Hey everyone.
I have a wierd problem when using the "Units[Standard]" addon.
I'm trying to do some simple thermodynamics calculations, and need to raise certain values in an irrational power.
It looks like this:
with(Units[Standard]):
n:=1.38:
p1:=1.1[bar]:
v1:=3[dm^3]:
v2:=0.4[dm^3]:
p2:=(p1*v1^n)/(v2^n):
If I execute it, I get this error:
Error, (in Units:-Standard:-^) a unit can only be raised to a rational power
I wish to solve the following equations simultaneously:
(diff(g(t), t, t))*f(x)-(diff(f(x), x, x))*g(t) = 0
(diff(f(x), x))^2*g(t)-(diff(g(t), t))^2*f(x) = 0
I searched the help files and did the following:
I have tried using solve but get an error
solve({`&x`(diff(g(t), t, t), f(x))-`&x`(diff(f(x), x, x), g(t)) = 0, `&x`((diff(f(x), x))^2, g(t))-`&x`((diff(g(t), t))^2, f(x)) = 0}, [f(x), g(t)])
I really like this package:
http://www.maplesoft.com/applications/view.aspx?SID=1671
But it seems to be impossible to intersect more than two areas:
with(InequalityGraphics);
inequalityplot(sin(x)+4*y>8 and x*y>1 and y<3-x,x=-2..4,y=-2..4,feasiblepoints=30);
It works if I leave out a condition:
inequalityplot(sin(x)+4*y>8 and x*y>1,x=-2..4,y=-2..4,feasiblepoints=30);
  1. How do I
  2. Write a maple program to calculate the probability that k cards in 3-dimensonal set game (out of 27 cards) contain a set for k=3…9.
      3  randomly generate 12 cards in 4-dimensonal set game, either find a set or report “no set”.
question1.22.mwMy system differential equations are sys:=[deq1,deq2]
and the linearization point is given by linp:=[...]
Then I use linearization command to get a linear model of the system
linmod:=Linearize(sys,[input],[output],linp)
then maple returns a state-space equation of the linearized system.
I want to get the system transfer function, my method is ,first,extract...
i have the list of figure that produced by bellow maple.
for i from 0 to 10 do
  y := i/2;
  f := 2*x + y;
  plot( f, x, color=black); od;
i want the value of y print corresspond to  each line  of figure.
for Example, the first value of y =0 should be  printed  correspond to the first  line and so on.
 Thus, in dispaly plot, each line correspond to its value of y.
could please help me how to do this?
being stalled myself here why don't these work?
for i from 1 to 200 do
  if ithprime(i)=prevprime(500) then print i; end if;
solve(ithprime(i)=prevprime(500),i)
What would be a better way?  I could do
for i from 1 to 200 while ithprime(i)<500 do end do; i;
I am trying to construct a 7x7 matrix T such that T[i,j]=k, when multiply(monoid[i],monoid[j])=monoid[k]
I've defined monoid to be a boolean matrix such that there is at least one 1 in each row and column.
I am just not sure how to get my input to return the matrix. I keep getting a 7x7 zero matrix.
This is what I have:
T[i,j]:= Matrix(7);for i to 7
do for j from 1 by 1 to 7
do T[i,j]:=(multiply(monoid[i...
Im building a series of Java applets. My applets have text areas where students will write answers to questions. I am looking for a way to make my text areas be MathML boxes. Anotherwords, instead of adding the answer in normal text (1/2) it will be in Maple format. (1/2) should be a fractions, and not just a string as you see in this post.
My data are 3 numbers that evolve in time: it makes a matrix n*3, where n is the number of occurences in time. I want to apply automaticaly a calculation (solution of a polynomial) n times on my data. How do I do that?
Thanks in advance,
Florent
Hi, I have the following problem with Maple 12:
all the decimals in plots (tickmarks) are displayed with a comma (e.g. 0,5).
Is it possible to replace the comma by the  point (i.e. 0,5 -> 0.5 ) ?
Unfortunately I cant see appropriate setting in the Maple help.
However the problem is rather serious: some journals (e.g. Phys Rev D)
require the tickmarks to be written without commas (the
hey there, i have a simple question: lets say i have a list like:
list:=[[1,1],[2,4],[4,8],[5,7],[8,1],[5,3],[4,2]]
for some reason i only need the elements of this list from [4,8] to [5,3]. how do i
select these parts from my original list? (and i dont want to create the new list
by saying: take element 3..6 from list). thanks and cheers
This is my code:
> F := a*c;
                              a c
> K := (a*c)^2;
                             a^2  c^2
> simplify(%);
First 1979 1980 1981 1982 1983 1984 1985 Last Page 1981 of 2463
