Session Save doesnt work:
DeepLearning:-Save("model.ckpt");
Error, (in DeepLearning:-Save) format not supported
DeepLearning:-Save("model.h5");
DeepLearning:-Save("model.keras");
Which format is supported?
With two vectors a and b, we know that
Norm(CrossProduct(a, b)) = Norm(a)* Norm(b) * sin(a,b).
I tried with a := <1, 2, -2>; b := <2, 10, 11>;
Note that a perpendicular to b and
I tried
with(VectorCalculus);
SetCoordinates(cartesian[x, y, z]);
a := <1, 2, -2>;
b := <2, 10, 11>;
Norm(a);
Norm(b);
v := CrossProduct(a, b);
Norm(v);
Are there two vectors a and b with integer coordinates and  not perpendicular,  so that Norm(a), Norm(b), Norm(CrossProduct(a, b)) are interger numbers satisfying
I am trying to isolate each variable in this equation.I get a weird answer when I solve for n in this equation. I do know it is possible to isolate n in this equation. You might have to use/apply the Lambert Series identies to isolate it. Any help/insight would be appreciated.
Attached is a picture of the equation.
For syntax highlighting etc of Maple programs
Why int gives this error? Is this a known problem?
Update
fyi, This is reported to Maplesoft.
Here is updated worksheet. The int() command does not generate the error the second time it used, but generates the error the very first time used. Hopefully will be fixed in 2022 Maple.
Example 1
expr:=(7*x - 3 + sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x) + sqrt(-2*((-x^2 + x + (x^3*(x - 1)^2)^(1/3)/2)*sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x) + x^2*(x - 1))/sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x)))/(12*x*(x - 1));
(1/12)*(7*x-3+(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+(-2*((-x^2+x+(1/2)*(x^3*(x-1)^2)^(1/3))*(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+x^2*(x-1))/(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2))^(1/2))/(x*(x-1))
int(expr,x)
Error, (in IntegrationTools:-Indefinite:-AlgebraicFunction) invalid argument for sign, lcoeff or tcoeff
int(expr,x)
int((1/12)*(7*x-3+(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+(-2*((-x^2+x+(1/2)*(x^3*(x-1)^2)^(1/3))*(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+x^2*(x-1))/(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2))^(1/2))/(x*(x-1)), x)
Download int_problem_feb_13_2022.mw
I can I obtain the sigma-algebra generated by a given set.
sigma_algebra.mw
I am attempting to use the pdsolve function in Maple to explicitly solve a PDE which is basically a perturbation of the Laplace equation.  Nothing happens when I enter pdsolve, however, is this because a boundary condition is also needed to produce a solution?  The BC which I have is that f(x, y, z) goes to zero as sqrt(x^2 + y^2 + z^2) goes to infinity but I am not sure how to enter such a BC in Maple.
PDE := diff(diff(f(x, y, z), x), x) + diff(diff(f(x, y, z), y), y) + diff(diff(f(x, y, z), z), z) - exp(-t*exp(sqrt(x^2 + y^2 + z^2)))*(diff(diff(f(x, y, z), x), x) + diff(diff(f(x, y, z), y), y) + diff(diff(f(x, y, z), z), z))/(1 + m/(2*sqrt(x^2 + y^2 + z^2)))^4 = 3/2*exp(sqrt(x^2 + y^2 + z^2) - t*exp(sqrt(x^2 + y^2 + z^2)))*(diff(f(x, y, z), x)*tx/sqrt(x^2 + y^2 + z^2) + diff(f(x, y, z), y)*ty/sqrt(x^2 + y^2 + z^2) + diff(f(x, y, z), z)*tz/sqrt(x^2 + y^2 + z^2))/(1 + m/(2*sqrt(x^2 + y^2 + z^2)))^4;
pdsolve(PDE);
Good day everyone,
I am running a maple code for a pde and is given the error code "Error, (in pdsolve/numeric/process_IBCs) initial/boundary condition must be given in terms of the dependent variables of the problem only ([W]), got ((D@@2)[1](W))(0, tau) = 0". The link is attached below.
pde.mw
Clifford http://math.tntech.edu/rafal/cliff12/index.html
I read really good reviews from fellow Maple users about Clifford Package( above link).
I couldn't access the link provided. What is the best way to install Clifford Package or get access to the link.
Thank You.
Hey everyone!
I have a complex function stored in a file (Comp-func.txt). The function is continues everywhere on the real axis (X-axis.txt). However, its log shows a jump somewhere close to x=-1.5. I would like to understand how Maple interprets this "jump" and how to avoid such numerical artifact.
thank you.
 Comp-func.txt
Jump-Log-Func.mw
X-axis.txt
Can I compute using maple some Riemann Stieltjes integrals
RSI.mw
This also looks like an applyrule bug.
kernelopts(version);
`Maple 2021.2, X86 64 LINUX, Nov 23 2021, Build ID 1576349`
double_angle_rule := [
        sin(x::name/2)*cos(x::name/2) = 1/2*sin(x),
        sin(x::name/2)^2 = 1/2*(1-cos(x)),
        cos(x::name/2)^2 = 1/2*(1+cos(x))
[sin((1/2)*x::name)*cos((1/2)*x::name) = (1/2)*sin(x), sin((1/2)*x::name)^2 = 1/2-(1/2)*cos(x), cos((1/2)*x::name)^2 = 1/2+(1/2)*cos(x)]
C := < cos(1/2*u)*sin(1/2*u), cos(1/2*u)^2 >;
Vector(2, {(1) = cos((1/2)*u)*sin((1/2)*u), (2) = cos((1/2)*u)^2})
This application fails. Why?
applyrule~(double_angle_rule, C);
Error, dimension bounds must be the same for all container objects in an elementwise operation
Download applyrule-bug2.mw
This looks like a bug to me but please correct me if it is not.
half_angle_rule := [
        sin(x::name) = 2*sin(x/2)*cos(x/2),
        cos(x::name) = 1 - 2*sin(x/2)^2
[sin(x::name) = 2*sin((1/2)*x)*cos((1/2)*x), cos(x::name) = 1-2*sin((1/2)*x)^2]
In this example, Maple applies the rule to the first element only.
It should apply to both.
A := < sin(u), sin(u) >;
applyrule~(half_angle_rule, A);
Vector(2, {(1) = sin(u), (2) = sin(u)})
Vector[column](%id = 36893628627946684772)
In this example, Maple applies the rule to the second element only.
B := < cos(u), cos(u) >;
applyrule~(half_angle_rule, B);
Vector(2, {(1) = cos(u), (2) = cos(u)})
Vector[column](%id = 36893628627946688132)
Download applyrule-bug1.mw
How to trace the 2 parabolas that pass through 4 cocyclical points. Thank you
First 370 371 372 373 374 375 376 Last Page 372 of 2458
