Is there a reason why maple can't directly integrate over iterable objects (lists, vectors, matrices, etc.)?
From a first glance I would think doing
int(<sin(x), cos(x)>, x=0..2)
should be equivalent to:
map(int, <sin(x), cos(x)>, x=0..2)
Is there a good reason why this would be a bad idea?  (for whatever it's worth, that's what mathematica does by default).
Dear Maple community,
I'm trying to calculate a Steady State Vector of the attached matrix using this Maple routine, but, unfortunately, don't get any solution even after a 30 min calculation on a 64Gb machine. Am I doing something wrong and, if so, could you please give me a hand how to conduct this calculation? Thanks!
Maple_SteadyStateVector.mw
Hello all,
at the beginning of my document I need to assign a value to my variable, for example 0.4, so I can calculate a number of material pararamters for this exact value. At the end I want to include a plot that demonstrates the material behaviour for the variable ranging from 0 to 1.
However, I have found that I can not plot a graph if I have assigned a value to that variable before. The "unassign" command sadly does not work.
I am a beginner in Maple so i am probably missing something obvious, but I would appreciate any help.
I have a quite big program designed with packages and subpackages.
I realized that i'm not to well understand the operation of local/ global/ export variables in this case.
Let's detail the issue.
I consider a package like this :
MAIN PACKAGE:=module()
local XM
global YM
export ZM
      SUBPACKAGE1:=module()
      local X1
      global Y1
      export Z1
      end module;
      SUBPACKAGE2:=module()
      local X2
      global Y2
      export Z2
      end module;
end module;
Question:
Can you describe in the simpliest way the rules for accessing to the variables in the case the variables are local/ global/ export and in the case you are writting procedures inside the MAINPACKAGE or the SUBPACKAGEs ?
In others words may you help me to answer to these questions  ?
Is the local variable XM accessible to the procedures used in SUBPACKAGE1? no
Is the local variable X1 accessible to the procedure used in MAINPACKAGE ? no
Is the global variable YM accessible to the procedures used in SUBPACKAGE1? yes
Is the global variable Y1 accessible to the procedure used in MAINPACKAGE ? yes
Is the export variable ZM accessible to the procedures used in SUBPACKAGE1? yes
Is the export variable Z1 accessible to the procedure used in MAINPACKAGE ? yes with the syntax SUBPACKAGE:-Z1
I let my opinion but i need certainty on these points...
I attach a first draft that i would like you help me.
AboutModuleLocalGlobalExport.mw
I thank you in advance for your help.
I could not find a function in StringTools package which removes all substrings (not single characters) from one long string directly.
For example given a Latex string
s:=" \\left \\int x \\,dx \\left";
And I want to remove all "\\left"  from it, which results in "  \\int x \\,dx "
In Mathematica, there is a function called StringDelete which removes all occurances of the substring in one call. Like this
s = " \\left \\int x \\,dx \\left";
StringDelete[s, "\\left"]
In Maple, I tried StringTools:-Remove(x->evalb(x="\\left"),s) and this did not work.Also tried
StringTools:-Remove(x->StringTools:-Compare(x,"\\left"),s)
But this returned "leftintxdxleft"
And StringTools:-Delete needs a range, which one then has to first find.
I found this:
idx:=[StringTools:-SearchAll("\\left",s)]; #returns index of first character in the string
StringTools:-Delete(s,idx[1]..idx[1]+4); #this only remove the first one. Need to loop to remove all.
Which returns the first substring. So one has to make a loop and keep removing all substrings found from the call to StringTools:-SearchAll
This is all too much work. But can be done.
The question is: What is the simplist way to remove all substrings from one string? All substrings are the same and the substrings can be more than one character.
Here is another example
s:="1234566X6Y67890A6BC66DEFGH";
And want to remove all "66" substrings, so the result will be
"12345X6Y67890A6BCDEFGH";
I am sure there must be an easier way to do this in Maple than having to call 2 or 3 functions and using a loop, but I could not find it so far.
