convert(50, base, 12);
this can change base for integer, however can not change decimal
assume i change decimal to fraction first and then apply convert base to 12 to numer and denom, and divide again to get decimal
it may get a decimal based on base 12
however, how to make this base 12 operation apply in linear algebra calculation
Hi All
Assume that we have:
and the hybrid function with block pulses with the following form:
if we want to introduce this form to maple so that we can do:
then how can we do this????
especially if we want to approximate t or t^2 or sin(3*t) by mentioned form, how maple can help us?
thanks a lot for coming answers
Mahmood   Dadkhah
Ph.D Candidate
if not using
EigenvectorSol := simplify(solve({seq(seq((NewMatrix3 . NewInput3(1..-1,i))[j]=(v[i]* NewInput3(1..-1,i))[j], j=1..3), i=1..3)}, {seq(x||i, i=1..9)}));
and if want to see clearly the steps about how to solve for eignvector, how to do?
because i use solve, it has error
InputMatrix3 := Matrix([[31.25,30.8,30.5],[30.8,30.5,0],[30.5,0,0]]);
NewInput3 := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
FirstEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[1]; # find back eigenvalue from eigenvector
SecondEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[2]; # find back eigenvalue from eigenvector
ThirdEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[3]; # find back eigenvalue from eigenvector
v:=[ FirstEigenValue, SecondEigenValue, ThirdEigenValue];
NewMatrix3 := Matrix([[x1,x2,x3], [x4,x5,x6], [x7,x8,x9]]);
EigenvectorT := Matrix([[rhs(EigenvectorSol[1]), rhs(EigenvectorSol[2]), rhs(EigenvectorSol[3])],[ rhs(EigenvectorSol[4]), rhs(EigenvectorSol[5]), rhs(EigenvectorSol[6])],[ rhs(EigenvectorSol[7]), rhs(EigenvectorSol[8]), rhs(EigenvectorSol[9])]]);
Old_Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3));
sys1:=MatrixMatrixMultiply(NewInput3-Matrix([[FirstEigenValue, 0, 0], [0, FirstEigenValue, 0], [0, 0, FirstEigenValue]]),Matrix([[x],[y],[z]]));
sys1a := NewInput3-Matrix([[FirstEigenValue, 0, 0], [0, FirstEigenValue, 0], [0, 0, FirstEigenValue]]);
fsolve({sys1[1][1]=0,sys1[2][1]=0,sys1[3][1]=0}, {x,y,z});
solve([sys1[1][1]=0,sys1[2][1]=0,sys1[3][1]=0], [x,y,z]);
solve([sys1[1]=0,sys1[2]=0,sys1[3]=0], [x,y,z]);
> solve([sys1[1] = 0, sys1[2] = 0, sys1[3] = 0], [x, y, z]);
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({set, list})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received [(Vector[row](1, {(1) = HFloat(2571.1332294000003)*x+HFloat(1901.9)*y+HFloat(953.125)*z})) = 0, (Vector[row](1, {(1) = HFloat(1901.9)*x+HFloat(1594.5707294000001)*y+HFloat(939.4)*z})) = 0, (Vector[row](1, {(1) = HFloat(953.125)*x+HFloat(939.4)*y+HFloat(645.9307294)*z})) = 0]
v1 := <sys1a[1,1] | sys1a[1,2] | sys1a[1,3]>;
v2 := <sys1a[2,1] | sys1a[2,2] | sys1a[2,3]>;
v3 := <sys1a[3,1] | sys1a[3,2] | sys1a[3,3]>;
v1 := <sys1a[1,1] | sys1a[2,1] | sys1a[3,1]>;
v2 := <sys1a[1,2] | sys1a[2,2] | sys1a[3,2]>;
v3 := <sys1a[1,3] | sys1a[2,3] | sys1a[3,3]>;
eigenvector1 := Basis([v1, v2, v2]);
eliminate({sys1[1][1]=0,sys1[2][1]=0,sys1[3][1]=0},{x,y,z});
eliminate({sys1[1][1]=0,sys1[1][2]=0,sys1[1][3]=0},{x,y,z});
sys1:=MatrixMatrixMultiply(NewInput3-Matrix([[SecondEigenValue, 0, 0], [0, SecondEigenValue, 0], [0, 0, SecondEigenValue]]),Matrix([[x],[y],[z]]));
sys1:=MatrixMatrixMultiply(NewInput3-Matrix([[ThirdEigenValue, 0, 0], [0, ThirdEigenValue, 0], [0, 0, ThirdEigenValue]]),Matrix([[x],[y],[z]]));
This is probably a silly question, but I am trying to compare the difference between two variables in the numerical solution of a system of ODEs. Ideally, I would like a method to find the maximal difference that occurs between two variables.
The following is a highly simplified example of what I'm talking about. In this case I'd like some means to find the timepoint and magnitude of the maximal difference between y2(t) and y3(t) for t>0, which from the plot can be seen to occur at about 1.75 seconds. Note: I realise this particular case admits an analytic solution of y3(t) which could be exploited, but in the general case I'm interested in that won't be true.
Thanks in advance for any help you can provide.
