I google and found a program using C# connect with Maple. The Maple file is mla file - a pakage library type of Maple. I want to review data structure and all interfaces funtions to understand the way to implement this features.
Please help me the way to read the original Maple code. I uploaded the .mla file into mediafire if you want to review it. Link http://www.mediafire.com/download/abd9kpk3q6oq8lb/CHEMISTRY.mla
Quan Nguyen
Hi there,
I'm trying to simulate an stochastic SIR model following the Gillespie algorithm, as described here [1].
When trying to update each process' probabilities, it looks like Maple is not updating their values. Although each element of the lists S, I and R is updated the ai lists are not updated.
For example, for a given index i
a2[i]:= m*S[i]:
takes the same value for every i, regardless of the value of S[i].
Can anybody tell why this is happening or what's wrong with the worksheet? This is the attempt: MaplePrimes_SIR_model_simulation_Gillespie_algorithm.mw
On the other hand, I tried making things more clear through a couple of procedures. However, when it comes to the point where a random number with an exponential distirbution is computed:
Rexp := RandomVariable(Exponential(mu)):
it looks like Maple is unable to evaluate mu. But having a look at the Variables explorer, it has a defined value, indeed.
So what's wrong in the worksheet? Thi is the attempt: MaplePrimes_SIR_model_simulation_Gillespie_algorithm.mw
jon
[1] http://www.biosym.uzh.ch/modules/models/ETHZ/StochasticSimulation/sir_stoch.xhtml
Hi every one.
I want to export some plots from maple as images in ".jpg" or ".png" formats. I was wondering that is there a way to specify the resolution of the exported pictures? I need high quality pics.
I just bought Maple Student edition. I won't allow me to validate myself and won't allow me to install the software unless I remove Java 8 and install the much older Java 6?!
Please help.
Hi! when i'm trying to solve, i get the following warning: Warning, solutions may have been lost.
The equations i'm trying to solve are as the following:
>A=0.1;
> D=0.19;
> eqns:={y^1.5-9/8*B^0.5*y+3/4*x*y^0.5-3/4*(Pi/3)^0.5*[1+(1+3/4*(Pi/3)*(B*(1+x^2))^0.5)*x^2]/(1+x^2)^0.5=0, Pi/2-3*D=8/3*y^3+x*y^2+4*B^0.5*[1/3*B*y^1.5-2/45*B^2.5-3/2*y^2.5]-9/2*B*(1/3*B*y-3/40*B^2-3/4*y^2)-3*x*B^0.5*[1/3*B*y^0.5-1/7*B^1.5-1/2*y^1.5],B=A/(1+x^2)};
> vars:={x,y,B};
> solve(eqns,vars);
What am i doing wrong?
Many thanks!
Hi, all
I use INT to calculate multiple integration as below. It runs more than 20 hours without results. I wander is there any problem in my codes.
A := sin(k*Pi*(x-h*cos(theta))/a)*sin(l*Pi*(y-h*sin(theta))/b)*sin(k[0]*h)*sin(k*Pi*x/a)*sin(l*Pi*y/b);
W := evalf[5](int(int(int(int(A, h = 0 .. (x-a)/cos(theta)), theta = Pi+arctan((b-y)/(a-x)) .. 3*Pi*(1/2)), x = 0 .. a), y = 0 .. b, numeric))
Why the disparity in the solution of P1 and P2? P1 uses finite difference while P2 uses midrich.
See them here P1.mw     and   P2.mw
  Suppose I would like to use writedata for a series of files, e.g. test1.txt, test2.txt, test3.txt.
I tried
a_min:=1;a_max:=3;
b_min:=1;b_max:=3;
A:=array(a_min..a_max,b_min..b_max);
for i from a_min to a_max do
  for j from b_min to b_max do
     A[i,j]:=i*j;
for i from 1 to 3 do
  file_name:=`test||i`;
  writedata[APPEND](file_name,A);
Seems "||" inside `` does not work, is there any robust solution for this issue?
Thank you very much
I am trying to define a new typt and I am beating my head against the wall...
What I have working:
TypeTools:-AddType(Element,'record(l,R)');
This defines a type which I can then use in type(xpr,Element) to be false or true depending on whether xpr is a record containing (at least) entries l and R or not.
