I am fitting polynomial differential equations to data, and I came across some troubling behavior. I have sets of coordinates in x, y, z, and values w at these coordinates. The x,y,z coordinates and the data at these coordinates are concatenations of three subsets of data each, and depending on the order of the concatenation, I get different polynomials from the stats fit command. The difference is not trivial -- it makes a huge differentce in the stability of the differential equations. I have written a demonstration worksheet to show this problem.
John Starrett
Solve IVP with complex coef. with compplex varables numerically..
the sys. is x'=-iDelta1x(t)+y(t)+epsilon
y'=-iDelta2y(t)+x(t)z(t)
z'=-2(x*(t)y(t)+x(t)y*(t)), where * means complex conjugate
I solve it as:
epsilon:=5:Delta1:=4:Delta2:=4:assume(z(t),real):
var:={x_R(t),y_R(t),z_R(t),x_I(t),y_I(t),z_I(t)}:
dsys :={diff(x(t),t)=-I*Delta1*x(t)+y(t)+epsilon, diff(y(t),t)=-I*Delta2*y(t)+x(t)*z(t), diff(z(t),t)=-2*(conjugate(x(t))*y(t)+conjugate(y(t))*x(t))}:
functions := indets(dsys, anyfunc(identical(t))):
redefinitions := map(f -> f = cat(op(0, f), _R)(t) + I*cat(op(0,f), _I)(t), functions):
newsys := map(evalc @ Re, redefinitions) union map(evalc @ Im, redefinitions):
incs := {x_R(0)=0, x_I(0)=0, y_R(0)=0, y_I(0)=0,z_R(0)=-1/2, z_I(0)=0}:
dsol1 :=dsolve({newsys,incs},var,numeric, output=listprocedure, abserr=1e-9, relerr=1e-8,range=0..1):
but it seems there is not runing propebly
If we a complex number in Maple, like for example:
I*b+a+x+I*y+I^2*c
How can we make maple rewrite it like this?
a+x-c+I*(y+b)
I tried using the comands Re(%) and Im(%) but Re just gives the whole expression again and Im gives 0.
Hey
I have a excel spreadsheet with a number of data points which I want to plot in Maple.  I have imported the data and I did manage to produce a point plot, but how can I exclude some of the data points when I plot the point plot?
I would, for example, like to exclude the negative values and only plot the data which is greater than zero.
I am relatively inexperienced with Maple and would like to either be pointed in the right direction or shown a similar example to my problem for reference.
My problem is I need to write a programme using the below equations
d^2x/dt^2=ax+by
d^2y/dt^2=cx+by
I then have to use the below values to show my programme works
a=b=c=d=1
x(0)=1
Dx(0)=0
y(0)=0
Dy(0)=1
After proving it works I have to apply it to a mass spring system using realistic parameters. Using visual and analytical ways to show findings.
md^2x/dt^2=-kx-k(x-y)
md^2y/dt^2=-k(y-x)-ky
when x and y are the displacement from the equilibrium. Initially the masses are displaced from their equilibrium posistions and released so that
x(0)=a, y(0)=b, Dy(0)=Dx(0)=0
then repeat with different smaller calculations
Any help would be much appreciated
When I write in maple the following:
x*(x+y)
What do I need to write to make maple make the operation that will evaluate the expression and show the following?
x^2+x*y
simplify(%) or evaluate(%) only shows it the same way it was inputted to start with.
  I have the following code for using "PolynomialSystem" solve equations of polynomial
with(SolveTools):
f:=PolynomialSystem({x+y-3, x^2+y^2-5}, {x, y}):
print(x,y);
print(f);
f[1];f[2];
a:=f[1][1];b:=f[1][2];
print(a,b);
c:=-evalf(a);d:=-evalf(b);
The output is
x, y
{x = 2, y = 1}, {x = 1, y = 2}
{x = 2, y = 1}
{x = 1, y = 2}
x = 2
y = 1
x = 2, y = 1
-x = -2.
-y = -1.
From what I have seen, I cannot subtract the values of x and y as 2 and 1. Is there any way that I can get the values of solutions of variables, namely I can assign a variable "a" as 2, and the other variable "b" as 1?
