Suppose I want to run several systems of equations as below, however, the processing time exceeds 45 thousand seconds (reaching hours of calculations)
  • What is better, buying a new processor (new notebook) or buying a new stick of RAM?
  • Or does none of this affect Maple? Therefore, it is just a computational disadvantage (the delay time), characterizing the slowness of the program for very large systems as an imminent characteristic.
  • Another question: The newer Maples (new versions) seem to be heavier to run. Is it just me? What seems to me is that the previous versions of Maple, because they contain fewer resources, are lighter and run certain calculations faster. Would this be correct?
  • Last question: Is it possible to do parallel processing in Maple? So that calculations on huge systems can be run faster
Thank you so much! :)
Help me, I want to make this system be stable on graphs? How to make this system stable in plot?
This is my model:
dx/dt=\[Alpha]*
  x[t]*(1 - (x[t]/n)) - ((\[Beta]*x[t]*
     y[t])/(1 + (\[CapitalTau]*\[Beta]*x[t]))) - (x[
    t]*\[CapitalEpsilon]);
dy/dt=y'[t] == -\[Gamma]*y[t];
Prove: If a is an irrational number, then the function y = cos (ax) + cos x is not periodic.
Is it possible to graphically represent or calculate this fact using an example?
I try to get some Bilinear form for some PDE equation  and already i have algorithm by writing in lecture but i can't apply i don't what is mistake i did, and i didn't seen some of this lecture code in maple  like (myint(expr,var))
 i  do upload PIcture of algorithm and example which they get Bilinear form
Bilinear.mw
thanks for any help
I have a 2-parameters quartic equation in n (where n>=2 and integer) and want to find for which parameter values it is zero, if any exists.
Here I am analyzing the signs of each coefficient, but is there a faster way to solve my problem?
quartic_equation_in_n.mw
I am creating an algebra that includes shift operators. These operators commute with one another, but do not commute with anything else. I know that the Physics package enables you to make symbols non-commutative, but I would still like these operators to commute with one another. How can I do that?
Maple code example p.136 programming guide.
Explain the function of the word "divisible" in this maple code?
Why isn't divisible defined with an operator like -> ?
>L:= [seq( i, i=2..100)]:
> divisor := 2:
>while ( numelems( L ) > 0 )
do
divisible, L := selectremove( i->(i mod divisor = 0), L ):
n := numelems( divisible );
if ( n > 0 ) then
printf( "%d integer%s whose smallest prime divisor is %d\n",
n, `if`( n > 1, "s", "" ), divisor ):
divisor:=nextprime(divisor);
If a point is chosen in the Euclidean plane, then it is red or black.
It must be proven that there is then an equilateral triangle with corners of the same color.
dsolve gets stuck on a problem. Attached is the worksheet.
In Case I, dsolve solves the two ODEs separately. In Case II, dsolve solves them together, but only if I define a constant. In Case III the constant is not defined. dsolve never returns, and I have to hit the stop sign. The question I have: Is there a consistent method to the failure so that I can avoid the problem in the future with other ODEs?
dsolve_bug.mw
Question: Is there a style for the icons from the palettes?
(The rest of this post is a screenshot because MaplePrimes can't show the change in fonts.)s a
How do I get alpha to display as the Greek letter in DataFrame Row column?
