this equation is complicated
how to dsolve for this equation for function f ?
f(t,x,diff(x,t)) - f(t,x,p) - (diff(x,t)-p)*diff(f(t,x,p), p) = tan(t)
how to find the contour of time series data? and how to find curvature function of this contour?
In this fuction the maximize is about at t=46 and x=46 but in the plot I look other max at other value, why?because is discontinus fuction?I need not the local max (it is potential energy but I think don't matter)optimization2enerpot.mws
updated:
P := evalm(p2 + c*vector([cos(q1+q2+q3), sin(q1+q2+q3)]));
with(Groebner):
p1 := vector([a*cos(q1), a*sin(q1)]);
p2 := evalm(p1 + b*vector([cos(q1+q2), sin(q1+q2)]));
Pe := map(expand, P);
A := {cos(q1) = c1, sin(q1) =s1, cos(q2)=c2, sin(q2)=s2, cos(q3)=c3, sin(q3)=s3};
P := subs(A, op(Pe));
F1 := [x - P[1], y - P[2], s1^2+c1^2-1, s2^2+c2^2-1, s3^2+c3^2-1 ];
F2 := subs({a=1, b=1, c=1}, F1);
g2 := Basis(F2, plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[1], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[2], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[3], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[4], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[5], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[6], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[7], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[8], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[9], plex(c3, s3, c2, s2, c1, s1));
                                   1, c1
                               2       2    2   2
                           16 y  + 16 x , s1  s2
                                 8 x, c1 s2
                                2      2    2
                             2 y  + 2 x , s1  c2
                                 2 x, c1 c2
                            3            2
                         2 x  - 2 x + 2 y  x, s2 c2
                                   1, c2
                                   2 x, s3
                                    2, c3
originally i think
g2[1], g2[7], g2[9] have single variables c1, c2, c3 respectively
can be used to solve system
but without x and y, these equations can not be used
if choose leading term has x and y , but there is no single variable s1 or c1.
originally expect solve as follows
g2spec := subs({x=1, y=1/2}, [g2[3],g2[5],g2[6]]);
S1 := [solve([g2spec[1]])];
q1a := evalf(arccos(S1[1]));
q1b := evalf(arccos(S1[2]));
S2 := [solve(subs(s1=S1[1], g2spec[2])), solve(subs(s1=S1[2], g2spec[2])) ];
q2a := evalf(arccos(S2[1]));
q2b := evalf(arccos(S2[2]));
S3 := [solve(subs(s1=S2[1], g2spec[2])), solve(subs(s1=S2[2], g2spec[2])) ];
q2a := evalf(arccos(S3[1]));
q2b := evalf(arccos(S3[2]));
I found from this forum that to plot a 2D array of points use can be made of the Maple procedure surfdata.
Does anyone have suggestions on how to plot contours in (preferrably) Maple 16 or Maple 17?
I tried the following
Output := Array(-10 .. 10, -10 .. 10, proc (i, j) options operator, arrow; i^2+j^2 end proc):
F := proc (x, y) -> x^2+y^2 end proc:
surfdata(Output, color = F, dimension = 2);
but "the option dimension = 2" is a Maple 18 addition.
Ideally, I would like also to be able to plot contours with options found in the procedure
contourplot
Please illustrate the answer on the example of a simple wave equation, for instance.
I'm wondering if there is an available command that can evaluate the number of terms required to produce a desired outcome.
Specifically, I am interested in determining the probability of a Poisson distribution, given the parameter (mean) value and the probability outcome. I can obtain the desired result using trial and error / brute force, but I am curious to know if there is a more efficient way.
Suppose that, lambda = 2.6 and the cumulative sum of the probabilities is 95%. I know that I must add the first 6 terms for P(x) in the series (x=0,1, ..,5) to sum to 0.95. Each term ...  P(x=0)= 0.07, P(x=1)=0.19, and so on.
However, how can we know that desired 95% outcome can be determined from the first 5 terms without trial & error?
Hi guys ,
i computed a tensorial term with respect to a metric and i think i made mistake !! what do you think ?
problem.mw
Best Regards
will give me
which is indeed a solution of the PDE1
will give me
which is not a solution of the PDE2
However, both differential equations are equal, only the arguments are swapped around. Am I doing something wrong, or is this a bug?
