Hi I am trying to integrate the product of two matrices.  The independent variable is "x" and the constant is "L".  The two matrices are H and B.  I would like to integrate the two matrices on the x-domain from x= 0 to L.  Any help would be greatly appreciated.  Also I am new to Maple.  Is there a good beginner's book that would cover topics like matrix integration?  Thanks-Tom
H= [1, x, x^2, x^3]          (1x4 matrix)
Hi, would appreciate some help. Is there any command in Maple that would hep check general SARIMA equations? for instance, if we take the following model (0,1,0)*(1,1,1)_5, then the general SARIMA equation will be: (1 - K)*(1-K^5)*X_t = (1 + B*K)*(1+B*(K^5))*Z_t i.e. X_t - X_(t-1) - X_(t-5) + X_(t-6) = Z_t + B*Z_(t-1) + B*Z_(t-5)+ B*Z_(t-6) Is there any option in Maple that would allow me to check if this equation is correct? many thanx.
I have 4 points in 2D and I want to plot them with different colors:
This works in Maple 12:
plots[pointplot]([1,2,3,4],[5,4,7,8],color=["Red","Blue","Magenta","Pink"]);
And I want to connect each other with line segments:
But this doesn't work:
plots[pointplot]([1,2,3,4],[5,4,7,8],color=["Red","Blue","Magenta","Pink"],connect=true);
Error, (in plots/pointplot) number of colors must match number of points
I am trying to use the following command
simplify(30/366)
The answer that I am getting is 5/61
how can I get the answer in numerical form.
For example 5/6 would be 0.082 if I round up the answer.
Using the calculator I get
0.081967213114754098360655737704918
After I round up, I get 0.082
Take care
How do I multiply Combitronics, using Maple
For example
with(combinat);
choose(7,6)
I want to multiply 7 Choose 6 with 5 Choose 3
If use I use the calculator I get
7C6 = 7
5C3 = 10
= 70
Take care
