It's Alan's birthday and he's having a
party. Seven other people will attend.
Everyone will sit around the dining table.
The seating arrangement must meet the
following conditions:
* Amy and Alan sit together. Brad and
Beth sit together.
* Charles sits next to either Debbie or
Emily.
* Frances sits next to Debbie.
* Amy and Alan do not sit next to either
Brad or Beth.
* Brad does not sit next to Charles or
Frances.
* Debbie and Emily do not sit next to
each other.
* Alan does not sit next to either Debbie
or Emily.
* Amy does not sit next to Charles.
Who should sit where?
Dear all;
nice to speak with you.
complete a table randomly by positive three-digit numbers and display only the symmetrical numbers.
im trying to calculate the divergence of a 3x3 tensor. The tensor is created by the following code:
with(VectorCalculus);
with(LinearAlgebra);
SetCoordinates(cartesian[x, y, z]);
alias(u = u(t, x, y, z), v = v(t, x, y, z), w = w(t, x, y, z)); alias(eta = eta(t, x, y, z));
U := VectorField(`<,>`(u, v, w));
M := OuterProductMatrix(U, U);
The last command gives a 3x3 tensor:
Now I want to calculate the divergence of this tensor. But the function "Divergence" (VectorCalculus-package) is only able to handle vectors. A workaround would be the extract the data row by row -> convert it to a vector -> calculate the divergence.
Is there a more elegant possibility to do this?
for my simulation I have to calculate several gradients and jacobian matrices. The equations are quite complex and with my current setup hard to read.
Here is some exampel code:
Divergence(U);
Jacobian(U);
Diff(U, t);
The Divergence operator gives me a very compact result:
But Jaobian and Diff look like:
To achive a better readability I want to do two things (if possible):
1) hide the independet variables (t,x,y,z) in the result of Jacobian, Diff
2) display the result of Diff in a row vector (3x1) instead
Is this possible?
Thanks in advance for your help
I am looking to return all the substrings of a string that match a particular pattern (regexp). This is a very common text processing operation.
StringTools[RegMatch] returns boolean about whether the given pattern exists somewhere in the string. That's a start, but it is not efficient to hunt around for where the match is in order to extract the characters.
StringTools[Search] and [SearchAll] can return position information, but they work on exact matches of the pattern space, not on regular expressions. I could pre-generate all the possible matching sequences of up to some length and search for those exactly, but that is inconvenient at best and pretty much useless if there is a .* or .+ in the regular expression (as the space of potential matches grows exponentially.)
StringTools[RegSub] can be used to find one match by using something like ".*(REALPATTERN).*" = "\1" but since this does not extract any position information, one would at the very least then have to StringTools[Search] of the exact match to determine the position, then take a substring of the original string, and continue searching. And if you are going to do that, you might as well just use StringTools[RegMatch] with an optional third argument of a symbol to return the matched characters, instead of fooliing around with deleting everything else using RegSub.
Have I overlooked a possibility?
Example of use:
I would like to search "variable %1 needs to be of the form %3+2.9 in order to use routine %2 to find the fizturl", extracting the "%1", "%3", "%2". This would be regular expression "%[0-9]+". Notice that there might be other digits in the string that I do not want to extract, so I cannot just search for digits. I also cannot just remove all characters "[^0-9%]" as that would leave digits and would, for example, merge together the %3+2.9 into %329 leaving post-processing to extract the true pattern matches.
For what I am doing at the moment, I do not need to know the positions those occured at, just the matches.
Why is it that
dismantle(3*a);
returns a SUM entity?
SUM(3)
   NAME(4): a
   INTPOS(2): 3
dismantle(3+a);
also returns a SUM entry
SUM(5)
   NAME(4): a
   INTPOS(2): 1
   INTPOS(2): 3
   INTPOS(2): 1
ToInert() looks fine for both of these.
Tested on Maple 16, Maple 17, Maple 18
I want to solve a Laplace integral transform step-by-step its as follows:
f(t):=e^at
IntTutor(Int(e^-st f(t),t=0..infinity)
but it says that the expression can't be integrated, and secondly it does not work with 'infinity'. How I can solve this for step-by-step solution?
Thanxs
When I open My Maple 18 on my Macbook pro, with all updates on the operating system and on Java, my Maple starts up fine, but when I press 2+2 and the enter, nothing happens.
I have tried reinstalling Maple, without any change of the problem
Per Kirkegaard
hi
i want to use Direct Search Package for solve system of equation but i have an error:
Error, SolveEquations is not a command in the DirectSearch package.
please help me. code is attached.boltmohasebe.mw
Hi all.
I try to get the real part from the complex expression. But it turns out to not be the simplest result:
A:=I*sin(k*Pi*(x-h*cos(theta))/a)*sin(l*Pi*(y-h*sin(theta))/b)*exp(-I*k[0]*h)*sin(k*Pi*x/a)*sin(l*Pi*y/b)
convert(exp(-I*k[0]*h), sin);
simplify(Re(A));
Maple results in:
Re(sin(k*Pi*(-x+h*cos(theta))/a)*sin(l*Pi*(-y+h*sin(theta))/b)*exp(-I*k[0]*h)*sin(k*Pi*x/a)*sin(l*Pi*y/b))
while the simplified result should be:
sin(k*Pi*(x-h*cos(theta))/a)*sin(l*Pi*(y-h*sin(theta))/b)*sin(k*Pi*x/a)*sin(l*Pi*y/b)*sin(k[0]*h)
I wander how to get the simplifyed result in maple. Thanks
How can I breal kong code lines in "Code Edit Region" like "..." in Matlab?
How can one use maple to linearized nonlinear ODE of this type Linearize.mw
with maple.
Best regards.
  Suppose I have the following code
f[1]:=x1^2+x2;
f[2]:=-x2^3+x1-2;
solve({f[1], f[2]}, {x1, x2}):
a,b:= eval([x1, x2], %[1])[]:
a, b;
It could work and give me "1 and -1".
I would like to have a general subroutine, solving f[1]...f[n]. I cannot input  "solve({f[1], f[2],....,f[n]}, {x1, x2}):" just like that. Is ther any way to use "solve" or similar module to handle arbitary number of variables?
I am trying to use solve to determine 5 unknowns from 12 equations each with seperate data points); however, maple requires you to have equal number equations and variables. Is there any way around this?
There are two ways of expressing the solution to a cubic equation, one of them uses cos and arccos [1]. How do I / is there a way to ask Maple to get this form?
More generally, can Maple be instructucted to solve equations using trig identities?
[1] http://en.wikibooks.org/wiki/Trigonometry/The_solution_of_cubic_equations
First 1324 1325 1326 1327 1328 1329 1330 Last Page 1326 of 2429