Now I want to define a type ExpandedLine that is a Vector of Element (Element in the sense above). In fact, in the context of my application I am willing to settle for ExpandedLine being a Vector of record.
Tried various approaches (and making sure Vector is in uneval quotes in the AddType statement) like:
TypeTools:-AddType(ExpandedLine,'Vector'(record));
and variations but no luck.
Any help is appreciated.
Mac Dude
I want to put the solution obtained from ShowSolution() command of Student[Calculus1] into my LaTeX file. How I can achieve that?
I succeeded in getting latex of ExpandSteps because it was a module, but ShowSolution() is not a module.
I have nonlinear partial differential equations (see the attached file) need to be solved:
https://drive.google.com/file/d/0B14...ew?usp=sharing
With initial condition: h(x, y) = K1 (constant), dh/dx = K2 (constant); dh/dy = K3 (constant); And h(x,y) is function of (x,y) other factors are constant. Could anyone tell me how to solve these equations by using numerical method? Do you know any library in c/ c++ language that can solve these equations??
I have tried with Maple 17 and the response is: "Error, (in pdsolve/info) first argument is not a differential equation". Whole of my input:
with(PDEtools); declare(U1(x, y), U2(x, y), U3(x, y));
PDEs = [diff(U1(x, y), y) = U2(x, y),
diff(U1(x, y), x) = U3(x, y),
(diff(U2(x, y), y))*((L-U1(x, y))^2+(D2+tan(alpha)*(L+U1(x, y)))^2)+.5*U2(x, y)*(2*tan(alpha)*U1(x, y)-D2) = 0,
(diff(U3(x, y), x))*((L-U1(x, y))^2+D1^2*cos(alpha+2*U2(x, y))^2)+.5*U3(x, y)*D1*cos(alpha+2*U2(x, y))+.5*D1*sin(alpha+2*U2(x, y))*(L-U1(x, y)) = 0];
[ d d / d
PDEs = [--- U1(x, y) = U2(x, y), --- U1(x, y) = U3(x, y), |--- U2(
[ dy dx \ dy
\ / 2 2\
x, y)| \(L - U1(x, y)) + (D2 + tan(alpha) (L + U1(x, y))) /
/ d
+ 0.5 U2(x, y) (2 tan(alpha) U1(x, y) - D2) = 0, |--- U3(x, y)
\ dx
\ / 2 2 2\
| \(L - U1(x, y)) + D1 cos(alpha + 2 U2(x, y)) /
+ 0.5 U3(x, y) D1 cos(alpha + 2 U2(x, y))
+ 0.5 D1 sin(alpha + 2 U2(x, y)) (L - U1(x, y)) = 0]
pdsolve(PDEs);
I will be very appreciated with your help!!!
I need to convert a base 10 int(defined as num) to its base 3 format using a while loop. I would like to store the remainder of the num%3 to a list/sequence/array in maple. Now, if I were to use a sequence, I would need a pre-defined range. How do I solve this issue?
I've got a piece-wise function(for which I've made the procedure) f defined over x<=-1, -1<x<1 and x>=1 which I am trying to plot over the range of (-2,2). I've tried using plot(f,-2..2) but it doesn't show any curve. Should I add a few more parameters to plot()?
I've got the following lists :
list1:=[1, 5, 14, 30, 55, 91, 140, 204, 285, 385, 506, 650, 819, 1015,
1240, 1496, 1785, 2109, 2470, 2870]
list2:=[1, 5, 14, 30, 55, 91, 140, 204, 285, 385, 506, 650, 819, 1015,
each generated by a procedure I defined. I need to verify that they are equal, which is the case. However, when I tried to use the evalb function as well as a flag that I was updating during a loop, in both cases, I got 'false' as  the answer along with the error message:
"error, final value in a for loop must be numeric or a character"
What I am doing wrong?
I am required to generate a list containing the square of numbers 1 through k where k is an arbitrary int,defined from 1 to n. To do this, I've currently got the following commands:
local k, mylist:=[];
for k from 1 to n do
mylist[k]=sumsquare(k);
where sumsquare() is a procedure I defined to compute the sum of the squares of 1 through a number passed as an argument
At present this gives me an out of bounds error.
How can I initialize mylist to be of size n, like in other languages such as C++?
First 1323 1324 1325 1326 1327 1328 1329 Last Page 1325 of 2429
