I am trying to input data via a data table. Have several problems here.
I used an array because I want the row and column numbers to start at 0.
1st When the table appers after that the document runs hediously slow as in a second or two to enter a digit or letters appear after typing.  Like something is absorbing the computer resources. But I have a fast machine.
2nd Any data I  enter to the table vanishes but does get stored.
3rd I tried to turn it all into a procedure but cant get that to work.
with(DocumentTools:-Components)
[Button, CheckBox, CodeEditRegion, ComboBox, DataTable, Dial, Label, ListBox, MathContainer, Meter, Microphone, Plot, RadioButton, RotaryGauge, Shortcut, Slider, Speaker, State, TextArea, ToggleButton, VideoPlayer, VolumeGauge]
with(DocumentTools:-Layout)
[Cell, Column, DocumentBlock, Equation, Font, Group, Image, InlinePlot, Input, Output, Row, Section, Table, Textfield, Title, Worksheet]
with(DocumentTools)
[AddIcon, AddPalette, AddPaletteEntry, Components, ContentToString, CreateTask, Do, GetDocumentProperty, GetProperty, InsertContent, InsertTask, Layout, RemovePalette, RemovePaletteEntry, RemoveTask, Retrieve, RunWorksheet, SetDocumentProperty, SetProperty, Tabulate]
ary := Array(0 .. 3, 0 .. 3)
Array(%id = 18446746457454449478)
DT := DataTable(identity = "DataTable0", variable = 'ary', rowheader, columnheader, columnnames = [beta^0, beta, beta^2, beta^3], rownames = [alpha^0, alpha, alpha^2, alpha^3])
xml := Worksheet(Group(Input(Textfield(DT))))
DocumentTools:-InsertContent(xml)
PN1 := copy(ary, 0 .. (), 0 .. ())
Array(%id = 18446746457454471998)
Matrix(PN1)
Matrix(%id = 18446746457454477550)
PN1[0, 0]
6
BiPolyNum := proc (a := 4, b := 4) local ary, DT; description "Creates Bi Polynumbers"; ary := Array(0 .. a, 0 .. b); DT := DataTable(identity = "DataTable0", variable = 'ary', rowheader, columnheader, columnnames = [1, beta, beta^2, beta^3], rownames = [1, alpha, alpha^2, alpha^3]); DocumentTools:-InsertContent(xml); return copy(ary) end proc
proc (a := 4, b := 4) local ary, DT; description "Creates Bi Polynumbers"; ary := Array(0 .. a, 0 .. b); DT := DocumentTools:-Components:-DataTable(identity = "DataTable0", variable = 'ary', rowheader, columnheader, columnnames = [1, beta, beta^2, beta^3], rownames = [1, alpha, alpha^2, alpha^3]); DocumentTools:-InsertContent(xml); return copy(ary) end proc
f := BiPolyNum()
Array(%id = 18446746457454464046)
f
Matrix(f)
Matrix(%id = 18446746457454466582)
Download DataTable_Experiment.mw
I have a bunch of polynomials in q that involve unknown roots of unity and I want to bound them above by another polynomial.
For example: f(q):=q3-a*q2+b*q2-5.
Here a and b are powers of some roots of unity. These roots/powers depend on some variables which are unimportant.
My incorrect method up until now was to let all root of unity equal 1 so they vanish, and then run a short script that finds all coefficients of the poly f and makes them positive.
But in this case it returns an answer of q^3+5 as the quadratic terms vanish - I don;t want this to happen! I really want the bound q3+2*q2+5.
If I run the script that changes the coefficients first, then maple can't  recognise if -a is positive or negative and so this doesn't work. If it helps this is it:
f:=g[i,j];
coffs:=[];
for m from 0 to degree(f) do
   coffs:=[op(coffs), abs(coeff(f,q,m))] end do;
fabs:=0;
for m from 1 to degree(f,q)+1 do
   fabs:=fabs+coffs[m]*q^(m-1) end do;
      g[i,j]:=fabs end do;
Any ideas would be great. Thanks!
EDIT: to perhaps make it clearer. The kind of roots of unity i'm dealing with are things like z2*j*k+q*k+(1/2)*l where z is a (q-1)th root of unity, and j,k,l are unknown integer variables.
Hi everybody,
I use dsolve(..., numeric, events =[...], parameters = [...], range=0..TMAX) to solve a parameterized system of 2 ODEs (unknowns x(t) and v(t)).
