m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
m2 := Determinant(m-Matrix([[1,0,0],[0,1,0],[0,0,1]]));
1. which family of polynomials do m2 belong to?
2. how to analyze m2?
What´s the error here??????
Solução do Sistema de EDO's por Transformada de Laplace
with(inttrans):
eq1 := diff(x(t), t)+(2.2*x(t)*y(t)+0.5e-1*x(t)/(5+0.5e-1*t)) = 0;
diff(x(t), t)+2.2*x(t)*y(t)+0.5e-1*x(t)/(5+0.5e-1*t) = 0
eq2 := diff(y(t), t)+(2.2*x(t)*y(t)-(0.5e-1*(0.25e-1-y(t)))/(5+0.5e-1*t)) = 0;
diff(y(t), t)+2.2*x(t)*y(t)-0.5e-1*(0.25e-1-y(t))/(5+0.5e-1*t) = 0
eq3 := diff(z(t), t)-2.2*x(t)*y(t)+0.5e-1*z(t)/(5+0.5e-1*t) = 0;
EQ := [eq1, eq2, eq3]:
for i to 3 do La[i] := laplace(EQ[i], t, s) end do;
s*laplace(x(t), t, s)-1.*x(0.)+2.200000000*laplace(x(t)*y(t), t, s)+laplace(x(t)/(100.+t)^1., t, s) = 0.
-1.*y(0.)-0.2500000000e-1*(exp(100.*s))^1.*Ei(1., 100.*s)^1.+1.*s^1.*laplace(y(t), t, s)^1.+2.200000000*laplace(x(t)^1.*y(t)^1., t, s)+1.*laplace(y(t)^1./(100.+1.*t)^1., t, s) = 0.
s*laplace(z(t), t, s)-1.*z(0.)-2.200000000*laplace(x(t)*y(t), t, s)+laplace(z(t)/(100.+t)^1., t, s) = 0.
LL := subs({laplace(x(t), t, s) = X, laplace(y(t), t, s) = Y, laplace(z(t), t, s) = Z}, [La[1], La[2], La[3]]);
[s*X-1.*x(0.)+2.200000000*laplace(x(t)*y(t), t, s)+laplace(x(t)/(100.+t)^1., t, s) = 0., -1.*y(0.)-0.2500000000e-1*(exp(100.*s))^1.*Ei(1., 100.*s)^1.+1.*s^1.*Y^1.+2.200000000*laplace(x(t)*y(t), t, s)+1.*laplace(y(t)/(100.+t)^1., t, s) = 0., s*Z-1.*z(0.)-2.200000000*laplace(x(t)*y(t), t, s)+laplace(z(t)/(100.+t)^1., t, s) = 0.]
sol := solve(LL, [X, Y, Z]):
assign(sol):
SOLS[X, Y, Z]:
SOLT := map(invlaplace, [X, Y, Z], s, t);
[-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(x(_U1)/(100.+_U1), _U1 = 0. .. t))+x(0), -1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))+y(0)+0.2500000000e-1*ln(1.+0.1000000000e-1*t), 2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(z(_U1)/(100.+_U1), _U1 = 0. .. t))+z(0)]
SOLTT := evalf(subs({x(0) = 0.5e-1, y(0) = 0, z(0) = 0}, SOLT));
[-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(x(_U1)/(100.+_U1), _U1 = 0. .. t))+0.5e-1, -1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))+0.2500000000e-1*ln(1.+0.1000000000e-1*t), 2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(z(_U1)/(100.+_U1), _U1 = 0. .. t))]
xx := evalc(Re(SOLTT[1]));
yy := evalc(Re(SOLTT[2]));
0.2500000000e-1*ln(abs(1.+0.1000000000e-1*t))-1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))
zz := evalc(Re(SOLTT[3]));
plot([xx, yy, zz], t = 0 .. 500, legend = [x, y, z]);
Warning, expecting only range variable t in expression -2.200000000*int(x(_U1)*y(_U1),_U1 = 0. .. t)-1.*int(x(_U1)/(100.+_U1),_U1 = 0. .. t)+.5e-1 to be plotted but found names [_U1, x, y]
Download laplace.mw
Dear Friends
I have a problem in CPU time in MAPLE.
