Let P(u,v) = -u⁴+88u³v-146u²v²+88uv³-v⁴+2u²+40uv+2v²-1, with P(u,v)=0,
and u0 = sqrt(2)/6 i,  v0 = -sqrt(2)/6 i. We see that P(u0,v0)=0.
Direct substitution of implicitdiff(P(u,v),v,u) at u0, v0 leads to 0/0.
For obtaining the true value of dv/du at (u0,v0) we have written in Maple:
solve(limit(subs(v=v0+k*(u-u0), implicitdiff(P(u,v),v,u)), u=u0)-k, k);
There are two solutions: 49/113 - 72*sqrt(2)/113*I, and 49/113 + 72*sqrt(2)/113*I.
However we were unable to determine the true value of d²v/du² at (u0,v0).
QUESTION:  How to determine it?
Hi. I'm comparing two 7x3-man teams lists. I can see there are at least 2 teams that have common members, new[1] and past[4], new[4] and past[3]. There may be others but the chat gpt code below doesn't definitively find any of them.
common.mw
The company library with all the good stuff has passed a 100 Mb size, and I wonder if it is possible to find out, which parts of the library that use most of the storage space?
After exertion with ordinary differential equations now relaxation:
Determine the formation law, limit and sum limit for
u_n+3=(13/12)*u_n+2 - (3/8)*u_n+1 + (1/24)*u_n .
Starting values ​​u_1=0, u_2=1, u_3=1.
If we calculating it take to much time but if we make a procedure it will be more effectable for such example, i want the exact and approximat and error
with(PDEtools)
with(LinearAlgebra)
with(inttrans)
with(SolveTools)
undeclare(prime)
eq := diff(y(x, t), `$`(t, 2))+(1+x)*(diff(y(x, t), x))-y(x, t) = 2*y(x, t)^3
diff(diff(y(x, t), t), t)+(1+x)*(diff(y(x, t), x))-y(x, t) = 2*y(x, t)^3
eq1 := laplace(eq, t, s)
s^2*laplace(y(x, t), t, s)-s*y(x, 0)+laplace(diff(y(x, t), x), t, s)*x-laplace(y(x, t), t, s)-(D[2](y))(x, 0)+laplace(diff(y(x, t), x), t, s) = 2*laplace(y(x, t)^3, t, s)
eq2 := subs({y(x, 0) = 1, (D[2](y))(x, 0) = 1}, eq1)
s^2*laplace(y(x, t), t, s)-s+laplace(diff(y(x, t), x), t, s)*x-laplace(y(x, t), t, s)-1+laplace(diff(y(x, t), x), t, s) = 2*laplace(y(x, t)^3, t, s)
eq3 := s^2*laplace(y(x, t), t, s) = s-laplace(diff(y(x, t), x), t, s)*x+1+laplace(diff(y(x, t), x), t, s)+2*laplace(y(x, t)^3, t, s)+laplace(y(x, t), t, s)
eq4 := expand(eq3/s^2)
laplace(y(x, t), t, s) = 1/s-laplace(diff(y(x, t), x), t, s)*x/s^2+1/s^2+laplace(diff(y(x, t), x), t, s)/s^2+2*laplace(y(x, t)^3, t, s)/s^2+laplace(y(x, t), t, s)/s^2
"u[0](x):=invlaplace(1/s+1/(s^2),s,x)"
proc (x) options operator, arrow, function_assign; invlaplace(1/s+1/s^2, s, x) end proc
u[0](x)
1+x
n := N
N
k := K
K
f := proc (u) options operator, arrow; u^3 end proc