The solution over the whole range [0, TMAX] is constructed by assembling partial solutions over adjacent subranges of [0, TMAX].
(please look the attached file and feel free to contact me if you need more details than those given below
There exist two types of solution :
  • Type 1 : trivial solution : for all t in some range [a>=0, b<= TMAX], the solution is x(t)=0 and v(t)=0
  • Type 2 : for all t in some range [b>=0, c<= TMAX] {x(t), v(t)} is the solution of the differential system
The end of the simulation corresponds :
  • either to t=TMAX
  • either to x(t) = CMAX where CMAX is some predefined value for x(t)
I use events to manage the two following situations
  • x(t) = CMAX
  • x(t) = 0 and v(t) < 0 : this is the situation which describes the transition between Type 2 solutution and Type 1 solution
The global solution is constructed by assembling partial solutions over subranges [0, b[1]], [b[1], b[2]], [b[2], b[3]] ... where type 1 solutions "live" in [b[n], b[n+1]] if n is odd and type 2 solutions in  [b[n], b[n+1]] if  n is even.
The assembly of the partial solutions doesn't work correctly : I identified the reason but I'm not capable to fix it.
If you look to the red instructions on yellow background you will see they do not return the same answer than the pink instructions (look to the blue outputs over the plot) .
This is probably due to a very big mistake on my part  but I can't fix it !
Once again, if my explanations are not sufficient or if I'm not enough clear, feel free to ask me any questions you need.
ParametricDsolve.mw
Why is maple showing 1D math when evaluating?
Dear sir,
I request to provide the procedure to evaluate the following double integral in steps. Please find the enclosed attachment
I wanted to calculate the bessel function's limit, but there is no results.
NULLNULLwith(MTM):
constants := s
s
eq1 := `assuming`([limit(MTM:-bessely(1, -I*r*sqrt(s)), infinity)], [s > 0])
BesselY(1, -(infinity*I)*s^(1/2))
eq2 := eval(eq1)
eq3 := `assuming`([limit(MTM:-bessely(1, -I*r), infinity)], [s > 0])
BesselY(1, -infinity*I)
eq4 := eval(eq3)
eq5 := `assuming`([limit(beselj(1, -I*r*sqrt(s)), infinity)], [s > 0])
beselj(1, -(infinity*I)*s^(1/2))
eq6 := eval(eq5)
eq7 := `assuming`([limit(MTM:-besselj(1, -I*r), infinity)], [s > 0])
-I*BesselI(1, infinity)
Download test.mw
Below is my attempt to distinguish between add vs sum commands.  In principle, the sum command is symbolic.  I attempt the comparison in general, but get an error for the add command.  This error appears to occur if I do not assign numeric values to the general variables in the function.  I would like to execute the comparison symbolically.  Can this be done or does add only execute numerical evaluations?
Download sum_vs_add.mw
sum_vs_add.mw
How can I find the next number in the following set of numbers?
3,10,2,7,7,?
Thank you for your help!
How do I extract harmonics and plot a spectrum from a piecewise function?
The function is "Ia" shown below near the bottom in the "Plot Line Current" section.
NULLNULL
Parm_List := [Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490]
[Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 120*Pi, R = 5, Idc = 22.3, mu = .5490]
Va := sqrt(2)*Vrms*sin(theta)Vmax =  RmsMS phase to neutral voltage
Vb := sqrt(2)*Vrms*sin(theta-2*Pi*(1/3))
Vc := sqrt(2)*Vrms*sin(theta+2*Pi*(1/3))
Vab := Va-Vb
Vbc := Vb-Vc
Vca := Vc-Va
com0 := rhs(simplify(solve({Vb = Vc, -Pi < theta and theta < 0}, theta, allsolutions))[1]) = -(1/2)*PiNULL
com1 := rhs(simplify(solve({Vc = Va, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/6)*PiNULL
com2 := rhs(simplify(solve({Vb = Vc, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/2)*PiNULL
com3 := rhs(simplify(solve({Va = Vb, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (5/6)*PiNULL
com4 := rhs(simplify(solve({Va = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (7/6)*Pi
com5 := rhs(simplify(solve({Vb = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (3/2)*Pi
com6 := rhs(simplify(solve({Va = Vb, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (11/6)*PiNULL
NULL  NULL
with(plots)
PlotVpn := plot(subs(Vrms = 100, [Va, Vb, Vc]), theta = -(1/2)*Pi .. 3*Pi)
PlotVpp := plot(subs(Vrms = 100, [Vab, Vbc, Vca]), theta = -(1/2)*Pi .. 3*Pi, linestyle = dot, thickness = 1)``
display({PlotVpn, PlotVpp})
plot(subs(Vrms = 100, [Va, Vb, Vc, Vab, Vbc, Vca]), theta = -(1/2)*Pi .. 3*Pi)
The  #1 diode is forward biased and switches on when Va>Vc (Va=Vc). The voltage VD will be equal to Va-Vb until diode #2 turns on when Vc< Vb. Then VD will equal Vc-Vc.
