I am trying to see if I can get speed up by using dsolve inside thread.
I made very simple example of global list of two differential equations to start with.
Next, created two threads where each picks one ode from the global list to process. So they should in theory run in parallel. The list of ode's is a global list in the worksheet for now.
But I keep getting error when calling dsolve
               Error, (in dsolve) type `System` does not exist
I tried also passing the actual ode to the thread, still, same error.
Next, I did not pass anything, but called dsolve directly from inside thread proc on same ode. The ode is local variable inside the proc. I still get same error.
                        Does this mean dsolve is not supported by threads?
But when I searched this subject, AI says it works in threads:
Everything works OK when I run dsolve in worksheet outside thread (i.e. normally).
I will show below worksheet showing these cases. I must not be doing something right. But what? Can one not pass data from global worksheet to the thread this way? Or does one needs to load something in each thread to make this work?
`The "Physics Updates" version in the MapleCloud is 1840 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
libname;
Example 1. Passing index of list to thread
g_list:=[sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0,
         diff(y(x),x)=lambda*sin(lambda*x)*y(x)^2+a*cos(lambda*x)^n*y(x)-a*cos(lambda*x)^(n-1)]:
work_func:=proc(i::posint)
  :-dsolve(g_list[i]):
Threads:-Wait(  seq( Threads:-Create( work_func(i)), i=1..2) );
Example 2. Passing actual ode itself to thread
work_func:=proc(ode::`=`)
  :-dsolve(ode):
Threads:-Wait(  seq( Threads:-Create( work_func(g_list[i])), i=1..2) );
Example 3. Normal processing. No threads
  :-dsolve(ode):
for item in g_list do
    work_func(item);
#no error
Example 4. do not pass anything. Just call dsolve
  local x,t;
  local ode:=sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0;
  :-dsolve(ode):
Download error_dsolve_using_threads_dec_26_2024.mw
Here are the graphs of a parabola and a straight line:
plots:-display(
        plot(x^2, x=-1..1),
        plot((x+1)/2, x=-1..1),
color=["Red","Green"]);
Suppose I want to plot the part of the parabola that lies below
the straight line, and suppose, just to be nasty, I choose to do it
with implicitplot:
plots:-implicitplot(y=x^2, x=-1..1, y=0..(x+1)/2);
That is not a parabola at all.  [And where does the "ynew" label come from?]
This behavior was introduced in Maple 2022.
In Maple 2021 we get the expected result:
Download mw.mw
It is not clear to me how to set up parallel processing for let's say 10 completely independent tasks/processes process1,process2 .....process10
Further, no communication between the 10 tasks/processes, process1,process2 .....process10, takes place and they only use  previously calculated functions and variables in the worksheet.
So how do you set up the 10 processes to run in parallel using proc or grid.  ??
I cannot make out from the examples in the manual how and where the processes are run.
I am looking for a more eligent way to convert a Vector to a Diagonal Matrix.
V:=Vector[column](3, [0.5863730366, 0.1171249270, 0.2965020364])
Vector(3, {(1) = .5863730366, (2) = .1171249270, (3) = .2965020364})
Vm:=Matrix(3,[[V[1],0,0],[0,V[2],0],[0,0,V[3]]])
Matrix(3, 3, {(1, 1) = .5863730366, (1, 2) = 0, (1, 3) = 0, (2, 1) = 0, (2, 2) = .1171249270, (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = .2965020364})
Vm1:=Matrix(3,3):
for i to 3 do
Vm1[i,i]:=V[i];
Vm1
Download 2024-12-26_Q_Diagonal_Matrix_from_Vector.mw
This is an ode from textbook. dsolve gives new error I have not seen before.
Maple 2024.2 on windows 10.