What would be the closest function in Maple to Mathematica's StringDelete?
Requesting a code to compute (and graph) the following self referencing sequence:
a(1)=1. If a(n) is a novel term (seen for the first time) then a(n+1)= d(a(n)) where d(k) is the number of divisors of k.
if a(n) has been seen before then a(n+1) = a(n)+m where m is the least prior term which has not already been used in this way (once m is used it cannot be used again).
Sequence starts:
1,1,2,2,3,2,4,3,5,2,4,6,4,7,2,5,7,11,2...,
note that there are often multiple copies of the least unused term, which might make accounting for them tricky.
hello dear maple maple users.
I'm trying to solve this system of equations using fsolve but i'm geting this unrealistic curve.
I don't know exactly how, can help me understand!!!!!.
fsolve.mw
I am working with the JetCalculus package along with the DifferentialGeometry package. Notation: if there are 2 independent variables (x,y), then u[1,2] would now represent the 3rd mixed partial derivative of u, once with respect to x and twice with respect to y. Please check Example 3 here, https://de.maplesoft.com/support/help/Maple/view.aspx?path=DifferentialGeometry/JetCalculus/TotalDiff
If I have an expression like u[1,0]+f(u[0,0])*u[0,1]+u[1,1]*u[0,3], then I am looking for a procedure which gives me the Lead derivative term. In the example above, it is u[1,1]*u[0,3], and then I can find the lead coefficient, i.e u[1,1].
Please note that the Lead derivative is not unique and can have several terms. For example, orders are the same for u[1,1] and u[0,2].
Idea: If I can find a way to extract the subscripts and do operations on them, then it would be very helpful.
Any help/guidance is much appreciated. Thanks.
EDIT 1: LeadingDerivative command is not the solution for me.
Dear maple users,
A fine day wishes to all.
How to replace a value in already computed data value.
In my problem, I have evaluated a set of values (with help of #ma1 := evalf(seq((A4(t)), t = 0.0..1, 0.1));)
ma1 := 0., .1941703021, .3203871063, .4089371834, .4712881303, .5145114133, .5435036431, .5617715009, .5718586242, .5756277760, .5744585726
I need to change 0 value as a 1.
I have used subs(ma[1]=1,ma1), but its coming wrong.
diff(w(r, theta), r)/r + diff(w(r, theta), r, r) + diff(w(r, theta), theta, theta)/r^2 = r^3*cos(3*theta)
Can it be solved without boundary conditions?
Hi there.
Following by https://www.mapleprimes.com/questions/232199-Bug-In-EllipticCPi
there is some strange behavior of EllipticPi - this function return complex answer when nu>1
WolframAlpha and some another online calculators return real values - just real part of Maple's value.
Why Maple's EllipticPi return complex answer?
help.mw
How to solve Linear first-order PDE by the Lagrange method?
dx/(x) =dy/0=dt/0=du/3=dv/v=dw/w, where x,y,t are independent variables and u,v,w are dependent variables.
hello guys,
I want to plot the phase plane between F and m when:
F := 736*R^4/sqrt((-1380*Pi*R*m(r)^3 + 368*R^4 - 1587*m(r)^2*R^2 + 1280*m(r)^2*a)^2);
R := X^(1/3)/(-l^2 + 4*a) - 3*l^2*m(r)^2/X^(1/3);
X := m(r)*l^2*(sqrt((27*l^2*m(r)^4 - 16*a^2*l^2 + 64*a^3)/(-l^2 + 4*a)) + 4*a)*(-l^2 + 4*a)^2;
m := (l^2*r^2 + r^4 + a*l^2)/(2*l^2*r)
for positive constant a and l
please guide me,
Hello everyone. I took part in a project in which we had to solve problems with Maple 2015. The managers gave us a permanent license. However recently I had trouble on my computer and now Maple doesn't work anymore because it somehow lost the license. The project ended last year, so I can't really ask them anymore. Is there any way to get the license working again? I checked on the site but didn't found anything useful and I'd really need it for the final exam of the last year of high school...
