How can I show all the parameters in title ?
with(DEtools):with(plots):with(plottools):
sigma1:=e1*alpha: sigma2:=e2*delta:
g:=x/(1+beta*x^2);
f:=(theta*x-1)*(1-x)*(1+beta*x^2)-y;
h:=alpha*g-z-sigma1;
j:=delta*y-sigma2;
x/(beta*x^2+1)
(theta*x-1)*(1-x)*(beta*x^2+1)-y
alpha*x/(beta*x^2+1)-e1*alpha-z
-delta*e2+delta*y
p0:=theta->plot([1/theta,y,y=0..1],linestyle=dash,color= green):
p1:=e1->plot([x,e1,x=0....1.5],color=blue):
q0:=animate(p0,[theta],theta=2...10):
q1:=animate(p1,[e1],e1=0.1..1):
q2:=plot([1,y,y=0..1],linestyle=dash,color= green):
p3:=beta->plot([x,x/(1+beta*x^2),x=0..1.5],color=magenta);
q3:=animate(p3,[beta],beta=0..1.5):
display([q0,q1,q2,q3],view=[0..1.5,0..1]);
proc (beta) options operator, arrow; plot([x, x/(1+beta*x^2), x = 0 .. 1.5], color = magenta) end proc
Download animate_plots.mw
I am quite a rookie in using Maple.
A project is going on while I need to use previous formulas and variables defined in A.mw, while I don't want to redefine everything again in my worksheet, is there any approach to inherit everything in A.mw to my current worksheet?
How would I go about creating a tetrad of a specific signature in the Differential Geometry package. The GrahmSchmidt and NullTetrad give me orthonormal and complex null tetrads. But I was wondering if there was a way to generate a tetrad of specific signature.
The union is simple
with(plottools):
display([torus([1,1,1], 1, 2),torus([1,6,1], 1, 2)], scaling=constrained, lightmodel=light1, shading=zgrayscale,color=[red,red]);
but how to plot the intersection?
I have been try to code the
mdl:-Fit(x, y, opts)
command in Deep learning package
But i feel new to that command I am making errors
Can I get a small toy code how to call it and its output on train and test
so that i could learn
kind help please
 i want to increase my value monotonically  . but i don't want to do it like sequence. how can i write code.
for example my value ..starts at 0...to some values i just want to increase.
help me plz
I'm having a symmetric bivariate polynomial P(x,y) with a high degree (larger than 8). I want to know if there exists a root of P(x,y) or not. I may not need a specific root but rather to know if P(x,y) has a root or not. I've been doing some research but I only find the command that helps solve univariate functions or solve systems of bivariate functions.
In conclusion, my question is: How can I know that a symmetric bivariate polynomial has a root or not using Maple?
Here is the polynomial I want to check
P(x,y)=x^12*y^3 + 10*x^11*y^4 + 43*x^10*y^5 + 105*x^9*y^6 + 161*x^8*y^7 + 161*x^7*y^8 + 105*x^6*y^9 + 43*x^5*y^10 + 10*x^4*y^11 + x^3*y^12 - x^12*y^2 - 8*x^11*y^3 - 17*x^10*y^4 + 8*x^9*y^5 + 82*x^8*y^6 + 128*x^7*y^7 + 82*x^6*y^8 + 8*x^5*y^9 - 17*x^4*y^10 - 8*x^3*y^11 - x^2*y^12 - x^12*y - 4*x^11*y^2 - 62*x^10*y^3 - 341*x^9*y^4 - 902*x^8*y^5 - 1410*x^7*y^6 - 1410*x^6*y^7 - 902*x^5*y^8 - 341*x^4*y^9 - 62*x^3*y^10 - 4*x^2*y^11 - x*y^12 + x^12 - 8*x^11*y - 62*x^10*y^2 - 680*x^9*y^3 - 3169*x^8*y^4 - 7312*x^7*y^5 - 9540*x^6*y^6 - 7312*x^5*y^7 - 3169*x^4*y^8 - 680*x^3*y^9 - 62*x^2*y^10 - 8*x*y^11 + y^12 + 10*x^11 - 17*x^10*y - 341*x^9*y^2 - 3169*x^8*y^3 - 11838*x^7*y^4 - 21793*x^6*y^5 - 21793*x^5*y^6 - 11838*x^4*y^7 - 3169*x^3*y^8 - 341*x^2*y^9 - 17*x*y^10 + 10*y^11 + 43*x^10 + 8*x^9*y - 902*x^8*y^2 - 7312*x^7*y^3 - 21793*x^6*y^4 - 30696*x^5*y^5 - 21793*x^4*y^6 - 7312*x^3*y^7 - 902*x^2*y^8 + 8*x*y^9 + 43*y^10 + 105*x^9 + 82*x^8*y - 1410*x^7*y^2 - 9540*x^6*y^3 - 21793*x^5*y^4 - 21793*x^4*y^5 - 9540*x^3*y^6 - 1410*x^2*y^7 + 82*x*y^8 + 105*y^9 + 161*x^8 + 128*x^7*y - 1410*x^6*y^2 - 7312*x^5*y^3 - 11838*x^4*y^4 - 7312*x^3*y^5 - 1410*x^2*y^6 + 128*x*y^7 + 161*y^8 + 161*x^7 + 82*x^6*y - 902*x^5*y^2 - 3169*x^4*y^3 - 3169*x^3*y^4 - 902*x^2*y^5 + 82*x*y^6 + 161*y^7 + 105*x^6 + 8*x^5*y - 341*x^4*y^2 - 680*x^3*y^3 - 341*x^2*y^4 + 8*x*y^5 + 105*y^6 + 43*x^5 - 17*x^4*y - 62*x^3*y^2 - 62*x^2*y^3 - 17*x*y^4 + 43*y^5 + 10*x^4 - 8*x^3*y - 4*x^2*y^2 - 8*x*y^3 + 10*y^4 + x^3 - x^2*y - x*y^2 + y^3
`debugger/no_output`;
From the Maple 2023 user manual for AudioTools, when I attempt to input:
with(AudioTools):
Tone := f -> Play(Create(x -> evalhf(sin(1/22050*x*Pi*f)), duration = 1)):
Tone(440);
I get the following error message:
Error, (in DocumentTools:-GetProperty) Attempted to retrieve property of unknown component Speaker0.