`The "Physics Updates" version in the MapleCloud is 1839 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
libname;
ode:=y(x)^2*diff(y(x),x$3)-(3*y(x)*diff(y(x),x)+2*x*y(x)^2 )*diff(y(x),x$2)+(2*diff(y(x),x)^2+2*x*y(x)*diff(y(x),x)+3*x^2*y(x)^2)*diff(y(x),x)+x^3*y(x)^3=0;
y(x)^2*(diff(diff(diff(y(x), x), x), x))-(3*y(x)*(diff(y(x), x))+2*x*y(x)^2)*(diff(diff(y(x), x), x))+(2*(diff(y(x), x))^2+2*x*y(x)*(diff(y(x), x))+3*x^2*y(x)^2)*(diff(y(x), x))+x^3*y(x)^3 = 0
dsolve(ode);
Error, (in factor) too many levels of recursion
infolevel[dsolve]:=5;
5
dsolve(ode);
Methods for third order ODEs:
trying 3rd order ODE linearizable_by_differentiation
differential order: 3; trying a linearization to 4th order
trying differential order: 3; missing variables
trying differential order: 3; exact nonlinear
trying 3rd order, integrating factor of the form mu(y'') for some mu
Trying the formal computation of integrating factors depending on any 2 of [x, y, y', y'']
         *** Sublevel 2 ***
         Methods for first order ODEs:
         trying a quadrature
         trying 1st order linear
         <- 1st order linear successful
Successful computation of 3 integrating factors: [x*exp(-1/2*x^2*(I*2^(1/2)+1))*KummerM(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2)/y(x), x*exp(-1/2*x^2*(I*2^(1/2)+1))*KummerU(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2)/y(x), x*exp(-1/2*x^2*(I*2^(1/2)+1))*(Int(x*KummerM(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2)*exp(-1/2*x^2*(I*2^(1/2)-1)),x)*KummerU(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2)-Int(x*KummerU(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2)*exp(-1/2*x^2*(I*2^(1/2)-1)),x)*KummerM(3/4+1/8*I*2^(1/2),3/2,I*2^(1/2)*x^2))/y(x)]
Attempting computing related first integrals...
Download dsolve_factor_dec_24_2024.mw
tracelast;  gives long output with this at end
#(IntegrationTools:-Indefinite:-Polynomial,14): return poly/primitivepart*thisproc(primitivepart,var)
 IntegrationTools:-Indefinite:-Polynomial called with arguments: (8*I)*x*KummerM(3/4+((1/8)*I)*2^(1/2), 3/2, I*2^(1/2)*x^2)*x1*2^(1/2)-(3*I)*2^(1/2)*KummerM(3/4+((1/8)*I)*2^(1/2), 3/2, I*2^(1/2)*x^2)*y+(7*I)*2^(1/2)*KummerM(((1/8)*I)*2^(1/2)+7/4, 3/2, I*2^(1/2)*x^2)*y+12*x^2*KummerM(3/4+((1/8)*I)*2^(1/2), 3/2, I*2^(1/2)*x^2)*y+8*x*KummerM(3/4+((1/8)*I)*2^(1/2), 3/2, I*2^(1/2)*x^2)*x1+4*KummerM(((1/8)*I)*2^(1/2)+7/4, 3/2, I*2^(1/2)*x^2)*y, x1, nofactor = false
 #(IntegrationTools:-Indefinite:-Polynomial,8): newpoly := factor(poly)
 locals defined as: p = p, primitivepart = primitivepart, base = base, exponent = exponent, subpolys = subpolys, change = change, newpoly = newpoly, u = u
Also, this error can not be cought using try/catch.
I cannot find any examples of how to raise the software memory limits to maximum with the mentioned  -T switch in the manual to avoid memory allocation error popup.
Neither are there any examples posted on the web.
It cannot be a hardware allocation error, as the system memory is large.
So how is the -T switch implimented
I'm working on solving a system of ODEs in Maple that models an epidemic scenario, tracking the number of susceptible, infected, and recovered individuals over time. Here's what I've done so far:
Download sir_model.mw
Created a table of results at daily intervals with the following code:
results := [seq([t = tval, s = round(evalf(sol(tval)[2][1])), i = round(evalf(sol(tval)[2][2])),r = round(evalf(sol(tval)[2][2]))], tval = 0 .. 50)];
printf("%-10s %-15s %-15s %-15s\n", "Day", "Infected", "Recovered");
printf("---------------------------------------------\n");
for entry in results do
    printf("%-10d %-15d %-15d %-15d\n", entry[t],entry[s], entry[i], entry[r]);
but I encountered an error (in fprintf) integer expected for integer format
just a quick question: Is it possible to customize the default worksheet with my own settings/styles, such that my settings are loaded automically when I create a new worksheet? I've tried to change my settings/styles and apply that globally but, once I leave MF and re-launch it, my settings/styles are not loaded.
Thanks very much in advance.
