everyone! I want to get a system of equations (Fig. 1). But my result is a table (Fig. 2), so I wonder how to convert a table into a sequence or a system. And I am very sorry that my code is not concise, since I am a beginner. Thank you very much!
Download Equations.mw
I'm in the process of making a resonant LLC calculator to define Lr,Lm and Cr. In short, to do this I need to define the fonction of the Gain for different Qualifty factor at a given m value m. My issue is that the below code returns different results everytime. I'm trying to get the value at the top of the Q curve using the maximise fonction and trying to solve wx for that maximum value. Anybody can see what am I doing wrong. Sometime it outpiuts an imaginary number where sometime it doesn't. The expression seems correct as its producing the correct plot/curve.
Thank you for the help.
> restart:with(plots):
> m:=6.3:
> Q1:=1:
> GainQ1:=(8/(Pi^2))*((wx^2)*(m-1))/(sqrt((((m*wx^2)-1)^2)+(Q1^2*wx^2)*((wx^2-1)^2)*((m-1)^2))):
> semilogplot({GainQ1},wx=0.2...2,Gain,axes=boxed,thickness=5,title=`Gain (w, Q, m)`):
> Top_of_Q1:=eval(maximize(GainQ1),wx=0.1..2);wx:=solve(GainQ1=Top_of_Q1);
Hello Iam following this tutorial to solve pde with laplace transforms  but have a problem with eval which is not evaluating the following expression
with(PDEtools);
with(inttrans);
# Equations for c in physical space
PDE1 := diff(c(r, t), t) = K_1*diff(r*diff(c(r, t), r), r)/r;
#initial condition
ic1 := c(r, 0) = V
# Equation in Laplace space
PDEL1 := laplace((lhs - rhs)(PDE1), t, p);
# Apply initial condition to simplify
simplified_PDEL1 := eval(PDEL1*{ic1})
which is displayed (an treated) as
with c(r,0) not being replaced by V. When I try to solve the problem with dsolve I get the following error
Error, (in dsolve) invalid input: `PDEtools/NumerDenom` expects its 1st argument, ee, to be of type algebraic, but received {c(r, 0) = V}
If I replace manually C(r,0) by V then the error dissapears. Is this how eval is supposed to behave ?
Cheers,
I need to work with the shapiro-wilks statistical test for the normaility of the population.
I remark that the precision of this test with Maple is not very good.
I try the same test with STATISTICA, STHDA and  XLSTAT.
For p-value, I obtained 0.3478, 0.3439 and 0.348 with the 3 others softs and 0.4146 with Maple.
For the W, I obtained 0.986, 0.9825 and 0.983 with the 3 others and 0.9761 with Maple.
My sample has 80 elements, risk 0,05.
Is there anybody to explain this difference between the results and perhaps to confirm if it does exist a best method with Maple.
The test :
pvalue2 := Statistics:-ShapiroWilkWTest(Mat2, level = 0.05, output = 'pvalue')
statvalue2 := Statistics:-ShapiroWilkWTest(Mat2, level = 0.05, output = 'statistic')
Thank you very much for help.