Sys := {diff(y1(t), t) = y1(t)^2-4*y1(t)+y2(t)*y1(t)-y2(t)+1, diff(y2(t), t) = y1(t), diff(y3(t), t) = -y3(t)+1, y1(0) = 0, y2(0) = 0, y3(0) = 0}
Sol := dsolve(Sys, numeric)
proc (x_rkf45) local _res, _dat, _vars, _solnproc, _xout, _ndsol, _pars, _n, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x_rkf45) else _xout := evalf(x_rkf45) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _dtbl, _dat, _vmap, _x0, _y0, _val, _dig, _n, _ne, _nd, _nv, _pars, _ini, _par, _i, _j, _k, _src; option `Copyright (c) 2002 by Waterloo Maple Inc. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _pars := []; _dtbl := array( 1 .. 4, [( 1 ) = (array( 1 .. 19, [( 1 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 2 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 3 ) = ([0, 0, 0, Array(1..0, 1..2, {}, datatype = float[8], order = C_order)]), ( 4 ) = (Array(1..49, {(1) = 3, (2) = 3, (3) = 0, (4) = 0, (5) = 0, (6) = 0, (7) = 1, (8) = 0, (9) = 0, (10) = 0, (11) = 0, (12) = 0, (13) = 0, (14) = 0, (15) = 0, (16) = 0, (17) = 0, (18) = 1, (19) = 30000, (20) = 0, (21) = 0, (22) = 1, (23) = 4, (24) = 0, (25) = 1, (26) = 15, (27) = 1, (28) = 0, (29) = 1, (30) = 3, (31) = 3, (32) = 0, (33) = 1, (34) = 0, (35) = 0, (36) = 0, (37) = 0, (38) = 0, (39) = 0, (40) = 0, (41) = 0, (42) = 0, (43) = 1, (44) = 0, (45) = 0, (46) = 0, (47) = 0, (48) = 0, (49) = 0}, datatype = integer[8])), ( 5 ) = (Array(1..25, {(1) = .0, (2) = 0.10e-5, (3) = .0, (4) = 0.500001e-14, (5) = .0, (6) = 0.5047658755841546e-2, (7) = .0, (8) = 0.10e-5, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = 1.0, (14) = .0, (15) = .5, (16) = .0, (17) = 1.0, (18) = 1.0, (19) = .0, (20) = .0, (21) = 1.0, (22) = 1.0, (23) = .0, (24) = .0, (25) = .0}, datatype = float[8], order = C_order)), ( 6 ) = (Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order)), ( 7 ) = ([Array(1..4, 1..7, {(1, 1) = .0, (1, 2) = .203125, (1, 3) = .3046875, (1, 4) = .75, (1, 5) = .8125, (1, 6) = .40625, (1, 7) = .8125, (2, 1) = 0.6378173828125e-1, (2, 2) = .0, (2, 3) = .279296875, (2, 4) = .27237892150878906, (2, 5) = -0.9686851501464844e-1, (2, 6) = 0.1956939697265625e-1, (2, 7) = .5381584167480469, (3, 1) = 0.31890869140625e-1, (3, 2) = .0, (3, 3) = -.34375, (3, 4) = -.335235595703125, (3, 5) = .2296142578125, (3, 6) = .41748046875, (3, 7) = 11.480712890625, (4, 1) = 0.9710520505905151e-1, (4, 2) = .0, (4, 3) = .40350341796875, (4, 4) = 0.20297467708587646e-1, (4, 5) = -0.6054282188415527e-2, (4, 6) = -0.4770040512084961e-1, (4, 7) = .77858567237854}, datatype = float[8], order = C_order), Array(1..6, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = 1.0, (2, 1) = .25, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = 1.0, (3, 1) = .1875, (3, 2) = .5625, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = 2.0, (4, 1) = .23583984375, (4, 2) = -.87890625, (4, 3) = .890625, (4, 4) = .0, (4, 5) = .0, (4, 6) = .2681884765625, (5, 1) = .1272735595703125, (5, 2) = -.5009765625, (5, 3) = .44921875, (5, 4) = -0.128936767578125e-1, (5, 5) = .0, (5, 6) = 0.626220703125e-1, (6, 1) = -0.927734375e-1, (6, 2) = .626220703125, (6, 3) = -.4326171875, (6, 4) = .1418304443359375, (6, 5) = -0.861053466796875e-1, (6, 6) = .3131103515625}, datatype = float[8], order = C_order), Array(1..6, {(1) = .0, (2) = .386, (3) = .21, (4) = .63, (5) = 1.0, (6) = 1.0}, datatype = float[8], order = C_order), Array(1..6, {(1) = .25, (2) = -.1043, (3) = .1035, (4) = -0.362e-1, (5) = .0, (6) = .0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 1.544, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = .9466785280815533, (3, 2) = .25570116989825814, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = 3.3148251870684886, (4, 2) = 2.896124015972123, (4, 3) = .9986419139977808, (4, 4) = .0, (4, 5) = .0, (5, 1) = 1.2212245092262748, (5, 2) = 6.019134481287752, (5, 3) = 12.537083329320874, (5, 4) = -.687886036105895, (5, 5) = .0, (6, 1) = 1.2212245092262748, (6, 2) = 6.019134481287752, (6, 3) = 12.537083329320874, (6, 4) = -.687886036105895, (6, 5) = 1.0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = -5.6688, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = -2.4300933568337584, (3, 2) = -.20635991570891224, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = -.10735290581452621, (4, 2) = -9.594562251021896, (4, 3) = -20.470286148096154, (4, 4) = .0, (4, 5) = .0, (5, 1) = 7.496443313968615, (5, 2) = -10.246804314641219, (5, 3) = -33.99990352819906, (5, 4) = 11.708908932061595, (5, 5) = .0, (6, 1) = 8.083246795922411, (6, 2) = -7.981132988062785, (6, 3) = -31.52159432874373, (6, 4) = 16.319305431231363, (6, 5) = -6.0588182388340535}, datatype = float[8], order = C_order), Array(1..3, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 10.126235083446911, (2, 2) = -7.487995877607633, (2, 3) = -34.800918615557414, (2, 4) = -7.9927717075687275, (2, 5) = 1.0251377232956207, (3, 1) = -.6762803392806898, (3, 2) = 6.087714651678606, (3, 3) = 16.43084320892463, (3, 4) = 24.767225114183653, (3, 5) = -6.5943891257167815}, datatype = float[8], order = C_order)]), ( 8 ) = ([Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = 1.0, (2) = .0, (3) = 1.0}, datatype = float[8], order = C_order)]), ( 9 ) = ([Array(1..3, {(1) = .1, (2) = .1, (3) = .1}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, 1..3, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0}, datatype = float[8], order = C_order), Array(1..3, 1..3, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0}, datatype = float[8], order = C_order), Array(1..3, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = 0, (2) = 0, (3) = 0}, datatype = integer[8]), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order), Array(1..3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8], order = C_order)]), ( 10 ) = ([proc (N, X, Y, YP) option `[Y[1] = y1(t), Y[2] = y2(t), Y[3] = y3(t)]`; YP[1] := Y[1]^2-4*Y[1]+Y[2]*Y[1]-Y[2]+1; YP[3] := -Y[3]+1; YP[2] := Y[1]; 0 end proc, -1, 0, 0, 0, 0]), ( 11 ) = (Array(1..6, 0..3, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (2, 0) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (3, 0) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (4, 0) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (5, 0) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (6, 0) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0}, datatype = float[8], order = C_order)), ( 12 ) = (), ( 13 ) = (), ( 14 ) = ([0, 0]), ( 15 ) = ("rkf45"), ( 17 ) = ([proc (N, X, Y, YP) option `[Y[1] = y1(t), Y[2] = y2(t), Y[3] = y3(t)]`; YP[1] := Y[1]^2-4*Y[1]+Y[2]*Y[1]-Y[2]+1; YP[3] := -Y[3]+1; YP[2] := Y[1]; 0 end proc, -1, 0, 0, 0, 0]), ( 16 ) = ([0, 0, 0, []]), ( 19 ) = (0), ( 18 ) = ([])  ] ))  ] ); _y0 := Array(0..3, {(1) = 0., (2) = 0., (3) = 0.}); _vmap := array( 1 .. 