The switching angle for the diodes is given above. If phase control is used all commutation is delayed by the angle α.
NULL``
Without phase delay the average (DC) voltage applied to the laod is the average value of the 6 commutation periods over one cycle:
Van := sqrt(2)*Erms*sin(theta)Emax =  RmsMS phase to neutral voltage
Vbn := sqrt(2)*Erms*sin(theta-2*Pi*(1/3))
Vcn := sqrt(2)*Erms*sin(theta+2*Pi*(1/3))
Eq1 := Vdo = 6*(int(Van-Vbn, theta = com1 .. com2))/(2*Pi)
Vdo = 3*3^(1/2)*2^(1/2)*Erms/Pi
Eq2 := Vdc = 6*(int(Van-Vbn, theta = com1+alpha .. com2+alpha))/(2*Pi)
Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi
Commutation
The switching between diodes can not occur instantaneously because the supply circuit is inductive. Current can not change instantaneously in and inductive circuit.
The transfer of load current from the out-going phase to the incomming phase is accomplshed by a period of symultaneous conduction of the two adjacent diodes the creation of a circulating current between these two phases that resembles short circuit between the two phases.
The circulating current produces equal voltage drop with opposid polarities in each phase. In the out-going phase the drop adds to the soruce voltage and in the incomming phase the drop subtracts from the source voltage. Only the drop in the incomming phase effects the DC output voltage.
During commutation intervil com1 to com2 phases a and c are shorted while Id is transfered from phase c to phase a. During this time voltage Va-Vb minus the voltage drop in a phase caused by the commutation. This voltage drop is 1/2 the Vac voltage.
`&Delta;e` := 1/2*(Van-Vcn)
(1/2)*2^(1/2)*Erms*sin(theta)-(1/2)*2^(1/2)*Erms*cos(theta+(1/6)*Pi)
and      Va=Vc at π/6
`&Delta;E__Avg` = 6*(int(`&Delta;e`, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu))/(2*Pi)
`&Delta;E__Avg` = 3*((1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha)+(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha)-(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu)-(1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*2^(1/2)*Erms*(cos((1/6)*Pi+alpha)+sin((1/3)*Pi+alpha)-sin((1/3)*Pi+alpha+mu)-cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-(3/2)*Erms*2^(1/2)*3^(1/2)*cos(alpha)*cos(mu)/Pi+(3/2)*Erms*2^(1/2)*3^(1/2)*sin(alpha)*sin(mu)/Pi
`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))*3^(1/2)/Pi
combine(`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))*3^(1/2)/Pi, trig)
`&Delta;E__Avg` = (1/2)*(-3*Erms*2^(1/2)*3^(1/2)*cos(alpha+mu)+3*2^(1/2)*Erms*3^(1/2)*cos(alpha))/Pi
`&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
DC output voltage
V__D = Vdc-`&Delta;E__Avg`
subs([Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi, `&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi], V__D = Vdc-`&Delta;E__Avg`)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi+(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)+cos(alpha+mu))/Pi
Equating the intigral of the voltage drop between the phase A and C  to the intigral of the voltage rise across the two phase inductances (thes intigrals represent eqivalent flux).