#varp:=alpha
QQFProj := proc(q12::algebraic, q23::algebraic,
                q34::algebraic, q14::algebraic,{varp:=:-alpha},
                  prnt::boolean:=true) #{columns:=[QQFproj,Q13proj,Q24proj]}
  description "Projective quadruple quad formula and intermediate 13 and 24 quads. Useful for cyclic quadrilaterals";
  local qqf,q13,q24, sub1,sub2,sub3, R,values,DF,lens;
  uses   DocumentTools;
  sub1:= (q12 + q23 + q34 + q14);
  sub2:=-4*(q12*q23*q34);
  sub3:=64*q12*q23;
  qqf:=(sub1+sub2)^2-sub3;
  q13:=(q12-q23)^2;
  q24:=varp*(q23-q34)^2;
  if prnt then
   values:=<qqf,q13,q24>;
   DF:=DataFrame(<values>, columns=[`"Values Equations"`],rows=[`#1  QQF`,`#2  Q13`,cat(`#3  Q24 (`,varp,`)`)]);
   lens := [4 +8* max(op(length~(RowLabels(DF)))),4+ min(max( 10*(length~(values))),1000)];#op(length~(ColumnLabels(DF)0)
   Tabulate(DF,width=add(lens),widthmode = pixels,weights = lens);
  return qqf,q13,q24
  return qqf,q13,q24
 q12:=1/2:q23:=9/10:q34:=25/26:q41:=9/130:#Cyclic quadrilateral
q12:=sqrt(17+a)/2:q23:=(r^2+t^2)^2/10:q34:=((a+b+c)^4/26):q41:=sqrt(17+b)/130:
Q:=QQFProj(q12,q23,q34,q41,true):
Download 2024-12-01_Q_Data_Table_alpha_as_Greek_Letter.mw
An oddly shaped Christmas package is a collection of centrally stacked cube-shaped boxes with ever smaller sides. From bottom to top, the edge lengths of the stacked cubes run like the sequence of the reciprocals of the sequence of the square roots of the natural numbers. How high is the package? How much paper is needed to wrap the package? What is the total volume enclosed by all the packages?
why i take intgral from equation it must apply for each term but just by sign is show up how it will work?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(w(x, t))
w(x, t)*`will now be displayed as`*w
declare(f(x, t))
f(x, t)*`will now be displayed as`*f
pde := diff(w(x, t), `$`(t, 2))-a*(diff(w(x, t), `$`(x, 4)))-b*(diff(w(x, t), `$`(x, 2), `$`(t, 2)))+(diff(w(x, t), t))*(diff(w(x, t), `$`(x, 2)))+2*(diff(w(x, t), x))*(diff(w(x, t), x, t)) = 0
diff(diff(w(x, t), t), t)-a*(diff(diff(diff(diff(w(x, t), x), x), x), x))-b*(diff(diff(diff(diff(w(x, t), t), t), x), x))+(diff(w(x, t), t))*(diff(diff(w(x, t), x), x))+2*(diff(w(x, t), x))*(diff(diff(w(x, t), t), x)) = 0
Y := w(x, t) = 2*(diff(ln(f(x, t)), `$`(x, 2)))
w(x, t) = 2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2
L := eval(pde, Y)
2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))/f(x, t)^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-4*(diff(diff(f(x, t), t), x))^2/f(x, t)^2+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))/f(x, t)^3-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-a*(2*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))/f(x, t)-12*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+60*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-30*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))^3/f(x, t)^4+240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))*(diff(diff(f(x, t), x), x))/f(x, t)^3-20*(diff(diff(diff(f(x, t), x), x), x))^2/f(x, t)^2+720*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4/f(x, t)^5-540*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2/f(x, t)^4+60*(diff(diff(f(x, t), x), x))^3/f(x, t)^3-240*(diff(f(x, t), x))^6/f(x, t)^6)-b*(32*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2/f(x, t)^3+16*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(diff(f(x, t), t), t), x))*(diff(f(x, t), x))/f(x, t)^3+12*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-48*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^4-240*(diff(f(x, t), x))^4*(diff(f(x, t), t))^2/f(x, t)^6+384*(diff(f(x, t), x))^3*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^5+48*(diff(f(x, t), x))^4*(diff(diff(f(x, t), t), t))/f(x, t)^5-144*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))^2/f(x, t)^4+32*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3+96*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))/f(x, t)^3-48*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))/f(x, t)^4-36*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), t))^2/f(x, t)^4-288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^4-72*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2/f(x, t)^4-144*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2/f(x, t)^4+288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))^2/f(x, t)^5+2*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))/f(x, t)+24*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)^3-8*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2-12*(diff(diff(diff(diff(f(x, t), t), t), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-4*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*(diff(f(x, t), t))/f(x, t)^2-16*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2-12*(diff(diff(diff(f(x, t), t), x), x))^2/f(x, t)^2+4*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2)+(2*(diff(diff(diff(f(x, t), t), x), x))/f(x, t)-2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))/f(x, t)^2-4*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(f(x, t), x))^2*(diff(f(x, t), t))/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4)+2*(2*(diff(diff(diff(f(x, t), x), x), x))/f(x, t)-6*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))/f(x, t)^2+4*(diff(f(x, t), x))^3/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), t), x), x), x))/f(x, t)-6*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))/f(x, t)^2-2*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))/f(x, t)^2+12*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3-6*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+12*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))/f(x, t)^3-12*(diff(f(x, t), x))^3*(diff(f(x, t), t))/f(x, t)^4) = 0