for j from 0 to 3 do A[j] := subs(lambda = 0, (diff(f(seq(sum(lambda^i*u[i](x), i = 0 .. 20), m = 1 .. 2)), [`$`(lambda, j)]))/factorial(j)) end do
(1+x)^3
3*(1+x)^2*u[1](x)
3*(1+x)*u[1](x)^2+3*(1+x)^2*u[2](x)
u[1](x)^3+6*(1+x)*u[1](x)*u[2](x)+3*(1+x)^2*u[3](x)
A[0]
(1+x)^3
y[0] := 1+x
1+x
(14)
y[1] := invlaplace(2*laplace(A[0], x, s)/s^2, s, x)-invlaplace(x*laplace(diff(y[0], x), x, s)/s^2, s, x)+invlaplace(laplace(y[0], x, s)/s^2, s, x)-invlaplace(laplace(diff(y[0], x), x, s)/s^2, s, x)
(1/10)*x^2*(x^3+5*x^2+10*x+10)-(1/2)*x^3+(1/6)*x^2*(x+3)-(1/2)*x^2
(15)
y[1] := expand((1/10)*x^2*(x^3+5*x^2+10*x+10)-(1/2)*x^3+(1/6)*x^2*(x+3)-(1/2)*x^2)
(1/10)*x^5+(1/2)*x^4+(2/3)*x^3+x^2
(16)
"u[1](x) :=y[1]  "
proc (x) options operator, arrow, function_assign; y[1] end proc
(17)
A[1]
3*(1+x)^2*((1/10)*x^5+(1/2)*x^4+(2/3)*x^3+x^2)
(18)
y[2] := invlaplace(2*laplace(A[1], x, s)/s^2, s, x)-invlaplace(x*laplace(diff(y[1], x), x, s)/s^2, s, x)+invlaplace(laplace(y[1], x, s)/s^2, s, x)-invlaplace(laplace(diff(y[1], x), x, s)/s^2, s, x)
(1/840)*x^4*(7*x^5+63*x^4+212*x^3+476*x^2+672*x+420)-(1/60)*x^4*(x^3+6*x^2+10*x+20)+(1/420)*x^4*(x^3+7*x^2+14*x+35)-(1/60)*x^3*(x^3+6*x^2+10*x+20)
(19)
y[2] := expand(%)
(1/120)*x^9+(3/40)*x^8+(5/21)*x^7+(7/15)*x^6+(17/30)*x^5+(1/12)*x^4-(1/3)*x^3
(20)
" u[2](x):=y[2]"
proc (x) options operator, arrow, function_assign; y[2] end proc
(21)
A[2]
3*(1+x)*((1/10)*x^5+(1/2)*x^4+(2/3)*x^3+x^2)^2+3*(1+x)^2*((1/120)*x^9+(3/40)*x^8+(5/21)*x^7+(7/15)*x^6+(17/30)*x^5+(1/12)*x^4-(1/3)*x^3)
(22)
y[3] := invlaplace(2*laplace(A[2], x, s)/s^2, s, x)-invlaplace(x*laplace(diff(y[2], x), x, s)/s^2, s, x)+invlaplace(laplace(y[2], x, s)/s^2, s, x)-invlaplace(laplace(diff(y[2], x), x, s)/s^2, s, x)
(1/10810800)*x^5*(7623*x^8+99099*x^7+518778*x^6+1634490*x^5+3647930*x^4+5167305*x^3+4221360*x^2+900900*x-1081080)-(1/25200)*x^5*(21*x^6+210*x^5+750*x^4+1680*x^3+2380*x^2+420*x-2100)+(1/831600)*x^5*(63*x^6+693*x^5+2750*x^4+6930*x^3+11220*x^2+2310*x-13860)-(1/25200)*x^4*(21*x^6+210*x^5+750*x^4+1680*x^3+2380*x^2+420*x-2100)
(23)
y[3] := expand(y[3])
(286/945)*x^9+(131/336)*x^8+(1/7)*x^10+(17/70)*x^7-(1/40)*x^6-(1/20)*x^5+(1/12)*x^4+(1091/23100)*x^11+(11/15600)*x^13+(11/1200)*x^12
(24)
addingterm := y[0]+y[1]+y[2]+y[3]
1+x+(37/60)*x^5+(2/3)*x^4+(1/3)*x^3+x^2+(2351/7560)*x^9+(781/1680)*x^8+(101/210)*x^7+(53/120)*x^6+(1/7)*x^10+(1091/23100)*x^11+(11/15600)*x^13+(11/1200)*x^12
(25)
Download aproximate_and_exact_solution.mw
a table like that
