For the past days I observe that reply to posts stucks at the progess bar
(using a firefox browser). I am wondering whether that is only on my installation. Loading pages is not slow as reported here. I have a suspicion that this happens after having previewed a reply before submission. I observe also sometimes a yellow background of the preview and sometimes a blue background.
I try to submit now with blue backgound
with(VectorCalculus); SetCoordinates('cartesian[x, y, z]')
with(ScientificConstants)
"with(Units[Simple]):"
g := evalf(Constant(g, units))
9.80665*Units:-Unit(m/s^2)
`#mover(mi("\`v__0\`"),mo("&rarr;"))` := `<,>`(v[0]*Unit('m'/'s'), 0*Unit('m'/'s'), 0*Unit('m'/'s'))
Vector(3, {(1) = v[0]*Units:-Unit(m/s), (2) = 0, (3) = 0})
`#mover(mi("a"),mo("&rarr;"))` := `<,>`(0*Unit('m'/'s'^2), g, 0*Unit('m'/'s'^2))
Vector(3, {(1) = 0, (2) = 9.80665*Units:-Unit(m/s^2), (3) = 0})
int(`#mover(mi("a"),mo("&rarr;"))`, t)
Vector(3, {(1) = 0, (2) = 9.80665*t*Units:-Unit(m/s^2), (3) = 0})
As you can see in (4) units are wrong. I have tried to insert them in int expression but nothing has work. Moreover using Units[Standard] packecge i get
Error, (in int) wrong number (or type) of arguments: wrong type of integrand passed to indefinite integration.
Download Units_and_Integrals.mw
I can't understand the error message generated during this animation. Any ideas? Thanks
TriagleSemblablesTest.mw
I want to have a 14 larger font instead of Times New Roman 12 for the whole worksheet or else a different font later.
Can't make sense of how this is all organized in Maple
You would say set a template , but ?
Hello. Can anybody point out to me what I am doing wrong below? I'm trying to solve the online model 4.1 of the book "An introduction to infectious disease modelling" by E. Vynnycky & R.G. White (2010). But all the information is below.
Where I get errors from the code below is right at the bottom, in dsolve:
# My Maple 2023 code:
# Initial values:
Sus_0 := total_popn - Infectious_0 - Immune_0:
Preinfectious_0 := 0:
Infectious_0 := 1:
Immune_0 := total_popn*prop_immune_0:
# Transmission- and infection-related parameters:
preinfectious_period := 8:
infectious_period := 7:
R_zero := 13:
f := 1/preinfectious_period:
r := 1/infectious_period:
beta := R_zero/(total_popn*infectious_period):
prop_immune_0 := 0:
# Demography-related parameters:
total_popn := 100000:
# Useful statistics:
new_infns := beta*Susc*Infe:
new_infectious := Prei*f:
prop_sus = Susc/total_popn:
R_n := R_zero*prop_sus:
propn_imm := 1 - prop_sus:
sum_pop := Susc + Prei + Infe + Immu:
ln_infectious := ln(Infe):
ln_cum_infe := ln(Cum_Infe):
ln_new_infectious := ifelse(0 < t, ln(new_infectious), 0):
# Defining the system of ODEs:
sys_ode:={
diff(Susc(t),t)=-beta*Susc(t)*Infe(t),
diff(Prei(t),t)=beta*Susc(t)*Infe(t)- Prei(t)*f,
diff(Immu(t),t)=Infe(t)*r,
diff(Cum_Infe(t),t)= Prei(t)*f,
diff(Infe(t),t)=Prei(t)*f-Infe(t)*r,
ics:={
Susc(0)=Sus_0,
Infe(0)=Infectious_0,
Immu(0)=Immune_0,
Prei(0)=Preinfectious_0,
Cum_Infe(0)=Infectious_0
Solution1:=dsolve({sys_ode,ics},type=numeric);
# HERE I GET THIS ERROR MESSAGE: "Error, (in dsolve/numeric/process_input) system must be entered as a set/list of
# expressions/equations"
Solution2:=dsolve({sys_ode,ics});
# HERE I GET THIS ERROR MESSAGE: "Error, (in dsolve) invalid arguments; expected an equation, or a set or list of them,
# received: {{diff(Immu(t),t) = 1/7*Infe(t), diff(Infe(t),t) = # 1/8*Prei(t)-1/7*Infe(t), diff(Prei(t),t) =
# 13/700000*Susc(t)*Infe(t)-1/8*Prei(t), diff(Susc(t),t) = -13/700000*Susc(t)*Infe(t), diff(Cum_Infe(t),t) = # 1/8*Prei(t)}}"
MY QUESTION: Can anybody tell me what I'm doing wrong in Solution1 and Solution2?
Best wishes and many thanks!
Ubuntu 22.04.
I have Maple-202[1-3] and an old installation of maplev-mode. maplev-mode fails to work.
In the emacs messages buffer, I see (typed from memory):
loading maple
maple loaded
maple not running
I removed all of maplev from my system.
