Problem_116_Solutio.htm
Hi, would like to know if maple commands can replicate/automate this solution.
rsolve({a(n)=9/19*a(n+1)+10/19*a(n-1),a(0)=0},a)
=-9a(1)+9a(1)(10/9)^n
     I'm using fsolve in a loop, as an example can we find the first 10 roots of sin(x) and store then in an array.
x:=array(0..10):
x[0]:=0:
for i from 1 to 10 do
x[i]:= fsolve(sin(y)=0, y=x[i-1]..10 , avoid={y=x[i-1]});
Firstly this solve only 0,2*Pi, 3*Pi...Why does it skip Pi? also can I change the range to x[i-1]..infinity?
maple won't seem to let me plot e^x*sin(2*Pi*x ) for some reason is there any reason why?
Hello Everyone,
I got a question about the inverse laplace transform of the classic second order system:
Step_Respon=1/(s*((s^2/omega_n^2)+2*zeta*s/omega_n+1))
zeta < 1
if I take the inverse laplace transform, it will give me root of (zeta^2-1) term, how can I force maple to consider the range of zeta before doing inverse laplace transform?
the follow is a code that I've started.  This code is from working template that I created previously. that works and iterates as expected, but this equations with these parameters gives me the pintf error in bold at the bottom.
Can you please help with the error at the bottom of code that is in bold????
> restart;
> Digits := 14;
14
> f := proc (x) options operator, arrow; 3-x-x*exp(r*(1-x...
does anyone know how to make a programme to find values of B^j+1 and B^j+1 where:
matrix([[A^j+1],[B^j+1]]) = matrix([[C,D], [E,F]])*matrix([[A^j],[ B^j])
and with the initial condition that A^j =0, B^j=1. and then run to find say A^6 etc
thx
I created a maplet in maple using the following codes:
> restart:
> with(Maplets[Elements]):
> m5:=Maplet(
> Window('title'="Turev",
> ["Fonksiyon:",TextField['Y1']()],
> ["Turev Degiskeni:",TextField['Y2'](3)],
> TextBox['TB1']('editable'='false',3..40),
> [Button("Turevi Hesapla",Evaluate('TB1'='diff(Y1,Y2)')),
> Button("Tamam",Shutdown(['Y1','Y2','TB1'])),
> Button("Temizle",SetOption('Y1'=""))]
How do you export an array of plots from Standard GUI? If I select the array with the mouse and then right-click (to get the context menu), my selection is reduced to the single cell of the array that the mouse pointer is over. Do I have to resort to plotsetup?
Lately as my computations become ever more intense, I have been having trouble with fsolve. Why exactly does fsolve sometimes return itself as in:
E:=fsolve({C1,C2,C3,C4},{c1,c2,c3,c4}}
returns--> fsolve({C1,C2,C3,C4},{c1,c2,c3,c4}}
and somtimes fsolve returns a blank.
What is going on internally here? Shouldn't it keep trying till it runs out of memory?
Pat
Does anyone know if it is possible to loglogplot a function like:
y=const, x=0..10^3
y=x^(-3/8), x=10^3..10^8
It would be really useful to plot.
I have added a .mw file showing the problem. I wish to calculate the integral at the bottom of the post. unfortunately the function im using defined at he beginning of the file doesnt behave well for values k larger than 25/30...
The integral I need to evaluate therefore cant be evaluated if one wants to integrate from 0 to Infinity.
Also just integrating till 20 or so is not accurate enough...
Has anybody an idea about better implementation of the problem....
I need more help with code please!
A box of candy hearts contains 52 hearts, of which 19 are white, 10 are tan, 7 are pink, 3 are purple, 5 are yellow, 2 are orange, and 6 are green. If you select 9 pieces randomly without replacement, what is the probability that A_3 of the 9 are white, and B_3 of the 9 are white, 2 are tan 1 is pink and 1 is yellow and 2 are green
19 Whites in the pack / 52 hearts in the pack = .3654 possibility of picking a white from 1 draw.
How can I write code for : A coin is tossed 4x, the sequence of H and T is observed. I need to list each of the 16 sequences (which, when done manually are :
S= {hhhh,hhht,hhth,hthh,thhh,hhtt,htht,thth,tthh,thht,htth,ttth,ttht,thtt,httt,tttt}
b) Let events A,B,C,D be given A= {at least 3 heads}, B= {at most 2 heads}, C= {heads on the third toss}, D= {1 head and 3 tails}. If the probability set function assigns 1/16 to each outcome in the sample space find ...
Hi in trying to solve these coupled differential equations i get a weird error:
> t := diff(X(x), x) = -(1-6*R(x)^(1/2))^(1/2)*x*X(x)/(X(x)*x+R(x))^(1/2), diff(R(x), x) = (1-6*R(x)^(1/2))^(1/2)*x^2*X(x)/(X(x)*x+R(x))^(1/2);
(1/2)
/ (1/2)\
d \1 - 6 R(x) / x X(x)
--- X(x) = - -----------------------------,
I am trying to evalute a double integral symbolically using Maple 15.  I have gotten it to work when some of the parameters are specific numbers, but it won't work if I use variables, even if I assume sufficient conditions on them for the integral to make sense.  I have tried to use AllSolutions but it didn't work.  Breaking it down into steps isn't working either.
I am working on a file on a remote server and I don't think I can upload it here. ...
First 1636 1637 1638 1639 1640 1641 1642 Last Page 1638 of 2430