Clicking the error message in Maple then goes to this page:
https://www.maplesoft.com/support/help/errors/view.aspx?path=Error,%20(in%20DocumentTools:-GetProperty)%20Attempted%20to%20retrieve%20property%20of%20unknown%20component%20Speaker0.
How do I get a function to play as an audio file in Maple 2023?
Is there a way to enclose in parentheses or brackets a highlighted selection of Maple Input?  This is a nice feature on WXMaxima to quickly and accurately enclose any selection of input syntax in parentheses or brackets.  Otherwise it can become tricky to add the opening and closing parentheses/brackets separately.
How do I insert an Input Prompt (">")?
On Maple 2023, each new input is marked on the right-hand side as (1), (2), (3), etc.  This is equivalent on WXMaxima as %i1, %i2, %i3, etc.  On WXMaxima, I can left-click between any two previous inputs to insert a new input, for example %i4 might be between %i1 and %i2 if I added %i4 after %i3.  However, I can't seem to do this on Maple.  Is there a way to go back and add a new input between two previous inputs on Maple 2023?
Likewise, I can't seem to add a new input prompt after the last input prompt if the last input prompt has not executed.
Is there a way to express any number in any number base using Maple?
Start with converting any positive real number (rational or irrational) into any positive real number base (rational or irrational), such as: what is "1/65536" in base "999" or what is "sqrt(2)" in base "exp(1)"?
But also for negative, imaginary, and complex numbers: for example, what is "(1/3)-sqrt(3)*I" in base "-Pi*I"?
Specifically, I would like to know what are the first 1024 digits of "exp(1)" in base 16777216, but a general function to convert any number into any base would be preferred.  Base 16777216 is a fun example since each digit can be expressed as a hexadecimal color (from #000000 to #ffffff) on a computer monitor.  Not sure how to get Maple to color the digits automatically though.
It's unfortunate that the "convert/base" feature on Maple only works for integers and bases that are positive integers.
https://en.wikipedia.org/wiki/golden_ratio_base
https://en.wikipedia.org/wiki/negative_base
https://en.wikipedia.org/wiki/quater-imaginary_base
I am trying to animate quadrics, and I don't understand the issue with my fourth animation on the elliptic paraboloid
Thanks for your help
QQEllipticPar.mw
Please help me how to plot the following Chemotaxis System in Maple. Great Thanks
PDE 1= diff(p(x,t),t)-diff(p(x,t)*q(x,t),x)=D*diff(p(x,t),x,x)
PDE 2 = diff(q(x,t),t)-diff(p(x,t),x)=0
with the initial conditions
p(x)=0.5+1/(1+exp(2*(x-30)))
p(x)=0.5+1/(1+exp(-2*(x-30)))
and the boundary conditions
p(0, t) = 1.5, p(1, t) = 0.5
q(0, t) = 0.5, q(1, t) = 1.5
Certainly, ½ cannot be a root of the following equations:
interface(version)
solvefor[x]((x-RealDomain:-`^`(2, -1))*RealDomain:-`^`(x-2*RealDomain:-`^`(3, -1), -1)*(1-sqrt(1-x*(x-2*RealDomain:-`^`(3, -1))*RealDomain:-`^`(RealDomain:-`^`(x-RealDomain:-`^`(2, -1), 2), -1))) = 0)
Warning, solvefor is deprecated. Please use solve command.
[x = 0, x = 1/2]
`~`[limit]((x-1/2)*(1-sqrt(1-x*(x-2/3)/(x-1/2)^2))/(x-2/3), [x = 0, x = 1/2])
[0, undefined]
solvefor[x]((x-RealDomain:-`^`(2, -1))*RealDomain:-`^`(x-2*RealDomain:-`^`(3, -1), -1)*(1-sqrt(1+3*x*(x-2*RealDomain:-`^`(3, -1))*RealDomain:-`^`(5*RealDomain:-`^`(x-RealDomain:-`^`(2, -1), 2), -1))) = 0)
[x = 0, x = 1/2]
`~`[limit]((x-1/2)*(1-sqrt(1+3*x*(x-2/3)/(5*(x-1/2)^2)))/(x-2/3), [x = 0, x = 1/2])
[0, undefined]
Download solvefor_BUG.mw
But why can't Maple's solvefor rigorously verify (or at least try to check) the solution by itself?
Please note that this issue is irrelevant to the alleged deprecated command. You may reproduce these via :-solve, Degrees:-solveRealDomain:-solvePDEtools:-Solve, etc.
First 215 216 217 218 219 220 221 Last Page 217 of 2430