numer(lhs(2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))/f(x, t)^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-4*(diff(diff(f(x, t), t), x))^2/f(x, t)^2+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))/f(x, t)^3-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-a*(2*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))/f(x, t)-12*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+60*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-30*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))^3/f(x, t)^4+240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))*(diff(diff(f(x, t), x), x))/f(x, t)^3-20*(diff(diff(diff(f(x, t), x), x), x))^2/f(x, t)^2+720*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4/f(x, t)^5-540*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2/f(x, t)^4+60*(diff(diff(f(x, t), x), x))^3/f(x, t)^3-240*(diff(f(x, t), x))^6/f(x, t)^6)-b*(32*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^3+16*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(diff(f(x, t), t), t), x))*(diff(f(x, t), x))/f(x, t)^3+384*(diff(f(x, t), x))^3*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^5+32*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3+96*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))/f(x, t)^3-48*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))/f(x, t)^4-72*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2/f(x, t)^4-144*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2/f(x, t)^4+288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))^2/f(x, t)^5+48*(diff(f(x, t), x))^4*(diff(diff(f(x, t), t), t))/f(x, t)^5-144*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))^2/f(x, t)^4-36*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+24*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)^3-8*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2-12*(diff(diff(diff(diff(f(x, t), t), t), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-4*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*(diff(f(x, t), t))/f(x, t)^2-16*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2+48*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2/f(x, t)^3+12*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-48*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^4-240*(diff(f(x, t), x))^4*(diff(f(x, t), t))^2/f(x, t)^6-288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^4+2*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))/f(x, t)-12*(diff(diff(diff(f(x, t), t), x), x))^2/f(x, t)^2)+(2*(diff(diff(diff(f(x, t), t), x), x))/f(x, t)-2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))/f(x, t)^2-4*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(f(x, t), x))^2*(diff(f(x, t), t))/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4)+2*(2*(diff(diff(diff(f(x, t), x), x), x))/f(x, t)-6*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))/f(x, t)^2+4*(diff(f(x, t), x))^3/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), t), x), x), x))/f(x, t)-6*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))/f(x, t)^2-2*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))/f(x, t)^2+12*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3-6*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+12*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))/f(x, t)^3-12*(diff(f(x, t), x))^3*(diff(f(x, t), t))/f(x, t)^4) = 0))*denom(rhs(2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))/f(x, t)^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-4*(diff(diff(f(x, t), t), x))^2/f(x, t)^2+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))/f(x, t)^3-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-a*(2*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))/f(x, t)-12*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+60*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-30*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))^3/f(x, t)^4+240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))*(diff(diff(f(x, t), x), x))/f(x, t)^3-20*(diff(diff(diff(f(x, t), x), x), x))^2/f(x, t)^2+720*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4/f(x, t)^5-540*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2/f(x, t)^4+60*(diff(diff(f(x, t), x), x))^3/f(x, t)^3-240*(diff(f(x, t), x))^6/f(x, t)^6)-b*(32*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^3+16*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(diff(f(x, t), t), t), x))*(diff(f(x, t), x))/f(x, t)^3+384*(diff(f(x, t), x))^3*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^5+32*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3+96*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))/f(x, t)^3-48*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))/f(x, t)^4-72*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2/f(x, t)^4-144*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2/f(x, t)^4+288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))^2/f(x, t)^5+48*(diff(f(x