3, [( 1 ) = (1), ( 2 ) = (2), ( 3 ) = (3)  ] ); _x0 := _dtbl[1][5][5]; _n := _dtbl[1][4][1]; _ne := _dtbl[1][4][3]; _nd := _dtbl[1][4][4]; _nv := _dtbl[1][4][16]; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then if _Env_smart_dsolve_numeric = true or _dtbl[1][4][10] = 1 then if _xout = "left" then if type(_dtbl[2], 'table') then return _dtbl[2][5][1] end if elif _xout = "right" then if type(_dtbl[3], 'table') then return _dtbl[3][5][1] end if end if end if; return _dtbl[1][5][5] elif _xout = "method" then return _dtbl[1][15] elif _xout = "storage" then return evalb(_dtbl[1][4][10] = 1) elif _xout = "leftdata" then if not type(_dtbl[2], 'array') then return NULL else return eval(_dtbl[2]) end if elif _xout = "rightdata" then if not type(_dtbl[3], 'array') then return NULL else return eval(_dtbl[3]) end if elif _xout = "enginedata" then return eval(_dtbl[1]) elif _xout = "enginereset" then _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); return NULL elif _xout = "initial" then return procname(_y0[0]) elif _xout = "laxtol" then return _dtbl[`if`(member(_dtbl[4], {2, 3}), _dtbl[4], 1)][5][18] elif _xout = "numfun" then return `if`(member(_dtbl[4], {2, 3}), _dtbl[_dtbl[4]][4][18], 0) elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return procname(_y0[0]), [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _dtbl[4] <> 2 and _dtbl[4] <> 3 or _x0-_dtbl[_dtbl[4]][5][1] = 0. then error "no information is available on last computed point" else _xout := _dtbl[_dtbl[4]][5][1] end if elif _xout = "function" then if _dtbl[1][4][33]-2. = 0 then return eval(_dtbl[1][10], 1) else return eval(_dtbl[1][10][1], 1) end if elif _xout = "map" then return copy(_vmap) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _y0) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n-_ne, _ini, _y0, _pars, _vmap) end if; `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars); if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') and _dtbl[1][4][10] <> 1 then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)] elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] else return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)], [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] end if elif _xin = "eventstop" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then return 0 end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 10 and 10 <= _dtbl[5-_i][4][9] then _i := 5-_i; _dtbl[4] := _i; _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) elif 10 <= _dtbl[_i][4][9] then _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) else return 0 end if elif _xin = "eventstatus" then if _nv = 0 then error "this solution has no events" end if; _i := [selectremove(proc (a) options operator, arrow; _dtbl[1][3][1][a, 7] = 1 end proc, {seq(_j, _j = 1 .. round(_dtbl[1][3][1][_nv+1, 1]))})]; return ':-enabled' = _i[1], ':-disabled' = _i[2] elif _xin = "eventclear" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then error "no events to clear" end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 10 and 10 < _dtbl[5-_i][4][9] then _dtbl[4] := 5-_i; _i := 5-_i end if; if _dtbl[_i][4][9] < 10 then error "no events to clear" elif _nv < _dtbl[_i][4][9]-10 then error "event error condition cannot be cleared" else _j := _dtbl[_i][4][9]-10; if irem(round(_dtbl[_i][3][1][_j, 4]), 2) = 1 then error "retriggerable events cannot be cleared" end if; _j := round(_dtbl[_i][3][1][_j, 1]); for _k to _nv do if _dtbl[_i][3][1][_k, 1] = _j then if _dtbl[_i][3][1][_k, 2] = 3 then error "range events cannot be cleared" end if; _dtbl[_i][3][1][_k, 8] := _dtbl[_i][3][1][_nv+1, 8] end if end do; _dtbl[_i][4][17] := 0; _dtbl[_i][4][9] := 0; if _dtbl[1][4][10] = 1 then if _i = 2 then try procname(procname("left")) catch:  end try else try procname(procname("right")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and member(lhs(_xin), {"eventdisable", "eventenable"}) then if _nv = 0 then error "this solution has no events" end if; if type(rhs(_xin), {('list')('posint'), ('set')('posint')}) then _i := {op(rhs(_xin))} elif type(rhs(_xin), 'posint') then _i := {rhs(_xin)} else error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; if select(proc (a) options operator, arrow; _nv < a end proc, _i) <> {} then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _k := {}; for _j to _nv do if member(round(_dtbl[1][3][1][_j, 1]), _i) then _k := `union`(_k, {_j}) end if end do; _i := _k; if lhs(_xin) = "eventdisable" then _dtbl[4] := 0; _j := [evalb(assigned(_dtbl[2]) and member(_dtbl[2][4][17], _i)), evalb(assigned(_dtbl[3]) and member(_dtbl[3][4][17], _i))]; for _k in _i do _dtbl[1][3][1][_k, 7] := 0; if assigned(_dtbl[2]) then _dtbl[2][3][1][_k, 7] := 0 end if; if assigned(_dtbl[3]) then _dtbl[3][3][1][_k, 7] := 0 end if end do; if _j[1] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[2][3][4][_k, 1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to defined init `, _dtbl[2][3][4][_k, 1]); _dtbl[2][3][1][_k, 8] := _dtbl[2][3][4][_k, 1] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to rate hysteresis init `, _dtbl[2][5][24]); _dtbl[2][3][1][_k, 8] := _dtbl[2][5][24] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to initial init `, _x0); _dtbl[2][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to fireinitial init `, _x0-1); _dtbl[2][3][1][_k, 8] := _x0-1 end if end do; _dtbl[2][4][17] := 0; _dtbl[2][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("left")) end if end if; if _j[2] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[3][3][4][_k, 2], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to defined init `, _dtbl[3][3][4][_k, 2]); _dtbl[3][3][1][_k, 8] := _dtbl[3][3][4][_k, 2] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to rate hysteresis init `, _dtbl[3][5][24]); _dtbl[3][3][1][_k, 8] := _dtbl[3][5][24] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to initial init `, _x0); _dtbl[3][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to fireinitial init `, _x0+1); _dtbl[3][3][1][_k, 8] := _x0+1 end if end do; _dtbl[3][4][17] := 0; _dtbl[3][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("right")) end if end if else for _k in _i do _dtbl[1][3][1][_k, 7] := 1 end do; _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); _dtbl[4] := 0; if _dtbl[1][4][10] = 1 then if _x0 <= procname("right") then try procname(procname("right")) catch:  end try end if; if procname("left") <= _x0 then try procname(procname("left")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and lhs(_xin) = "eventfired" then if not type(rhs(_xin), 'list') then error "'eventfired' must be specified as a list" end if; if _nv = 0 then error "this solution has no events" end if; if _dtbl[4] <> 2 and _dtbl[4] <> 3 then error "'direction' must be set prior to calling/setting 'eventfired'" end if; _i := _dtbl[4]; _val := NULL; if