In using Isolate in RootFinding to compute roots of a real polynomial, the output contains, say, z= some number.  How to get rid of the "z =" so that I can declare that "some number" to be some variable?
I am writing a matrix to file where each matrix element is placed on a new line. An example of such code:
HH:=Matrix([[x**2,x**z,z**12],[2*x,5**y,6**1]]):
filenameHH:=fopen("test.txt",WRITE,TEXT):
nRow,nCol :=LinearAlgebra[Dimension](HH);
for i from 1 to nRow do
   for j from 1 to nCol do
      fprintf(filenameHH,"%a\n",HH[i,j]):
fclose(filenameHH):
When this is printed to file, it will print as the power sign ^ regardless of the input it is given. This particular output file will be read in by another language, and due to this the power symbol "^" is not desired, but instead " ** ". By converting the matrix into a string format and applying string operations, this can be done; but is there a simpler way to do it?
-Yeti
I am solving a simple system of algebraic equations in a "for" loop. I would like to write all the values of solutions to a matrix, but I only get the symbols. Here is my code:
A:=1:E:=0.1:L0:=<5,5,5,5>:m0g:=0.05:u:=<-5/4,-1/4,-3/4,-1/4>:v:=<-1/2,-3/2,1/2,1/2>:w:=<0,1,0,-1>:
Force:=Matrix(m,2);
for i from 1 to m do
 r1||i:=H||i*L0(i)/(A*E)+H||i/m0g*(arcsinh(V_A||i/H||i)+arcsinh((m0g*L0(i)-V_A||i)/H||i))-sqrt(u(i)^2+v(i)^2);
 r2||i:=V_A||i*L0(i)/(A*E)*(m0g*L0(i)/(2*V_A||i)-1)+H||i/m0g*(sqrt(1+((m0g*L0(i)-V_A||i)/H||i)^2)-sqrt(1+(V_A||i/H||i)^2))-abs(w(i));
 rozw||i:=fsolve({r1||i, r2||i}, {H||i,V_A||i},H||i=0..1);Force(i,1):=H||i;Force(i,2):=V_A||i;subs(rozw||i,Force(i,..));
evalf(Force);
Thanks in advance,
Iza
I need to create randomly several {1,2,3}-sequences of length 15. I execute:
> with(RandomTools):
> w:=Generate(list(posint(range = 3), 15)):
The problem is that when I close the program and then open and run it again, it always produces the same sequences.
What should I do in order to make it work really randomly? That is, to start at a "random" sequence as well?
Can any one help me correct my doc wherein I want to record 5 minutes with microphone and play it for the same duration through my speaker with a click of button component. I find problem in file path specification.This document in my PC is  in E:\A_PhD2017\MAPLEPhDFiles\RequestCorrection_Microphone_Speaker_from_primetime.mw
Components added are only three: microphone0, Speaker0 and Button0
Edit*Data*Available*Action*contains*the*following*commands
rate := DocumentTools:-GetProperty("Microphone0", samplerate); 1; R := DocumentTools:-GetProperty("Microphone0", value)
Array(%id = 18446745571883247742)
Edit Click Action for Button contains the following commands.
R := DocumentTools:-GetProperty("Microphone0", value); 1; srate := DocumentTools:-GetProperty("Microphone0", samplerate); 1; DocumentTools:-SetProperty("Speaker0", samplerate, srate); 1; DocumentTools:-SetProperty("Speaker0", value, R)
16000
No errors displayed for both the above doc tools use``
Also nonstop continuous evaluation takes place! Where is the loop formation if at all there is any?
Thanks for answering
Ramakrishnan V
Download RequestCorrection_Microphone_Speaker_from_primetime.mwRequestCorrection_Microphone_Speaker_from_primetime.mw
PhDFiles\....mw
I'm trying to write and simplify expressions involving partial derivatives of an arbitrary function, say f(x,y).
Specifically, I would like diff(f(t,y),t) to evaluate to D[1](f)(t,y), instead of
diff(f(t,y),t)
And eval(diff(f(x,y),x),x=t) gives the same result.
Interestingly, diff(f(2*t,y),t) does evaluate to 2*D[1](f)(2*t,y), as expected.