Thanks in advance!
Sorry file was not attached
ASME B31.3-2002 - Flexibility Analysis
This document considers the requirements for flexibility analysis of pipe work in accordance with standard ASME B31.3 2002 Edition.
Temperature Reduction for Swagelok fittings and tube.
Based on 316L Stainless steel fittings and tube, from Data Sheet MS-01-107 rev S and shown below a linear interpolation is used to determine the factor for operation at 100 and 130 centigrade.
with(Interpolation)
with(plots)
Temperature values from table. temp := [93, 204, 315, 426, 537]
Factor values from fable. fact := [1, .96, .85, .79, .76]
Graph of data points. pointplot(temp, fact)
facto := LinearInterpolation(temp, fact)
_m2344257169824
(1.1)
Factor for operation at 100 centigrade.facto(100) = HFloat(0.9974774774774775)NULL
Factor for operation at 130 centigrade. facto(130) = HFloat(0.9866666666666667)NULL
Swagelok compatability
From the B31.3 standard, Table 326.1 Component Standards, Swagelok fittings are not listed directly but it is considered that they are covered under the entry for Unified inch screw threads (UN and UNR thread form) with designation ASME B1.1. Stainless steel pipe is covered directly with designation ASME B36.19M.
Therefore the use of these parts is acceptable under the standard.
Specific Tube Sizes.
The initial specification suggests a DN15 tube size. This equates to 5/8", however the range of fittings in this size is limited. A preferred size would be to either go down to 1/2" or up to 3/4" tube. These will give an actual bore of ~10mm and ~15mm respectivly. In terms of the pressure and temperature specification the following information is provided from Swagelok data sheet MS-01-181.
1/2" x 0.049" wall pressure rating at 37C. TP05__37 := 3700*Unit('psi') = 3700*Units:-Unit(` psi `)NULL
3/4" x 0.065" wall pressure rating at 37C. TP75__37 := 3300*Unit('psi') = 3300*Units:-Unit(` psi `)NULL
Hence pressure ratings, converted to bar at 130C are:
TP05__130 := convert(TP05__37*facto(130), units, bar) = HFloat(251.70460624926636)*Units:-Unit(bar)NULL
TP75__130 := convert(TP75__37*facto(130), units, bar) = HFloat(224.49329746556185)*Units:-Unit(bar)NULL
Hence the tubing used in the design is acceptable.
Weld Fitting Specifications
There are several types of welded fittings as "Tee" "Reduceing Tee" and "Reducing Unions" and they have various pressure ratings.
A 3/4" tube butt weld "Tee" Tee75__37 := 2400*Unit('psi') = 2400*Units:-Unit(` psi `)NULL
The weld fittings have pressure rating at 130C of. Tee75__130 := convert(Tee75__37*facto(130), units, bar) = HFloat(163.2678527022268)*Units:-Unit(bar)NULL
Hence the weld fittings used in the design are acceptable.
Tube wall calculation
with(Units[Standard])
Determine the minimum wall thickness based on the design code.
Design pressure. P__D := 150*Unit('bar') = 150*Units:-Unit(bar)NULL
Outside diameter of nominal 3/4" tube. D__75 := 19.05*Unit('mm') = 19.05*Units:-Unit(mm)NULL
Quality factor. E := 1 = 1 for seamless stainless steel tube.