not assigned(_EnvEventRetriggerWarned) then _EnvEventRetriggerWarned := false end if; for _k in rhs(_xin) do if type(_k, 'integer') then _src := _k elif type(_k, 'integer' = 'anything') and type(evalf(rhs(_k)), 'numeric') then _k := lhs(_k) = evalf[max(Digits, 18)](rhs(_k)); _src := lhs(_k) else error "'eventfired' entry is not valid: %1", _k end if; if _src < 1 or round(_dtbl[1][3][1][_nv+1, 1]) < _src then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _src := {seq(`if`(_dtbl[1][3][1][_j, 1]-_src = 0., _j, NULL), _j = 1 .. _nv)}; if nops(_src) <> 1 then error "'eventfired' can only be set/queried for root-finding events and time/interval events" end if; _src := _src[1]; if _dtbl[1][3][1][_src, 2] <> 0. and _dtbl[1][3][1][_src, 2]-2. <> 0. then error "'eventfired' can only be set/queried for root-finding events and time/interval events" elif irem(round(_dtbl[1][3][1][_src, 4]), 2) = 1 then if _EnvEventRetriggerWarned = false then WARNING(`'eventfired' has no effect on events that retrigger`) end if; _EnvEventRetriggerWarned := true end if; if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then _val := _val, undefined elif type(_dtbl[_i][3][4][_src, _i-1], 'undefined') or _i = 2 and _dtbl[2][3][1][_src, 8] < _dtbl[2][3][4][_src, 1] or _i = 3 and _dtbl[3][3][4][_src, 2] < _dtbl[3][3][1][_src, 8] then _val := _val, _dtbl[_i][3][1][_src, 8] else _val := _val, _dtbl[_i][3][4][_src, _i-1] end if; if type(_k, `=`) then if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then error "cannot set event code for a rate hysteresis event" end if; userinfo(3, {'events', 'eventreset'}, `manual set event code `, _src, ` to value `, rhs(_k)); _dtbl[_i][3][1][_src, 8] := rhs(_k); _dtbl[_i][3][4][_src, _i-1] := rhs(_k) end if end do; return [_val] elif type(_xin, `=`) and lhs(_xin) = "direction" then if not member(rhs(_xin), {-1, 1, ':-left', ':-right'}) then error "'direction' must be specified as either '1' or 'right' (positive) or '-1' or 'left' (negative)" end if; _src := `if`(_dtbl[4] = 2, -1, `if`(_dtbl[4] = 3, 1, undefined)); _i := `if`(member(rhs(_xin), {1, ':-right'}), 3, 2); _dtbl[4] := _i; _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if; return _src elif _xin = "eventcount" then if _dtbl[1][3][1] = 0 or _dtbl[4] <> 2 and _dtbl[4] <> 3 then return 0 else return round(_dtbl[_dtbl[4]][3][1][_nv+1, 12]) end if else return "procname" end if end if; if _xout = _x0 then return [_x0, seq(evalf(_dtbl[1][6][_vmap[_i]]), _i = 1 .. _n-_ne)] end if; _i := `if`(_x0 <= _xout, 3, 2); if _xin = "last" and 0 < _dtbl[_i][4][9] and _dtbl[_i][4][9] < 10 then _dat := eval(_dtbl[_i], 2); _j := _dat[4][20]; return [_dat[11][_j, 0], seq(_dat[11][_j, _vmap[_i]], _i = 1 .. _n-_ne-_nd), seq(_dat[8][1][_vmap[_i]], _i = _n-_ne-_nd+1 .. _n-_ne)] end if; if not type(_dtbl[_i], 'array') then _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if end if; if _xin <> "last" then if 0 < 0 then if `dsolve/numeric/checkglobals`(op(_dtbl[1][14]), _pars, _n, _y0) then `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars, _i) end if end if; if _dtbl[1][4][7] = 0 then error "parameters must be initialized before solution can be computed" end if end if; _dat := eval(_dtbl[_i], 2); _dtbl[4] := _i; try _src := `dsolve/numeric/SC/IVPrun`(_dat, _xout) catch: userinfo(2, `dsolve/debug`, print(`Exception in solnproc:`, [lastexception][2 .. -1])); error  end try; if _src = 0 and 10 < _dat[4][9] then _val := _dat[3][1][_nv+1, 8] else _val := _dat[11][_dat[4][20], 0] end if; if _src <> 0 or _dat[4][9] <= 0 then _dtbl[1][5][1] := _xout else _dtbl[1][5][1] := _val end if; if _i = 3 and _val < _xout then Rounding := -infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further right of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further right of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further right of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further right of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif 10 < _dat[4][9] then if _dat[4][9]-10 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further right of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-10, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further right of %1", evalf[8](_val) end if elif _i = 2 and _xout < _val then Rounding := infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further left of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further left of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further left of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further left of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif 10 < _dat[4][9] then if _dat[4][9]-10 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further left of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-10, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further left of %1", evalf[8](_val) end if end if; if _EnvInFsolve = true then _dig := _dat[4][26]; _dat[4][26] := _EnvDSNumericSaveDigits; _Env_dsolve_SC_native := true; if _dat[4][25] = 1 then _i := 1; _dat[4][25] := 2 else _i := _dat[4][25] end if; _val := `dsolve/numeric/SC/IVPval`(_dat, _xout, _src); _dat[4][25] := _i; _dat[4][26] := _dig; [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] else Digits := _dat[4][26]; _val := `dsolve/numeric/SC/IVPval`(eval(_dat, 2), _xout, _src); [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] end if end proc, (2) = Array(0..0, {}), (3) = [t, y1(t), y2(t), y3(t)], (4) = []}); _vars := _dat[3]; _pars := map(rhs, _dat[4]); _n := nops(_vars)-1; _solnproc := _dat[1]; if not type(_xout, 'numeric') then if member(x_rkf45, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x_rkf45, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x_rkf45, ["last", 'last', "initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x_rkf45, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x_rkf45), 'string') = rhs(x_rkf45); if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else error "initial and/or parameter values must be specified in a list" end if; if lhs(_xout) = "initial" then return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x_rkf45), 'string') = rhs(x_rkf45)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _vars end if; if procname <> unknown then return ('procname')(x_rkf45) else _ndsol; _ndsol := pointto(_dat[2][0]); return ('_ndsol')(x_rkf45) end if end if; try _res := _solnproc(_xout); [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] catch: error  end try end proc
odeplot(Sol, [t, abs(y2(t)-y3(t))], t = 0 .. 10)
Download DsolveSolCompare.mw
I am having trouble with the SubstitutionTensor command.  It kicks out an error message for operand with different free indices, but the operands seems to be fine.  I checked all of the terms and they all seem fine. Thank you for your help.