I could get some results by using a custom differentiation function
`diff/f` := proc(x,y,v)
    if v = x then return D[1](f)(v,y):
    elif v = y then return D[2](f)(x,v):
    else return 0: # is there a fallback I can use without risking infinite recursion?
    fi:
and it works for the simple case, but now diff(f(2*t,y),t) does not work.
All this makes me feel that there must be a way to get what I want by default, but I can't figure it out.
Is there? Thank you in advance!
Hi Mapleprimes people and robots,
My question is regarding a recursive sequence.  It can be defined non-recursively as -
a(r) :=  0.8*3^r + 0.2*(-2)^r.
The first few terms are -
1,2,8,20,68,188, and so on.
Here is my Maple Worksheet.
recursive_sequence_A133467.mw      recursive_sequence_A133467.pdf
I want some Maple code that will produce 30 terms of this sequence.  It is defined as
s[1]:=1:
s[2]:=2:
for n>2 we let s[n] = s[n-1] + 6*s[n-2].
Let me know if my question does not make sense.
Matt
I have a second problem which is related to converting horizontal axis to degrees ( or in terms of Pi :  0 - Pi/2 ).
Thank you for your helps
Bengu
s1 := (1/3*(4*(1.66+10^(-1))^2-x^2))^(3/2)/(x^2*(1+.66+10^(-1)))-sin(2*a);
s2 := (1/3*(4*(1.66+10^(-2))^2-x^2))^(3/2)/(x^2*(1+.66+10^(-2)))-sin(2*a);
s3 := (1/3*(4*(1.66+10^(-3))^2-x^2))^(3/2)/(x^2*(1+.66+10^(-3)))-sin(2*a);
k1 := series(s1, x);
                    (-2)
       4.769067180 x     + (-0.5773502688 - 1. sin(2. a))
                           2    / 4\
          + 0.01164914507 x  + O\x /
k2 := series(s2, x);
                    (-2)
       4.293792441 x     + (-0.5773502692 - 1. sin(2. a))
                           2    / 4\
          + 0.01293857500 x  + O\x /
k3 := series(s3, x);
                    (-2)
       4.247636750 x     + (-0.5773502693 - 1. sin(2. a))
                           2    / 4\
          + 0.01307916821 x  + O\x /
p1 := convert(k1, polynom);
  4.769067180                                                2
  ----------- - 0.5773502688 - 1. sin(2. a) + 0.01164914507 x
      x
p2 := convert(k2, polynom);
  4.293792441                                                2
  ----------- - 0.5773502692 - 1. sin(2. a) + 0.01293857500 x
      x
p3 := convert(k3, polynom);
  4.247636750                                                2
  ----------- - 0.5773502693 - 1. sin(2. a) + 0.01307916821 x
      x
with(plots, implicitplot);
implicitplot([p1, p2, p3], a = 0 .. (1/2)*Pi, x = 0 .. 3, style = point, symbol = [box, cross, circle], labeldirections = [horizontal, vertical], labels = ["&theta; (radians)", "Switching  field (T)"], color = [blue, red, black], symbolsize = 13);
How can I fit my equation with the experimental data given below?
My equation is:  y = A*y^3+B*x ,  where x is the independent variable,  and y is the dependent variable.
Also how can I determine A and B constants?
