It would be nice to save various animated Maple images from into GIF images, but without the coordinates and the axes. THe same question in anoehr way: Can we plot the original function without any axes or coordinates?
mapleatha
ifactor(1522605027922533360535618378132637429718068114961380688657908494580122963258952897654000350692006139);
kilobytes used=921, alloc=1200, time=0.09
kilobytes used=1325, alloc=5296, time=0.13
kilobytes used=107733, alloc=9228, time=6.64
Process Maple segmentation fault (core dumped)
No matter what I do from the keyboard, a core dump is not a reasonable response.
This worksheet animates stereographic projection of a grid on a sphere onto the plane the sphere sits on.
Is there a way to display matching colors in corresponding cells in the two grids?
Stereographic_projection.mw
My question is whether any special interest groups exist in the Maple Cloud?  If so, is there a public listing of these groups?
I need to find out how to print the number of row or the numbers on right based only on the combination of the two numbers in first two columns. The external file looks like this:
I have prepared possible combinations of numbers and I need to read the numbers on the right which belongs to this combination. There is no such thing as the sum of two numbers = number of row, so it can't be done this easy.
Can somebody help please? Thanks a lot
I would like to understand how i can construct module with submodules.
In the maple help, this chapter should answer perfectly to my need : https://www.maplesoft.com/support/help/Maple/view.aspx?path=ProgrammingGuide/Chapter11
At this page, there is a package called Shapes which should be very useful for me.
However, i don't understand 1 point at the moment about the package architecture of this example of package.
Why there is a submodule also called Shapes inside the module Shapes ? In other words, why the different submodules point, segment, circle, square, triangle have not be constructed directly under the module Shapes but under the submodule Shapes?
I thank you in advance for your help.
Hi everyone, i'm working on a project and i'm having a problem as such:
I got t1 already (t1=26,88) by solving s(t)=0 and when I try to calculate s(t) with t=t1, i type s(t1) Maple give me 1.10^(-6) as result but the result should be 0.22144. Here are my codes:
hi, is there any option to make inequality in animate with filled/marked area?
display(animate(implicitplot, [abs(x + y*I - a) <= 2*(1 - abs(x + y*I)), x = -2 .. 2, y = -2 .. 2], a = -1.75 .. 1.75, frames = 100), implicitplot(x^2 + y^2 = 1, x = -2 .. 2, y = -2 .. 2, color = black));
Hey everyone,
I see I can use SimpleLieAlgebraData to create Lie algebras of types A, B, C, D, and also G2 and F4. Is there a built-in way to generate E6, E7, and E8? If not, is there any plan to add these?
These two animations do not work under Maple 2020. How do I make them work? What am I doing wrong?
plots[animate]( plot3d, [sin(A)*(x^2+y^2), x=-2..2, y=-2..2], A=0..2*Pi );
plots[animate]( plot, [A*sin(x), x=0..10], A=0..2 );
mapleatha
system_of_PDE.pdf
How to solve the system of partial differential equations in Maple.  I have attached a pdf file, please check it. Kindly help me.
[Edit: I've also atached the OP's worksheet below.--Carl Love]
not_solve_sys_pde.mw
Hi everyone!
Is it possible to evaluate int(diff(u(x,y,t),x)*v(x,y,t)+diff(v(x,y,t),x)*u(x,y,t),x) directly as u(x,y,t)*v(x,y,t) in Maple?
hi, do you know how to use discont in this plot? (is it even possible?)
animate(implicitplot, [y^2 = x^3/(2*a - x), x = -5 .. 5, y = -5 .. 5], a = -5 .. 5);
  ODES := (1+E)*(diff(f(eta), eta, eta, eta))+f(eta)*(diff(f(eta), eta, eta))-(diff(f(eta), eta))^2-E*delta*(diff(f(eta), eta, eta))^2*(diff(f(eta), eta, eta, eta))+M*(diff(f(eta), eta)-1)+Upsilon*(1-(diff(f(eta), eta))^2) = 0,
          diff(theta(eta), eta, eta)+(3/4)*R*(diff((1+(B-1)*theta(eta))^3*(diff(theta(eta), eta)), eta))+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))*(diff(theta(eta), eta))+Pr*Df*(diff(phi(eta), eta, eta))+Pr*Ec*(diff(f(eta), eta, eta))^2+Q*theta(eta) = 0,
           diff(phi(eta), eta, eta)+Sc*(diff(phi(eta), eta))+Nt*(diff(theta(eta), eta, eta))/Nb-Sc*kappa*phi(eta)+Sc*Sr*(diff(theta(eta), eta, eta)) = 0:
  bcs:= f(0) = 0,
        D(f)(0) = 1,
        D(f)(10) = 0,
        (D(theta))(0) = -.2*(1-theta(0)),
        theta(10) = 0,
        phi(0) = 1,
        phi(10) = 0:
  params:=[E=EV,Nb = 3.9, lambda = .01, Sc = 1, Nt = .5, delta = 0.9, Pr = 7., M = mv, R =5., B = 6., Df = 1., Ec  =5., kappa = 1., Sr = 3., Upsilon =- 3., Q = 3.]:
  EVals:=[-1, -3, -7]:
  Mvals:= [3, 5, 7]:
  ans:=Matrix( numelems(Mvals)*numelems(EVals)+1, 5):
  ans[1,..]:= < 'M' | 'E' | expr1 | expr2 |expr3>:
  for k from 1 by 1 to 3 do
      mv:= Mvals[k]:
      for j from 1 by 1 to 3 do
          EV:=EVals[j]:
          sol:=dsolve( eval([ODES, bcs], params), numeric, output=listprocedure);
          ans[3*(k-1)+j+1,..]:= `<|>`([ mv,
                                        EV,
                                        R__e^(-0.5)*sh= eval( -diff(phi(eta), eta),
                                                              [sol[], params[]]
                                                            )(0),
                                        R__e^(-0.5)*NU= eval( -diff(theta(eta), eta),
                                                              [sol[], params[]]
                                                            )(0),
                                        R__e^(0.5)*C__f=eval( (1+0.5)*(diff(f(eta), eta,eta)-1/3*diff(f(eta), eta)^3),[sol[], params[]])(0)]);od:od:ans;
               Matrix(%id = 18446744074195107958)
      plot( [ seq( [ seq( [ans[j,1], rhs(ans[j,2+k]) ], j=i..10,3 ) ], i=2..4 ) ],
            color=[red, green, blue],
            labels=[typeset(M), typeset( lhs(ans[2,2+k]) )],
            labelfont=[times, bold, 20],
            legend=[typeset(E=0.01),typeset(E=0.1),typeset(E=0.2)],
            legendstyle=[font=[times, bold, 20]],
            title=typeset( ans[1,2+k], " versus ", M, " parameterized by ", E),
            titlefont=[times, bold, 24]
 od;
Error, invalid input: rhs received 0, which is not valid for its 1st argument, expr
I trying to display factorials in a matrix as e.g 6!4!/5! not 144.
with(InertForm)
[ConvertToString, Display, FromMathContainer, MakeInert, NoSimpl, Parse, SameStructure, ToMathContainer, ToMathML, Typeset, Value]
M := Matrix(4, 4); for m from 0 to 4 do for n from 0 to 4 do M(m+1, n+1) := factorial(NoSimpl(2*m+3*n))/(factorial(NoSimpl(m+2*n+1))*factorial(NoSimpl(m))*factorial(NoSimpl(n))) end do end do; M
Matrix(%id = 36893490820101234804)
Download How_to_display_factorial_unevaluated.mw
First 455 456 457 458 459 460 461 Last Page 457 of 2469