with(Physics):
Setup(mathematicalnotation = true, coordinatesystems = X, usephysicsevaluator = false)
[coordinatesystems = {X}, mathematicalnotation = true, usephysicsevaluator = false]
Define(l[mu]);
{Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-d_[mu], eta[mu, nu], Physics:-g_[mu, nu], l[mu], Physics:-KroneckerDelta[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
Define(G[mu, nu] = eta[mu, nu]+Physics:-`*`(l[mu](X), l[nu](X)))
{Physics:-Dgamma[mu], G[mu, nu], Physics:-Psigma[mu], Physics:-d_[mu], eta[mu, nu], Physics:-g_[mu, nu], l[mu], Physics:-KroneckerDelta[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
declare(l(X))
l(x1, x2, x3, x4)*`will now be displayed as`*l
Setup(metric = rhs(G[]))
[metric = {(1, 1) = 1+l[1](X)^2, (1, 2) = l[1](X)*l[2](X), (1, 3) = l[1](X)*l[3](X), (1, 4) = l[1](X)*l[4](X), (2, 2) = 1+l[2](X)^2, (2, 3) = l[2](X)*l[3](X), (2, 4) = l[2](X)*l[4](X), (3, 3) = 1+l[3](X)^2, (3, 4) = l[3](X)*l[4](X), (4, 4) = -1+l[4](X)^2}]
g_[];
g[mu, nu] = (Matrix(4, 4, {(1, 1) = 1+l[1](X)^2, (1, 2) = l[1](X)*l[2](X), (1, 3) = l[1](X)*l[3](X), (1, 4) = l[1](X)*l[4](X), (2, 1) = l[1](X)*l[2](X), (2, 2) = 1+l[2](X)^2, (2, 3) = l[2](X)*l[3](X), (2, 4) = l[2](X)*l[4](X), (3, 1) = l[1](X)*l[3](X), (3, 2) = l[2](X)*l[3](X), (3, 3) = 1+l[3](X)^2, (3, 4) = l[3](X)*l[4](X), (4, 1) = l[1](X)*l[4](X), (4, 2) = l[2](X)*l[4](X), (4, 3) = l[3](X)*l[4](X), (4, 4) = -1+l[4](X)^2}))
Christoffel[`~alpha`, mu, nu] = convert(Christoffel[`~alpha`, mu, nu], g_)
Physics:-Christoffel[`~alpha`, mu, nu] = (1/2)*Physics:-g_[`~alpha`, `~beta`]*(Physics:-d_[nu](Physics:-g_[beta, mu], [X])+Physics:-d_[mu](Physics:-g_[beta, nu], [X])-Physics:-d_[beta](Physics:-g_[mu, nu], [X]))
Christoffel[beta, mu, nu] = convert(Christoffel[beta, mu, nu], g_)
Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](Physics:-g_[beta, mu], [X])+(1/2)*Physics:-d_[mu](Physics:-g_[beta, nu], [X])-(1/2)*Physics:-d_[beta](Physics:-g_[mu, nu], [X])
SubstituteTensor(g_[mu, nu] = eta[mu, nu]+Physics:-`*`(l[mu](X), l[nu](X)), Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](Physics:-g_[beta, mu], [X])+(1/2)*Physics:-d_[mu](Physics:-g_[beta, nu], [X])-(1/2)*Physics:-d_[beta](Physics:-g_[mu, nu], [X]), evaluateexpression)
Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])-(1/2)*Physics:-d_[beta](l[mu](X), [X])*l[nu](X)-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])
Christoffel[`~alpha`, mu, nu] = Simplify(Physics:-`*`(eta[`~alpha`, `~beta`]-Physics:-`*`(l[`~alpha`](X), l[`~beta`](X)), rhs(Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])-(1/2)*Physics:-d_[beta](l[mu](X), [X])*l[nu](X)-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X]))))
Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`]
SubstituteTensor({Physics:-`*`(eta[`~mu`, `~nu`], d_[gamma](l[nu](X))) = d_[gamma](l[`~mu`](X)), Physics:-`*`(l[nu](X), eta[`~mu`, `~nu`]) = l[`~mu`](X), Physics:-`*`(l[`~mu`](X), l[mu](X)) = 0}, Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`])
Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`]
Ricci[mu, nu] = convert(Ricci[mu, nu], Christoffel)
Physics:-Ricci[mu, nu] = Physics:-d_[alpha](Physics:-Christoffel[`~alpha`, mu, nu], [X])-Physics:-d_[nu](Physics:-Christoffel[`~alpha`, alpha, mu], [X])+Physics:-Christoffel[`~beta`, mu, nu]*Physics:-Christoffel[`~alpha`, alpha, beta]-Physics:-Christoffel[`~beta`, alpha, mu]*Physics:-Christoffel[`~alpha`, beta, nu]
SubstituteTensor(Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`], Physics:-Ricci[mu, nu] = Physics:-d_[alpha](Physics:-Christoffel[`~alpha`, mu, nu], [X])-Physics:-d_[nu](Physics:-Christoffel[`~alpha`, alpha, mu], [X])+Physics:-Christoffel[`~beta`, mu, nu]*Physics:-Christoffel[`~alpha`, alpha, beta]-Physics:-Christoffel[`~beta`, alpha, mu]*Physics:-Christoffel[`~alpha`, beta, nu], evaluateexpression)
Physics:-Ricci[mu, nu] = (1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X]))+(-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`])*(-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[beta](l[lambda](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/2)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])*eta[`~alpha`, `~lambda`]+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`])-(-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])-(1/2)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`])*(-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/2)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/2)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X]))-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X]))-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X]))+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[mu](l[tau](X), [X]), [X])*l[alpha](X)
SubstituteTensor({Physics:-`*`(eta[`~mu`, `~nu`], d_[gamma](l[nu](X))) = d_[gamma](l[`~mu`](X)), Physics:-`*`(l[nu](X), eta[`~mu`, `~nu`]) = l[`~mu`](X), Physics:-`*`(l[`~mu`](X), l[mu](X)) = 0}, Physics:-Ricci[mu, nu] = (1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X]))+(-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`])*(-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[beta](l[lambda](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/2)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])*eta[`~alpha`, `~lambda`]+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`])-(-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])-(1/2)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`])*(-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/2)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/2)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X]))-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X]))-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X]))+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[mu](l[tau](X), [X]), [X])*l[alpha](X))
Physics:-Ricci[mu, nu] = (1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`])*((1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/2)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/2)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X]))-(-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])-(1/2)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`])*(-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/2)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/2)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X]))-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X]))-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X]))+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)
(14)
expand(Physics:-`*`(Physics:-`*`(Physics:-Ricci[mu, nu] = (1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])-(1/2)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]+(1/2)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`])*((1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/2)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/2)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/2)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X]))-(-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)+(1/2)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)+(1/2)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)+(1/2)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)+(1/2)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])-(1/2)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]+(1/2)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])-(1/2)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`])*(-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/2)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/2)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/2)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/2)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`])+(1/2)*eta[`~alpha`, `~tau`]*(Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X]))-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X]))-(1/2)*eta[`~alpha`, `~kappa`]*(Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X]))+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X), l[`~mu`](X)), l[`~nu`](X)))
