> restart:
with(DynamicSystems):
> sys := TransferFunction(1/((1+0.1*s)(1+0.002*s+0.0001*s^2)));
> BodePlot(sys,range=10^(-1)..10^(3));
I get the following warning:
             Warning, transfer-function(s) are not rational-polynomial(s) in s
Why?.. How can I make it work without any warning?
Thanks everybody for help!
I'm running this numerical integration 14 hours continuously,without result.
The problem is the numerical integration
 evalf(int(F(q)*sin(q*Theta)/q)) assuming(0
This is taking forever.
Now,this is already done using Fortran (not time consuming at all),but the choice is not mandatory,so I'm using Maple 13.
Now,I think, to do this I have to do the integral using any other numerical method, evalf(int(,)) isn't good enough.
how to rewritten the PDEs to the matrix form like the following in Maple
Thank you for suggestions. The system in matrix form looks like z(k+1)=Az(k). The solution to that is z(k)=A^kz(0). Now, phase planes of the system would look different for different matrix A (specifically, eigenvalues of A). For example, for complex eigenvalues phase plane would look like a spiral. I'm having difficulties plotting those phase planes. It's easy for differential equation, but I'm not sure how to work with system of difference equation in Maple.
I have attempted making a translation the Wolfram Mathematic's document: Singular Value Decomposition.
I present Problems in showing the arches of angles. Besides result do not correspond .
Plot_singular_value_.mw
Gracias
with(OrthogonalExpansions) not working in Maple 15 (work in Maple 14). What is the equivalent package for FourierSeries calculations?
Kamel Boughrara
 I have the following equation that I want to plot for theta and t with other parameter values in the equation fixed as below. But when I try to animate the solution I get an 'unable to plot' error message. What can I do to plot the equation, U(theta, t) below.
 U(theta, t) := 1/2/Pi+Q*sin(k*theta)+P*sin(m*theta)+1/4*(-I*Q*exp(1/2*k*(-sigma^2*k+2*I*theta...
does anybody have any idea how to simplify
> t:=5^(-n)*2^n;
to
> s:=(2/5)^n;
Pavel
I have Maple 15. I am trying to calculate the limit of this function
((x^3-2x^2+sin(x))^(1/3))/(6x+2)
for x tend to +infinity. As you can get it with a rapid manual calculus, this limit is 1/6. But Maple returns undefined for this very simple limit. Why? How can i get Maple to calculate limits correctly? Derive 6 return the correct answer
How can i delete a row in a (2D) Matrix?
Thanks,   (Mohsen)
evolf := proc(f);
h1 := z + f(x);
h2 := z - f(x);
h3 := z*f(x);
h4 := f(x)/z;
h5 := z+diff(f(x),x);
h6 := z-diff(f(x),x);
h7 := z*diff(f(x),x);
h8 := diff(f(x),x)/z;
h9 := subs(x=z, f(x));
test := [h1, h2, h3, h4, h5, h6, h7, h8, h9];
F = 0;
for i from 1 to 9 do
    F = F + 1/(1+exp(subs(x=0,test[i])-subs(x=0,f(x))));
Hi there,
I am using plot3d in worksheet mode to create a bunge of complex 3d-geometries containing "patches" (style = wireframeopaque) and wireframes (style = wireframe) representing the deformed and undeformed geometry of a system. I would like to export them as vector graphics since only then the results look nice enough to be used in a report.
When using Maple 12 rightclick->export->EPS, works nearly. Unfortunately the patches are not really...
I have tried everything I can think of but cannot figure out how to phase a sine wave so that I see 3 plots of
f(x)=sin(x)
as a set of {0°, 120°, 240°} together on the same plot...
Hi there,
I have a system of seven equations and want to make a phase plane with field arrows for two independent variables (C vs I). When I use DEplot it doesn't give me field with arrows. I just wonder if anybody could please help me in this issue. Here is my system:
dp/dt = P kappa I-gamma[1] CE- delta[1] CH
dE/dt = lambda E(E[0]-E)-gamma[1] C E
dI/dt = gamma[1] CE + eta Ia/(epsilon+K) -kappa I -alpha K I-delta[2] I M
dIa/dt = alpha K I+delta[2] I M
I have a model which contains 3 variables and several parameters, the equtions are as following:
diff(i(t),t) = alpha*B(t)*S(t)/(K+B(t))-r*i(t)
diff(S(t),t) = -alpha*B(t)*S(t)/(K+B(t))+b*(N-S(t))
diff(B(t),t) = e*i(t)+g*B(t)
How can I solve them to get the solutions by using Maple, and plot them?
Sorry I'm just a new learner with little math background. Plz explain more specific if you want. Thanks for your help.
First 1852 1853 1854 1855 1856 1857 1858 Last Page 1854 of 2430