I write the codes in maple related to the nonlinear heat conduction problem in one dimension by Collocation method, but after 30 minutes no solution has been observed!!!
My codes are for N=4!, i.e., I have 25 equations with 25 unknowns!!!
If MAPLE can not solve this simple system, How can I solve 3 dimensional pdes by N=9,
In this case, I have 1000 equations with 1000 unknowns!!!
please help me and suggest me a fast iterative solver.
I should remark that my problem is stated in this paper
http://www.sciencedirect.com/science/article/pii/S1018364713000025
If there exist any other suitable method, I will be happy to receive any support.
With kind regards,
Emran Tohidi.
> restart;
> Digits := 20; N := 4; st := time(); u := sum(sum(a[m, n]*x^m*t^n, m = 0 .. N), n = 0 .. N); u := unapply(u, x, t); ut := diff(u(x, t), `$`(t, 1)); ut := unapply(ut, x, t); ku := simplify(1+u(x, t)^2); ku := unapply(ku, x, t); ux := diff(u(x, t), `$`(x, 1)); ux := unapply(ux, x, t); K := ku(x, t)*ux(x, t); K := unapply(K, x, t); Kx := diff(K(x, t), `$`(x, 1)); Kx := unapply(Kx, x, t); f := proc (x, t) options operator, arrow; x*exp(t)*(1-2*exp(2*t)) end proc;
> S1 := {seq(u(i/N, 0)-i/N = 0, i = 0 .. N)}; S2 := {seq(u(0, j/N) = 0, j = 1 .. N)}; S3 := {seq(u(1, j/N)+ux(1, j/N)-2*exp(j/N) = 0, j = 1 .. N)}; S4 := {seq(seq(Kx(i/N, j/N)+f(i/N, j/N)-ut(i/N, j/N) = 0, i = 1 .. N-1), j = 1 .. N)}; S := `union`(`union`(`union`(S1, S2), S3), S4); sol := DirectSearch:-SolveEquations([op(S)], tolerances = 10^(-4), evaluationlimit = 1000000);
> assign(sol);
> u(x, t);
> CPUTIME := time()-st;
plot3d(u(x, t) - x exp(t), x = 0 .. 1, t = 0 .. 1)
I just bought and installed "The mathematical Survival Kit" but I can't figure out how does it work
Anybody can help?
Thanaks
Martina
EDIT:
Let f:X->f(X)  be a polynomial function from C^n to C^p. Let r(X) be the rank of the Jacobian matrix of f in X. What is the maximal value of r(X) when X goes throught C^n ?
In other words, I'd want to obtain the maximal dimension of the components of im(f).
How to proceed ?
with(combinat):
symMonomial := proc(test)
h := 0;
for i from 1 to nops(test) do
                h[i] := choose(test,i);
od;
c := copy(test);
k := 0;
for k from 1 to nops(test) do
                c[k] := 0;
                for i from 1 to nops(h[k]) do
                                ki := 1;
                                for j from 1 to nops(h[k][i]) do
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
return c;
sympoly := proc(test, number_of_roots)
with(combinat):
h := 0;
                h[i] := choose(z,i);
od;
c := 0;
                c[k] := 0;
                                ki := 1;
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
poly := x^number_of_roots;
for k from 1 to number_of_roots do
                poly := poly + c[k]*x^(number_of_roots-k);
od;
z := [x1, x2, x3, x4, x5, x6, x7, x8, x9, x10];
sigma := symMonomial(z);
f := expand(sigma[1]*sigma[2]);
f := expand(sigma[1]*sigma[1]); # two lambda value are the same
f := expand(sigma[1]*sigma[1]*sigma[1]); # three lambda value are the same
f := expand(sigma[1]^2+2*sigma[1]*sigma[2]+sigma[2]);
f := subs(x1=3, f);
f := subs(x2=2, f);
f := subs(x3=3, f);
f := subs(x4=4, f);
f := subs(x5=5, f);
f := subs(x6=6, f);
f := subs(x7=7, f);
f := subs(x8=8, f);
f := subs(x9=9, f);
f := subs(x10=lambda, f);
evalf(solve(f, lambda));
if degree(f) = 2 then
                f := f + lambda^3;
end if:
how to convert above f back to matrix form such as
m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]);
m2 := Determinant(m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]));
after tested m2 can not be expressed in terms of shell like polynomial,
it seems that it is from symmetric polynomial and it is from a non-homogenous polynomial which homogenize with a lambda
if solve f for new eigenvalue,
can traditional eignvector method calculate new eigenvector for these new kind of eigenvalues method?