Physics:-Ricci[mu, nu]*l[`~mu`](X)*l[`~nu`](X) = (1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]
(15)
"SubstituteTensor({l[~mu](X)*l[mu](X)=0,l[nu](X)*eta[~mu,~nu]=l[~mu](X),eta[~mu,~nu]*d_[gamma](l[nu](X))=d_[gamma](l[~mu](X))},rhs(Physics:-Ricci[mu,nu]*l[~mu](X)*l[~nu](X) = -1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X),[X]),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](Physics:-d_[alpha](l[~alpha](X),[X]),[X])*l[mu](X)-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~alpha](X),[X])*Physics:-d_[mu](l[alpha](X),[X])-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X),[X]),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](Physics:-d_[mu](l[~alpha](X),[X]),[X])*l[alpha](X)-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~alpha](X),[X])*Physics:-d_[nu](l[alpha](X),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*Physics:-d_[mu](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X),[X]),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](Physics:-d_[mu](l[~alpha](X),[X]),[X])*l[nu](X)+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~alpha](X),[X])*Physics:-d_[alpha](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X),[X]),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](Physics:-d_[nu](l[~alpha](X),[X]),[X])*l[mu](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~tau]*Physics:-d_[nu](l[alpha](X),[X])*Physics:-d_[tau](l[mu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~tau]*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X),[X]),[X])+1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~tau]*Physics:-d_[nu](l[mu](X),[X])*Physics:-d_[tau](l[alpha](X),[X])+1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~tau]*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X),[X]),[X])-1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~kappa]*Physics:-d_[alpha](l[mu](X),[X])*Physics:-d_[kappa](l[nu](X),[X])-1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~kappa]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X),[X]),[X])-1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~kappa]*Physics:-d_[alpha](l[nu](X),[X])*Physics:-d_[kappa](l[mu](X),[X])-1/2*l[~mu](X)*l[~nu](X)*eta[~alpha,~kappa]*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X),[X]),[X])+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]-1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)-1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]+1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[nu](l[iota](X),[X])*l[mu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*eta[~beta,~omega]*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])*eta[~alpha,~chi]-1/4*l[~mu](X)*l[~nu](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X),[X])*eta[~beta,~omega]*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])*eta[~alpha,~chi]+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[alpha](l[omega](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[nu](X)*Physics:-d_[iota](l[mu](X),[X])*eta[~beta,~iota]*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[mu](X)*Physics:-d_[iota](l[nu](X),[X])*eta[~beta,~iota]*l[alpha](X)*Physics:-d_[lambda](l[beta](X),[X])*eta[~alpha,~lambda]+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*l[~alpha](X)*l[~lambda](X)*Physics:-d_[alpha](l[lambda](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*l[~alpha](X)*l[~lambda](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~iota](X)*Physics:-d_[mu](l[iota](X),[X])*l[nu](X)*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[nu](l[chi](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*Physics:-d_[beta](l[chi](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*l[nu](X)*Physics:-d_[chi](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*l[~chi](X)*l[beta](X)*Physics:-d_[chi](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*l[~omega](X)*Physics:-d_[mu](l[omega](X),[X])*l[alpha](X)*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*Physics:-d_[alpha](l[tau](X),[X])*Physics:-d_[nu](l[mu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[~tau](X)*Physics:-d_[alpha](l[tau](X),[X])*l[mu](X)+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[nu](l[~tau](X),[X])*Physics:-d_[alpha](l[tau](X),[X])*l[mu](X)+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*Physics:-d_[mu](l[tau](X),[X])*Physics:-d_[nu](l[alpha](X),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[~tau](X)*Physics:-d_[mu](l[tau](X),[X])*l[alpha](X)+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[~kappa](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[~kappa](X),[X])*l[mu](X)*Physics:-d_[kappa](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[alpha](l[mu](X),[X])*Physics:-d_[kappa](l[nu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X),[X]),[X])+1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[~kappa](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[~kappa](X),[X])*l[nu](X)*Physics:-d_[kappa](l[mu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[alpha](l[nu](X),[X])*Physics:-d_[kappa](l[mu](X),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X),[X]),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[~kappa](X)*Physics:-d_[mu](l[kappa](X),[X])*l[nu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[~kappa](X),[X])*Physics:-d_[mu](l[kappa](X),[X])*l[nu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X),[X]),[X])*l[nu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[mu](l[kappa](X),[X])*Physics:-d_[alpha](l[nu](X),[X])+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~beta](X),[X])*l[mu](X)*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[nu](l[mu](X),[X])*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[nu](X)*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[alpha](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[alpha](X),[X])+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*Physics:-d_[alpha](l[~alpha](X),[X])*l[beta](X)+1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*l[~alpha](X)*Physics:-d_[alpha](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[nu](X),[X])*Physics:-d_[lambda](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[mu](l[~beta](X),[X])*l[alpha](X)*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[mu](l[alpha](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~beta](X),[X])*l[mu](X)*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*Physics:-d_[nu](l[~alpha](X),[X])*l[beta](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[nu](l[beta](X),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[~tau](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X),[X])-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*Physics:-d_[nu](l[alpha](X),[X])*Physics:-d_[tau](l[mu](X),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[nu](l[~alpha](X),[X])*l[~tau](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X),[X])-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[nu](l[~tau](X),[X])*l[mu](X)*Physics:-d_[tau](l[alpha](X),[X])-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*Physics:-d_[nu](l[mu](X),[X])*Physics:-d_[tau](l[alpha](X),[X])-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X),[X]),[X])+1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~tau](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X),[X]),[X])*l[mu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[nu](l[kappa](X),[X])*Physics:-d_[alpha](l[mu](X),[X])-1/2*l[~mu](X)*l[~nu](X)*Physics:-d_[alpha](l[~alpha](X),[X])*l[~kappa](X)*Physics:-d_[nu](l[kappa](X),[X])*l[mu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*Physics:-d_[alpha](l[~kappa](X),[X])*Physics:-d_[nu](l[kappa](X),[X])*l[mu](X)-1/2*l[~mu](X)*l[~nu](X)*l[~alpha](X)*l[~kappa](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X),[X]),[X])*l[mu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*Physics:-d_[beta](l[~alpha](X),[X])*l[nu](X)-1/4*l[~mu](X)*l[~nu](X)*l[~beta](X)*Physics:-d_[alpha](l[mu](X),[X])*l[~alpha](X)*Physics:-d_[beta](l[nu](X),[X])))"
