I obtain the adjacency matrix from a graph. We know that it is indexed according to the order of vertices in the Vertices. But what if I want to rearrange it in a different order? Here is a specific example.
with(GraphTheory):
g:=Graph({{2,3},{1,2}});
Vertices(g); #[1,2,3]
AdjacencyMatrix(g);
I would like to display this matrix in the order of [3, 1, 2].
I get the following error: "Error, (in dsolve) invalid input: 'PDEtols/sdsolve' expects its 1st argument, SYS, to be of type OR(set(..."
I don't know what's wrong. My equations look like a set to me.
My equations:
{0 = -F__Ay - F__By, 0 = 25*F__Oy + 25*F__Ay - 25*F__By, diff(theta__1(t), t)*t - theta__1(t) = 0, -x__1(t) + 25*cos(theta__1(t)) = 0, -y__1(t) + 25*sin(theta__1(t)) = 0, (2500*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 - 50*cos(theta__1(t))*diff(theta__2(t), t)*theta__2(t) = F__Ax + F__Ox + F__Bx, (2500*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 - 50*cos(theta__1(t))*diff(theta__2(t), t)*theta__2(t) = F__Ay + F__Oy + F__By, diff(theta__2(t), t)*t - Pi/4 - theta__2(t) = 0, x__1(t) + 25*cos(theta__1(t)) - x__2(t) - 50*cos(theta__2(t)) = 0, y__1(t) + 25*sin(theta__1(t)) - y__2(t) - 50*sin(theta__2(t)) = 0, (1250*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 = -F__Ax - F__Bx, (1250*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 = -50*F__Ay + 50*F__By}
My solve:
dsolve({eqs[1] = 0, eqs[2] = 0, eqs[3] = 0, eqs[4] = 0, eqs[5] = 0, eqs[6] = 0, eqs_Mq[1] = eqs_g[3], eqs_Mq[1] = eqs_g[6], eqs_Mq[2] = eqs_g[1], eqs_Mq[2] = eqs_g[2], eqs_Mq[3] = eqs_g[4], eqs_Mq[3] = eqs_g[5]}, numeric)
Anyone can tell me what I'm doing wrong?
clutch.mw
I have say a
1) n cross n matrix A
2)  n cross 1 matrix B
I want to elementwise divide that is /~ each column of  by B and store in A itself like this
If b_1 is in B and a_11 is in A i want   b_1/~a_11 in a_11
That is i divide
B /~ A first column
B /~ A second column
Like that for all its n columns
Kind help please
To illustrate, here is an HTML example that overlays a circle and a letter
<span style="position: relative; font-size: 2em;">&#x25CB;<span style="position: absolute; top: 1.0em; right: 0.4em; font-size: 0.4em;">Y</span></span>
than can be pasted here to visualize.
I am not sure if that is possible with Maples typesetting tags.
Hello everyone!
I have an expression for the resonant frequency in terms of some geometric paremeter, say "x", i.e. f(x). I want to plot it together with the resonant wavelength (lambda=c/f) in the same plot. The "dualaxisplot" produces two curves (f(x), lambda(x)) with two uniform axes to the left and to the right. I am wondering is there a reasonably simple way to make it look as one curve, but with the second (e.g. lambda) axes nonuniformely scaled to fit the curve f(x)?
Many thanks in advance for your suggestions!
How do I combine a number of functions into a composite one?
For example
x := T -> (A - 1/T)/C;
y := x -> sqrt(1/27*B^3/C^3 + 1/4*x^2);
Combined into a final composite function
R := T -> exp((y - 1/2*x)^(1/3) - (y + 1/2*x)^(1/3)); such that the function R evaluates x and y as functions themselves.
Many times this sort of function definition makes it easier for the human.