A*x = lambda*x
hi ,
i solve my odes with ode analyzer and obtained h(t) , u(t) and s(t) ... i wana put u(t) and s(t) in another equation to obtain T(t,r) , i did as follow but i have an error :
400*(s(t)*(diff(T(t, r), r))+u(t)*(diff(T(t, r), t))/r) = 0.3e-1*((diff(T(t, r), r)+r*(diff(T(t, t), r, r)))/r+(diff(T(t, r), r))/r^2)+0.1e-2*(2*((diff(u(t), t))/r+s(t)/r)^2+((diff(s(t), t))/r-u(t)/r)^2)
4.00000000000000*u(t)^2*h(t)*(diff(y(t), t))-8.00000000000000*h(t)^2*x(t)^2+16.0000000000000*u(t)*h(t)*x(t)*(diff(h(t), t))+(1367.18750000000*(-29.8200000000000+u(t)))*h(t)^2*x(t)+363.281250000000*u(t)*h(t)*y(t)-1367.18750000000*h(t)^2*(30-u(t))*x(t)+u(t)^2*h(t)-0.225000000000000e-1+0.225000000000000e-1*(0.749297072727423e-1+1.49578322716831*sin(t-0.75e-1))^2+4.00000000000000*(u(t)*y(t)+h(t)*x(t))^2 = 0
diff(s(t), t) = 8.00000000000000*(diff(x(t), t))*h(t)+16.0000000000000*y(t)*x(t)+8.00000000000000*u(t)*(diff(y(t), t))
diff(h(t), t) = y(t)
diff(u(t), t) = x(t)
x(t) = 427.2460938*u(t)+385620.1174/u(t)-25671.38673
h(0) = 0.1e-10, s(0) = .6, u(0) = .62, x(0) = 596561.43714, y(0) = .12096, T(0, r) = 0, t = 0 .. .18, r = 0 .. .125
pdsolve(1, 2, 3, 4, 5, 6, {7}, numeric);
Error, (in pdsolve) invalid input: `pdsolve/numeric` expects its 2nd argument, IBCs, to be of type {list, set}, but received 2
according to my previous question
http://www.mapleprimes.com/questions/201435-ODE-With-Constraint
I wrote the following code. at first, the code solve the equation for f and when it slves that, I want to solve Theta in such a way that use the values of f in previous calculation. I use the command 'known' but i couldnt find thesolution
I would be most grateful if you could help me in this problem
Thanks for your attentions in advance
restart; # Notice that Restart (capital R) has no effect (to catch that use semicolon, not colon)
a:=0.13:
b:=0.41:
reynolds:=1.125*10^7;
Eq1:=diff(f(x),x$3)+diff(f(x),x$2)*f(x)+b^2*sqrt(2*reynolds)*diff(diff(f(x),x$2)^2*x^2,x$1);
Eq2:=diff(g(x),x$3)+diff(g(x),x$2)*g(x)+c*a^2*sqrt(2*reynolds)*diff(diff(g(x),x$2)^2*x,x$1);
eq1:=isolate(Eq1,diff(f(x),x,x,x));
eq2:=subs(g=f,isolate(Eq2,diff(g(x),x,x,x)));
EQ:=diff(f(x),x,x,x)=piecewise(x<c*0.1,rhs(eq1),rhs(eq2));
c:=75:
Q:=proc(pp2) local res,F0,F1,F2;
print(pp2);
if not type(pp2,numeric) then return 'procname(_passed)' end if:
res:=dsolve({EQ,f(0)=0,D(f)(0)=0,(D@@2)(f)(0)=pp2},numeric,output=listprocedure);
F0,F1,F2:=op(subs(subs(res),[f(x),diff(f(x),x),diff(f(x),x,x)])):
F1(c)-1;
fsolve(Q(pp2)=0,pp2=(0..102));
se:=%;
res2:=dsolve({EQ,f(0)=0,D(f)(0)=0,(D@@2)(f)(0)=se},numeric,output=listprocedure);
G0,G1,G2:=op(subs(subs(res2),[f(x),diff(f(x),x),diff(f(x),x,x)])):
plots:-odeplot(res2,[seq([x,diff(f(x),[x$i])],i=0..2)],0..2); #This plots from and past 0.1*c
pr:=1;
prt:=0.89;
