After Maple 2025 start-up (with disabled start-up page) and closing the blank worksheet (note the dark grey workspace) there is still one mserver running (highlighted in yellow).
I have not seen a difference when I kill this process and open a new worksheet which starts a new mserver.exe task (and run Maple code).
The task seems to be inactive (no processor load and memory allocation visible).
Is it a task only used by the interface task (javaw.exe)?
What might be the purpose of this mserver.exe?
Update: The task is inactive in a sense that it does not show immetiate activity when annother mserver.exe task runs (i.e. exceuting a worksheet). However, after a day memory allocation shows changes. When exactly these changes happend is unclear.
Has anyone had any success in turning off the scrollable matrix feature on Mac? I found the post
 https://www.mapleprimes.com/questions/238061-How-To-Disable-The-New-Scrollable-Matrices
and tried to follow the steps outlined by Acer, but I cannot get it to work. Specifically, I greated a preference file at the location:
 //Users/$USER/Library/Preferences/Maple/<version>/Maple preferences which has the statement
ScrollableMathTableOutput=false
Any success stories, or tips, will be greatly appreciated.
I want to ask a question, but I cannot submit it using the link below. I tried several times, but it didn’t work. I wrote it like this, but I didn’t get the desired answer.
http://www.mapleprimes.com/questions/231499-Changing-The-Variables-
with(PDEtools):
tr1:={x=xi- lambda*t - delta,u(x,t)=Theta(xi) };
PDE := diff(u(x,t),t) + diff(u(x,t),x) + alpha*u(x,t)^2*diff(u(x,t),x)
      + beta*diff(u(x,t), t, x$2);
ode := dchange(tr1,PDE,[xi,Theta(xi)]);
{x = -lambda*t-delta+xi, u(x, t) = Theta(xi)}
diff(u(x, t), t)+diff(u(x, t), x)+alpha*u(x, t)^2*(diff(u(x, t), x))+beta*(diff(diff(diff(u(x, t), t), x), x))
diff(Theta(xi), xi)+alpha*Theta(xi)^2*(diff(Theta(xi), xi))
NULL NULL
Download 963.mw
I want to solve the equation shown in the image, along with its given conditions, using Maple and obtain the same results as in the image, but it does not work. Could you please help me?
interface(showassumed = 0):
df := diff(w(xi), xi) = rho + eta*w(xi)^2:
# Condition (1): rho * eta>0,
assume(rho * eta>0);
w1 := dsolve([df, w(0)=0]);
w(xi) = tan(xi*(rho*eta)^(1/2))*(rho*eta)^(1/2)/eta
Download 852.mw
Although several similar problems were asked many years ago (see, e.g., the section “Formal linear algebra” here), there appears to be no new progress so far. It is said that such functionalities exists in the Physics package, but I cannot find any corresponding examples.
In short, can Maple at present calculate these examples in terms of symbolic array constructs completely automatically?
residue(z^3*cos(1/(z - 2)), z = 2);
                  3       1
         residue(z  cos(-----), z = 2)
                        z - 2
l notice the help document  asks me to increse the n,but the n of essential singularity is infinity
I wrote a simple expand command in Maple - expand(cos((u - 2*k)*x))
only to get the result
2*cos(x*u)*cos(x*k)^2 + 2*sin(x*u)*sin(x*k)*cos(x*k) - cos(x*u)
The presence of a squared term seems to indicate a bug??
I need to compute complicated numerical integral, and my Maple integration does not produce very stable results. Is the a way to do that on line?
In the below I had to add the assumption x>=0 to get simplifications. Am I wrong with my interpretation that the other assumptions should have been sufficient?
We are looking for the smallest natural number n with the property that both the digit sum Q(n) of the number n and the digit sum Q(n + 1) of the successor of n are divisible by 5.
In Maple 2025.1, why don't all the hotkeys show up when I press the Alt key?
Maple 2025.0 is OK,but update to 2025.1 all the hotkeys don't show up when I press the Alt key.Why?
During a birthday party, the birthday child realizes: In 1968, I was the same age as the sum of the digits of my birth year. How old will I be now at the end of 2025?
(Please no AI solution)
In the decimal system, specify the smallest natural number k that begins with the digit 7 and has the following additional property:
If you delete the first digit 7 and write it at the end, the newly created number z = (1/3)*k.
My name is William Cheung.  I am a Snapdragon X AIPC product manager.  I am reaching out to inquire about the current and future compatibility of Maple on Snapdragon X Windows PCs, which run on ARM64 architecture. With the growing adoption of ARM-based systems in enterprise and academic environments—especially those powered by Qualcomm’s Snapdragon X Elite platform—we are evaluating software solutions that can run efficiently on these devices.
Could you please confirm:
  1. Whether Maple, as a commercial product, currently supports Windows on ARM (either natively or via emulation)?
  2. If not, is there a roadmap or timeline for ARM-native support?
  3. Are there any known performance or compatibility issues when running Maple on Snapdragon X PCs using Microsoft’s Prism emulation?
Note that I have successfully installed and run Maple 2025 with sample worksheet files on my Snapdragon X Windows PC.
Thank you for your time and assistance. I look forward to your response.
Hello, I am struggling with a Maple Flow document that has gotten a too large to manage - maybe around 100 printed pages of relatively straightforward calculations, basic plots, etc. - nothing exotic or what should be computationally intensive.  The worksheet takes a long time to load, if it loads at all, is prone to freezing and requires force quitting of the OpenJDK Platform binary when this happens, and oftentimes generates a kernal connection error:
So, in short, lots of issues that make usability a challenge. The document is easily broken into smaller sections, which I would prefer to do anyway. I have attempted to use the RunWorksheet command and can more or less get it to work for very simple cases:
However, the output is not ideal in that it includes the variable string. This command also doesn't appear to pass custom-defined units. The other issue is that when I test this same syntax on a fully-developed, formatted, etc., Maple Flow worksheet, I get invalid input warnings and can never get any values returned.
Ideally, what I would like to do is call a variable defined in one Maple Flow worksheet and have it be immediately usable in another Maple Flow document, or at least usable with some minimal processing. If anybody has any ideas, I would appreciate it.
First 19 20 21 22 23 24 25 Last Page 21 of 2457