I am trying to recover with maple the analytical solution of the problem of conduction within two composite cylinders given in Carslaw and Jeager's book: "Conduction of heat in solids" (link here). Here is my take on the problem
with(PDEtools);
C := diff_table(c(rho, t));
E := diff_table(e(rho, t));
PDE1 := diff(C[], t) - K_1*(diff(diff(C[], rho), rho) - diff(C[], rho)/rho) = 0;
PDE2 := diff(E[], t) - K_2*(diff(diff(E[], rho), rho) - diff(E[], rho)/rho) = 0;
ic1 := eval(C[], t = 0) = V;
ic2 := eval(E[], t = 0) = 0;
bc_1 := eval(C[], rho = a) = eval(E[], rho = a);
bc_2 := K_1*eval(diff(C[], rho), rho = a) = K_2*eval(diff(E[], rho), rho = a);
bc_3 := eval(E[], rho = infinity) = 0;
bc_4 := (diff(C[]/rho, rho), rho = 0) = 0;
pdsolve([PDE1, PDE2],[ic1,ic2, bc_1,bc_2,bc_3,bc_4]);
Unfortunately I end up with the following errors:
Error, (in pdsolve/sys) too many arguments; some or all of the following are wrong: [{c(rho, t), e(rho, t)}, [c(rho, 0) = V, e(rho, 0) = 0, c(a, t) = e(a, t), K_1*(diff(c(a, t), a)) = K_2*(diff(e(a, t), a)), e(infinity, t) = 0, ((diff(c(rho, t), rho))/rho-c(rho, t)/rho^2, rho = 0) = 0]]
If I call pdsolve without any initial and boundary conditions, I have the general form of the equation which is correct (product of exponential function in time with Bessel functions for space) but I don't know how to determine the coeficients with maple from there.
Note also that the boundary condition "bc_2" does not seem to be correcty evaluated (it is supposed to specify the continuity of the flux ar r=a). Instead it just evaluate the expression with r swapped with a. If one write the same line of code with r=0 instead of r=a then the evaluation seems correct.
Any help would be very appreciated,
Cheers
I have a problem with the type of the pvalue in the Shapiro-Wilks test.
My program :
pv := ShapiroWilkWTest(Mat1, level = 0.05);
whattype(pv);  list
eval(pv[2]);  "pvalue = 0.25..."  This result is an element of a list but not a real number
I would like to obtain the real value of pvalue in order to make a calulous with it.
I have tried as an example in Maple :
pv := ShapiroWilkWTest(Mat1, level = 0.05,output=pvalue); but it doesn't run.
May someone help me? Thank you very much
I solved the differential equation using 'dsolve' and Maple returns it with fiver possible solutions. How can we get the single possible solution for w(x) if we assume c, g (constants) are positive? Also, can we convert JacobiSN() to a simple trigonometric or algebraic function?
with(DEtools)
q := (1/2)*(diff(w(x), x))^2+(1/8)*w(x)^4-(1/2)*c*w(x)^2-g = 0
dsolve((1/2)*(diff(w(x), x))^2+(1/8)*w(x)^4-(1/2)*c*w(x)^2-g = 0, {w(x)})
w(x) = (2*c+2*(c^2+2*g)^(1/2))^(1/2), w(x) = (-2*(c^2+2*g)^(1/2)+2*c)^(1/2), w(x) = -(2*c+2*(c^2+2*g)^(1/2))^(1/2), w(x) = -(-2*(c^2+2*g)^(1/2)+2*c)^(1/2), w(x) = 2*JacobiSN((1/2)*(-2*c+2*(c^2+2*g)^(1/2))^(1/2)*x+_C1, ((c*(c^2+2*g)^(1/2)-c^2-g)*g)^(1/2)/(c*(c^2+2*g)^(1/2)-c^2-g))*g/(g*(-c+(c^2+2*g)^(1/2)))^(1/2)
Download solve.mw
I have a problem to export datas in an excel file.
I have no problem to read some datas in this file, but when i want to write a matrix 1x1 in a cell, there is no error message but nothing happen in the file.
Here is my program :
with(ExcelTools);
kernelopts(datadir);
File1 := FileTools:-JoinPath(["Excel", "test.xlsx"], base = datadir);
Mat1 := Import(File1, "Somme", "G2:G8"); # it runs very well
R := array(1 .. 1, 1 .. 1, [[564]]);
Export(R, "test.xlsx", "Somme", "G1"); # nothing happens in the file
I have a function C that depends on Omega and mu_s values. I am trying to get a 3d plot of C for certain Omega and mu_s values. First, I got the graph for Omega=0.1..10, mu_s=0.1..0.6 (red plot). Then, for Omega=0.1..50, mu_s=0.1..0.6 (green plot). In the second case, I expected the first part of the graph to be the same as before, but with values of C for Omega till 50. However, the first part of the plot changes as well. I do not understand why. Can someone help me with it, please?