there is four formula for calculate them which i know them by name of author the first one is adomian second one is (BiazarShafiofAdomian) which one member of mableprimes write code for me,but i don't know how use for all kind function maybe in future i upload this program for fix this issue, the third one is by zhao which is i think i easy for calculate just  i need someone one to wite the program and do some test for some example i  upload some picture in case for getting algorithm to writting and have some example for testing  so  lets see who can do this algorithm is very usfule when we solve ODE or PDE by LDM, also last method is by taking integral have a good method, in this question this algorithm is zhao which is usfull one
I am using a proceure to conpute de integral of a function by he Simpson's rule. My function is defined from a function and a procedure, but I am getting the error  "Error, (in w) invalid input: hfun2 expects its 1st argument, t, to be of type numeric, but received (1/10)*i+1/20"
As you can see in the attaxhed file, I have tried several ways to compute the integral but always returns the above error. Please, can yo help me?
forum.mw
I upload picture of solution and i try to solve but i fail i don't know how maple can do that just take laplace of one sidehow posible ?
with(PDEtools)
with(LinearAlgebra)
with(inttrans)
with(SolveTools)
undeclare(prime)
eq := diff(y(x), `$`(x, 2))+(1+x)*(diff(y(x), x))-y(x) = 2*y(x)^3
diff(diff(y(x), x), x)+(1+x)*(diff(y(x), x))-y(x) = 2*y(x)^3
eq1 := laplace(eq, x, s)
s^2*laplace(y(x), x, s)-(D(y))(0)-s*y(0)-2*laplace(y(x), x, s)+s*laplace(y(x)*x, x, s)+s*laplace(y(x), x, s)-y(0) = 2*laplace(y(x)^3, x, s)
with(inttrans)
[addtable, fourier, fouriercos, fouriersin, hankel, hilbert, invfourier, invhilbert, invlaplace, invmellin, laplace, mellin, savetable, setup]
eq := diff(y(x, t), x)+y(x, t)^2 = 1
s*laplace(y(x, t), x, s)-y(0, t)+laplace(y(x, t)^2, x, s) = 1/s
eq2 := subs(y(0, t) = 3, eq1)
s*laplace(y(x, t), x, s)-3+laplace(y(x, t)^2, x, s) = 1/s
lap := s*laplace(y(x, t), x, s) = 1/s+3-laplace(y(x, t)^2, x, s)
eq3 := lap/s
laplace(y(x, t), x, s) = (1/s+3-laplace(y(x, t)^2, x, s))/s
expand(%)
laplace(y(x, t), x, s) = 1/s^2+3/s-laplace(y(x, t)^2, x, s)/s
Geq := y(x, t) = invlaplace(1/s^2+3/s, s, x)-invlaplace(laplace(y(x, t)^2, x, s)/s, x, s)
y(x, t) = x+3-invlaplace(laplace(y(x, t)^2, x, s), x, s)/s
k := K
K
f := proc (y) options operator, arrow; y^2 end proc
for j from 0 to 4 do A[j] := subs(lambda = 0, (diff(f(sum(lambda^i*y[i](x), i = 0 .. 20)), [`$`(lambda, j)]))/factorial(j)) end do
