Is there any easy way to download (or upload) several files in my maplecloud simultaneously. I seem to be able to highlight several files, but when I control-click it then only selects one.
Jason
I tried to use control+C and control+V to copy and paste equations from maple to MS word under windows 7, it works fine. But when it comes to the Mac OS, it generate some meaningless codes. Is there any way to do it under Mac OS?
I am trying to solve the so called Bethe ansatz equations in Mathematical Physics.
I have four multivariate polynomials equations with four unknown p_i(x[1],x[2],x[3],x[4]) i=1,2,3,4; which have integer coefficients. The equations are mixed; P_i is linear in x[j] for x[j]\ne x[i]; and x[i] is of order 10. Due to this structure,  I first eliminate x[4] from these equations. Then use resultant to eliminate x[3],  I got error messages (invalid series, in gcd...
I want to put vector n = (a, b, c) as normal vector of plane with assume a^2 + b^2 + c^2 > 0. For example
with(geom3d):assume(a^2 + b^2 + c^2>0):
plane(P,a*(x-1) + b*(y+2) + c*(z-3)=0,[x,y,z]);
But, i got: "Error, (in geom3d:-plane) unable to define the plane"
Plese help me. How can i put vector n = (a, b, c) as normal vector of plane?
Thank you very much.
Solve the equation sinx=1.5
How do I mask an input string?
That is when queried for an input, as the characters are typed they are presented differently.
Write the equation of the sphere has its centre at C(1, 2, 3) and cut the  straight line
Delta: x = t+1, y = t-1, z = -t at the points A and B so that the triangle ABC is a equilateral triangle.
This is my code.
Please help me the following code
f:=x->x^3-3*x^2+2;
g:=x->k*(x+1)+3;
solve([f(x) = g(x), diff(f(x),x) = diff(g(x),x)],[x,k]);
evalf(%);
The result of Maple is
[[x = .168254401781027, k = -.924597779530090]]
But, the system of equations has three solutions.
Problem. Write the equation of the sphere passing through the three points
A(-1, 2, 1), B(-3, 4, -5), C(1, 2, -3) and its centre
1) lies in  the plane (P): 2*x + 3*y -z = 0;
2)lies on the sphere (x-3)^2 + (y+1/3)^2 + (z-1)^2=1.
This is my code
1)
restart;with(geom3d):
point(A,-1,2,1):
point(B,3,-4,5):
I solved an equation, and Maple returns two values.  Even though I said, assuming v1i>0, the solve command returnse this:
logically evalf(x^(1/10)); should return x^(0.1000...0), not x^(1/10). Or it's just case of other rule?
I'm having trouble maximizing this funciton:
S=  (w1*E1+w2*E2+w3*E3)/(CoVar[1,2]), subject to the constraint w1+w2+w3=1
I need it to choose w1, w2, and w3 to maximize S
When I do the following command in Maple:
i have a differential equation like the one below
diff(y(t),t) = (20-y(t))*y(t)/(10+y(t))-C
i want to solve for C. i want to solve for C , is there a command i can use. i can't find it in maple help. i just started to use this software. please help
How can I create using Maplet a window that is not modal, so I could minimize or maximize it (I know what to do to make it resizable and that's not the question I would like to ask).
This simple example creates modal window with no minimize and no maximize button:
> with(Maplets[Elements]);
> maplet := Maplet(Window([]));
> Maplets[Display](maplet);
Is there an option to set for a Window or maybe I should change some settings in Maple 13 that I'm using ?
First 1766 1767 1768 1769 1770 1771 1772 Last Page 1768 of 2430