Thank you very much!
How can one deduce values of f(eta), diff(f(eta),eta) and diff(f(eta),eta$2) from values of f1,f2,f3,f4,.. in the results of the finite difference here Trial.mw . I need the outcome for f and its 1st and 2nd derivatives as listed above. Please help.
How do I compute the Lyapunov exponents for Lorenz system
Is it possible to organize output of plots in Mathematica-like manner
in one list (placed in one cell)?
In Maple I use tables for these purposes:
Maybe, does there exist a more elegant solution?
hi...plese help me
how i can solve set of non linear differential equation with a unknown parameter with numeric role in maple software??
thank a lot ...
Hello, my problem is that I've changed in tools maple default mode to "Maple input" from "2-d" I've aplied it globbaly and it doesnt'work. Still when type Enter it switch automatically to 2-d Math, and I have to change it by Ctrl-M to 1-d. Any ideas how to solve it? I want 2-d just to output.
eqn1 := (3*y/(y^2+1)^(5/2)+(3*(x+y))/(1+(x+y)^2)^(5/2)+(3*(y+z))/(1+(y+z)^2)^(5/2)+(3*(x+y+z))/(1+(x+y+z)^2)^(5/2))*(-2*x^2/(x^2+1)^2+1/(x^2+1)-2*x*(x+y)/(1+(x+y)^2)^2+1/(1+(x+y)^2)-2*x*(x+z)/(1+(x+z)^2)^2+1/(1+(x+z)^2)-2*x*(x+y+z)/(1+(x+y+z)^2)^2+1/(1+(x+y+z)^2))+(-3*x/(x^2+1)^(5/2)-(3*(x+y))/(1+(x+y)^2)^(5/2)-(3*(x+z))/(1+(x+z)^2)^(5/2)-(3*(x+y+z))/(1+(x+y+z)^2)^(5/2))*(-2*y^2/(y^2+1)^2+1/(y^2+1)-2*y*(x+y)/(1+(x+y)^2)^2+1/(1+(x+y)^2)-2*y*(y+z)/(1+(y+z)^2)^2+1/(1+(y+z)^2)-2*y*(x+y+z)/(1+(x+y+z)^2)^2+1/(1+(x+y+z)^2)):
eqn2 := x/(x^2+1)+x/(1+(x+y)^2)+x/(1+(x+z)^2)+x/(1+(x+y+z)^2)-y/(y^2+1)-y/(1+(x+y)^2)-y/(1+(y+z)^2)-y/(1+(x+y+z)^2):
eqn3 := subs({x = (tan(alpha)-tan(beta)+tan(gamma))*(1/2), y = (tan(alpha)+tan(beta)-tan(gamma))*(1/2), z = (-tan(alpha)+tan(beta)+tan(gamma))*(1/2)}, eqn1):
eqn4 := subs({x = (tan(alpha)-tan(beta)+tan(gamma))*(1/2), y = (tan(alpha)+tan(beta)-tan(gamma))*(1/2), z = (-tan(alpha)+tan(beta)+tan(gamma))*(1/2)}, eqn2):
My question is how to solve eqn3 and eqn4 of tan(alpha)&&tan(beta).
I want to solve the equations eqn3 and eqn4 to solve the  tan(alpha)  and tan(beta),  give me a help .thanks a lot
Download 0112.mw
I just started my Calculus I class and I have a project to prove some various theorems. Maple rocks for this.
How can I insert the Q.E.D. symbol (looks like a little black square) at the end of my proofs?
ok so I run Maple 18 , but the problem is that maple does not show me the phase portrait , it only keep showing me what i write,
for example , i write this
  DE1 := diff(y(t),t) = z(t);
  DE2 := diff(z(t),t) = -y(t)*cos(t);
  phaseportrait([DE1,DE2],[y,z],t=-5..5,[[y(0)=1,z(0)=0],[y(0)=0,z(0)=2],[y(0)=0,z(0)=-2]],y=-Pi..Pi,z=-3..3,color=aquamarine,linecolor=blue);
and maple just show me these back
what should i do?
First 1325 1326 1327 1328 1329 1330 1331 Last Page 1327 of 2429
