Suppose (1 + 2x)^n = a0 + a1*x + a2*x^2+...+an*x^n.
I want to find value of n so that max(a0, a1, ..., an) is a8
I tried directly.
With n = 12
A:=expand((1+2*x)^12,x);
max(coeffs(A));
And with n = 11
B:=expand((1+2*x)^11,x);
max(coeffs(B));
Therefore,  n = 12 or  n = 11.
How can I solve the problem with Maple?
What is the command to get a sequence of the first twenty prime numbers
why system inconsistent
when only want to obtain a equation H
in terms of a1 , a3, b2, b3, c1, c2, x1, x2, lambda
pdsolve([
Diff(H(x1,x2,lambda), x1) = a1*x1 + a3*lambda,
Diff(H(x1,x2,lambda), x2) = b2*x2 + b3*lambda,
Diff(H(x1,x2,lambda), lambda) = c1*x1 + c2*x2
], H(x1,x2,lambda));
Hi all. I am using Maple 18.
1. Does Maple only output an answer, or can it be made to display the steps it took to achieve the result, in a way that is logical and understandable by the user? For example, I would like to see it display steps when integrating or differentiating, or dividing a polynomial by another polynomial. Basically any process that involve simplifyinf or factorisation.
2. I am trying to divide x^2 + 5x + 9 by x+2, but all Maple displays is the expression
How can I make it do the polynomial division and output the steps it took? I tried using simplify and evaluate from the context menu but the output is still just the expression.
3. Has something happened to this site? It was working fine in Opera until two days ago, and has sinmce started displaying "Error generating page" where the replies to questions should be. No problems with the "posts" section, only in the "questions" section.
Is there a document with all elementairy plottools commands to find?
i must construct a numberline and lines to e4xplain with a arrow and text under it.
with(Finance):
with(Statistics):
X:=RandomVariable(Binomial(nn, pp));
Drift(X);
How to listplot two vectors on the same graph?
That means having two lines.
f1 := -2*x1 - x2;
f2 := -x1 - 4*x2;
g1 := 2*x1 + 3*x2 - 6;
g2 := -x1;
g3 := -x2;
penalty := lambda1*Max(f1-M,0)+lambda2*Max(f2-M,0)+(M^2)*(max(g1,0) + max(g2,0) + max(g3,0));
M := 1;
k := 1;
s := 1;
lambda1 := 0.5;
lambda2 := 0.5;
with(Optimization):
Minimize(subs(lambda2=0.5, subs(lambda1=0.5, subs(M=1, penalty))));
correct answer for these parameters should be below, however, Minimize got error
when lambda1 = 0.5, lambda2 = 0.5
(x1, x2) = 1.551123, 0.965918
f(x1, x2) = (–4.068164, –5.414795);
want to export to excel to file from matrix
Error, (in FindLambda) invalid input: `convert/Array` expects its 1st argument, A, to be of type {Array, Matrix, Vector, array, list, listlist}, but received csvfile
csvfile = Matrix(30,7);
print(close3(t+i), rhs(Sol5[1][1]), ratioA, oddsratio, oddsratioSimUp, oddsratioSimDown,1);
csvfile[i+1,1] := close3(t+i);
csvfile[i+1,2] := rhs(Sol5[1][1]);
csvfile[i+1,3] := ratioA;
csvfile[i+1,4] := oddsratio;
csvfile[i+1,5] := oddsratioSimUp;
csvfile[i+1,6] := oddsratioSimDown;
csvfile[i+1,7] := 1;
29.95, 0.03355620525, 0.7651906074, 0.6000000000, 0.5294117647,
0.5714285714, 0
-8
29.95, 0.03361194645, 1.750709592 10 , 0.4444444444,
0.5000000000, 0.6000000000, 0
5
29.6, 0.03432592221, 1.013882143 10 , 0.6000000000, 0.4444444444,
0.6923076923, 1
29.55, 0.03447081290, -0.000009845029875, 0.7142857143,
0.6000000000, 0.5000000000, 0
29.8, 0.03403562903, 30660.46200, 0.5294117647, 0.4117647059,
0.7142857143, 0
30.4, 0.03327345914, -0.5761838946, 0.6000000000, 0.5714285714,
0.5294117647, 0
30.3, 0.03376575281, 6.256895964, 0.5000000000, 0.6000000000,
0.5000000000, 0
30.95, 0.03231017771, 0.5328449644, 0.6000000000, 0.6000000000,
0.5000000000, 0
31.1, 0.03104289658, -26.93771895, 0.5000000000, 0.5000000000,
0.6000000000, 0
29.2, 0.03366016138, -0.08555779615, 0.4444444444, 0.5000000000,
0.6000000000, 0
28.95, 0.03415453360, 0.4007940838, 0.6000000000, 0.4444444444,
0.6923076923, 0
