How can I know the solution is correct??
Here is the code:
s := solve(sin(x^2) = 1/2);
test := subs(x = s[1], sin(x^2) = 1/2);
Does MapleSim 6 cover temperature dependent fluid media? In the modelica standard library (MSL), there is for example a medium model for T-dependent properties, defined by tables or polynomials (Modelica.Media.Incompressible).
Is it included in MapleSim 6 or can be somehow modelled?
I am trying to produce a worksheet that will give me the two roots of a quadratic equation.
This is what I have:
Maple Worksheet
As you can see, It's not giving me the right answers. What do I do?
Paul
I see a document with maple graphics in it, but i don't see the maple code in the document.
Has the author protected his code ?
I like to see the maple code used for the document ..how to read this maple code?
Note: try to find answer on the Maple site , but no idea where to find thisinformation on how to set up a document..frustrating.
hi,
i obtained values for h(t) and u(t) and i wana obtaine s(t) , i don't konw how can i do it
for h(t) and u(t) ,
sol1 := dsolve([4.00000000000000*u(t)^2*h(t)*(diff(diff(h(t), t), t))-8.00000000000000*h(t)^2*(427.2460938*u(t)+385620.1174/u(t)-25671.38673)^2+16.0000000000000*u(t)*h(t)*(427.2460938*u(t)+385620.1174/u(t)-25671.38673)*(diff(h(t), t))+(16406.2500000000*(-29.8200000000000+u(t)))*h(t)^2*(427.2460938*u(t)+385620.1174/u(t)-25671.38673)+7171.87500000000*u(t)*h(t)*(diff(h(t), t))-16406.2500000000*h(t)^2*(30-u(t))*(427.2460938*u(t)+385620.1174/u(t)-25671.38673)+u(t)^2*h(t)-0.225000000000000e-1+0.225000000000000e-1*(.997494986604054+.106105802501554*sin(t-1.5))^2+4.00000000000000*(h(t)*(427.2460938*u(t)+385620.1174/u(t)-25671.38673)+u(t)*(diff(h(t), t)))^2 = 0, diff(u(t), t) = 427.2460938*u(t)+385620.1174/u(t)-25671.38673, h(1.44) = 0.145e-4, (D(h))(1.44) = .12093, u(1.44) = .62], numeric)
and s(t) is , s(t)=1/r*d/dt(u(t)*h(t))
thanks.
Code was computed on two different PC:
1) Win 8.1, Maple 17.02 x64
2) Win 8.1, Maple 18.01 x64
In brief:
n:=3:
Grid:-Seq('f(i)', i = 1 .. n):
works well in Maple 17.02 but gives an error in Maple 18.01. Why?
However,
(j -> Grid:-Seq('f(i)', i = 1 .. j))(n):
works well for both Maple versions.
according to examples from Maple help page
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Grid%2fSeq
we have to pass exactly 'f(i)' (not just f(i)) into Grid:-Seq(...). Why?
Why doesn't Digits:=30: work properly for Grid:-Seq(...)?
For details see attached file. Output was produced in Maple 17.02. In Maple 18.01 the output will differ.
restart; n := 3; f1 := proc (i) options operator, arrow; evalf(sqrt(i)) end proc; f2 := proc (i) options operator, arrow; evalf(sqrt(i+1)) end proc; f3 := proc (i) options operator, arrow; evalf(i*Pi) end proc; g1 := proc (f, n) local za, zb, zc, str; str := sprintf("g1(%a,n)", f); za := seq(f(i), i = 1 .. n); zb := Grid:-Seq(f(i), i = 1 .. n); zc := (proc (j) options operator, arrow; Grid:-Seq(f(i), i = 1 .. j) end proc)(n); print("------------------------------"); print(cat("(a):   ", str), za); print(cat("(b):   ", str), zb); print(cat("(c):   ", str), zc); print("------------------------------") end proc; g2 := proc (f, n) local za, zb, zc, str; str := sprintf("g2(%a,n)", f); za := seq('f(i)', i = 1 .. n); zb := Grid:-Seq('f(i)', i = 1 .. n); zc := (proc (j) options operator, arrow; Grid:-Seq('f(i)', i = 1 .. j) end proc)(n); print("------------------------------"); print(cat("(a):   ", str), za); print(cat("(b):   ", str), zb); print(cat("(c):   ", str), zc); print("------------------------------") end proc
g1(f1, n);
"(a):   g1(f1,n)", 1., 1.414213562, 1.732050808
"(b):   g1(f1,n)", 1, 2^(1/2), 3^(1/2)
"(c):   g1(f1,n)", 1, 2^(1/2), 3^(1/2)
"(a):   g1(f2,n)", 1.414213562, 1.732050808, 2.
