Howdy.........Is there anyway i can force Maple simplify the LHS to equal the RHS. I know the're equivalent, but the RHS is neater IMHO.
(1/3)*sqrt(3) = 1/sqrt(3)
Hi, I was about to calculate the limit
limit(sin(x)+sin(y),{x=0,y=0})
and Maple 17 returns the same expression, with no answer.
What I am doing wrong?
As showed in attached file
the laurent series of exp(1/z) at z=1 is equal to the taylor series of exp(z) at z=1
Hello every one,
Here I will recall the PDE and its numerical solutiion provided by Maple help.
PDE := diff(u(x,t),t)=-diff(u(x,t),x);
IBC := {u(x,0)=sin(2*Pi*x),u(0,t)=-sin(2*Pi*t)};
pds := pdsolve(PDE,IBC,numeric,time=t,range=0..1);
p1:=pds:-plot(t=0,numpoints=50):
p2:=pds:-plot(t=1/8,numpoints=50,color=blue):
p3:=pds:-plot(t=1/4,numpoints=50,color=green):
plots[display]({p1,p2,p3});
I want to export data...
I posted a problem the other day to do with this specific problem and the issues got sorted out:)
The aim of the program is to find the catenary by iteration...
It's majorly diverging though and i'm not sure why.
Any ideas?
Rach
Trying_to_get_the_Ca.mw
I have been trying to figure out how to use the flexible beam properly. I'm looking for a clear example on how to actually use this component. I have had no luck so far. I must be be missing something.
The current example, http://www.mapleprimes.com/questions/94996-Flexible-Robot-Arm, does not really show much.
Does someone have a simple example? Perhaps using the Flexible Beam as a cantilever, with one end fixed...
Sometimes maple tends to press enter two times when I want to access a label with Ctrl+L
Here is what I mean:
This happened because it "pressed" enter 2 times. This doesn't happen all the time. Did anybody have this problem? Any way to fix it?
P.S. My space bar is alright 100%
Iexported as LaTex and get the following file. When I use TeXmaker run, the pdffile not full out put the result. It can not break page. I asked this questionat http://tex.stackexchange.com/questions/114182/how-to-break-page-result-of-maple-outputand get the ansewr. Is the maple2e.sty too old? \documentclass{article}\usepackage{maple2e} \def\emptyline{\vspace{12pt}}\DefineParaStyle{MapleOutput}\DefineParaStyle{Maple Output}\DefineCharStyle{2DMath}\DefineCharStyle{2DOutput}\begin{document}\pa...
Hi everyone
It's been a while since I last used Maple, so maybe these are simple questions
The first is:
I have a DE
eqbz:=diff(y(x),x)=-l/x^2*(y(x)^2-yeq(x)^2)
yeq(x) is a simple function of x and I want to solve it with "l" as a parameter and ic:=y(0.01)=1
sol:=dsolve({eqbz,ic},numeric,output=listprocedure,range=0.01..10^3,parameters=[l])
then I proceed to plot
ysol:=eval(y(x),sol)
ysol(parameters=[l=x]):
I have two lists viz.
m:=[0,1,2,3,4,5]; n:=[0,1,2,3,4,5,6,7,8,9];
I have to define a mapping (i.e. a Maple table) say `p` such that
(1) p(0)=0,
(2) p(max(m))=p(max(n)) and
(3) For all other i in m p(i) is a random choice from n but with condition that p(i)>=p(i-1).
Help is desperately needed. regards
I use the module DynamicSystem to transform a state system in transfer functions. Next, i can plot Bode diagram with this module.
However, i have a little problem. I don't manage to extract only one transfer function from a dynamic system when i have several transfer functions (see example below)
I'd like to plot the first transfer function alone in fact. How can i extract y1(s) ?
I tried to export my maple document to latex using file->export function, but it won't export file correctly. For example
in maple
> a := 5431; b := 15971; c := 20551;
> f := -a-b-c;
                             -41953
in latex
\usepackage{maplestd2e}
I have an intermittent font issue in Maple 15 on Mac OS X 10.4 and 10.5.
Every-so-often it happens that certain characters do not show in the Maple output. These are usually greek characters or somewhat more exotic mathematical symbols. I do shuffle file back & forth between my systems which are Maple 15 and OS X 10.4.11 and 10.5.8. Java id 1.5 on both of these. Occasionally, a file may also get to a machine running Maple 17 on 10.6.8 with Java 1.6, but that is...
I want to write the following summation but Maple give the following error
summation:
find the center of rotation  of the triangle ABC, if it is rotated to give triangle A'B'C', given that A(4,-2), B(5,-4), C( 6,-1),    A'(4,2), B'(6,3) and C'(3,4).
First 1590 1591 1592 1593 1594 1595 1596 Last Page 1592 of 2430