Bengu
Xvals := [.53993447, .5599647, .57995479, .59995566, .61996118, .63994512, .65994136, .6799731, .69996782, .71997949, .73997422, .75995044, .77994976, .7999707, .81995146, .83995244, .85996729, .87994951, .8999458];
Yvals := [-.79625455, -.75585259, -.67800183, -.47955884, -.25493698, -0.65747361e-1, .10114507, .26994542, .41484068, .50621122, .60363251, .65510417, .7251356, .75804148, .76002419, .8030069, .82774732, .8429559, .8692888];
with(Statistics);
points := ScatterPlot(Xvals, Yvals);
PLOT(CURVES(Matrix(19, 2, {(1, 1) = .53993447, (1, 2) =
   -.79625455, (2, 1) = .5599647, (2, 2) = -.75585259, (3, 1) =
   .57995479, (3, 2) = -.67800183, (4, 1) = .59995566, (4, 2) =
   -.47955884, (5, 1) = .61996118, (5, 2) = -.25493698, (6, 1)
   = .63994512, (6, 2) = -0.65747361e-1, (7, 1) = .65994136,
   (7, 2) = .10114507, (8, 1) = .6799731, (8, 2) = .26994542,
   (9, 1) = .69996782, (9, 2) = .41484068, (10, 1) = .71997949,
   (10, 2) = .50621122, (11, 1) = .73997422, (11, 2) =
   .60363251, (12, 1) = .75995044, (12, 2) = .65510417, (13, 1)
   = .77994976, (13, 2) = .7251356, (14, 1) = .7999707, (14, 2)
   = .75804148, (15, 1) = .81995146, (15, 2) = .76002419, (16,
   1) = .83995244, (16, 2) = .8030069, (17, 1) = .85996729,
   (17, 2) = .82774732, (18, 1) = .87994951, (18, 2) =
   .8429559, (19, 1) = .8999458, (19, 2) = .8692888}, datatype
   = float[8]), COLOUR(RGB, 0., 0.054901961, 0.47058824),
  STYLE(POINT)), AXESLABELS("", ""), VIEW(DEFAULT, DEFAULT))
display(points);
Statistics:-Fit(a*y^3+b*x, Xvals, Yvals, y);
   HFloat(2.996866026020011) y  - HFloat(0.9272751314432008)
example("?");
I want to find the first positive solution of the system of trigonometric equations inside the loop.
The solutions are in the form of "d=number*_Z +number" but I need one exact solution to use it for next run of the loop.
L[0]:=0:
for i from 1 by 1 to 3 do
assume(0<d[i], d[i]<1):
assume(-0.01<a[i], a[i]<0):
L[i]:= L[i-1]+ d[i]:
sys[i]:={Re((-80*Pi*I*a[i]/((a[i]+1)^3))*exp(4*Pi*I*L[i])) = -0.4, Im((-80*Pi*I*a[i]/((a[i]+1)^3))*exp(4*Pi*I*L[i])) = 0.8}:
solve(sys[i], {a[i],d[i]}, useassumptions = true,AllSolutions=true):
These are the solutions:
d[1] = 0.03689590440 + 0.5000000000 _Z1
d[2] = -1.000000000 d[1] + 0.03689590440 + 0.5000000000 _Z2
d[3] = -1.000000000 d[1] - 1.000000000 d[2] + 0.03689590440 + 0.5000000000 _Z3
Hello all,
This is my first time with Maple, I have been a student of Mathematica for 7 years. I purchased Maple to learn a new software and I have heard great things about it. I somehow dont feel the flexibility of Mathematica in Maple documentations. It seems to be a bit constrained and not very straight forward in some aspects. Please correct me if I am wrong and also point out to tutorials or documents that I should be looking at before nose diving into Maple.
worksheet example here:
I have faced 2 simple problems which I think is a bug in some form, or I may be wrong. Please advise.
  1. How do I insert Equation 7 before Equation 6? The worksheet wont let me do it.
  2. Why are 'and' and 'in' bolded automatically in SECTION format?
I need a help on the error message below as when I enter it on my browser the answer is that there isn't any hel for this subject.
Error Message:
Error, (in DynamicSystems:-EquilibriumPoint) the independent variable in the equations does not match the 'continuoustimevar' (t) specified by the DynamicSystems[SystemOptions].
Hey friends
I want to solve this relation with respect to "M"analytically but maple answer me: "Warning, solutions may have been lost"
How I can solve this problem and get to an analytical solution. It must be noted -1<w<-1/3. we can fix "w" with any value inn this interval. It be accepted any solution for any fixed "w".
Analytically_solution.mw
Hi everyone,
I am desperatly trying to find a reason to those weird results I get using LSSolve. It could really help me to understand, maybe I am using the function the wrong way.
I have a system of equations which is overdetermined that I wrote using an electrical simulation and kirchoff's laws.
