Given a vector with six elements called, say, c, how do I assign the sum of its values to a name called d without having to write d=c[1]+c[2]...?
Find the value of the integral I=∫√(tanx)dx
The following is a differential equation with separable variables.  It is solved with dsolve and "manually".  Why is the dsolve solution so complicated?
Ratch
Find the value of the integral I=∫√(sinx)dx
I'm now using Maple 15 to get derivative funtions in a function with multiple parameters. So I want to find out the derivative w.r.t just one parameter. In the forum, I found out one way to solve this issue.
In order to prove the correctness of the function D[3](m,n,p,r,x), I firstly use a very simple program to test it.
In the Engineering PoA-Example.mw file, I've used a simple function called testFor with 5 parameters to generate a mathematical...
Hi everyone,
Here is the code:
Ralpha:=sqrt(d)*IdentityMatrix(2):
alpha:=Array([WienerProcess(Ralpha),WienerProcess(Ralpha),WienerProcess(Ralpha),WienerProcess(Ralpha)]):
alpha1:=k->Vector[column]([[alpha[1](k)[1]],[alpha[1](k)[2]],[alpha[2](k)[1]],[alpha[2](k)[2]],[alpha[3](k)[1]],[alpha[3](k)[2]],[alpha[4](k)[1]],[alpha[4](k)[2]]]):
Finance[ExpectedValue](alpha1(0)[1]*alpha1(0)[1],timesteps=100,replications=10^4);
I have a rather large multivatiate polynomial "Dtest"  I need to divie it by a cubic poly "DGm" using rem and quo. Both are determinants multiplied out,  both given below. Have spent the past 2 nights trying to sort, collect, expand, equate coefficients plex groebner etc. Am trying to collect up all the powers of c3 but cant anything to work. even expand doesn't fully expand "Dtest". If I set c1 and c2 to 1 things are...
Hi guys
Is there any build-in function which converts [[x>5, x<10], [x < 0]] to "x>5 and x<10 or x<0"? I've written my own function, but I want something build-in.
Hi everyone,
Working on my project, I have this error "Error, (in VectorCalculus:--) too many levels of recursion".
The project is about filetring a stochastic process.
When I want to calculate one of the integrals, I have that error.
Here is the code:
Rxi:=sqrt(d)*IdentityMatrix(4):
xi:=WienerProcess(Rxi);
Reta:=sqrt(d)*IdentityMatrix(2):
eta:=Array([WienerProcess(Reta...
Hi, I am trying to solve the following differential systems using dsolve numeric but there is something wrong with my code.
I am fairly new to Maple and cant work out why it is telling me that it doesnt work. COuld somebody help me?
DifferentialSystem := {diff(r(t),t$2)-r*(diff(theta(t),t)^2=-1000/r^2 ,
                            r(diff(theta(t),t$2)+2(diff(r(t),t)*(diff(theta(t),t)=0,
                            r(0)=sqrt(65), theta(0)=1.446...
I have to solve a linear system
in Maple. A is a tridiagonal matrix.
My problem is that my matrix A is big and therefore, I have to wait too long. Is there some function in Maple that can help this problem?
So the question is to find complex number W from :
but I want the answer in polar form using e (Euler's number).
The question is specific to ask for the complex number W that lying in the first quadrant and having the largest possible real part. I calculated and got :
Hi. I have a question that concerns indices of vector of functions within for-loop.
I have a following piece of code:
Check the correctness of the solution by substituting for all found roots.
This are my found roots:
a:=12+10x^4+7x^3-89x^2+65x
and i found my roots (e.g);
b:= -3.5666666666,1.238969999,5.7777777,8888888888
First,a Maple file is exported as the html file,but it took too much time to load the applet(com.maplesoft.applets.MathMLViewer)to display the mathematical symbols,such as the symbols of integral and differential,as shown in Figs.1 and 2.How to accelerate
loading rate of Java applet?
Second,the problem will occur in the browsers of IE and firefox that the equation is incomplete display as shown in Figs3.Is there a method can handle the problem?
The last,using the...
First 1745 1746 1747 1748 1749 1750 1751 Last Page 1747 of 2430