"(b):   g1(f2,n)", 1.414213562, 1.732050808, 2.000000000
"(c):   g1(f2,n)", 1.414213562, 1.732050808, 2.000000000
"(a):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(b):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(c):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(a):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(b):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(c):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(a):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(b):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(c):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(a):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(b):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(c):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
Digits := 30;
30
"(a):   g1(f1,n)", 1., 1.41421356237309504880168872421, 1.73205080756887729352744634151
"(a):   g1(f2,n)", 1.41421356237309504880168872421, 1.73205080756887729352744634151, 2.
"(a):   g1(f3,n)", 3.14159265358979323846264338328, 6.28318530717958647692528676656, 9.42477796076937971538793014984
"(b):   g1(f3,n)", 3.14159265358979323846264338328, 6.283185308, 9.424777962
"(c):   g1(f3,n)", 3.14159265358979323846264338328, 6.283185308, 9.424777962
"(a):   g2(f1,n)", 1., 1.41421356237309504880168872421, 1.73205080756887729352744634151
"(a):   g2(f2,n)", 1.41421356237309504880168872421, 1.73205080756887729352744634151, 2.
"(a):   g2(f3,n)", 3.14159265358979323846264338328, 6.28318530717958647692528676656, 9.42477796076937971538793014984
Download Grid[Seq].mw
Hello guys...
please help me to solve these equation.I have some equation with some boundary condition.
Why can't I have good results for it?
q3:=-0.1080877976e-1:
q2:=0.04351279185:
q1:=-0.7037638761e-1:
q0:=0.05575044494:
c:=3:
eq := q3*m^6+q2*m^4+q1*m^2+q0;
rishe := solve(eq = 0, m);
a := 1/(2*c); rho := a/`#msub(mi("t"),mn("1"))`;
f0 := evalf(cosh(abs(rishe[1])*xi));
f1 := evalf(cosh(abs(Re(rishe[3]))*xi)*cos(abs(Im(rishe[3]))*xi));
f2 := evalf(sinh(abs(Re(rishe[3]))*xi)*sin(abs(Im(rishe[3]))*xi));
pin := C0*k0*f0+C1*f1+C2*f2;
ppin := diff(pin, xi); pis := C0*f0+(k1*C1+C2*k2)*f1+(C2*k1-k2*C1)*f2;
pin1 := evalf(subs(xi = a, pin));
pin2 := evalf(subs(xi = -a, pin));
pin3 := evalf(subs(xi = a, ppin));
pin4 := evalf(subs(xi = -a, ppin));
pis1 := evalf(subs(xi = a, pis));
pis2 := evalf(subs(xi = -a, pis));
hal := solve({pin1 = sigma01xx, pin2 = sigma01xx, pin3 = 0, pin4 = 0, pis1 = sigma01xy, pis2 = sigma01xy}, {C0, C1, C2, k0, k1, k2});
how can I have a good result with this method?
please help me to solve this multi equations multi variable.
I have a big expression with multiple terms. The expression is kind of :
expr = a*ln(u) + b*ln(u) + a*ln(v)+b*ln(v)
I want to factor ln(u) and ln(v) to get (a+b)*ln(u) + (a+b)*ln(v)
I tried factor(expr,ln(u)) but I get the error :
Error, (in factor) 2nd argument, ln(2*da+(4*da^2+4*d^2-4*da*Sigma[a]+Sigma[a]^2+Delta[b]^2)^(1/2)-Sigma[a]), is not a valid algebraic extension.
I tried without Delta[b] and Sigma[a] : deltab and sigmaa but it didn't work either.
Do you have an idea how to factor the many ln ?