I am trying to resolve it using the LSSolve function. Here is the list of residuals :
list := [-0.444299277411586e-2+(270.100000000000-Phi12_18)*D18, -.264819908561346+(627.030000000000-Phi23_18)*D18, .191242220011840+(-259.080000000000-Phi34_18)*D18, 0.269723795794403e-1+(-40.5060000000000-Phi45_18)*D18, 0.674200455699644e-2+(-10.1270000000000-Phi56_18)*D18, .109534122562258+(-197.290000000000-Phi67_18)*D18, 0.481462872723211e-3+(-2.41420000000000-Phi78_18)*D18, -0.346014532189641e-4+(-2.53290000000000-Phi89_18)*D18, -0.402474969346295e-4+(-2.94150000000000-Phi910_18)*D18, -0.632005430249463e-3+(-8.57100000000000-Phi1011_18)*D18, -0.105749265697549e-1+(-37.6580000000000-Phi1112_18)*D18, -0.116305497595306e-1+(-55.3250000000000-Phi1213_18)*D18, -0.581547498854927e-3+(-2.76630000000000-Phi1314_18)*D18, -0.371408130367776e-2+(-22.0900000000000-Phi1415_18)*D18, -0.886173700610320e-2+(-56.4810000000000-Phi1516_18)*D18, -0.478846208996643e-1+(262.447651185421-Phi12_18)*D29+(262.447651185421-Phi12_24)*D36, .348429199898355+(62.3165310883292-Phi23_18)*D29+(62.3165310883292-Phi23_24)*D36, .237294781239637+(41.8563477700905-Phi34_18)*D29+(41.8563477700905-Phi34_24)*D36, 0.356987380524040e-1+(6.12136413036823-Phi45_18)*D29+(6.12136413036823-Phi45_24)*D36, 0.892515544035472e-2+(1.53042068810978-Phi56_18)*D29+(1.53042068810978-Phi56_24)*D36, .163733792213247+(26.7554245920538-Phi67_18)*D29+(26.7554245920538-Phi67_24)*D36, 0.917897899527287e-3+(-0.110562085900856e-3-Phi78_18)*D29+(-0.110562085900856e-3-Phi78_24)*D36, 0.242480164562623e-4+(-.283316330467957-Phi89_18)*D29+(-.283316330467957-Phi89_24)*D36, 0.281967728090880e-4+(-.329007391842407-Phi910_18)*D29+(-.329007391842407-Phi910_24)*D36, -0.812318100863302e-3+(-1.22850243118112-Phi1011_18)*D29+(-1.22850243118112-Phi1011_24)*D36, -0.174002698946928e-1+(-9.57006175329410-Phi1112_18)*D29+(-9.57006175329410-Phi1112_24)*D36, -.125540933056649+(-44.2197489328973-Phi1213_18)*D29+(-44.2197489328973-Phi1213_24)*D36, -0.627722694977691e-2+(-2.21106159188713-Phi1314_18)*D29+(-2.21106159188713-Phi1314_24)*D36, -0.739424545575381e-1+(-24.8403831529913-Phi1415_18)*D29+(-24.8403831529913-Phi1415_24)*D36, -.203976357415920+(-68.0132712014090-Phi1516_18)*D29+(-68.0132712014090-Phi1516_24)*D36, 0.196522429267177e-1+(197.940000000000-Phi12_24)*D27, 0.368371276889244e-2+(57.8900000000000-Phi23_24)*D27, 0.144256702539785e-2+(48.4450000000000-Phi34_24)*D27, -0.115630146715321e-3+(10.-Phi45_24)*D27, -0.283028527731083e-4+(2.50010000000000-Phi56_24)*D27, -0.300476205822746e-2+(66.2640000000000-Phi67_24)*D27, -0.653509876948917e-3+(2.69040000000000-Phi78_24)*D27, -0.126753046978926e-2+(4.44790000000000-Phi89_24)*D27, -0.147212636486122e-2+(5.16530000000000-Phi910_24)*D27, -0.484316181019253e-2+(16.6000000000000-Phi1011_24)*D27, -0.298854531528585e-1+(96.8770000000000-Phi1112_24)*D27, -.120604432493978+(315.410000000000-Phi1213_24)*D27, -0.603334119632106e-2+(15.7700000000000-Phi1314_24)*D27, -0.664471982996522e-1+(167.170000000000-Phi1415_24)*D27, 0.786913003105101e-1+(-326.760000000000-Phi1516_24)*D27]
