the problem is as follows:
if((a>0) and (b>0) then (c:=2*a, d:=3b, e:=9b.....)
elif ((a<0) and (b>0)) then (c:=.., d:=..., e:=....)
elif.....
else c:=..., d:=..., e:=...
end if
i know i have the if conditions right, but not sure about sequential conditions..what is the correct syntax for this??
I'm getting errors like parse errors, unterminated if, and invalid sequence (on the :=)...
array.mw
if I assign an array to the variable name x via another named array (A) then if I change all of A, x remains unchanged. this is what I'd expect
however if I change just one element of A then x also changes
this is illustrated in the attached worksheet.
Why is this happening? And how can I stop x from changing if I change a single elment of A?
I'm exporting arrays of plots as html (so I get multiple gif files). At the moment I do this off the menus (file\export as) is there a way to write this command at the prompt in worksheet mode?
I am trying to resize some 2D and 3D plots. I find that the following writes a resized plot to the desktop, but it is cumbersome to use in a program when there are multiple plots:
MYPLOT := %:
     plotsetup(jpeg, plotoutput = "/Users/username/Desktop/EXPAND.jpg",
     plotoptions = "height=1000,width=1000");
MYPLOT;
plotsetup(default)
Look here concerning this theorem, which states that in any triangle, the three points of intersection of the adjacent angle trisectors form an equilateral triangle, called the Morley triangle.
Help me find all the lines that are carried out from the origin and perpendicular to the 3-D surface.
question2.15.mw
I have a...
question2.12.mw I use invlaplace command to get inverse laplace transform of an expression,but the result is too jumbled,
How can I get a concise form?  I tried in many ways,but failed.
Can you help me? Thanks a lot!
plots[implicitplot](tan(x*sqrt(cp^2/3220^2-1))*(cp^2/3220^2-2)^2+4*tan(x*sqrt(cp^2/6450^2-1))*sqrt((cp^2/3220^2-1)*(cp^2/6450^2-1)) = 0, x = 0 .. 14, cp = 0 .. 7000, gridrefine = 7, signchange = false),
the command above can't give me the whole figure, it lost some points in [0,3.5(approximation)],
can someone help me,
thank you very much
On my computer the following command for weighted median calculation
with(Statistics):
n:=60000;
X:=Sample(RandomVariable(Normal(0,1)),n);
w:=<seq(i,i=1..n)>;
Median(X,weights=w);
is worked for n=6000, but don't work for n=60000.
How it is work on another computers ?
Please, check.
I am working on this d2.pdf       problem,is ther any solution with maple?
 The coefficients are function of (T) and I would like Si's is also a function of T.
The well known(!) Heun's equation is,
df:=diff(y(z),z,z)+(gamma/z+delta/(z-1)+epsilon/(z))*diff(y(z),z)+(alpha*beta*z-q)/(z*(z-1)*(z-a))*y(z) = 0;
The solution is the general Heun's functions and it should be written as HeunG according to the help file of Maple 14 but my solution is found in terms of some function called HG which is not listed in the help system.
1. Are they the same?
I am using display command to get implicitplot. But I only get the graphs in one red colour. I want to get graphs in different colours. How to do that?
How does one get the InequalityGraphics package? I don't see it as a standard package within Maple 14.
If I open help for pdsolve/numeric in Maple14 I can read
PDEsys - single or set or list of time-dependent partial differential equations in two independent variables
How can I solve numerical PDE system with more than two variable? If I try it, I get error message
Error, (in pdsolve/numeric/process_PDEs) can only numerically solve PDE with two independent variables, got {r, t, t0}
First 1978 1979 1980 1981 1982 1983 1984 Last Page 1980 of 2463