int(Van-Vcn, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu) = int(2*L*omega, theta = 0 .. Id)
2^(1/2)*Erms*cos((1/6)*Pi+alpha)+2^(1/2)*Erms*sin((1/3)*Pi+alpha)-2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu)-2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu) = 2*L*omega*Id
(14)
2^(1/2)*Erms*3^(1/2)*cos(alpha)-2^(1/2)*Erms*3^(1/2)*cos(alpha)*cos(mu)+2^(1/2)*Erms*3^(1/2)*sin(alpha)*sin(mu) = 2*L*omega*Id
(15)
-((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu))*3^(1/2)*2^(1/2)*Erms = 2*L*omega*Id
(16)
combine(-((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu))*3^(1/2)*2^(1/2)*Erms = 2*L*omega*Id, trig)
-Erms*2^(1/2)*3^(1/2)*cos(alpha+mu)+2^(1/2)*Erms*3^(1/2)*cos(alpha) = 2*L*omega*Id
(17)
cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms
(18)
cos(alpha+mu) = -(1/3)*3^(1/2)*2^(1/2)*L*omega*Id/Erms+cos(alpha)
(19)
NULL``
subs(cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms, V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)+cos(alpha+mu))/Pi)
V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)-(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms)/Pi
(20)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-3*L*omega*Id/Pi
(21)
Line Currents
NULL NULL
Commutation Intervals
Plot Line Currents
Ia := piecewise((-Pi)*(1/6)+alpha < theta and theta <= (-Pi)*(1/6)+alpha+mu, Ia__Int1, (-Pi)*(1/6)+alpha+mu <= theta and theta <= (1/6)*Pi+alpha, Ia__Int2, (1/6)*Pi+alpha < theta and theta <= (1/6)*Pi+alpha+mu, Ia__Int3, (1/6)*Pi+alpha+mu < theta and theta <= (1/2)*Pi+alpha, Ia__Int4, (1/2)*Pi+alpha < theta and theta <= (1/2)*Pi+alpha+mu, Ia__Int5, (1/2)*Pi+alpha+mu < theta and theta <= 5*Pi*(1/6)+alpha, Ia__Int6, 5*Pi*(1/6)+alpha < theta and theta <= 5*Pi*(1/6)+alpha+mu, Ia__Int7, 5*Pi*(1/6)+alpha+mu < theta and theta <= 7*Pi*(1/6)+alpha, Ia__Int8, 7*Pi*(1/6)+alpha < theta and theta <= 7*Pi*(1/6)+alpha+mu, Ia__Int9, 7*Pi*(1/6)+alpha+mu < theta and theta <= 3*Pi*(1/2)+alpha, Ia__Int10, 3*Pi*(1/2)+alpha < theta and theta <= 3*Pi*(1/2)+alpha+mu, Ia__Int11, 3*Pi*(1/2)+alpha+mu < theta and theta <= 11*Pi*(1/6)+alpha, Ia__Int12, 11*Pi*(1/6)+alpha < theta and theta <= 11*Pi*(1/6)+alpha+mu, Ia__Int13)                Ib := piecewise((-Pi)*(1/6)+alpha < theta and theta <= (-Pi)*(1/6)+alpha+mu, Ib__Int1, (-Pi)*(1/6)+alpha+mu <= theta and theta <= (1/6)*Pi+alpha, Ib__Int2, (1/6)*Pi+alpha < theta and theta <= (1/6)*Pi+alpha+mu, Ib__Int3, (1/6)*Pi+alpha+mu < theta and theta <= (1/2)*Pi+alpha, Ib__Int4, (1/2)*Pi+alpha < theta and theta <= (1/2)*Pi+alpha+mu, Ib__Int5, (1/2)*Pi+alpha+mu < theta and theta <= 5*Pi*(1/6)+alpha, Ib__Int6, 5*Pi*(1/6)+alpha < theta and theta <= 5*Pi*(1/6)+alpha+mu, Ib__Int7, 5*Pi*(1/6)+alpha+mu < theta and theta <= 7*Pi*(1/6)+alpha, Ib__Int8, 7*Pi*(1/6)+alpha < theta and theta <= 7*Pi*(1/6)+alpha+mu, Ib__Int9, 7*Pi*(1/6)+alpha+mu < theta and theta <= 3*Pi*(1/2)+alpha, Ib__Int10, 3*Pi*(1/2)+alpha < theta and theta <= 3*Pi*(1/2)+alpha+mu, Ib__Int11, 3*Pi*(1/2)+alpha+mu < theta and theta <= 11*Pi*(1/6)+alpha, Ib__Int12, 11*Pi*(1/6)+alpha < theta and theta <= 11*Pi*(1/6)+alpha+mu, Ib__Int13)
IaPlot := plot(subs([Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490], Ia), theta = -(1/6)*Pi .. 3*Pi)
IbPlot := plot(subs([Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490], Ib), theta = -(1/6)*Pi .. 3*Pi)
NULLNULL
Line Rms Current
with(OrthogonalSeries)
Download Graetz_Bridg7b.mw
Hello all,
How to animate a set of vectors?
for example,
q:=Matrix(3,10,(i,j)->i^2+j+2*i); # some matrix which holds the 3x1 vectors.
animate(arrow,[q(..,i)],i = 1..10);
I get an error
Error, unsupported type of index, i
In real use, the input to 'arrow' function will be a vector valued function so the 'animate' command will show the resulting vectors.
thanks.