y[0](x)^2
2*y[0](x)*y[1](x)
y[1](x)^2+2*y[0](x)*y[2](x)
2*y[1](x)*y[2](x)+2*y[0](x)*y[3](x)
y[2](x)^2+2*y[1](x)*y[3](x)+2*y[0](x)*y[4](x)
(14)
" y[0](x):=x+3"
proc (x) options operator, arrow, function_assign; 3+x end proc
(15)
lapy[1] := -laplace(A[0], x, s)/s
-(9*s^2+6*s+2)/s^4
(16)
simplify(%)
(-9*s^2-6*s-2)/s^4
(17)
invlaplace(%, s, x)
-(1/3)*x*(x^2+9*x+27)
(18)
simplify(-(1/3)*x*(x^2+9*x+27))
(19)
normal(-(1/3)*x*(x^2+9*x+27), ':-expanded')
-(1/3)*x^3-3*x^2-9*x
(20)
"y[1](x):=-1/3 x^3-3 x^2-9 x"
proc (x) options operator, arrow, function_assign; -(1/3)*x^3-3*x^2-9*x end proc
(21)
lapy[2] := -laplace(A[1], x, s)/s
-(-72/s^3-48/s^4-16/s^5-54/s^2)/s
(22)
simplify(-(-72/s^3-48/s^4-16/s^5-54/s^2)/s)
(54*s^3+72*s^2+48*s+16)/s^6
(23)
expand(%)
54/s^3+72/s^4+48/s^5+16/s^6
(24)
invlaplace(%, s, x)
(1/15)*x^2*(2*x^3+30*x^2+180*x+405)
(25)
expand(%)
(2/15)*x^5+2*x^4+12*x^3+27*x^2
(26)
Download laplace_of_special_ode.mw
example 1 i could't solve but example to i did
i am not jobles to post in here and you delete them one by one, when i post i am waiting for response not you delete them, with this cuase my question are repeat or something like that
this time delete my post i will upload 1000 of nonsense question and post  and go delete all of them ...
I have an equation and I want to solve it parametrically to find x , but I couldn't do that with "solve" command. (I know x should be  real and positive). What should I do?
Root_of.mw
I notice a LOT of posts/answers being deleted.  Why?  What is the purpose of this destructive nature?
To mapleprimes administrators - Please restore deleted content not related to spam.
If it is some disgruntled mapleprimes user, I'm only guessing, but just because someone didn't reply or upvote a particular answer doesn't mean it isn't good.  Lost knowledge on mapleprimes is just the first sign of a collapsing civilization ... well .. maybe that's a bit of a stretch.
It still begs the question, why?
this example is easiest one for getting solution but i can't collect each part and do like elite i can do each part seperatly but it take to much time i want collect solution and do by easier way if possible this is a laplace adomian decomposition methd which contain adomian polynomial too i want upgrade the code, can any one help the  process for get better vision of this topic
i do upload some picture and my mw. for more undrestanding
and please can any one explan why when i take laplace why is write D[2](u)(x, 0) must be D[1]?