I have a module with quite a few procedures and it is getting too long and complex. Basicially I write each procedure in a seperate document, them copy and paste it into the module. I want to improve matters as save each proc and read it in to the module
e.g.  Qdim:=proc(A,B).........end proc
        save Qdim , "Qdim.?"   have tried .txt ,.mla , .m  They save fine.
in the module have tried
read "Qdim.txt" etc.   I have included Qdim in export but Qdim doesnt work Qdim(A,B) returns Qdim(A,B)
read "C:\Users\Ronan\Documents\MAPLE\Rational Trinonometry\Qdim.m";
which procuces an error
Error, (in unknown) could not open `C:UsersRonanDocumentsMAPLERational TrinonometryQdim.m` for reading
Not sure if this is documented explicitly to Maple users, but normally (prior to Maple 2017) interface(typesetting=extended) was all that was required to output display diff(y(x),x) as y'(x)
With Maple 2017 typesetting=extended is default and one must use with(Typesetting)  Settings(typesetprime=true) in order to output the display of diff(y(x),x) as y'(x).
Perhaps this is well documented somewhere, however I was unable to find the change.
I am new to Maple and I am trying to add units to the "Flow Through an Expansion Valve" Application Demonstration.  I was trying pressure in [PSI], temperature in [degC] and flow rate in [kg/hour] everything else in SI units.  I included with(Units:-Standard) but had no luck with the fsolve function.
Any chance someone could make a version of this demonstration applicaton that includes units?
 MaplePrimes member has sent you a message on MaplePrimes.
Member: faisal http://www.mapleprimes.com/users/faisal
E-Mail Address:
> restart; with(PDETools), with(plots);
> n := .3; Pr := 7; Da := 0.1e-4; Nb := .1; Nt := .1; tau := 5;
> Eq1 := (1-n)*(diff(f(x, y), `$`(y, 3)))+(1+x*cot(x))*f(x, y)*(diff(f(x, y), `$`(y, 2)))-(diff(f(x, y), y))/Da+(diff(f(x, y), y))^2+n*We*(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), `$`(y, 3)))+sin(x)*(theta(x, y)+phi(x, y))/x = x*((diff(f(x, y), y))*(diff(f(x, y), y, x))+(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), x)));
> Eq2 := (diff(theta(x, y), `$`(y, 2)))/Pr+Nt*(diff(theta(x, y), y))^2/Pr+Nb*(diff(phi(x, y), y))*(diff(theta(x, y), y))/Pr+(1+x*cot(x))*f(x, y)*(diff(theta(x, y), y)) = x*((diff(f(x, y), y))*(diff(theta(x, y), x))+(diff(theta(x, y), y))*(diff(f(x, y), x)));
> Eq3 := Nb*(diff(phi(x, y), `$`(y, 2)))/(tau*Pr)+Nt*(diff(theta(x, y), `$`(y, 2)))/(tau*Pr)+(1+x*cot(x))*f(x, y)*(diff(phi(x, y), y)) = x*((diff(f(x, y), y))*(diff(phi(x, y), x))+(diff(phi(x, y), y))*(diff(f(x, y), x)));
> ValWe := [0, 5, 10];
> bcs := {Nb*(D[2](phi))(x, 0)+Nt*(D[2](theta))(x, 0) = 0, f(0, y) = ((1/12)*y)^2*(6-8*((1/12)*y)+3*((1/12)*y)^2), f(x, 0) = 0, phi(0, y) = -.5*y, phi(x, 12) = 0, theta(0, y) = (1-(1/12)*y)^2, theta(x, 0) = 1, theta(x, 12) = 0, (D[2](f))(x, 0) = Da^(1/2)*(D[2, 2](f))(x, 0)+Da*(D[2, 2, 2](f))(x, 0), (D[2](f))(x, 12) = 0};
> pdsys := {Eq1, Eq2, Eq3}; for i to 3 do We := ValWe[i]; ans[i] := pdsolve(pdsys, bcs, numeric) end do;
> p1 := ans[1]:-plot(theta(x, y), x = 1, color = blue); p2 := ans[2]:-plot(theta(x, y), x = 1, color = green); p3 := ans[3]:-plot(theta(x, y), x = 1, color = black);
> plots[display]({p1, p2, p3});
I am trying to solve a system of equations (I'm using MapleTA< but I'm pretty sure that this applies to any Maple product).  I have successfully solved the system, and obtain a set of solutions, which has name Soln.  I can access the element Soln[1], which is an expression:
vn2 = 12/7
Now, I just want that 12/7, as a decimal.  I try evalf(Soln[1]), but again I end up with vn2 = 12/7.  How do I get the decimal number out, without it being an expression?
on the basis of Fundamental theorem of calculus, the function " f " has Antiderivative F , whichi F is continuous and differentiabe in the range of integration, i have a question ? if function f has an Antiderivative F, should it be also continuous and differentiabe in that range? in the picture below it says "when f is continuous", can f be discontinuous? how it can be ? any examples?
First 987 988 989 990 991 992 993 Last Page 989 of 2470
