Hi, is there a detailed list of differences between those 3 product lines of Maple ? Maybe additional packages for the pro version  ? Are worksheets, created with one version, completely compatible to other ?
I am kind of new with using maple, and I am hoping that someone can give me some help on nonlinear curve fitting.  I checked out the help topics, and I thought that I had put everything in correctly, as per the help file.  However when I try to do a fit to data, nothing is returned.  Here is what I have input:
So, I have r^3=1/64. I need help finding r
Hi all, I'm not good at maple, so need a help from experts. I'm using Maple v.12. -part of the code- ... de2:= # Nonlinear DE is here # ics:= X(0) = 1, (D(X))(0) = 1; sol:= dsolve({de2, ics}, numeric, method = rkf45); (or sol := dsolve({de2, ics}, x(t), numeric, stiff = true, range = 0 .. 200);) Error, (in f) unable to store '1.0000000024691*{1.}^2+2000010000.' when datatype=float[8] -end of the code- As you see above, It's a simple process to solve DE. so most of the DE, like (1) below, is solved very well through the code. But my case is (2). I could see error msg as you see above.
Good day, I cannot run this maple, why?
I need help!
I'm trying to plot a sphere, and then shade-in the bottom one-third of it.  Is that possible?
Also, I then need to plot a sphere with 8 approximating disks.
Does anyone have any ideas of how to do these?
I have a Matrix O[n,m]:=Value with n:=1..10 and m:=1..10 How can I present the values in a 3D plot with x->n Y->m and Z->Value. One time I want to make a histogramm out of it and in a second case just connect them to a surface How can I do that Thank you very much in advance!
have a look at this plot, i'm using standard worksheet (in classic this problem doesn't exist).
plot(sin(x),x=-5..5,tickmarks=[default,20]);
Instead of -for example- 0,5 i want decimal points 0.5
Playing with the tickmarks option would do the trick, but a "global switch" would be better.
What to do ?
Thomas
Hello everybody, I was wondering, is there a way to call procedures from a different worksheet? I am writing a big procedure which calls many smaller ones and that would be really clearer if I keep them in a different worksheet.. Thanks a lot in advance..
Hi, I have a polynomial expression like this:
2*a^32*b^3 + 3*c^2*a^3 + 4*a^5*c^2
I would like to apply rules like these ones:
a = a^x and b = b^y,  ∀ x,y ∈ N*
It should result:
2*a*b + 7*c^2*a
I would do this manually, but I intend to use this to really big expressions and it would be quite boring. Any ideas?
Thanks in advance and sorry the english,
Pedro Paganela - Engineering Student
Dear experts, I want to plot a matrix with B[n,m] and n:=1..10 and m:=1..10 The problem is that the plots achses are labled with n and m. I want to lable the achses with N:=0.25 to 2.5 in steps of 2.5.... How can I do that?
Hello everybody, I am a bit stuck here because I have the problem above, any help would be really appreciated.. E1:={{0,2},{0,7},{0,a},{0,b},{1,3},{1,8},{1,9},{1,a},{1,e},{2,3},{2,a},{2,d},{2,e},{3,4},{3,6},{4,8},{5,7},{5,a}, {5,e},{6,c},{6,e},{7,8},{7,a},{7,e},{8,b},{9,a},{a,c},{c,d},{c,e},{e,f}}; for e in E1 do e; end do; {0, 2} {0, 7} {0, a} {0, b} {1, 3}
NOT covered
in Chapter 7 of the textbook (either in other literature, or on the
Internet). Give a brief description of your example, and illustrate its
properties with a Maple worksheet
How Do i Approach to this question
Find an example of a chaotic attractor in 3D which is
Hello everybody, I have a question, any help would be really appreciated. Let me illustrate my problem with a small example. Say I want to define 1000 variables like this: x_1:=1; x_2:=2; x_3:=3; .... x_1000:=1000; That would be very tedious to be done by habd so I would like to use a 'for' to do that.. Is that possible? The code below does not work: for i from 1 to 1000 do x_i := i ; end do; Any ideas? Thanks a lot in advance..
Hi all!
So I have an equation like so:
I have to plot a graph of the resistance against variable frequency of up to 1Ghz.
So I am plotting for frequencies 1Hz, 1x10^2, ... 1x10^9
Question is, how do I use Maple to input a set of frequencies into f of the above equation, giving out the resistance, and then plot a graph.
I am new to maple.
Thanks in advanced.
daniel
First 2173 2174 2175 2176 2177 2178 2179 Last Page 2175 of 2459
