I am trying to plot in Maple 16 (just installed) and I am getting text output. Maple 15 worked just fine.
Anyone have ideas?
Regards.
> plot3d(x^2-y^2, x = -2 .. 2, y = -2 .. 2);
Hi all, I am a teacher of middle/high school math. I have found that when I use the solve function on:
x/3=(x+0.2)/15+1.5
I get 5.674999999
In fact, as I was typing the above equation just now using Maple Math, I noticed it returns:
The Export function in ExcelTools completely overwrites Excel 2010 ".xlsx" files with no errors or messages.  The same command works properly for Excel 2003 ".xls" files.  It looks like a bug to me.
i have a procedure like this
> palindrome:=proc(n)
   option cache;
   uses ST = StringTools;
   if length(n) :: even or odd
   and modp(n,11) <> 0 then
   return false;
   return ST :- IsPalindrome(convert(n,'string'));
> palindrome("mom");
   error, (in palindrome...
I'm trying to visualize a 3-Dimensional function, the color being the 4th dimension. All the examples that I have found of the so called plot3d function only involve 2D functions, the third dimension really being the return value of the function. I need more: I have a 3D function which takes in (x,y,z) if you like, and outputs one number. I'd like to visualize this function in maple.
~Austen
See the code mli.mws
What is the mistake in this command ?
chfonc:=cat('piecewise(' , seq(cat(convert(t<lf[k],string) , ' , 1 , ' ,convert(t<lf[k],string), ' , 1 , ' ) , k=1..p) , '1) ') :
I am trying to solve three non-linear coupled initial value problems. The equations are a bit complicated. The MAPLE code is
with*plots
eq[1] := (1/6)*Ra*v(x)^3*((2*v(x)*w(x)^2*(v(x)^2/w(x)^2-3)*(diff(w(x), x))-6*w(x)^3*(1-v(x)/w(x))^2*(diff(v(x), x)))*A+v(x)^2*w(x)^2*(2*v(x)/w(x)-3)*(diff(w(x), x))-3*w(x)^4*(1-v(x)/w(x))^2*(diff(v(x), x)))/(w(x)^2*(w(x)+2*A)^2*(2*v(x)+3*B))+u(x)
eq[2] := (1/105)*(diff(u(x)^2*(v(x)^2+11*B*v(x)+39*B^2...
The following simple code
myproc1:=proc({parlist::list:=[]})
return parlist[1];
myproc2:=proc(parlist::list)
return myproc1('parlist'=parlist);
myproc2([1,2]);
fails with
Error, (in myproc1) invalid subscript selector
The reason is that myproc1 has the optional argument parlist, which has the same name as myproc2. myproc2 seems to make...
I want to compare two signals where intersections between the two signals represent the instant of command (like boolean pulse) of a thyristor. The two signals are volatges and command of thyristor is boolean. A conversion of voltage to boolean signal should also done, I think ?
See image below.
First of, thank you commenters, you have helped me so much in the past!
I am doing a matrix inversion with random numbers and I would like to loop the process, and have each inverstion go into a matrix, such that the matrix will be a bunch of rows ( i number of rows) and three columns (the matrix inversion yeieds three values)
> for i to 2 do;
> a1h := Generate(float(range = 0.1316881e-2 .. 0.1359706e-2)); a1f := Generate(float(range = .317149811 .. .327463626...
I'm am new to maple and am not very familiar with it.
I have a state space represnetaiton (Xdot = AX+Bu  y+CX+Du)of a 3rd order non linear system.
X=[X1; X2; X3]
Xdot=[X1dot; X2dot; X3dot]
A=[0 -1 -1; 1 0.2 0; X3 0 -2.4]
B=[0; 0; 2]
C=[1 0 0]
D=0
With initial conditons:
X1(0)=X2(0)=x3(0)=An arbitrary concept of my choice.
I need to plot x1(t) Vs time.
I also need to plot the state trajectories...
I am really stuck in one more bit thats the least square problem.  leastsquare1.mw
Hope someone can help me to solve this bit and get me out of this problem :(.
Least square method is successfuly implemented in MATLAB code (WRITTEN IN THIS MESSAGE AT THE END), but I couldn't do it in Maple.  I am having problem in the for loop section,  I am attaching Matlab code and  maple code ...
I have a differential that I'm solving using rk4 on maple and I want to plot the resaulting points in an interval. How do I do that?
here is what I've already done:
> f := {y(0) = 0, diff(y(x), x) = cos(5*y(x))-x};
> p := dsolve(f, y(x), numeric, method = classical[rk4], stepsize = .1);
proc(x_classical)  ...  end;
> for i from 0 by .1 to 3 do p(i) end do;
scatter2d  quantile2 scatter1d is removed?
with(stats): with(statplots): with(transform):
with(random): with(describe): with(plots):
datax:=[normald[5,1](100)]:
datay:=[normald[7,3](100)]:
scatter2d(datax,datay);
quantile2(datax,datay);
scatter1d(datax);
scatter1d[jittered](datax);
who(things) replace it?
i have a systems of differential equation:
J[n]=2*A[n]
S[n+1]=J[n]
A[n+1]=S[n] + 0.5*A[n]
with initial condition A[0]=10, J[0]=30, S[0]=5
i have a had time writing a procedure for this systems. help please
do i need a for command for this procedure
First 1746 1747 1748 1749 1750 1751 1752 Last Page 1748 of 2430