28.3, 0.03605364033, 0.00001875789432, 0.3750000000,
28.75, 0.03523629490, 0.9740829247, 0.4117647059, 0.7333333333,
0.3750000000, 1
5
29.2, 0.03415861325, -6.244828641 10 , 0.6000000000,
0.7142857143, 0.4117647059, 1
28.8, 0.03514419367, -0.1430744128, 0.06666666667, 0.6000000000,
0.5000000000, 0
29.4, 0.03352191217, 0.1495513336, 0.5000000000, 1.000000000,
0.06666666667, 0
28.95, 0.03433350933, 2.034565984, 0.5000000000, 0.5000000000,
0.6000000000, 0
28.85, 0.03394117064, 16.52857996, 0.7142857143, 0.5000000000,
0.6000000000, 0
28.5, 0.03419513697, -67.32086106, 0.6000000000, 0.7142857143,
0.4117647059, 0
-8
27.05, 0.03748108008, -3.316856585 10 , 0.6000000000,
27.7, 0.03561234996, 0.9992012832, 0.5000000000, 0.5000000000,
0.6000000000, 1
7
27.25, 0.03636057571, -1.891574002 10 , 0.5000000000,
0.5000000000, 0.6000000000, 1
27.0, 0.03696844993, 1.002386970, 0.03225806452, 0.5000000000,
0.6000000000, 0
-8
26.85, 0.03745201461, -5.221638895 10 , 1.000000000,
0.03225806452, 0, 0
26.85, 0.03734798123, 1.050118943, 0.5000000000, 0.06666666667,
1.000000000, 1
I have some data for a model in MapleSim that I would like to use a time look up table with.  I've found that the two options for interpolation are linear and 1st derivative, but the data was intended to be interpretted as piecewise constant.  Is there any way to acheive this option in MapleSim?
Hi everybody,
I'm an mechanical enginer and I have to solve numerically this kind of differential equation : m(d2z/dt2)+c(dz/dt) + k*z = F where z is the displacement.
The best resolution for this problem is to use a Newmark method (which is available here at page 10 http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0CEEQFjAE&url=http%3A%2F%2Fpole-modelisation.univ-bpclermont.fr%2Fcisssi%2Findex.php%3Foption%3Dcom_docman%26task%3Ddoc_download%26gid%3D110%26Itemid%3D51&ei=8seqU5-wEaS00wXm14G4CA&usg=AFQjCNFerFoQ4O-nrIdOoUiX7SIkLMb6sA&sig2=MZ6BxmUPm7Gg3CGcH4nknQ&bvm=bv.69620078,d.d2k)
So I have written this method in Maple but nothing happen and I don't where the mistakes are. So if somebody could help me, that will be great.
My code is :
I tried to import the modelica library Buildings1.6 from the modelica website and get always the error "Nothing found in the modelica library".
Is it possible to import modelica libraries?
Thank you very much
in maple 12 or 15
assume
result := Vector(10);
for i from 1 to 10 do
        result[i] := i;
od;
how to plot it against i?
after tried plot(result(x), x=1..10);
1. How can I make maple NOT plot discontinuties with a vertical line? For example, plotting y=tan(x) displays vertical lines. Is there a setting to turn this off permanently?
2. When I type y=sin(x-Pi/2) and press enter, y = -cos(x) is displayed in blue. I am sure they are both the same thing, but I would like to see the expression that I typed, not an alternate expression that Maple wants to display.
3. Why do some expressions require a ; at the end, whilst others don't? Ie. y = sin(x) and y = 1+sin(x) do not, but y=2*sin(x) results in a "Warning, inserted missing semicolon at end of statement"
4. Is there a section on Mapleprimes(this site) where new users can ask questions? I would like to browse it to see what sort of problems other new Maples users have encountered. I am sure that my above questions may have been asked a few times over the years by newbies like myself.
Thanks in advance. :)
hi maple-friends !
for my work i have to solve a system of differential equations numerically - no problem with maple :-)
my problem: how can i get the resulting data of the numeric solutions in a file ?
(for example to use them with gnuplot)
what i have to do exactly ? i know just about writedata and readdata commands...
can anyone send me an example with a few comments ?
greetings,  kreso
First 1410 1411 1412 1413 1414 1415 1416 Last Page 1412 of 2429