Hello, I have a question regarding finding two vectors that result in a resulting vector with only the directions of the two needed vectors.
Given:
- Vector F_RC1
- Unit Vector of F_RC1Y (called EV_C1Y)
- Unit Vector of F_RC1_ST (called EV_C1_ST)
Needed
- F_RC1_ST
- F_RC1Y
The picture below and the file should make it clear.
vector_question.mw
How do I approach this? Best regards,
I knowI can use a loop but I would like something neater. igcd can be applied to a list. Is there a way to map or use @ to apply gcd to a list?
lst:= [4, 2, 8, 4];
lst1 := [a^3/10, -a^2/2, a, a^4/4]
                      lst := [4, 2, 8, 4]
                        [1   3    1  2     1  4]
                lst1 := [-- a , - - a , a, - a ]
                        [10       2        4   ]
gd:=igcd(lst);
                            gd := 2
gd1=(gcd@op)(lst1);
Maple's Student:-ODEs:-ODESteps solves an ode by doing change of variable on the independent variable, but the resulting ode is wrong and final answer is wrong.
Here is one such example
ode:=diff(diff(y(x),x),x)*sin(x)^2 = 2*y(x);
Student:-ODEs:-ODESteps(ode):
But this result is wrong. First of all, we can not have both x and t  in the same ode. This is what dchange gives
ode:=diff(y(x),x$2)*sin(x)^2-2*y(x)=0;
tr:={PDEtools:-Solve(t=ln(x),x)};
simplify(PDEtools:-dchange(tr,ode,[t]))
It looks like Student:-ODEs:-ODESteps is trying to solve  sin(x)^2*y'' + 2 y=0 as EULER type ode.
But Euler type ode will look like  x^2*y'' +2 y=0
It seems to have confused sin(x)^2 with x^2. This change of variable it used only works for EULER type ode with polynomial coefficient, not trig coefficients.
Maple 2024.2 on Windows 10
Let x be some name:
x := asdf;
asdf
I wish to make a new name, y, whose value is the first character in x:
convert(x, string):
y := convert(%[1], name);
a
That works but seems too convoluted.  Is there a better way of doing that?
i already use this method for a lot of equation but this time something not normal hapening what is problem?
with(PDEtools)
with(LinearAlgebra)
with(Physics)
with(SolveTools)
eq0 := -4*alpha*k^2*m^2*n^2*A[0]^2+4*beta*k*m*n^2*A[0]^3-4*gamma*k*m*n^2*A[0]^3+4*delta^2*m*n^2*A[0]^2-4*n^2*sigma*A[0]^4-4*m*n^2*w*A[0]^2 = 0
eq1 := -8*alpha*k^2*m^2*n^2*A[0]*A[1]+12*beta*k*m*n^2*A[0]^2*A[1]-12*gamma*k*m*n^2*A[0]^2*A[1]+8*delta^2*m*n^2*A[0]*A[1]-16*n^2*sigma*A[0]^3*A[1]+2*a*alpha*m*n*A[0]*A[1]-8*m*n^2*w*A[0]*A[1] = 0
eq2 := -4*alpha*k^2*m^2*n^2*A[1]^2+12*beta*k*m*n^2*A[0]*A[1]^2-12*gamma*k*m*n^2*A[0]*A[1]^2+4*delta^2*m*n^2*A[1]^2-24*n^2*sigma*A[0]^2*A[1]^2+a*alpha*m^2*A[1]^2+3*alpha*b*m*n*A[0]*A[1]-4*m*n^2*w*A[1]^2 = 0
eq3 := 4*beta*k*m*n^2*A[1]^3-4*gamma*k*m*n^2*A[1]^3-16*n^2*sigma*A[0]*A[1]^3+alpha*b*m^2*A[1]^2+alpha*b*m*n*A[1]^2+4*alpha*c*m*n*A[0]*A[1] = 0
eq4 := -4*n^2*sigma*A[1]^4+alpha*c*m^2*A[1]^2+2*alpha*c*m*n*A[1]^2 = 0
C := solve({eq0, eq1, eq2, eq3, eq4}, {a, b, c, `__ `*A[0]})
Download problem.mw
Can someone tell me how to calculate the Christoffel symbols in spherical coordinates in Euclidean three dimensional space?
Thank you very much in advance!
First 48 49 50 51 52 53 54 Last Page 50 of 2429