op(32, rhs(Physics:-Ricci[mu, nu]*l[`~mu`](X)*l[`~nu`](X) = -(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)))
(16)
op(17, rhs(Physics:-Ricci[mu, nu]*l[`~mu`](X)*l[`~nu`](X) = (1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]))
(17)
op(77, rhs(Physics:-Ricci[mu, nu]*l[`~mu`](X)*l[`~nu`](X) = (1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[`~alpha`](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[mu](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](Physics:-d_[mu](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[alpha](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[alpha](X)*Physics:-d_[nu](Physics:-d_[tau](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~tau`]*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~kappa`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[alpha](X)*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[alpha](X), [X])*Physics:-d_[tau](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*l[mu](X)*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[tau](l[alpha](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*l[mu](X)*Physics:-d_[nu](Physics:-d_[tau](l[alpha](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[nu](Physics:-d_[alpha](l[tau](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[nu](l[`~tau`](X), [X])*Physics:-d_[alpha](l[tau](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*Physics:-d_[nu](l[alpha](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[`~tau`](X)*Physics:-d_[mu](l[tau](X), [X])*l[alpha](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[mu](X)*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[kappa](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*l[nu](X)*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[kappa](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[kappa](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[mu](l[kappa](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[kappa](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~kappa`](X)*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~kappa`](X), [X])*Physics:-d_[nu](l[kappa](X), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~kappa`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[kappa](X), [X]), [X])*l[mu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[nu](l[mu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[beta](l[`~alpha`](X), [X])*l[alpha](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[nu](X), [X])*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[mu](l[omega](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*Physics:-d_[alpha](l[omega](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~omega`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[nu](l[chi](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*Physics:-d_[beta](l[chi](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*l[`~chi`](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[nu](l[iota](X), [X])*l[mu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*Physics:-d_[mu](l[iota](X), [X])*l[nu](X)*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*Physics:-d_[alpha](l[lambda](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[nu](X)*Physics:-d_[iota](l[mu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*l[`~lambda`](X)*l[beta](X)*Physics:-d_[lambda](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*l[`~iota`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*l[alpha](X)*Physics:-d_[lambda](l[beta](X), [X])*eta[`~alpha`, `~lambda`]-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[beta](l[alpha](X), [X])-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[beta](X)-(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*l[`~alpha`](X)*Physics:-d_[alpha](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[iota](l[nu](X), [X])*eta[`~beta`, `~iota`]*Physics:-d_[lambda](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~beta`](X), [X])*l[alpha](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[mu](l[alpha](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[nu](X)*Physics:-d_[chi](l[beta](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*l[beta](X)*Physics:-d_[chi](l[nu](X), [X])*eta[`~alpha`, `~chi`]+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[beta](l[`~alpha`](X), [X])*l[nu](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[mu](X)*Physics:-d_[omega](l[alpha](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[beta](l[nu](X), [X])+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*Physics:-d_[nu](l[`~alpha`](X), [X])*l[beta](X)+(1/4)*l[`~mu`](X)*l[`~nu`](X)*l[alpha](X)*Physics:-d_[omega](l[mu](X), [X])*eta[`~beta`, `~omega`]*l[`~alpha`](X)*Physics:-d_[nu](l[beta](X), [X])))
(18)
Download Maple_Question_7.3.14.mw
https://drive.google.com/file/d/0B2D69u2pweEvUDJIeGlOVjFvNWc/edit?usp=sharing
https://drive.google.com/file/d/0B2D69u2pweEvV1BiRXhULTNPcWM/edit?usp=sharing
https://drive.google.com/file/d/0B2D69u2pweEvdXNrRlNadldXS0U/edit?usp=sharing
i find that maple 15 values are the same as extreme optimization library however, the sign are different
is it maple 15 accuracy correct or extreme library correct?
https://drive.google.com/file/d/0B2D69u2pweEvT01pazBxOEk1bWc/edit?usp=sharing
i worry for my research whether based on correct accuracy.
it can run without error in maple 15, however, the eigenvector values are wrong in maple 15 different from eigenvector function's result
then i test it in maple 12, it got error when run with following input
Error, invalid input: simplify uses a 1st argument, s, which is missing
> InputMatrix3;
                           [[30.15,29.95,29.95],[29.95,29.95,0],[29.95,0,0]]
NewInput3 := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
FirstEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[1]; # find back eigenvalue from eigenvector
SecondEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[2]; # find back eigenvalue from eigenvector
ThirdEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[3]; # find back eigenvalue from eigenvector
v:=[ FirstEigenValue, SecondEigenValue, ThirdEigenValue];
NewMatrix3 := Matrix([[x1,x2,x3], [x4,x5,x6], [x7,x8,x9]]);
EigenvectorSol := simplify(solve({seq(seq((NewMatrix3 . NewInput3(1..-1,i))[j]=(v[i]* NewInput3(1..-1,i))[j], j=1..3), i=1..3)}, {seq(x||i, i=1..9)}));
EigenvectorT := Matrix([[rhs(EigenvectorSol[1]), rhs(EigenvectorSol[2]), rhs(EigenvectorSol[3])],[ rhs(EigenvectorSol[4]), rhs(EigenvectorSol[5]), rhs(EigenvectorSol[6])],[ rhs(EigenvectorSol[7]), rhs(EigenvectorSol[8]), rhs(EigenvectorSol[9])]]);
Old_Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3));
I am programing the RSA-Algorithm. Somewhere in the program the user gets the choice to get a rough summary of the algorithm and the various steps used.