Frac_C := proc (expr, a, t, alpha) local ig, m, tau;
m := ceil(alpha);
ig := (t-tau)^(m-alpha-1)*(diff(eval(expr, t = tau), tau$m));
`assuming`([(int(ig, tau = a .. t))/GAMMA(m-alpha)], [a < t]);
r := .5;
k := .7;
eq1 := Frac_C(x, 0, t, r)-y(t) = 0;
eq2 := Frac_C(y, 0, t, k)-x(t)-2*t = 0;
eq3 := x(0)-y(1) = 0;
eq4 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x), x = 1)) = 0;
eq5 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x, x), x = 1)) = 0;
eq6 := eval(diff(y(x), x), x = 0)-x(1)-2 = 0;
eq7 := y(0) = 0;
N := 5;
x[c] := [seq(a[i], i = 0 .. N)];
y[c] := [seq(b[i], i = 0 .. N)];
for n to N do
subs([seq(x(i) = x[c][i], i = 0 .. n), seq(y(i) = y[c][i], i = 0 .. n)], {eq1, eq2, eq3, eq4, eq5, eq6, eq7});
soln := solve({eq3, eq4, eq5, eq6, eq7, seq(coeff(lhs(eq), t, j) = 0, eq in {eq1, eq2})}, {a[n+1], b[n+1]});
x[c][n+1] := eval(a[n+1], soln);
y[c][n+1] := eval(b[n+1], soln);
x[s] := add(x[c][i]*t^(i-1), i = 1 .. N+1);
y[s] := add(y[c][i]*t^(i-1), i = 1 .. N+1);
x[s];
y[s];
Hi, i want to calculate fourier transform of functions with fractional powers. how can i do this? for example what is fourier transform of sqrt(x) ? I want a function or an expression as output, not the inetgral itself. thnx in advance
restart:with(inttrans):
f := x -> x^(1/2);
int(f(x)*exp(-I*w*x), x = -infinity .. infinity);
proc (x) options operator, arrow; x^(1/2) end proc
int(x^(1/2)*exp(-I*w*x), x = -infinity .. infinity)
fourier(f(x),x,w)
fourier(x^(1/2), x, w)
Download fracfourier.mw
How can I export data from the plot? Following is my Maple code.
with(PDEtools);
v_0 := 1;
vstar := 10;
r_0 := 1;
k := 0.1;
m := 0.1;
PDE := diff(v(r, t), t) = k*(diff(v(r, t), r, r) + diff(v(r, t), r)/r);
                                                / d         \
                           /  2         \   0.1 |--- v(r, t)|
          d                | d          |       \ dr        /
  PDE := --- v(r, t) = 0.1 |---- v(r, t)| + -----------------
          dt               |   2        |           r
                           \ dr         /
ans := pdsolve(PDE, HINT = f(r)*g(t));
ans := Typesetting:-mcomplete|vApplyFunction(rt)equalsf__1
                                              ||DifferentialD
  ApplyFunction(r) f__2ApplyFunction(t) where ||--------------
                                              ||DifferentialDt
  f__2ApplyFunction(t)equals0.1 f__2ApplyFunction(t) _c[1]
  DifferentialD
  --------------- f__1ApplyFunction(r)equals1. f__1ApplyFunction(
  DifferentialDr
                /DifferentialD                      \//
             1. |-------------- f__1ApplyFunction(r)|||
                \DifferentialDr                     /||
  r) _c[1] - ----------------------------------------||,
                                r                    ||
  Typesetting:-_Hold|[PDESolStruc|v(r, t) = f__1(r) f__2(t), [<
   d
  --- f__2(t) = 0.1 f__2(t) _c[1],
   dt
                                       / d         \\ ]\]\\
    2                               1. |--- f__1(r)|| ]|]||
   d                                   \ dr        /| ]|]||
  ---- f__1(r) = 1. f__1(r) _c[1] - ---------------- >]|]||
     2                                     r        | ]|]||
   dr                                               | ]|]||
build(ans);
                  /1         \             /           (1/2)  \
v(r, t) = c__3 exp|-- _c[1] t| c__1 BesselJ\0, (-_c[1])      r/
                  \10        /
             /1         \             /           (1/2)  \
   + c__3 exp|-- _c[1] t| c__2 BesselY\0, (-_c[1])      r/
             \10        /
design;
BC1 := eval(v(r, t) - v_0 = 0, r = 20);
                    BC1 := v(20, t) - 1 = 0
BC2 := D[1](v)(0, t) = 0;
NULL;
IC := v(r, 0) = v_0 + (vstar - v_0)*exp(-0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