I know that all D values must be positive. When resolving the system without any constraints (D >= 0), i get the values I expected (knowing the input I used in the simulation), with a really low error :
result := LSSolve(list);
[1.82130325886306*10^(-8), [D10 = 0.200009334740825e-2, D11 = 0.666620509302803e-3, D14 = 0.222215208246154e-2, D15 = 0.128202791383597e-2, D17 = 0.499886140344411e-2, D19 = 0.302925526676043e-3, D2 = 0.100002349341980e-2, D20 = 0.142849446596938e-3, D22 = 0.111121127122156e-1, D23 = 0.222228054119820e-2, D25 = 0.714293621502836e-3, D26 = 0.833326349912537e-3, D28 = 0.217396531719902e-3, D3 = 0.400217567900069e-3, D6 = 0.166878862202449e-3, D7 = 0.999969828547956e-2, Phi1011_17 = -1.22850243118112, Phi1011_19 = -20.5335193736012, Phi1011_21 = -104.090964313150, Phi1011_23 = 19.2144499395683, Phi1112_17 = -9.57006175329410, Phi1112_19 = -81.6848630234903, Phi1112_21 = -242.149849175388, Phi1112_23 = 109.001351349915, Phi1213_17 = -44.2197489328973, Phi1213_19 = -92.8267195929548, Phi1213_21 = -204.444165890808, Phi1213_23 = -61.4447612788985, Phi12_17 = 262.447651185421, Phi12_19 = 262.149192406679, Phi12_21 = 256.248405276737, Phi12_23 = 246.521172863223, Phi1314_17 = -2.21106159188713, Phi1314_19 = -4.64255435896474, Phi1314_21 = -10.2212158757032, Phi1314_23 = -3.07798400495386, Phi1415_17 = -24.8403831529913, Phi1415_19 = -30.5944507718603, Phi1415_21 = -45.5847025259923, Phi1415_23 = -77.3297680041818, Phi1516_17 = -68.0132712014090, Phi1516_19 = -74.2023324471993, Phi1516_21 = -95.1952296374558, Phi1516_23 = -132.328467080565, Phi23_17 = 62.3165310883292, Phi23_19 = 200.804225452845, Phi23_21 = 130.018791598707, Phi23_23 = 73.7043262431720, Phi34_17 = 41.8563477700905, Phi34_19 = 343.409987932231, Phi34_21 = 159.593996060841, Phi34_23 = 62.6564757702407, Phi45_17 = 6.12136413036823, Phi45_19 = 12.3839171939746, Phi45_21 = 46.0005281797016, Phi45_23 = 13.1665796516893, Phi56_17 = 1.53042068810978, Phi56_19 = 3.16614687399595, Phi56_21 = 11.4998114891963, Phi56_23 = 3.29093394692614, Phi67_17 = 26.7554245920538, Phi67_19 = -244.288977944524, Phi67_21 = 376.351493538080, Phi67_23 = 88.4830465193635, Phi78_17 = -0.110562085900856e-3, Phi78_19 = -6.28061380389266, Phi78_21 = 43.7035845962372, Phi78_23 = 3.35123473697264, Phi89_17 = -.283316330467957, Phi89_19 = -6.18811507913178, Phi89_21 = -13.9258224376815, Phi89_23 = 5.20325572546379, Phi910_17 = -.329007391842407, Phi910_19 = -7.18580970783931, Phi910_21 = -16.1669897128450, Phi910_23 = 6.04291224185087]]
When adding the constraints that D should be positive (and that are actually positive in the previous result), I get a worse result in term of precisions :
LSSolve(list, {D10 >= 0, D11 >= 0, D14 >= 0, D15 >= 0, D17 >= 0, D19 >= 0, D2 >= 0, D20 >= 0, D22 >= 0, D23 >= 0, D25 >= 0, D26 >= 0, D28 >= 0, D3 >= 0, D6 >= 0, D7 >= 0});