I tried installing from the downloaded master.zip (RELEASE-=NOTES says 3.0.5).
make install fails:
> pwd
/tmp/maplev-master
> make install
Makefile:27: MapleLisp.mk: No such file or directory
make: *** No rule to make target 'MapleLisp.mk'.  Stop.
I tried installing from the cloud, but, failed. The error message (even run as root)
Error, (in PackageTools:-Install) permission denied
Will maplev-mode work?
Tom Dean
To observe the nip impact of the Variable Nip Roller, we created the following schematic and simulation. I set the y-coordinate of the Web to be the same, so I don't think there is a big problem for the Variable Nip Roller to simulate the nip. However, the simulation does not simulate with the warning "Nip is not on the contact arc". What is the reason for this and how can I set the nip arc again?
I am exploring the construction of the recorded table ( Frequency Table) of a statistical series. How can I display only the discrete values, without showing the interval form in the first column 'Range'?  Thank you
TableauRecenséQ.mw
While answering a question on this site I accidentally met expressions of the form binomial(n, min(n, r)+1) where both n and r are positive integers and n is strictly lower than r.
For the record the common definition of the binomial coefficient binomial(n, k) is based on the double inequality 0 <= k <= n  and the only generalized definition where k could be larger than n I know of is the NegativeBinomial distribution where we use
binomial(-n, k) which, with 0 <= k <= n  again makes the first operator lower than the second.
I tried to understand how Maple does this
binomial(n, min(n, r)+1) assuming n < r,  n::posint
(more generallyn, for any strictly positive integer p, binomial(n, min(n, r)+p) = 0 under the assumptions above)
I guess that the explanationrelies upon what I did to get the output (2) in the attached file.
Can you confirm/infirm this and, as I wasn't capable to find any clue in help(binomial), [Maple 2015], if the way maple computes
these results is documented elsewhere.
Thanks in advence.
Let us start with this result
t0 := binomial(n, min(n, r)+1);
eval(t0) assuming n < r;
eval(%) assuming n::posint;
# I didn't find in help(binomial) the argument used to get this last result.
binomial(n, n+1)
# What happens if binomial is converted into factorials
t1 := convert(t0, factorial);
eval(t1) assuming n < r;
factorial(n)/(factorial(min(n, r)+1)*factorial(n-min(n, r)-1))
Error, (in assuming) when calling '`one of {eval, min, factorial}`'. Received: 'numeric exception: division by zero'
# Or into GAMMA function?
t2 := convert(t1, GAMMA);
eval(t2) assuming n < r;
GAMMA(n+1)/(GAMMA(min(n, r)+2)*GAMMA(n-min(n, r)))
Error, (in assuming) when calling 'GAMMA'. Received: 'numeric exception: division by zero'
# Try to replace min(n, r) = n by n-epsilon and take the limit as epsilon goes to 0
# from the right.
t3 := algsubs(min(n, r) = n-epsilon, t2);
limit(t3, epsilon=0, right)
GAMMA(n+1)/(GAMMA(n-epsilon+2)*GAMMA(epsilon))
We recover here the result (1), but does Maple really proceed this way?
Download binomial.mw
This is a Tension Zone, an example of web handling.
The example probe on Roller1 shows various probe items, such as summary_WrapAngle and summary_Slipvelocity, but the ex_probe I attached to the same roller shows only four probe items: angle, angular velocity, angular acceleration, and torque. Why are the items different even though they are probes on the same roller?
the maple document is  p151.mw
Hi everyone, I'm trying to do some simple algebraic simplification operations and run into algsubs replacement failures,
 the symbol σ' is typed in this way:  σ +  prime (left Palettes -> Common Symbols -> prime) + (selecting σ'  and  press  Ctrl+Shift+A  make it  a  atomic variable)
I'm new to this, any help or suggestion is welcome, thanks!
Good day to all of you friends, just asking for your kind help.
I have been trying to get solution of the next integral but didn't have succes. The goal of the code is to perfom a variable change.
Best regards
r := simplify(rhs(isolate(r+(2*M*`r__\`+\``+a*m/sigma)*log[10](r/`r__\`+\``-1)/(`r__\`+\``-`r__-`)-(2*M*`r__-`+a*m/sigma)*log[10](r/`r__-`-1)/(`r__\`+\``-`r__-`) = `r__&lowast;`, r)))
Delta := -2*M*r+a^2+r^2
omega := sqrt(r^2+a^2+a*m/sigma)NULL
F := simplify(Delta*lambda*m__p/(2*m__p^2*omega^2*r^2*sigma+2*lambda^2*omega^2*sigma))
`r__&prop;` := int(F, `r__&lowast;`)
Download maple_primes_question.mw
We can see a list of functions for a package in the documentation, for example the package GroupTheory:
Is there a code based way to see all the functions in this package?
How  to make the integration
into the following form:
Thanks in advance,Q1.mw
Boundary condition of my problem is   f(0) =1  and  d(f)(1) = -(k[f]/k[nf])*Bi*f(1).
But i am getting error when solve this.How to clear this .
my attached file is,
HNF_1.mw
First 169 170 171 172 173 174 175 Last Page 171 of 2468