I would really appreciate it!
Thank you!!
mint gives messages such as
 These local variables were assigned a value, but otherwise unused:  i
even though it does say what proc this is in, it does not give the line number where such problem is at.
So if a proc is long, say 100 or 200 lines, it is very hard to find the location of such things visually all the time.  Searching for "i" is not too useful.
Tried different options but there are no line numbers given for these messages.
"C:\Program Files\Maple 2022\bin.X86_64_WINDOWS\mint.exe" -i 2  foo.mpl
Using  -i 4 gives much more information, but no line numbers.
Are there other things to try? I think mint should be improved and list line number for each warning and message such as also These local variables were assigned a value, but otherwise unused:
It should give lines numbers where this happened to make it easier to locate in the editor.
Maple 2022.1 windows 10.
Assalomu alaykum.
I couldn't solve this integral equation but other online calculator done it. How to calculate in Maple. I use Maple 2021.
L[1, 0] := t + Pi*t/2 + (4*t^(3/2))/3;
L[2, 0] := t^(1/2) + Pi*t/4;
L := int((L[1, 0] + L[2, 0])/(x - t)^(1/2), t = 0 .. x);
Is it possible to integrate eq (1) in such a way that the final result will be of 1st order differential equation?
with(PDEtools)
eq := (diff(U(z), z))^3*(diff(U(z), z, z))+(diff(U(z), z))*(diff(U(z), z, z, z, z))-(diff(U(z), z, z))*(diff(U(z), z, z, z)) = 0
(diff(U(z), z))^3*(diff(diff(U(z), z), z))+(diff(U(z), z))*(diff(diff(diff(diff(U(z), z), z), z), z))-(diff(diff(U(z), z), z))*(diff(diff(diff(U(z), z), z), z)) = 0
eq1 := map(convert, eq, diff); eq2 := map(int, lhs(eq1), z)-C1 = 0
(1/4)*(diff(U(z), z))^4-(diff(diff(U(z), z), z))^2+(diff(diff(diff(U(z), z), z), z))*(diff(U(z), z))-C1 = 0
Download inttegration.mw
Hello everybody,
Something totaly unexpected came by, and i was wondering: how could this be? Im putting what would be the same input in, and yet, its not giving me the results i was expecting for the input i had itterated.
While one solution would be really cumbersome and slow, it tried to do it faster. It worked before, but now i hit a wall. No clue why, but it seems to be so.
Here is the example:
stelsel := {-x1+7*x2+3*x-x5 = -7, 2*x1+3*x2+4*x3-x5 = 10, 5*x1-3*x2+2*x3-x4-2*x5 = 8}
solve(stelsel*{x1, x2, x3, x4, x5})
Error, (in testeq) invalid arguments
stelsel := {-x[1]+7*x[2]+x[3]-x[5] = -7, 2*x[1]+3*x[2]+4*x[3]-x[5] = 10, 5*x[1]-3*x[2]+2*x[3]-x[4]-2*x[5] = 8}
solve(stelsel, {x[1], x[2], x[3], x[4], x[5]})
{x[1] = 17/3+(4/3)*x[2]-x[3], x[2] = x[2], x[3] = x[3], x[4] = 53/3-(23/3)*x[2]-7*x[3], x[5] = 4/3+(17/3)*x[2]+2*x[3]}
Greetings,
The Function
Download Mapleprimes_Question_Book_2_Paragraph_4.2.2.mw
How can one ask Maple 2022 to give the non-trivial solution to this differential equation
V’(t)=-2*V(t)^(2/3) with V(5)=0 ??
Have tried dsolve({V’(t)=-2*V(t)^(2/3),V(5)=0}). But that only gives me the trivial solution V(t)=0.
First 304 305 306 307 308 309 310 Last Page 306 of 2458