                                    (1/2)    /            2\
   IC := v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /
conds := {BC1, BC2, IC};
    conds := { v(20, t) - 1 = 0,
                                 (1/2)    /            2\
      v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /,
      D[1](v)(0, t) = 0 }
answer:=pdsolve(PDE,conds,HINT=);
Error, invalid =
Typesetting:-mambiguous(answerAssignpdsolveApplyFunction(PDEcomma
  condscommaTypesetting:-mambiguous(HINTequalslowast,
  Typesetting:-merror("invalid =")))semi)
u := r -> v_0 + (vstar - v_0)*exp((-1)*0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
u := proc (r) options operator, arrow, function_assign;
   v_0+(vstar-v_0)*exp(-.5*(r-r_0)^2/m^2)/(m*sqrt(2*Pi)) end proc
plot(u(r), r = 0 .. 10);
                                 (1/2)    /            2\
      D[1](v)(0, t) = 0 }
BCs := {BC1, BC2};
          BCs := {v(20, t) - 1 = 0, D[1](v)(0, t) = 0}
pde_solve = pdsolve(PDE, BCs, IC);
solution := pdsolve(PDE, conds, numeric);
                  solution := _m1440390954528
t1 = 0 .. 10;
r1 = 0 .. 10;
solution, t1, r1;
                        solution, t1, r1
sol := pdsolve(PDE, conds, numeric, time = t, range = 0 .. 20, spacestep = 0.1, timestep = 0.1);
                     sol := _m1440421519392
sol:-animate(t = 0 .. 20, frames = 100);
M := sol:-value();
sol:-plot3d(r = 0 .. 10, t = 0 .. 20);
I have give this below fit command my data is only continous data either positive or negative float data. Their never any complex number at all.
I use the below fit command
Error, complex argument to max/min
It can be observed it is running into error in C1 I dont know why can someone suggest where should I check and why is this happening kind help.   In Excel we can see the intercept coming big.
I attach the toycode to see the error I get too
toycode.mw
I want to know the exponent of one particular factor of an integer. For example:
k:=24;
ifactor(k) = (2)^3(3)
and I want to write a module to extract the exponent of (3) for any arbitrary k.
I can't select for the presence of 3 because it will pick up the factor (2)^3 and then it gets complicated to decide that I don't want this factor anyway.
If I somehow manage to select the factor (3) using "op" and scanning through each factor in turn, then substitute 3=x, it turns out that degree(%,x) doesn't work because the factor x is enclosed in brackets; similarly trying
log(%,3) fails for the same reason.
There has to be a simple way, but I just don't see it.
Any suggestions are appreciated.
In GraphTheory ,how do you make more than one edge between two points.
Could you help me to solve this problem for the parameter beta?
e1:= 0.5; e2:=0.2;theta:=5;yeq:=e2;
.5
.2
5
.2
f:=(theta*x-1)*(1-x)*(1+beta*x^2)-y;
g:=x/(1+beta*x^2); gs:=unapply(g,x);
(5*x-1)*(1-x)*(beta*x^2+1)-y
x/(beta*x^2+1)
proc (x) options operator, arrow; x/(beta*x^2+1) end proc
fs:=subs(y=yeq,f);
(5*x-1)*(1-x)*(beta*x^2+1)-.2
assumptions:=x>1/theta, x<1,beta>0,beta<1,gs(x)>e1;
solve(fs=0,x,useassumptions) assuming assumptions;
1/5 < x, x < 1, 0 < beta, beta < 1, .5 < x/(beta*x^2+1)
Warning, solve may not respect assumed property 'real' on 'x/(beta*x^2+1)'.
Error, (in type/realcons) too many levels of recursion
gs2:=subs(beta=0.6,gs(x));
x/(.6*x^2+1)
sol:= solve(subs(beta=0.6,fs=0),x,useassumptions) assuming x>1/theta, x<1;
.2514854589, .9665623271
subs(x=sol[1],gs2);
.2422912423
Download Rootsfind.mw
I put this command and It keep saying  plot(f(x), x = -0.667 .. 1.71, y = -5 .. 20, gridlines); Error, (in plot) unexpected options: [1.71 = -.667 .. 1.71, y = -5 .. 20] . How can I fix this
First 214 215 216 217 218 219 220 Last Page 216 of 2430
