Dear sir,
i want to change the horizontal and vertical axis in maple plot. on horizontal axis  i  want velocity  u(y) values and on vertical axis y values i am attaching the file also My codes are
U:=(y^2-2*h*y)*(-(5/2)*c1/(2*h^2*a^2+5));
 c1:=1:
 h:=1:
  a0:=subs(a=1,U):
 a1:=subs(a=1.5,U):
 a2:=subs(a=2.5,U):
 a3:=subs(a=3.5,U):
 a4:=subs(a=4.5,U):
 a5:=subs(a=5,U):
  plot([a0,a1, a2,a3,a4,a5], y=0..1, title = " Velocity profile for c1=1 and h=1", legend = [alpha = 1, alpha= 1.5,alpha= 2.5,alpha= 2.5,alpha= 4.5,alpha= 5], titlefont = ["ROMAN", 15], labels = ["y ", "u(y)"], labeldirections = ["horizontal", "vertical"], labelfont = ["HELVETICA", 10], style = [POINT],symbol = [BOX,CROSS,CIRCLE,DIAGONALCROSS,DIAMOND,SOLIDBOX],color = [black, black,black,black,black,black], axesfont = ["HELVETICA", "ROMAN", 8], legendstyle = [font = ["HELVETICA", 9], location = bottom],axes=boxed);
Think of ranking as a vector in R^Z, where Z is the total number of webpages on the web.
For a given network of Z web pages, let A = [a_jk(little)] be the matrix
a_jk(little) = { 1 if page k has a link to page j
                  { 0 otherwise
1. How do you determine the matrix A for my network of pages?
2. And the number of recommendations that page j gets...
In Maple , if i will take a particular value of (eta) then I am getting 11 solutions 5 -ve and 6 +ve. But I want to get the solution as a function of (eta), so that taking different values of (eta) I will get different solutions as a sequence.
Using the Turtle program as seen in the attached Maple document where
R - right turn
L - left turn
F - forward movement
B - backwards movement
I have the basic shape, but I dont know how to write a procedure so that it repeats at the necessary spots to create a fern that looks like this:
fern.mw
Using the Turtle Commands where the following letters represent commands:
B - back
L - left
R - right
Create a fractal that looks like this one:
Attached is a Maple sheet with a program ReadFile in the beginning that allows for the use of the F,B,L,R letters that I found online. Does anyone see where I took a wrong turn? (haha)
I am trying to find the zeros of the sine function below when i do maple just returnes 0.
> seq(seq(p[j,c],j=2..3),c=1..3)=seq(seq(1/(1+exp(-(mu+cat(tau,j)+cat(eta,c)+mix[j,c]))),j=2..3),c=1..3);
Basically, I want to use these expressions in subs.
How do I tell Maple to make the substitution of "lhs=rhs"?
(in the form of {p[2,1]=something,p[3,1]=something,p[2,2]=something,p[2,2]=something,p[2,3]=something,p[3,3]=something,})
I can then use subs() to replace them in my desired expression.
Casper
I just learned about the with(Threads) package and I wanted to do a bit testing and see if it's 'faster' or more 'efficient'.
Test.pdf
This was done on a i7 940X (QuardCore) laptop.
I dont really see how it is better in a sense?
Or am I using Seq for the wrong purpose?
Casper
Hi, I'm getting a weird answer for this problem.  It is a linear 3 mass four spring system between two rigid walls, and x(t), y(t), and z(t) are the horizonatl positions of the three masses.  Here's an what it looks like with the postive coordinate directions below each mass:
wall\\ ---spring---MASS---spring---MASS---spring---MASS---spring---\\wall
                           --->x...
x := 1;y := 3;a := [1,2,3,4,5,6,7,8,9,10];z := Matrix([seq([seq(a[k], k = x+m .. y+m)], m = 0 .. 2)]);ListTools:-Occurrences(1, Vector(z(.., 1)));
eq1 := 285 = .3354101966*sqrt(1/(1.025384421*10^(-9)*d^4/t[min]^3+5.568148129*10^(-8)*d+(3/550400)*d^2/t[min]));
I would like to plot tmin for varying values of d.
i can solve for tmin with a know value of d using fsolve
but can't do the plot I want
I have been trying to improve my code to speed up a bit.
Here is the toy example:
myfunc:=proc(phi,p,CH)
 # dummy code
 # dummy code
 # dummy code
 # dummy code
a:=myfunc(phi,p1,CH1)
b:=myfunc(phi,p2,CH1)
c:=myfunc(phi,p3,CH1)
ANS1:=w1*a+w2*b+(1-w1-w2)*b
a:=myfunc(phi,p1,CH2)
b:=myfunc(phi,p2,CH2)
c:=myfunc(phi,p3,CH2)
I've been working on interacting with the MapleSim optimized C code (first post was here: http://www.mapleprimes.com/questions/145427-MapleSim-Connector-C-Code-Api?sq=145427) and two manuals were recommend to me to read, which were very useful. I ended up writing up an alternate implementation of the main method described in the one manual (http://www.mapleprimes...
I didn't manage to evaluate the following sum of 2 matrix M*p²+K.
The 2 matrix can be evaluated separately.
But, strangely, whan i try to evaluate the sum, i can get the numerical values.
Let's see :
[img]http://www.gilawhost.com/images/s7ur3of2.gif[/img]
I have bracket matching turned on but donot get the rectangular yellow box around matching brackets as shown in the attached picture. Can anyone help me how to turn this feature on for both input and output?
First 1592 1593 1594 1595 1596 1597 1598 Last Page 1594 of 2430