Eq11:=diff(theta(x),x$2)+pr*diff(theta(x),x$1)*f(x)+pr/prt*b^2*sqrt(2*reynolds)*diff(diff(f(x),x$2)*diff(theta(x),x$1)*x^2,x$1);
Eq22:=diff(g(x),x$2)+pr*diff(g(x),x$1)*f(x)+pr/prt*a^2*c*sqrt(2*reynolds)*diff(diff(f(x),x$2)*diff(g(x),x$1)*x^1,x$1);
eq11:=isolate(Eq11,diff(f(x),x,x));
eq22:=subs(g=theta,isolate(Eq22,diff(g(x),x,x)));
EQT:=diff(theta(x),x,x)=piecewise(x<c*0.1,rhs(eq11),rhs(eq22));
QT:=proc(pp3) local res3,theta0,theta1;
print(pp3);
if not type(pp3,numeric) then return 'procname(_passed)' end if:
res3:=dsolve({EQT,theta(0)=1,D(theta)(0)=pp3,known=f},numeric,output=listprocedure);
theta0,theta1:=op(subs(subs(res),[theta(x),diff(theta(x),x)])):
theta0(c);
fsolve(QT(pp3)=0,pp3=(0..200));
res3(0);
Amir
in maple 15
https://drive.google.com/file/d/0B8F2D27rfQWgVXE1alN0V3JWU1U/edit?usp=sharing
there are 3 equation to be minimized
and i limit x between x + 5 and x - 5 as constraints
though f1 got a error in first line of command,
later i type a correct command for f1 in later part of script
What is the difference between the "old" Maplet format and the "new" Möbius Project App format? Is the Möbius Project just a new name for writing Maplets? Is the programming different; are the mechanics of putting the file in a form to be used by students different; does the file containing the program that can be directly run by students have a different format and extension; are the kinds of things students see different? Is the Maplets function on the way to being discontinued in favor of the Möbius Apps?
I cannot find anything in the documentation for either format that relates it to the other format, although the general description of the output seems entirely the same.
Hi:
how find the coefficients C1,C2?
q(0)=0,D(q)(0)=0
q(T) := sin(T)*_C2+cos(T)*_C1-(1/3000)*Pi*(4012562293500*Pi^3*cos(T)^3-32100498340000*Pi^3*cos(T)^2-3009421720125*Pi^3*cos(T)+16050249170000*Pi^3+435778855000*Pi*cos(T)^2-217889427500*Pi-3539762622):
We know that the set f:={(1,2),(2,a),(3,b)} can introduce a function from {1,2,3} to {2,a,b}. I want Maple to know f as a function. Is this job possible at Maple? I thought to find the Cartesian product of above latter sets and then try to select "f" as one of its subset but this did not help me to force Maple to take "f" as a function. Indeed, I want to work with this kind of function (like plotting and doing f+g, f-g, fog for two functions for example).
Thanks for your time and help.
how to plot tail of normal distribution
would like to see the shape of tail of distribution
i want to solve a system of differential equations in maple with "dsolve, numeric",
i got th error message: "Error, (in f) unable to store in Matrix ..."
what is the problem?
thanks a lot
First 1409 1410 1411 1412 1413 1414 1415 Last Page 1411 of 2429
