Hello everyone, I've been trying to solve a nonlinear ODE that has resulted in the following 5 equations
When solving a ODE system, I get "the lenght of the output exceeds the limit of 100000". This was expected so, it is OK with me. However, I would like to be able to see part of the output. Then, I can start making susbtitutions (algsubs) and shrink the output. So, how can I print just a few lines of the output?
I'm interesting to model with MapleSim a system with absolute coordinates. Indeed, i would like to compare my analytical results i have found with the symbolic equations i can generate with MapleSim and the model i have built was made with absolute coordinates.
So, is it possible to model a multi body sytem with absolute coordinates instead relative coordinates ?
For the moment, i have found any model (or tutorial) with absolute coordinates ?...
what is the difference between using DEtools forexample bernoullisol and dsolve directly?
I have a maple document with a few dozen plots. I am using the code
plotsetup(ps,plotoutput="C:\\plot.eps"); plot(x^2,x=-1..1); plotsetup(window);
to save the plot as an eps file. Is it possible to alter this code to save the file as a pdf? I've tried changing ps to pdf, but this doesn't seem to work. Thanks!
Hi I want to obtain the inverse of the following cumulative function: F(x)=1/n ∑_(i=1)^n(1-e^(-β/h (x-x_i-γh) ) )
Is it possible to print an asterisk in a superscript? For example, the plot
plot(x^2,x=-1..1,tickmarks=[[1/2=x^*],[1='a']]);
has x^* at the tickmark x=1/2, but I'd like it to be x*
Is it possible for tickmarks to be different colors? For example, say I'm working with the plot
plot(x^2,x=-1..1,tickmarks=[[-1,-1/2,1/2,1],[]]);
Is there a way to make the tickmarks at x=-1/2,1/2 red while making the tickmarks at x=-1,1 blue?
Or, alternatively, is there a way to turn the tickmarks at x=-1/2,1/2 into red subticks and make the tickmarks at x=-1,1 blue?
I woud like to have some help in using Maple to solve some complicated integrals.Specificaly, I would like to take the help of maple in differentiating an integral w.r.t. a parameter.
First, I will start with an integral for which Maple gives a solution. Let me first start with the assumptions :
I seem to be having trouble with the define_external command.
I want to call a C-library from maple, and I think I need to convert the maple data in C. So I need a custom wrapper.
But I can't get the simple example from here to work for me. Specifically, I tried this:
I am having trouble getting an algebraic solution for a first order four-ODE system. The problem seems trivial to me. However, Maple is taking a very long time to solve it. The system describes a reversible "chemical" reaction that have 4 states. Basically, the system is
C1<->C2<->C3<->O1
where the rate constants are ai towards the right and bi towards the left.
Any suggestion will do.
Hello all,
I have a question about converting a continuous piecewise function to Heaviside function, which the function includes trunc() in its conditions.
(I found differentiating piecewise function gives me "undefined" at boundary)
When I do that operation (convert(piecewisefunc, Heaviside)) I get the error below.
"Error, (in piecewise/simprootsstep) cannot determine if this expression is true or false: 0 < 183.3333333*Pi"
In the simplest case I could find of this...
How do I get Maple to simplify: sqrt(x.y)/x.y  to  1/sqrt(x.y)
If I remove any one of the 4 factores out of the equation above, it will just do it, but with the 4 together I just can not get it to give it to me in a "sensible" form.
Tx
Max
suppose I have a huge polynomial in several variables, say x, y and z, with some unknown coefficients:
(a*b+1)*x^3+(a+b+1)*x^2*y^2+(a-b^3)*x*y^2+a*y^10
Is there an efficient way to obtain all coefficients, when interpreting this as a polynomial in x and y?
(My goal is to make maple solve the equations in a and b  in order to let the polynomial be identically zero)
Many thanks!
Dear Maple users
I am looking for easy ways to manipulate lists. Especially I want to take a list of lists, say:
[[1,3], [5,8], [9,2], [5,12]]
and create a list of the second components:
[3,8,2,12]
Another problem: How do I collect every second element of a list, say:
[4,2,-1,9,5,6,2,0,14,7]
creating [2,9,6,0,7].
I can do it with loops, but I guess there is a smarter way to accomplish these tasks. I was looking...
First 1551 1552 1553 1554 1555 1556 1557 Last Page 1553 of 2429
