I have a matrix then I need to plot its columns as curves on one plot.
I'm interested in doing some experimental mathematics using the PSLQ integer relation algorithm.  The only third-party program for doing PSLQ problems I've been able to find is a GNU C++ program with a less-than-user-friendly command-line interface.  I've heard that Maple implements PSLQ and I like the symbolic input and presentation it offers as a CAS, but I can't find any information on which alternative types of Maple 18 make the PSLQ algorithm available.
I am trying to plot several curves with values from matrix columns on one plot.
L1 := zip(`[]`, groups, waitArray[ .. , 1]);
L2 := zip(`[]`, groups, waitArray[ .. , 2]);
plot([L1, L2])
plot(L1) and plot(L2) work fine.
But for a joined plot I have an error
Error, (in plot) incorrect first argument [Array(1..3, {(1) = [5, HFloat(0.2889190508261187)], (2) = [10, HFloat(0.9017773091123074)], (3) = [20, HFloat(2.4000000155705576)]}), Array(1..3, {(1) = [5, HFloat(0.019538366928174924)], (2) = [10, HFloat(0.06875266075705706)], (3) = [20, HFloat(0.1884304855100058)]})]
f1 := expand((a1*x^2+b1*x+c1)^n);
f2 := a1*x^2+b1*x+c1;
solve([coeff(f1, x, 4) = coeff(f2, x, 4),
coeff(f1, x, 3) = coeff(f2, x, 3),
coeff(f1, x, 2) = coeff(f2, x, 2),
coeff(f1, x, 1) = coeff(f2, x, 1),
coeff(f1, x, 0) = coeff(f2, x, 0)], [a1,b1,c1,d1]);
hi,
i cant solve this
int(1/1-exp(a*x)*erfc(a*x))
Vector([a, b]);  <a, b>;  # Identical results
a:=[1, 2]:  b:=[3, 4]:
Vector([a, b]), <a, b>;   # Different results. Why?
I have a vector of lists, and each list is composed of indexed names.  For each list, I would like to assign all the indexed names in the list to the first variable of the list.  Right now, I'm trying to select the entries of the list using the op command and then assign one to the other, and get the following error:
Error, invalid left hand side in assignment
June_29.mw
how to convert decimal number into given decimal number like algebra
for example, convert 191.715 , given a=12.2, b=3.5
how to find this a^2 + b^3
Hello, I am a student typing up my homework assignments with maple, and I am takinng Inferential Statistics.  I can't figure out how to make the bar over a variable, so I can note the average.  It is just a line over a letter.  Kind of when notating a vector without the arrow.  It would be very helpful because I can't figure out how to make that symbol, it is not listed on the symbols list on the left side.
hi.i encountered this erroe  [Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system] with solving set of differential equation.please help me.thanks a lot
dsys3 := {`1`*h1(theta)+`1`*(diff(h1(theta), theta, theta))+`1`*(diff(h2(theta), theta))+`1`*(diff(h2(theta), theta, theta, theta))+`1`*h3(theta)+`1`*(diff(h3(theta), theta, theta))+`1`*(diff(h1(theta), theta, theta, theta, theta)) = 0, `1`*h2(theta)+`1`*(diff(h2(theta), theta, theta, theta, theta))+`1`*(diff(h2(theta), theta, theta))+`1`*(diff(h1(theta), theta))+`1`*(diff(h1(theta), theta, theta, theta))+`1`*(diff(h3(theta), theta))+`1`*(diff(h3(theta), theta, theta, theta)) = 0, h3(theta)^5*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h3(theta), theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h3(theta), theta, theta, theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h1(theta)*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h1(theta), theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h2(theta), theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h2(theta), theta, theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h3(theta)^4*(diff(h2(theta), theta, theta, theta, theta, theta, theta))*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)-beta*h3(theta)^3*`1`-chi*ln(h3(theta))^2*`1`/kappa-chi*`1`/kappa-2*chi*ln(h3(theta))*`1`/kappa = 0, h1(0) = 0, h1(1) = 0, h2(0) = 0, h2(1) = 0, h3(0) = 1, h3(1) = 1, ((D@@1)(h1))(0) = 0, ((D@@1)(h1))(1) = 0, ((D@@1)(h2))(0) = 0, ((D@@1)(h2))(1) = 0, ((D@@1)(h3))(0) = 0, ((D@@1)(h3))(1) = 0, ((D@@2)(h3))(0) = 0, ((D@@2)(h3))(1) = 0}; dsol5 := dsolve(dsys3, 'maxmesh' = 600, numeric, output = listprocedure);
Let be given the complex number z  satisfying condition abs(z+3-2I)=3. I want to find the set of points representing the complex number w, knowing that w - z = 1 +3I. I tried
Restart:
assume(a::real, b::real,x::real, y::real);
z:=x+y*I;
w:=a+b*I;
abs(w-1-3*I+3-2*I)=3;
Edit
Restart:
Set:=abs(z+3-2*I):
w:=x+y*I;
sol:=solve(w - z =1+3*I,{z});
z1:=subs(sol,Set);
A:=abs(z1);
map(x->x^2,A=3);
I do have some m files and they containing procedures where i am interested in
How can i read those procedures in a m file
Hi Maple friends. :)
I would like to graph and solve: 2*sin(2 x)=1 for the interval 0<=x<=360. My textbook gives the answers of x=15, 75, 195 and 225.
But I get an error messages:
plot(2*sin(2*x) = 1, x = 0 .. 360);
Error, invalid input: plot expects its 1st argument, p, to be of type {array, list, rtable, set, algebraic, procedure, And(`module`, appliable)}, but received 2*sin(2*x) = 1
solve(2*sin(2*x) = 1, x = 0 .. 360);
Error, invalid input: too many and/or wrong type of arguments passed to solve; first unused argument is x = 0 .. 360
Any help would be appreciated! Thanks in advance.
x: =Matrix([[a1,a2],[a3,a4]])
after some calculation,
assign(%)
a1 etc have value,
how to make a1,a2,a3,a4 back to variable in maple 12?
How to calculate floor(10^(10^(10^(10^(10^(-10^10))))))? My simpleminded try is
Error, numeric exception: underflow
PS. I think that is about 10^(10^10).
First 1408 1409 1410 1411 1412 1413 1414 Last Page 1410 of 2429
