Dear Maple users
I am looking for easy ways to manipulate lists. Especially I want to take a list of lists, say:
[[1,3], [5,8], [9,2], [5,12]]
and create a list of the second components:
[3,8,2,12]
Another problem: How do I collect every second element of a list, say:
[4,2,-1,9,5,6,2,0,14,7]
creating [2,9,6,0,7].
I can do it with loops, but I guess there is a smarter way to accomplish these tasks. I was looking...
I have made a model in classic maple of a mechanical system. But, as this model is a a model of a kinematic closed system, it leads to DAEs equations. Consequently, i need to use specific tool to solve my DAEs.
I know that MapleSim can solve this kind of problem.
So is it possible to use numeric solver used in MapleSim in classic Maple to solve my DAE equations ?
How can i do to call this solver from classic Maple ?
Thank you for help.
here it is. sorry, at the top of the first sum, it's N1+N2 not N1+N1  :p    I tried many times, but can't succeed. the C is the combinasion, I also wrote it as
I noticed, that FileTools[Text][ReadLine] cannot read Cyrillic letter "я" in text files.
My test file containes 6 lines (Codepage 1251):
 Николай Петрович ТРУБЛАИНИ
 "ЛАХТАК"
 Ч А С Т Ь П Е Р В А Я
 НЕМОЙ ПАРОХОД  Г л а в а I
 Ветер налетел неожиданно. С неимоверной быстротой запенились волны. Они приближались к пароходу, стоявшему в миле от берега. Между реями мачт и в надстройках...
I have used classic Maple for some years but it's the first time, i use MapleSim.
So, i wanted to simulate a model given in the tutorials : the 2DRigidSliderCrank.
I launch the simulation but i receive this error message:
Do you know what is the matter with this code ?
What do i need to add to be able to simulate this model ?
===========================================================2DRigidSliderCrank==========================...
Hello everyone!
I have a small problem with setting of name's variable by using for do loop!
Small description of the issue: i have a loop which looks in that way:
for k from 1 to 4 do
y'k':=Matrix[a,b];
Еventually i want to have, for instance, four matrices with different filling but ranged from 1 to 4:
y1:=...
y2:=...
Especially i want to see names of the variables in the abovementioned way i.e. y1 and not y[1]!
I tried the following, but did not get 0. Why not?
>restart;
>b:=3*beta*Pi*(3-4*cos(z)+cos(2*z))/(16*z);
>-b+sqrt(b^2)
I know I can do this by hand, but this is part of a larger equation which I narrowed down to this issue.
I am having some problems when solving NullSpace when the matrix is somewhat 'complicated'.
Maple seems not able to find the nullspace.
Any hints or possible workaround?
Casper
nullspa.mw
how should i plot from the results of the desolve? i know i should use output=listprocedure,but i do not know how to use it. thank u,
i also have another question? what is the problem with my equations that have singularity ? i used maxfun=0 and stiff=true, but it does not make changes? should i change the initial conditons?maple.mws
I 've been using Maple 13 and recentely upgraded to Maple 17. But the following code yielded correct results in Maple 13 but not in Maple 17( gives an error: there is no taylor series expansion, try series).
I think there is some bug or some problem with "mtaylor" of Maple 17. Can anyone verify this?
CODE:
> restart;
> with(VariationalCalculus);
> interface(prettyprint = 3);
> with(LinearAlgebra);
Hello to you all. Pls. i just want to ask you guys about which package in maple can I use to solve nonlinear ODEs Also, can I use the Newtons Method?
Iwould like to calculate the inverse laplace transform of the expreesion which I call T.
< T:=tanh(s):
To do this I use the code "invlaplace" to solve it.
<invlaplace(T,s,t)
But it returns "invlaplace(tanh(s),s,t)".Done nothing.How to get its mathematical expression? I am really interested to get it.
PLZ help me in anyway as you can as I am completely stuck.
I wrote a procedure which rounds floats to a specified precision. I would like to apply it to a Matrix/List/Array/Vector that contains non-numeric cells as well as floats. I'm stuck at the type-checking stage.
# Round0 works on floats and lists and Matrices of floats:
Round0 := proc(x,n::integer:=1)
   parse~(sprintf~(cat("%.",n,"f"),x));
Round0(1.23456789);
1.2
Round0([1.23456789,9.87654321],2);
[1.23, 9.88]
I would like to recolor a list of plots using Maple default values. I have produced a list of colors with the plots:-setcolors(default) command. However, the colors are returned as a list of Hex values.  I first converted the Hex values to RGB values and then attempted to adapt a procedure written by Joe Riel, named -recolor- (refer to Joe's answer from which this question is branched).
But I must have done something wrong.
The conversion from Hex to RGB...
Our school is using a hosted version of Maple TA 9. We have a lot of questions in Moodle we would like to export to Maple TA. Is this possible?
Thanks in advance,
Henrik
First 1552 1553 1554 1555 1556 1557 1558 Last Page 1554 of 2430