, t), x))^4*(diff(diff(f(x, t), t), t))/f(x, t)^5-144*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))^2/f(x, t)^4-36*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+24*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)^3-8*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2-12*(diff(diff(diff(diff(f(x, t), t), t), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-4*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*(diff(f(x, t), t))/f(x, t)^2-16*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2+48*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2/f(x, t)^3+12*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-48*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^4-240*(diff(f(x, t), x))^4*(diff(f(x, t), t))^2/f(x, t)^6-288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^4+2*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))/f(x, t)-12*(diff(diff(diff(f(x, t), t), x), x))^2/f(x, t)^2)+(2*(diff(diff(diff(f(x, t), t), x), x))/f(x, t)-2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))/f(x, t)^2-4*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(f(x, t), x))^2*(diff(f(x, t), t))/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4)+2*(2*(diff(diff(diff(f(x, t), x), x), x))/f(x, t)-6*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))/f(x, t)^2+4*(diff(f(x, t), x))^3/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), t), x), x), x))/f(x, t)-6*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))/f(x, t)^2-2*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))/f(x, t)^2+12*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3-6*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+12*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))/f(x, t)^3-12*(diff(f(x, t), x))^3*(diff(f(x, t), t))/f(x, t)^4) = 0)) = numer(rhs(2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))/f(x, t)^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-4*(diff(diff(f(x, t), t), x))^2/f(x, t)^2+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))/f(x, t)^3-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-a*(2*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))/f(x, t)-12*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+60*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-30*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))^3/f(x, t)^4+240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))*(diff(diff(f(x, t), x), x))/f(x, t)^3-20*(diff(diff(diff(f(x, t), x), x), x))^2/f(x, t)^2+720*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4/f(x, t)^5-540*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2/f(x, t)^4+60*(diff(diff(f(x, t), x), x))^3/f(x, t)^3-240*(diff(f(x, t), x))^6/f(x, t)^6)-b*(32*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^3+16*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(diff(f(x, t), t), t), x))*(diff(f(x, t), x))/f(x, t)^3+384*(diff(f(x, t), x))^3*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^5+32*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3+96*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))/f(x, t)^3-48*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))/f(x, t)^4-72*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2/f(x, t)^4-144*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2/f(x, t)^4+288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))^2/f(x, t)^5+48*(diff(f(x, t), x))^4*(diff(diff(f(x, t), t), t))/f(x, t)^5-144*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))^2/f(x, t)^4-36*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+24*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)^3-8*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2-12*(diff(diff(diff(diff(f(x, t), t), t), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-4*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*(diff(f(x, t), t))/f(x, t)^2-16*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2+48*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2/f(x, t)^3+12*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-48*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^4-240*(diff(f(x, t), x))^4*(diff(f(x, t), t))^2/f(x, t)^6-288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^4+2*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))/f(x, t)-12*(diff(diff(diff(f(x, t), t), x), x))^2/f(x, t)^2)+(2*(diff(diff(diff(f(x, t), t), x), x))/f(x, t)-2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))/f(x, t)^2-4*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(f(x, t), x))^2*(diff(f(x, t), t))/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4)+2*(2*(diff(diff(diff(f(x, t), x), x), x))/f(x, t)-6*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))/f(x, t)^2+4*(diff(f(x, t), x))^3/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), t), x), x), x))/f(x, t)-6*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))/f(x, t)^2-2*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))/f(x, t)^2+12*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3-6*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+12*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))/f(x, t)^3-12*(diff(f(x, t), x))^3*(diff(f(x, t), t))/f(x, t)^4) = 