Mathieu
Well, I'm having issues getting this expression to simplify.  I have a bunch of polynomial results I store in an array, and the simplify command isn't cancelling obvious terms which should cancel out.
June_18.mw
Curiously, it will simplify if I use the command by selecting it from the drop down menu when I select the expression (see lines (7) vs. (8))
i am trying to export an animated gif file but the export windows freezes and exports an empty file with zero bytes
the animation was created by: display(map(p, convert(A(() .. (), 2), list)), insequence = true)
i have tried to give maple some time (2-3 hours) and i even tried to restart the computer and lauch maple and try to export it but it didnt worked
how can i export it or how can i plot the using commands
I want to solve the equation sqrt(x) + sqrt(1 - x^2) = sqrt(2 - 3*x - 4*x^2) in RealDomain. I tried
RealDomain:-solve(sqrt(x) + sqrt(1 - x^2) = sqrt(2 - 3*x - 4*x^2),x);
And I got one solution. But, at here
At here http://mathematica.stackexchange.com/questions/51316/how-can-i-get-the-exact-real-solution-of-this-equation
they said the given equation has two real solutions. How must I understand?
Hi everyone
Title might be misleading but couldn't come up with a short version of my problem.
The idea is to show an animation of several plots of an array, which all have different values in the positive and in the negative range. For distinguishing purposes I want to show positive values in a different colour than the negative values.
For better understanding imagine a chess board with the rows and columns and there are places with values, black chess pieces as positive values and white chess pieces as negative values. Each array in the sequence from A1 to An shows a movement.
For the plots I use sparsematrixplot which unfortunately just shows all non-zero values. So I seperated the original array and made two arrays, one with the positive values and one with the negative values. I am able to animate the sequence of several plots and can play the animation of two sequences consecutively with following:
A:=seq(sparsematrixplot(convert(H||g,matrix),color=green,view=[0..10,0..10]),g=1..G):
B:=seq(sparsematrixplot(convert(F||g,matrix),color=red,view=[0..10,0..10]),g=1..G):
display([A,B], insequence=true);
Hence my questions
1. Is it possible to plot an array with different colours for different values and can I animate these plots?
2. If not, is there a way to display the two plot sequences on top of each other?
Thanks for your help in advance.
i have the following problem:
i had create this tiny procedure to compute the berstein base elements:
Berstein base
And so i would like print space, between B(i,n,t) and the formula corresponing, without quotes :D
In other word i would an output like this:
B(i,n,t),      ,(formula)
Thank you in advance :)
Hy all.
I want to solve this equation, with„dd” as numerical result. What do I do wrong? Thanks. Nico
TTot := 70;
TC := 17;
GM := .26;
QMax := 870;
V := 3600*GM*QMax*TTot;
eq := V = int(QMax*exp((-t+TC)/dd)*(1+(t-TC)/TC)^(TC/dd), t = 0 .. TTot);
fsolve(eq, dd);
I'm trying to resolve a PDE using pdsolve().
The equation is :
diff(n(z,t),t)+diff(n(z,t)*v(z,t),z)=0
where n is the density of particles in a container and v their velocity.
I assume that the density decreases linearly at t=0 : n(z,0)=n[max]*(1-z/H) where H is the height of the container.
This gives the following system :
> sys := [diff(n(z, t), t)+(diff(n(z, t)*v(z,t), z)) = 0, n(z, 0) = k_1*(1-z/H)]
With a velocity of the form :
v(z,t) = (1/tau)(1/n(z,t)-1/n[max])
it works like a charm.
However, I would like to try a velocity of the form :
v(z,t) = v[max]*(1-(n(z,t)/n[max])^5)
(similar to Greenshield model).
pdsolve() raises an error when I try :
> sys := [diff(n(z, t), t)+k_2*(diff(n(z, t)*(1-(n(z, t)/k_1)^5), z)) = 0, n(z, 0) = k_2*(1-z/H)];
> pdsolve(sys);
"Error, (in pdsolve/BC/1st_order/_Fn/integrate) invalid input: op expects 1 or 2 arguments, but received 0"
op(sys) returns the expected result, so I guess the problem comes from the power.
Have you guys have any solution ?
Thanks a lot.
First 1411 1412 1413 1414 1415 1416 1417 Last Page 1413 of 2429