EngM.
Hello All,
I am trying to solve a nonlinear equation as a part of inverse kinematic for a robot tip.
The robot is mostly redundant, and thus, the optimization package is the best to use.
I looked the NLPSolve function in matrix form.
the equation(s) am trying to solve is of the following format
Tip - Desired = 0
Tip is a 6x1 vector and is a function (or expression) of q1 ..., qn number of joints.
Desired is 6x1 numerical values representing the desired Tip position and orientation.
for example, for a planar robot with only x,y coordinates
<cos(q[1])*cos(q[3])-sin(q[1])*sin(q[3])+sin(q[1])*q[2]+cos(q[1]), sin(q[1])*cos(q[3])+cos(q[1])*sin(q[3])-cos(q[1])*q[2]+sin(q[1])> - <1,1> = 0
I am a bit confused on how to use the NPLSolve command in matrix form.
I understand that I need to formulate a procedure p(v) where v is a vector (here it will be v := <q[1], .., q[n]> ) , however, I am not solving one objective function rather 6 of them for 6-degrees of freedom.
I tried something like
p:=proc(q)
    <cos(q[1])*cos(q[3])-sin(q[1])*sin(q[3])+sin(q[1])*q[2]+cos(q[1]) - 1,sin(q[1])*cos(q[3])+cos(q[1])*sin(q[3])-cos(q[1])*q[2]+sin(q[1]) -1>;
    Optimization[NLPSolve](3,p,initialpoint = evalf(q_start),maximize = false)
where q_start is 3x1 vector giving the initial point.
but I always get
Error, (in Optimization:-NLPSolve) non-numeric result encountered
How can I solve for set of equations?
thanks.
EngM
Dear all, I've been given the following procedure:
> int_part:=proc(f,h,n::integer) local k,u,v,s;
     > u:=f;
     > v:=h;
     > s:=0;
     > for k from 1 to n do;
     > u:=int(u,t);
     > s:=s-(-1)^(k)*u*v;
     > v:=diff(v,t);
> od;
> s; end:
To apply on the following function: f:=int((exp(-x*t))/sqrt(t(t+1)),t=1..infinity);
And f is a function of x. F(x).
It should give the asymptotic expansion up to O(x^-6). But probably I do something wrong. Can somebody help me please?
Best wishes, Math
I have a trigonometric equation that outputs with a solution in terms of _B1 which I want to remove.
restart: solve({7*cos(2*t)=7*cos(t)^2-5, t>=0, t<=2*Pi}, t, allsolutions, explicit);
output:
{t = arccos((1/7)*sqrt(14))},
{t = 2*Pi-arccos((1/7)*sqrt(14))},
{t = 2*arccos((1/7)*sqrt(14))*_B1-2*_B1*Pi+2*Pi*_Z1-arccos((1/7)*sqrt(14))+Pi}
Is there anyway to get rid of the _B1, or somehow evaluate it by a substitution?
Even numerically the answer still retains the _B1.
{t = 1.006853685}, {t = 5.276331623}, {t = -4.269477938*_B1+6.283185308*_Z1+2.134738969}
Also it would be nice to remove the _Z1 subscript too, as the domain of the equation is [0, 2pi].
I tried removing the 'AllSolutions' command , but then I am missing two solutions:
solve({7*cos(2*t)=7*cos(t)^2-5., t>=0 and t<=2*Pi}, t, Explicit);
 {t = 1.006853685}, {t = 2.134738969}
There should be 4 solutions in the domain [0, 2pi].
If the headline is not the appropriate means, then what is the command line based means of generating a new math container in a worksheet, suppose one has a button with the label "Create New Container inside Selected Section" if that makes my intent any more clear.
At first look the above movement seems to be impossible in real life.
First 900 901 902 903 904 905 906 Last Page 902 of 2463