with(inttrans)
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
with(PDEtools)
declare()
`Declared :`
u(x, t)*`to be displayed as`*u
`The prime differentiation variable has not been declared yet`
`Displayed derivatives and declared functions will be copied and pasted "as they were entered"`
declare(u(x, t))
eq := diff(u(x, t), `$`(t, 2))+u(x, t)^2-(diff(u(x, t), x))^2 = 0
diff(diff(u(x, t), t), t)+u(x, t)^2-(diff(u(x, t), x))^2 = 0
eqs := laplace(eq, t, s)
s^2*laplace(u(x, t), t, s)-(D[2](u))(x, 0)-s*u(x, 0)+laplace(u(x, t)^2, t, s)-laplace((diff(u(x, t), x))^2, t, s) = 0
solve({eqs}, {laplace(u(x, t), t, s)})
{laplace(u(x, t), t, s) = (s*u(x, 0)+(D[2](u))(x, 0)-laplace(u(x, t)^2, t, s)+laplace((diff(u(x, t), x))^2, t, s))/s^2}
subs({u(x, 0) = 0, (D[2](u))(x, 0) = exp(x)}, %)
{laplace(u(x, t), t, s) = (exp(x)-laplace(u(x, t)^2, t, s)+laplace((diff(u(x, t), x))^2, t, s))/s^2}
eq3 := invlaplace(%, s, t)
{u(x, t) = exp(x)*t-(int(u(x, _U1)^2*(t-_U1), _U1 = 0 .. t))+int((diff(u(x, _U1), x))^2*(t-_U1), _U1 = 0 .. t)}
"u[0](x,t):=exp(x)*t"
proc (x, t) options operator, arrow, function_assign; exp(x)*t end proc
n := N
N
k := K
K
f := proc (u) options operator, arrow; u^2 end proc
for j from 0 to 3 do A[j] := subs(lambda = 0, (diff(f(seq(sum(lambda^i*u[i](x, t), i = 0 .. 20), m = 1 .. 2)), [`$`(lambda, j)]))/factorial(j)) end do
(exp(x))^2*t^2
2*exp(x)*t*u[1](x, t)
u[1](x, t)^2+2*exp(x)*t*u[2](x, t)
2*u[1](x, t)*u[2](x, t)+2*exp(x)*t*u[3](x, t)
n := N
N
(14)
k := K
K
(15)
f := proc (u) options operator, arrow; (diff(u, x))^2 end proc
(16)
for j from 0 to 3 do B[j] := subs(lambda = 0, (diff(f(seq(sum(lambda^i*u[i](x, t), i = 0 .. 20), m = 1 .. 2)), [`$`(lambda, j)]))/factorial(j)) end do
(exp(x))^2*t^2
2*exp(x)*t*(diff(u[1](x, t), x))
(diff(u[1](x, t), x))^2+2*exp(x)*t*(diff(u[2](x, t), x))
2*(diff(u[1](x, t), x))*(diff(u[2](x, t), x))+2*exp(x)*t*(diff(u[3](x, t), x))
(17)
"#` know we need find all term of  u[0]=exp(x)*t` #` u`[1]=-invlaplace(1/(s^(2))(`A__0`+`B__0`))  u[2]=-invlaplace(1/(s^(2))(`A__1`+`B__1`))   ans so on ... at end i want collect all of them and find final result even if is aproximate and want do test of pde too "
Download explananing_of_get_solution.mw
[moderator: The Physics update Library fixes this bug with the same error generated and reported by the same Mapleprimes member on another ODESteps example.]
I have removed Physics update from libname path.
Now I find I get error calling latex command. When Physics update is on libname, no error.
The error is
         Error, (in Typesetting:-Parse) too many levels of recursion
I am using worksheet with typesetting extended. But also when I change it to typesetting standard, same error.
Does this mean one must keep Physics update on libname path for Maple to work OK?
Is this error expected if Physics update is not on libname?
Worksheet below that shows this problem
CASE 1. With Physics update in libname path, no error
libname;
ode:=[diff(x__1(t),t)=2*x__1(t)+x__2(t),diff(x__2(t),t)=2*x__1(t)+3*x__2(t)];
[diff(x__1(t), t) = 2*x__1(t)+x__2(t), diff(x__2(t), t) = 2*x__1(t)+3*x__2(t)]
the_output:=Student:-ODEs:-ODESteps(ode,output=typeset):
latex(the_output,'output'=string):
CASE 2.  Removing Physics from libname path, gives internal error
libname:=libname[2];
"C:\Program Files\Maple 2024\lib"
Download internal_error_from_latex_when_libname_changed_nov_2_2024.mw
it's easy to plot a numeric solution of a pde, e.g u(x,t) at a specific time but it's more difficult to plot a solution for a specific x-value as a function of time. How do I do that in Maple?
I find an error when calculating ExponentialFit(X, Y, x, summarize = embed) function. It's have an error in R-squared and Adjusted R-squared.
First 89 90 91 92 93 94 95 Last Page 91 of 2457
