I work on the period doubling phenomenon by integrating the dynamical system at some particular parameter values. My main commands are as follows
with(DEtools): with(plots): with(plottools):
a:=-1: b:=-3: c:=3: d:=1: omega:=1: v1:=1: f:=-4: epsilon:=0.01:
sys:=diff(u1(t),t)=v1*u1(t)-(omega+u2(t)^2)*u2(t)+u1(t)*(a*(u1(t)^2+u2(t)^2)+b*z(t)^2),
     diff(u2(t),t)=(omega+u1(t)^2)*u1(t)+v1*u2(t)+u2(t)*(a*(u1(t)^2+u2(t)^2)+b*z(t)^2),
     diff(z(t),t)=z(t)*(-v1+c*(u1(t)^2+u2(t)^2)+z(t)^2)+epsilon*z(t)*(v2+f*z(t)^4):
solC:=dsolve({eval(sys, v2=2.0500014987),
              u1(0)=0.6,u2(0)=0.6,z(0)=0.1},
              type=numeric, method=rkf45, maxfun=10^7,
              range=350..750):
p1:=odeplot(solC, [sqrt(u1(t)^2+u2(t)^2),z(t)],
               refine=2,
               color=burgundy,
               thickness=1);
The resulting curves are quite blurring and furry. I have tried to increase the "refine" or the "numpoints" values, but with minimal improvement. I would like to know if there a way to obtain clean and sharp integral curves?
I would be very grateful if someone could help me!
Thank you in advance.
With kind wishes,
Wang Zhe
Hi, I try Aproximate integral with simpsons method, but i want value in function the a with number solution:
with(Student[Calculus1]);
ApproximateInt(a*tan(x)-2*x, x = -100 .. 100, method = simpson, output = plot, partition = 500);
This error.
How we can construct conservation laws of fractional differential equation with Maple?
Hi I try this integral:
m2 := int(exp(-(1/2)*z^2)*((exp(B*J*sqrt(q)*z))^2-1)/(sqrt(Pi)*sqrt(2)*((exp(B*J*sqrt(q)*z))^2+1)), z = -infinity .. infinity)
But not resolve.
How can i do?
Regards.
Basically what I'm trying to do is use Newton's method to find the root of f(x)=sqrt(x)+ln(0.1x) starting at x0=5 within a tolerance of 0.001.
f := proc (x) options operator, arrow; sqrt(x)+ln(.1*x) end proc
> xk := 1.0;
                              1.0
> for k to 6 do xk1 := xk-f(xk)/(D(f))(xk); xk := xk1 end do;
When I do that, Maple barfs out pages of nonsense when I'm looking for it to give numerical values. It seemed to work fine with a different function, so maybe that's part of the problem? But I need to do it with the function I asked about.
Respected member!
Please help me to find the solution of attached problem,  I am a new user so please forgive any mistakes.maple.mwmaple.mw
I have been trying to solve a simple nonlinear equation. Im interested in the solution per say rather than the plot but when I browsed about the commands to use, this came up. I tried it in my case and it is giving me the following errors:
ode.mw
eq5:=C*sqrt(y(x)*((diff(y(x),x))^2+1))-y(x)=0;
C*(y(x)*((diff(y(x), x))^2+1))^(1/2)-y(x) = 0
C:=1;
bcs:=y(-1)=1, y(1)=1;
y(-1) = 1, y(1) = 1
dsys:={eq5,bcs};
{(y(x)*((diff(y(x), x))^2+1))^(1/2)-y(x) = 0, y(-1) = 1, y(1) = 1}
dsol:=dsolve(dsys, numeric); odeplot(dsol,[x,y(x)],0..1,color=red,axes=box);
Download ode.mw
The question explores the family of differential equations dy/dx = sqrt(1+(a*x)+(2*y)) for various values of the parameter a.
This figure shows the tangent field in the case a=1.
sketch a tangent field in the case a=-2.
need the following diagram on maple:
hello,
Given f(x)=2x^2-4x, how do I define and plot the functions f(x), 2f(x), 4f(x), -f(x) and -4f(x) in maple 15?
Thank You.
How wired icon of motor to icon of sources?thanks
Can anyone solve,
eqn := diff(x(t), t, t)+omega^2*x(t)-epsilon*mu*(diff(x(t), t))+epsilon*alpha*x(t)^2*(diff(x(t), t))+epsilon*Zeta*cos(Omega*t)*x(t)=0;
This equation using MMS (Method of Multiple Scales) in maple.
Pls use Polar transformation function as (1/2)*a(t)*exp(-I*beta(t))
Please reply.
Hi, I try expand in serie this function:
mtaylor(tanh(B*J*sqrt(q)*z+B*Jo*m), [q, m], 9)
But this is error.
How can i do?
Best Regards
Compare seq(-GAMMA(k+1, x), k = 0 .. -2) and seq(-GAMMA(k+1, x), k = -2 .. 0)
sum(-GAMMA(k+1, x), k = -2 .. 0) = -1/x*Ei(2,x)-Ei(1,x)-exp(-x) may be what you expect
I am trying to see the solution to a PDE that I am coding with initial and boundary conditions. I know with the ODE, it shows the solution, but with the PDE I cannot seem to see it. Any suggestions?
I would like to evaluate a double integral numerically. The integrand is a complicated function of the variables beta and s, with complex values. The computation lasts for decades without obtaining a result.
I was wondering whether there exists subroutines / methods / tricks that could be helpful to accelerate the integration process. I have attached a Maple script of the double integral of interest. Rough precision would be fine (4 or 5 digits).
Any help would be highly appreciated.
Federiko
Question.mw
First 1041 1042 1043 1044 1045 1046 1047 Last Page 1043 of 2462