[0.667302976414869964e-1, [D10 = 0.240199442379079e-2, D11 = 0.666577572133538e-3, D14 = 0.222218786790062e-2, D15 = 0.128192441757651e-2, D17 = 0.278678889056743e-2, D19 = 0.200473317719685e-3, D2 = 0.109938538155804e-2, D20 = 0.840721762649974e-4, D22 = 0.685770482726534e-3, D23 = -1.387530857*10^(-312), D25 = 0.714397733627028e-3, D26 = 0.833201232339238e-3, D28 = 0.204319731851617e-3, D3 = 0.419994015872111e-3, D6 = 0.191996909862889e-3, D7 = 0.103884505319047e-1, Phi1011_17 = -.709707335593168, Phi1011_19 = -15.7863975896827, Phi1011_21 = -151.171843708558, Phi1011_23 = 19.2211409030343, Phi1112_17 = -8.90604676283968, Phi1112_19 = -75.8627539382983, Phi1112_21 = -311.423930967299, Phi1112_23 = 109.002880650927, Phi1213_17 = -54.9212365194647, Phi1213_19 = -89.9790565093006, Phi1213_21 = -250.971671756001, Phi1213_23 = -61.5160003335629, Phi12_17 = 251.480872515883, Phi12_19 = 255.977573006508, Phi12_21 = 254.397100891354, Phi12_23 = 246.524672366158, Phi1314_17 = -2.74614386328796, Phi1314_19 = -4.48401822538664, Phi1314_21 = -12.5381572344771, Phi1314_23 = -3.08154491280567, Phi1415_17 = -31.8947514252141, Phi1415_19 = -30.8090400512349, Phi1415_21 = -51.0499196769535, Phi1415_23 = -77.3268969229600, Phi1516_17 = -87.7947790488482, Phi1516_19 = -75.5403005246575, Phi1516_21 = -101.763771364478, Phi1516_23 = -132.314524393221, Phi23_17 = 94.0093590848714, Phi23_19 = 86.4429757025976, Phi23_21 = 108.554765004168, Phi23_23 = 73.7072279431268, Phi34_17 = 87.6938924370977, Phi34_19 = 82.3922347753764, Phi34_21 = 88.5582078636840, Phi34_23 = 62.6604078051191, Phi45_17 = 13.1910198060107, Phi45_19 = 69.3008595136787, Phi45_21 = 15.5530983566712, Phi45_23 = 13.1677681559684, Phi56_17 = 3.29792072169498, Phi56_19 = 17.4003349272078, Phi56_21 = 3.88187632917493, Phi56_23 = 3.29123115133383, Phi67_17 = 60.0045707036166, Phi67_19 = 54.3070868626015, Phi67_21 = 87.9421288802858, Phi67_23 = 88.4929920125095, Phi78_17 = .279952186311827, Phi78_19 = -3.50632712699693, Phi78_21 = -20.3872167203319, Phi78_23 = 3.35213748642018, Phi89_17 = -0.991299169828910e-1, Phi89_19 = -4.44636683843093, Phi89_21 = 297.888811926331, Phi89_23 = 5.20500671661437, Phi910_17 = -.115101700555720, Phi910_19 = -5.16603761776826, Phi910_21 = 346.033351291632, Phi910_23 = 6.04494564310825]]
I also get the warning "limiting number of major iterations has been reached".
Can someone explain me?
It may not seem important at first sight, but sometimes when using my program I get wrong values and a negative D, which is not possible. Therefore I try to add a positive constraint, but the LLSolve function doesn't return anything except the error "no improved point could be found", which is weird because when I manually substitute the value I consider correct, i get a really low error. I can show you the related list of equations if you are interested...
Thanks in advance,
Lilian
the following code results in an error message: Error, (in forget) lexically scoped parameter out of context
If I click on this error message, it brings me to a page which I visited too often.
if I uncomment the irrelevant minimize command, the error message disappears.
How can I prevent this error without giving irrelevant commands?
kind regards,
Harry Garst
First 985 986 987 988 989 990 991 Last Page 987 of 2460