To do that I wrote a 1 1/2 page summary in Word. To see how the text is displayed withing the Window I took the first paragraph of my summary and put it in the following code:
with(Maplets[Elements]);
mapletExplainRSA := Maplet(Window('title' = "Erfahre mehr über RSA",
["Das verschlüsseln und entschlüsseln einer Nachricht dient der sicheren Kommunikation. Es existieren bereits Methoden der sicheren Kommunikation. Eine davon nennt man &ldquor;one way ciphers&ldquo; oder &ldquor;trap door ciphers&ldquo;.  &ldquor;One way&ldquo; da obwohl alle eine Nachricht verschlüsseln können, nur einer sie entschlüsseln kann. Für jedes Verschlüsselungsverfahren gibt es einen Schlüssel für das verschlüsseln und einen anderen Schlüsseln für das entschlüsseln.",
[Button("Nachricht verschlüsseln", Shutdown("True")), Button("Abbrechen", Shutdown())]]));
Maplets[Display](mapletExplainRSA)
The problem is that when I run this code the whole paragraph is written on the same line and hence does not even fit in the Maplet Window. Is there a way so that my rather long text will be formatet nicely within the Maplet window. Just like it would be displayed using Word. That is a text in paragraph style where sentences are wrapped automatically.
Oskar
******************************************where d1 to d45 -kappa and chi are constant**********
dsys4 := {d1*h1(theta)+d2*(diff(h1(theta), theta, theta))+d3*(diff(h2(theta), theta))+d4*(diff(h2(theta), theta, theta, theta))+d5*h3(theta)+d6*(diff(h3(theta), theta, theta))+d7*(diff(h1(theta), theta, theta, theta, theta)) = 0, d8*h2(theta)+d9*(diff(h2(theta), theta, theta, theta, theta))+d10*(diff(h2(theta), theta, theta))+d11*(diff(h1(theta), theta))+d12*(diff(h1(theta), theta, theta, theta))+d13*(diff(h3(theta), theta))+d14*(diff(h3(theta), theta, theta, theta)) = 0, h3(theta)^5*(d16+ln(h3(theta))^2*d15+2*ln(h3(theta))*d17)+(diff(h3(theta), theta, theta))*h3(theta)^4*(d19+ln(h3(theta))^2*d18+2*ln(h3(theta))*d20)+(diff(h3(theta), theta, theta, theta, theta))*h3(theta)^4*(d22+ln(h3(theta))^2*d21+2*ln(h3(theta))*d23)+h1(theta)*h3(theta)^4*(d25+ln(h3(theta))^2*d24+2*ln(h3(theta))*d26)+(diff(h1(theta), theta, theta))*h3(theta)^4*(d28+ln(h3(theta))^2*d27+2*ln(h3(theta))*d29)+(diff(h2(theta), theta))*h3(theta)^4*(d31+ln(h3(theta))^2*d30+2*ln(h3(theta))*d32)+(diff(h2(theta), theta, theta, theta))*h3(theta)^4*(d34+ln(h3(theta))^2*d33+2*ln(h3(theta))*d35)+h3(theta)^4*(d37+ln(h3(theta))^2*d36+2*ln(h3(theta))*d38)+h3(theta)^4*(diff(h2(theta), theta, theta, theta, theta, theta, theta))*(d40+ln(h3(theta))^2*d39+2*ln(h3(theta))*d41)-beta*h3(theta)^3*d42-chi*ln(h3(theta))^2*d43/kappa-chi*d45/kappa-2*chi*ln(h3(theta))*d44/kappa = 0, h1(0) = 0, h1(1) = 0, h2(0) = 0, h2(1) = 0, h3(0) = 1, h3(1) = 1, ((D@@1)(h1))(0) = 0, ((D@@1)(h1))(1) = 0, ((D@@1)(h2))(0) = 0, ((D@@1)(h2))(1) = 0, ((D@@1)(h3))(0) = 0, ((D@@1)(h3))(1) = 0, ((D@@2)(h3))(0) = 0, ((D@@2)(h3))(1) = 0}; dsol6 := dsolve(dsys4, 'maxmesh' = 600, numeric, output = listprocedure)
hi
DirectSearch answer has confused me. How to reduce the residual.
See the program.Direct.mw
I would like a plot of the solution of this differential equation : diff(phi(x),x,x)=phi(x)*(Ep(x)-E) with for example Ep(x)=(1-exp-(x-2))^2 and E=0.5
So :
>restart;with(plots); xith(DEtools);
>Ep:=x->(1-exp-(x-2))^2;E:=0.5;
>sol:=dsolve({eq,phi(o)=0,D(phi)(0)=0},type=numeric,range=0..10);
>odeplot(sol);
but nothing appear in the plot except axes
Thanks for answer
I want to solve two equations which I am mention in worksheet, i want the answers except complex values, when I am trying to solve in maple 18 it take too much time to evaluate, and also I did not get the answer, give some suggestions and ideas to do solve that work .
two_equations.mw
Thankyou...
Hi everyone,
I have a maple program that generates a polynomial g(y)=(80y^8 + 68y^6 + 12y^4 -4y^2 -1). This polynomial has two real roots (irrational roots), call them +/- y*. My code does a sequential calculation, and often sI am left with a higher order polynomial in y that has the form h(y)= p(y)*g(y), where p(y) is also a polynomial in y. This polynomial h(y)=p(y)*g(y) is not in factored form (i.e. it would look like expand(p(y)*g(y)). Is there a way to instruct maple to recoginize that +/-y* is also a root h(y)=p(y)*g(y)? So far I've tried things like applyrule([g(y*)=0],h(y*)), but nothing seems to work (I suspect because Maple cannot recgonize that g(y) is a factor of h(y)). I am not interested in computing this numerically. I am just trying to find a way to instruct Maple to recognize symbolically that h(y*) =0.
Thanks a million for anyone who has any idea.
Best,
Justin
Hi Maple users :)
do you know if exists a Maple package in order to perform a Panel method, for instance in the Hess-Smith version, for solving incompressible potential flow over thick 2d and 3d airfoil geometries?
Thank in advance for the help.
solve Differential equation "a-y=y' bc" use maple 17
the result is y(x)=a+_C1e^-(1/bc)
but the correct result  isn't y(x)=a-_C1e^-(1/bc) ?
Thank you in advance for your help
Hi :)
I have a Macbook Air running on OS X Mavericks. I am using Maple16.
I created a procedure, which construct two keys. Each of those keys consists of a list containing two elements. That is two primes. So at the end of my procedure I included the following code in order to write my data to a file:
> pkey := fopen(keyFile, WRITE, TEXT);
                      pkey:=1
> writedata(pkey, publicKey);
> fclose(pkey);
The problem is that I can't find the created file "keyFile".
So I tried breaking the problem down. I created a List and wanted to write that list in a textfile in a specific folder:
> L := [1, 2, 3];
> fd := fopen("Users\\****\\Desktop\\fdtest.txt", WRITE, TEXT);
                              fd:=1
> fprintf(fd, "This is a test");
                              14
> fclose(fd);
But this did not work either. It seems like the file fdtest.txt never gets created. This happens in general when I use fopen().
Schloemilch
First 1407 1408 1409 1410 1411 1412 1413 Last Page 1409 of 2429
