[0]:=h:
for i from 1 to n do
    L[i]:=inner(f,map((a,b) -> diff(b,a),vars,L[i-1])):
return(zip((w,v)->simplify(w-v),[seq(L)],[seq](cat(h,i),i=0..n))):
Below it is an example on how to call the procedure.
I used CodeTools:-ThreadSafetyCheck to check all the procedures used within LieDerList and LieDerList itself, but nothing wrong came out. However when I try to run
LieEq4:=Threads:-Map(w->LieDerList(x,w,[x,y,z]),models4):
where models4 is a list of 1765 elements, maple returns "Error, (in factors) attempting to assign to `LinearAlgebra:-Modular:-Create` which is protected". If I change Threads to Grid, there is no problem at all.
What am I overlooking? Is there a method to ensure the procedure is thread-safe?
Many thanks.
PS.  I found one problem - inner, which is related to LinearAlgebra package, is not thread-safe.
This is not new in Maple 2024, and also happens in Maple 2023. But it causes the famous "kernel connection has been lost" each time.
I think many of the kernel connection has been lost problems I see might be related. It could be memory problem in this case. I wonder if someone will be able to track what causes it. Is it expected that server.exe crash on such input?
ps. Reported to Maplesoft support.
36292
`The "Physics Updates" version in the MapleCloud is 1708 and is the same as the version installed in this computer, created 2024, March 27, 16:20 hours Pacific Time.`
integrand:=(2*x^2022+1)/(x^2023+x);
int(integrand,x);
Download reproducible_server_crash_test.mw
For reference, another software give this result instantly and with no crash:
My PC is windows 10, with 128 GB RAM.
May be someone could find what causes this new internal error in Maple 2024.
I did report it already to Maplesoft. It does not happen in Maple 2023. Attached both worksheets.
integrand:=(d*x)^m/(a+b*arctanh(c*x^n))^2;
int(integrand,x);
Error, (in int/gparse/gmon) too many levels of recursion
Download int_gparse_gmon_error_maple_2024_march_27_2024.mw
130032
int(integrand,x);
2*x*(c*exp(n*ln(x))-1)*(c*exp(n*ln(x))+1)*exp(m*(ln(d)+ln(x)-((1/2)*I)*Pi*csgn(I*d*x)*(-csgn(I*d*x)+csgn(I*d))*(-csgn(I*d*x)+csgn(I*x))))/(b*c*n*exp(n*ln(x))*(-b*ln(1-c*exp(n*ln(x)))+b*ln(c*exp(n*ln(x))+1)+2*a))+int(-2*exp(m*(ln(d)+ln(x)-((1/2)*I)*Pi*csgn(I*d*x)*(-csgn(I*d*x)+csgn(I*d))*(-csgn(I*d*x)+csgn(I*x))))*(c^2*m*(exp(n*ln(x)))^2+c^2*n*(exp(n*ln(x)))^2+(exp(n*ln(x)))^2*c^2-m+n-1)/(b*c*n*exp(n*ln(x))*(-b*ln(1-c*exp(n*ln(x)))+b*ln(c*exp(n*ln(x))+1)+2*a)), x)
Download int_gparse_gmon_NO_error_maple_2023.mw
I setup my package to display the a message when it is loaded. It is quiet convienent but I don't need it all the time. Obviously I can "#" in the code to hide it premanently. I was wondering if there is away to optionally turn it off/on. Something along the lines.
with(RationalTrigonometry,false) or with(RationalTrigonometry)[false]....
Or put something in the .ini flie to set the default behaviour.
restart:with(RationalTrigonometry):
 "Default global settings:-
     GeomClr = "Blue",
      Prntmsg = true,
       Prjpsn = 3 can be set to 1,
      Normalgpt = 1 or set to 0,
    Metric is a 3 x3 symmetric matrix defaults to the Identity
    matrix "
For a lesson I'm preparing, I want to illustrate some probability concepts using Maple.
In particular, I need to use the fact that the Expectation operator(let say the Mean operator) is a linear operator with respect to random variables.
However, I don't want to particularize my demonstration by using this or that statistical distribution but simply the notion of random variable.
I have therefore created a specific Distribution named  MinimalAbstractDistribution in which only the mean and variance are defined.
When Statistics:-Mean is applied to the expression (A*p+q) where p and q are names and A is a random variable with distribution MinimalAbstractDistribution, linearity is effectively used.
But not when it is applied to A/p or A-q.
Why that?
Is there a way of defining a statistical distribution so that Mean behaves as expected?
(You will easily understand that no workaround of the form
Mean(A+q);
eval(%, q=-q);
# or
add(Mean~([op(A-q)]))
can be accepted in a lesson).
Thanks for your attention
with(Statistics):
MinimalAbstractDistribution := proc(i)
  Distribution(Mean=mu[i], Variance=sigma[i]^2)
A := RandomVariable(MinimalAbstractDistribution(1))
_R
[Mean, Variance](A);
[mu[1], sigma[1]^2]
Mean(p*A+q);
Mean(p*(A+q))
p*mu[1]+q
p*(mu[1]+q)
# But
Mean(A-q);
Mean(A/p)
FAIL
FAIL
Download Mean_operator.mw
How do we define a matrix or a vector of the partial differential operator?
Both uses of evalf
evalf(Pi, 20);
evalf[20](Pi);
work, but only the latter is documented. Is there a reason behind (maybe historical)? Any reason not to use evalf(...,n) any more? I am also reluctant to update old worksheets if there is no need for the indexed version.
First 154 155 156 157 158 159 160 Last Page 156 of 2463
