I have one equation consists of "x" and "y(x)". This equation does not have any analytic solution, but I found a numeric solution by using "implisitplot". But, apparently this solution is not very good because if I want to plot anything which is related to either itself or its derivatives such as:
a(x) := y(x) + 1
or
b(x) := diff(y(x), x) + 1
I don't have any good result. What shall I do? Can you...
Thanks a lot. you solved my first problem. Now I have a new problem. Consider I have an equation like:
w(z) = 1-(2/H(z))*diff(H(z),z)
I want to plot "w" with respect to "z", but since with latter solving I don't have any functional form for H(z) I can't. What's your suggestion for this?
Say I have an equation like
equation:= (r,theta) -> J(0,5*r)*sin(r)*theta
(where J is BesselJ)
and I want to integrate 'equation' over 'r=0..5' or any other limit.
With, "Int(trial2(r, theta), r = 0 .. 5)" or even by using "int" instead of "Int", I'm not able to solve the integral. Even by using 'evalf' I get the same result back.
If I get rid of the 'theta' term from 'equation', of course the integration ends up as a real...
I want to verify a solution satisfies a given differential equation,
deq := diff(y(x), x) = y(x)/(x*(ln(x)-ln(y(x))));
sol := x = y(x)*exp(C*y(x)+1);
Because the differential equation and the solution are complex,I tried many way,but failed.
How can I verify sol is just a general solution of deq?
Can you help me? Thanks a lot.
Dear guys!
I know that an analitical solution of an aquation of order "n" like this is impossible. But I give you a simple example. For the equation y(x)^2+y(x)+x=0, we have a solution like y(x)=(-1+-sqrt(1-4*x))/2. But here we have an equation of the form
y(x)^(-0.2)*[y(x)^2-(1+x)^3-(1+x)^4]=1. I'm sure it has a numerical solution. What do you think?
This is what I'm trying to do:
> d := 40*Unit(m);
> a := .170*Unit(m/s^2);
> x := d+(1/2)*a*t^2;
> plot(x, t);
Error, (in plot) the units `m` and `m/s^2` have incompatible dimensions
Is there any way to tell Maple that my t is a variable of seconds?
First problem:
I have the following loop within some longer code. If I execute the worksheet, the loop gets stuck in the "print(within*loop)" section and never stops.
Second problem:
If I don't restart the sheet, Equation 3 doesn't do the 'subs' command properly. Also, if I put the "with(Package)" commands in the beginning, Equation3  also fails to do the subs properly.
Hi! I have an aquation and I want to solve it numerically. How can I do that?
The equation is:
H(z)^(2*n)*(H(z)^2-K1*(1+z)^3-K2*(1+z)^4)=1-K1-K2;
where K1 = 0.27, K2 = 5*10^(-5) and n = -0.1.
Thanks a lot!
 I want to solve this
The function of my problem is:
f(x) = piecewise(x < 0, 0, 0 <= x, exp(-1/x^2))
where a=0,x=0.5 and ξ=.25 i want to find reminder of f(x),R, and then plot R-n plot(n is degree of diff)
Hint:
I am a beginner in maple, these days I am learning maple user manual.
There is an example given by the manual:
___________________________________________
x:=872349
while x>0 do
irem(x,7)
x:=iquo(x,7)
end do
____________________________________________
I retype them in maple, but maple always returns "Error, illegal use of an object as a name"
I check my statements carefully, it is the same...
After fixing the problem outlined in a previous post, I seem to get another error that I can't explain.
"Error, (in int) wrong number (or type) of arguments" is the product of defining a function 'u(r,theta,t)' and then defining each of its components.
I've attached the file here as well. Could someone help with troubleshooting? MapleMem5.mw
I am trying to transform this expression:
sin(sqrt(K)*t/sqrt(M))
into this expression
sin(omega[n]*t)
using the equation:
How does one raise or lower indices of tensors when one is using the atlas package. Do we have to create a table and then use the inbuilt maple command raise/lower to do this or can one do this within the atlas package.
First 1976 1977 1978 1979 1980 1981 1982 Last Page 1978 of 2463
