i'm trying to run the following procedure:
> restart; with(LinearAlgebra);
> test:=proc(alpha, beta);
Error, unterminated procedure
         testAssignTypesetting:-mambiguous(
           procApplyFunction(αcomma β),
           Typesetting:-merror...
Every so often when I press return, the cursor will not move to another line.  I have to use an arrow key to move it to the next line to continue wit hthe execution.  This is extremely annoying.  Any idea why maple is beaving like that?
I can get the whole document executed when I use the !!! comand but the cursor ften stays in some command line in the middle of the document instead of the last line.
Also when I have a line of text in between...
I have an equation on paper that I am trying to rewrite in Maple for plotting purposes.
Because the equation is large, I split it up in different parts, "frontcoeff", "cosCterm", etc. Ultimately I want an equation "u" which is a function of (r,theta,t) and is composed of a summation over "k" and "m".
Image 1: http://postimage.org/image/1etwulgpw/
I then get the following error:
Image 2: http://postimage.org/image/1evagpvj8/
I'm looking for a way to fit a function to measured data points. The special thing about it is that each data point has an individual error in x- und y- direction, and I would like the fitting command to consider these individual errors. I'm aware of the Statistics[NonlinearFit] command, but there I only can assign one weight per data point - not one for each degree of freedom.
I'm a physics student, and in the moment this is my major problem for using...
Is there a way to plot a graph in a fliped way.
I tried to do this using Vectors. But this is not so easy.
plot(Vector(70,x->sin(x/10),Vector(70, x->x+1/10));
plot(sin(x),x=0..7)
>f:=x->(1/sqrt(1+x^3));  I typed this function into Maple, but I keep getting: Error, missing operator or ';'. I'm not sure what I'm missing!
Dear primers,
i read in a list of data (which are called roi), then i would like to fit these data (done in this case by a spline function) and compute the values for y=0.3.
for some reason, maple (i am using maple14) gives me only one value instead of two.
i would be happy if somebody could give me a hint how i get both values.
fsolveSpline.mw
How does one select rows of a Matrix with say column three having values less than 4?
If for example,
a:=Matrix(1..5,1..5,rand(1..10)):
One way that I know of is to first convert the Matrix to a listlist
b:=convert(a,listlist):
and then you can use
c:=select(b->b[3]<4,b)
then
d:=convert(c,Matrix)
Is there a way to that without all the conversions?
how do i use Maple to prove a+c is congruent to b+d mod n?
I was following the Getting Started tutorial wher it shows how to do a Taylor series expansion about z=2, for a 4th degree poly.  Maple returns
error, unable to parse 'mverbatim'
Further in the tutorial it asks me to type (x+2y)^3 when upon pressing enter, it returns the same error.
What can be done to correct this error?
Cary M.
Is it possible to construct a fairly complex Punnet square inheritance matrix in Maple 13?
Suggestions and examples or urls would be appreciated.
Cheers
Bryan
How do you find the midpoint of 2 points on Maple? For example, (0,2) and (1,3).
How do I graph a quadratic equation on Maple 13? For example, x^4+x^2=3x^2+8
I was wondering how to find the distance between 2 points on Maple 13. For example points (-1,3) and (4,-2).
I have a weird problem I hope you guys can help me with:
When I leftclick on a file type "mw" in Internet Explorer it opens as a xml file.  The filetype is associated in Windows with Maple and in Firefox and Google Chrome it starts Maple and loads the document. How do I get the same behaviour with IE? Im running IE v. 8.
-h
First 1977 1978 1979 1980 1981 1982 1983 Last Page 1979 of 2463