Allowable stress for 316L tube at 166C (300F). From B31.1 Table A1. S__allow := 115.14*Unit('MPa') = 115.14*Units:-Unit(MPa)NULL
Y__coeff := .4 = .4NULL
Miniumum wall thickness. t__min := P__D*D__75/(2*(E*S__allow+P__D*Y__coeff)) = 0.1179420505e-2*Units:-Unit(m)NULL
Actual wall thickness. W__75 := 1.65*Unit('mm') = 1.65*Units:-Unit(mm)NULL
if W__75 >= t__min then print(PASS) else print(FAIL) end if = PASSNULL``
NULLNULL
Conversions
From Appendix A
allowable stress for TP316L at 100C (212F).convert(16.7, units, ksi, MPa) = 115.1424468NULL
allowable stress for TP316L at room temperature.convert(25.0, units, ksi, MPa) = 172.3689323NULL
convert(18, units, m^3/h, L/minute) = 300NULL
convert(3300.0, units, psi, bar) = 227.5269907NULL
.58*% = 131.9656546NULL
convert(70.0, units, degF, degC) = 38.88888889NULL
convert(300.0, units, degF, degC) = 166.6666667NULL
convert(.117, units, Unit('dm'^3), Unit('L')) = .117NULL
with(ThermophysicalData:-Chemicals)
with(ThermophysicalData)
Property(MolarMass, He, useunits)
4.0026020*Units:-Unit(g/mol)
(3.1)
Property(density, Helium, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
.1625153176*Units:-Unit(kg/m^3)
(3.2)
Helium flow rate. flow[he] := 300*Unit('L')/Unit('min')``
Determine molar flow rate. molflow[he] := .1625153176*flow[he]*Units[Unit](kg/m^3)/(4.0026020*Units[Unit](g/mol)) = .2030120876*Units:-Unit(mol/s)NULL
Determine mass flow rate. massflow[he] := 4.0026020*molflow[he]*Units[Unit](g/mol) = 0.8125765879e-3*Units:-Unit(kg/s)NULL
Property(MolarMass, CO2, useunits)
44.0095000*Units:-Unit(g/mol)
(3.3)
Property(density, CO2, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
1.796636097*Units:-Unit(kg/m^3)
(3.4)
Property(MolarMass, Air, useunits)
28.9651159*Units:-Unit(g/mol)
(3.5)
Property(density, Air, temperature = 300*Unit(kelvin), pressure = 101325*Unit(Pa), source = CoolProp)
1.176995588*Units:-Unit(kg/m^3)
(3.6)
Determine the boiling point of water at 6 bar, the maxiumum pressure delivered by the cd90e unit.
boiling := Property(temperature, water, pressure = 6*Unit(bar), Q = 0)
431.9764773*Units:-Unit(K)
(3.7)
convert(boiling, temperature, Celsius)
158.8264773*Units:-Unit(`&deg;C`)
(3.8)
evalf(convert(30, units, Unit('ft'^3/'min'), liters/s))
14.15842330
(3.9)
Input Parameters
Allowable stress for calculations. S[A] := evalf(f*(1.25*S[c]+.25*S[h]))`` = 219.82275*Units:-Unit(MPa)NULL
Allowable stress at minimum temperature. S[c] := 172.37*Unit('MPa')
Allowable stress at maximum temperature. S[h] := 115.14*Unit('MPa')
Stress reduction factor for N=7000 to 14000 cycles. f := .9
From Table C6 of standard, modulus of elasticity for stainless steel at room temperature.convert(28.3*10^6, units, psi, MPa) = 195121.6314NULL
Named as E[A] := 195121*Unit('MPa') = 195121*Units:-Unit(MPa)NULL
alpha[stst] := 16*10^(-6)*(Unit('m')*(1/(Unit('m')*Unit('K')))) = (1/62500)*Units:-Unit(1/K)NULL
Flexibility Stress
text##
S[E] := sqrt(S[b]^2+4*S[t]^2) =  = (S[b]^2+4*S[t]^2)^(1/2)NULL
Allowable stress factor for analysis requirement. K[allow] := 208000*S[A]/E[A] = 234.3321939NULL
Pipe diameter for 1/2" tube. D__A := 12.7*Unit('mm') = 12.7*Units:-Unit(mm)NULL
Pipe diameter for 3/4" tube. D__B := 19.05*Unit('mm') = 19.05*Units:-Unit(mm)NULL
Change in temperature. Delta[T] := 130*Unit('K') = 130*Units:-Unit(K)NULL
Section A1
Combined length of section A1.L[A1] := 110*Unit('mm')+119*Unit('mm') = 229*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A1] := evalf(alpha[stst]*Delta[T]*L[A1]) = .4763200000*Units:-Unit(mm)NULL
