Hyperlinks ars restricted to URL, Mail, Maple, etc. For Windows I would like to see a new type called Double Click.
The location and file name would be entered. Executing this Hyperlink would be just like double clicking the file in Windows. The file could be anything as long as the underlying software is installed on the computer.
The file could be video, mp3, image, etc. This would have no restrictions.
It would help to make Maple even more multimedia.
Hello, so while I am toying with Maple and some excersizes, I have realized my skills aren't what I thought they were from when I last used Maple 8. I swear the program gets smarter and returns more errors now that I cannot properly define some functions.
For example, I have attempted to plot the vector function r(t)=<cos(t), sin(t), exp(sin(t))>. Required, in the same plot region, same graph, is to plot A) the function r(t), B) the derivative r'(t) AND the C...
I have a more relavant form of a question regarding procedures. I need to write a procedure with parameter f(x) and result in the plot of the function f(x) along with the plot of the curvature of f on the same graph. Ideally, parameter f(x) could be requested to be any function, such as x^2 or cos(x). I am new to procedures and do now know where to begin, even at such a basic level.
Any assistance greatly appreciated.
I am using Maple 14 and struggling with writing procedures. Here is an example of what I need to be able to program. I require a procedure which will receive as a parameter a function f(x) and plot that function (say in red) along with the curvature function (say in blue) on the same graph. Sample parameters include the functions f(x)=x^2 or sin(x) or exp(-x^2).
I feel somewhat confident in my maple commands, but procedures are a whole new thing to me. If even a basic...
I have those questions:
1) set
When I write these inputs,
x:={1,3,2}; y:={b,a,d,c}; z:={a[1],a[1,1],b[0],d[0],c[0],a[0],2};
the results are x := {1, 2, 3}, y := {a, b, c, d}, z := {2, a[0], a[1], a[1,1], b[0], c[0], d[0]}
Is there a way to get what I input
2) This problem in ordering numbers and words is verry important and hard when solving a large system of equations with:
restart:with(SolveTools): eqns:=[a[0...
The following simple procedure:
SubsColumn: = proc (A, V, k)
local B, m;
with (LinearAlgebra);
m: = ColumnDimension (A);
B: = <A[..,1..m]|V>;
B: = ColumnOperation (B, [k, m +1]);
B: = DeleteColumn (B, m +1);
B;
solve the problem of...
Could you please tell me, how can I model a varying stiffness spring using MapleSim 4?
I think, this can realized using a varying "c" parameter of a standard spring from the MapleSim library, but I don't know, how I can change the "c"-stiffness value during the modeling process.
Dear friends,
My following commands (MAPLE 14), generate the matrix zz1 (see below).
How could I get a plot with "n" (first column) in the "X-coordinate" and second/third and fouth columns in "Y-coordinate"?,
Thanks for your attention,
Jean-Jacques
interface(rtablesize=50):
f1 :=  (w1, w2,n) -> add(add(
 `if` (1/2 <= w1+j*w2+((1/n)*(1-w1-w2))*k and
why the results of two BessLk function is wrong? The results I got is negative,but it shouldn't be less than zero。For the same  integration expression, I use the mathematica, can get the right results.But when use maple,with the variable value's increasing,the results ranges from positive to negative.In fact, the result I got is outage probability,it should be positive.
What can be said about this divergent series:
 sum((cos(m)+I*sin(m))*(cosh(w)+sinh(w)),n=1 ..infinity) where m=Pi*n and w = ln(n)/n?
Calculate
int(cos(100*(x^4-x)), x = -infinity .. infinity)
with the relative error less than  10 percentages.
I use 'SystemConnect' command to connect two transfer function, as the following codes illustrated.
with(DynamicSystems);
sys1 := TransferFunction(10/(s*(s+10)));
sys2 := TransferFunction(k*s^2/(s+20));
Warning, improper transfer-function, degree(num) > degree(den)
sys3 := SystemConnect(sys1, sys2, connection = negativefeedback, outputtype = tf);
Error, (in unknown) cannot convert improper transfer function to state-space model
does anybody have experience with solving heat conduction for multi-layer domain?
the following command gives unrealistic results:
pdsolve(PDE,IBC, numerics)
Mo
I'm currently implementing the Poker test to determine whether a binary sequence possesses some specific characteristics that a truly random sequence would be likely to exhibit.
Maple can't solve the inequation `assuming`([solve(floor(160/m)>=5*2^m,[m])],[m::posint]);
However, `assuming`([solve((160/m)>=5*2^m,[m])],[m::posint]); works.
Is there a way to rewrite...
Hi friends,
I have this piecewise function:
restart:assume(n,integer):h := piecewise(n::odd, n^2, n^3);
I can not get explicitly the derivative:
diff(h,n);
But, with
restart:h1 := piecewise(And(n::integer, n::odd), n^2, n^3);
I can get the derivative explicitly:
diff(h1,n);
Why ?
First 1908 1909 1910 1911 1912 1913 1914 Last Page 1910 of 2431