U__A1 := 163*Unit('mm') = 163*Units:-Unit(mm)NULL
K[A1] := D__A*y[A1]/(L[A1]-U__A1)^2 = 0.1388719927e-2NULL
if K__A1 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A1 <= K__allowNULL
Section A2
Combined length of section A2.L[A2] := 610*Unit('mm')+119*Unit('mm') = 729*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A2] := evalf(alpha[stst]*Delta[T]*L[A2]) = 1.516320000*Units:-Unit(mm)NULL
U__A2 := 622*Unit('mm') = 622*Units:-Unit(mm)NULL
K[A2] := D__A*y[A2]/(L[A2]-U__A2)^2 = 0.1682004018e-2NULL
if K__A2 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A2 <= K__allowNULL
Section A3
Combined length of section A3.L[A3] := 723*Unit('mm')+288*Unit('mm') = 1011*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[A3] := evalf(alpha[stst]*Delta[T]*L[A3]) = 2.102880000*Units:-Unit(mm)NULL
U__A3 := 778*Unit('mm') = 778*Units:-Unit(mm)NULL
K[A3] := D__A*y[A3]/(L[A3]-U__A3)^2 = 0.4919334672e-3NULL
if K__A3 <= K__allow then print(PASS) else print(FAIL) end ifError, cannot determine if this expression is true or false: K__A3 <= K__allowNULL
unwith(Units[Standard])
Length of section B. L[B] := 526*Unit('mm')`` = 526*Units:-Unit(mm)
Length of section C. L[C] := 1331*Unit('mm') = 1331*Units:-Unit(mm)
Length of section D. L[D] := 416*Unit('mm') = 416*Units:-Unit(mm)
Length of section E. L[E] := 526*Unit('mm') = 526*Units:-Unit(mm)
Length of section F. L[F] := 762*Unit('mm') = 762*Units:-Unit(mm)
Length of section G. L[G] := 287*Unit('mm') = 287*Units:-Unit(mm)
Length of section H. L[H] := 440*Unit('mm') = 440*Units:-Unit(mm)
Length of section I. L[I] := 400*Unit('mm') = 400*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[B] := evalf(alpha[stst]*Delta[T]*L[B]) = 1.094080000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[C] := evalf(alpha[stst]*Delta[T]*L[C]) = 2.768480000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[D] := evalf(alpha[stst]*Delta[T]*L[D]) = .8652800000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[E] := evalf(alpha[stst]*Delta[T]*L[E]) = 1.094080000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[F] := evalf(alpha[stst]*Delta[T]*L[F]) = 1.584960000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[G] := evalf(alpha[stst]*Delta[T]*L[G]) = .5969600000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[H] := evalf(alpha[stst]*Delta[T]*L[H]) = .9152000000*Units:-Unit(mm)NULL
Length increase due to thermal expansion. y[I] := evalf(alpha[stst]*Delta[T]*L[I]) = .8320000000*Units:-Unit(mm)NULL
K[B] := D[B]*y[B]/(L[B]-u[B])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[C] := D[C]*y[C]/(L[C]-u[C])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[D] := D[D]*y[D]/(L[D]-u[D])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[E] := D[E]*y[E]/(L[E]-u[E])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[F] := D[F]*y[F]/(L[F]-u[F])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[G] := D[G]*y[G]/(L[G]-u[G])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[H] := D[H]*y[H]/(L[H]-u[H])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
K[I] := D[I]*y[I]/(L[I]-u[I])^2Error, (in Units:-Standard:-+) the units `mm` and `1` have incompatible dimensionsNULL
Error, (in unwith) no package called `Units:-Standard' is currently bound
Download CALC-0191-Upload.mw
First 439 440 441 442 443 444 445 Last Page 441 of 2458