0))*denom(lhs(2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))/f(x, t)^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-4*(diff(diff(f(x, t), t), x))^2/f(x, t)^2+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))/f(x, t)^3-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-a*(2*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))/f(x, t)-12*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+60*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-30*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))^3/f(x, t)^4+240*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))*(diff(diff(f(x, t), x), x))/f(x, t)^3-20*(diff(diff(diff(f(x, t), x), x), x))^2/f(x, t)^2+720*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4/f(x, t)^5-540*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2/f(x, t)^4+60*(diff(diff(f(x, t), x), x))^3/f(x, t)^3-240*(diff(f(x, t), x))^6/f(x, t)^6)-b*(32*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^3+16*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(f(x, t), x), x))*(diff(diff(diff(f(x, t), t), t), x))*(diff(f(x, t), x))/f(x, t)^3+384*(diff(f(x, t), x))^3*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))/f(x, t)^5+32*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3+96*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))/f(x, t)^3+48*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))/f(x, t)^3-48*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))/f(x, t)^4-72*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2/f(x, t)^4-144*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2/f(x, t)^4+288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*(diff(f(x, t), x))^2/f(x, t)^5+48*(diff(f(x, t), x))^4*(diff(diff(f(x, t), t), t))/f(x, t)^5-144*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))^2/f(x, t)^4-36*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), t))^2/f(x, t)^4+24*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))/f(x, t)^3-8*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2-12*(diff(diff(diff(diff(f(x, t), t), t), x), x))*(diff(diff(f(x, t), x), x))/f(x, t)^2-4*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*(diff(f(x, t), t))/f(x, t)^2-16*(diff(diff(diff(diff(f(x, t), t), x), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(f(x, t), t))^2/f(x, t)^3-2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*(diff(diff(f(x, t), t), t))/f(x, t)^2-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^2+48*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2/f(x, t)^3+12*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))/f(x, t)^3-48*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))/f(x, t)^4-240*(diff(f(x, t), x))^4*(diff(f(x, t), t))^2/f(x, t)^6-288*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^4+2*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))/f(x, t)-12*(diff(diff(diff(f(x, t), t), x), x))^2/f(x, t)^2)+(2*(diff(diff(diff(f(x, t), t), x), x))/f(x, t)-2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))/f(x, t)^2-4*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+4*(diff(f(x, t), x))^2*(diff(f(x, t), t))/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4)+2*(2*(diff(diff(diff(f(x, t), x), x), x))/f(x, t)-6*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))/f(x, t)^2+4*(diff(f(x, t), x))^3/f(x, t)^3)*(2*(diff(diff(diff(diff(f(x, t), t), x), x), x))/f(x, t)-6*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))/f(x, t)^2-2*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), t))/f(x, t)^2+12*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))/f(x, t)^3-6*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))/f(x, t)^2+12*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), x))/f(x, t)^3-12*(diff(f(x, t), x))^3*(diff(f(x, t), t))/f(x, t)^4) = 0))
2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*f(x, t)^6-4*(diff(diff(f(x, t), t), x))^2*f(x, t)^5-144*(diff(f(x, t), t))*(diff(f(x, t), x))^6-8*f(x, t)^4*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+120*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2+8*f(x, t)^3*(diff(f(x, t), t))*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))+96*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))+80*f(x, t)^3*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^2*(diff(diff(diff(f(x, t), x), x), x))-216*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2-96*f(x, t)^2*(diff(f(x, t), t))*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))-288*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3+360*f(x, t)*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)^3*(diff(diff(f(x, t), t), x))^2*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))*b+240*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))*a-720*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4*a-48*f(x, t)^2*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^4*b+240*f(x, t)*(diff(f(x, t), t))^2*(diff(f(x, t), x))^4*b-40*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-4*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))*f(x, t)^4-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))+36*f(x, t)^3*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))^2*b+540*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2*a-60*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a-24*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+8*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*b+8*f(x, t)^5*(diff(diff(diff(f(x, t), t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-4*f(x, t)^4*(diff(f(x, t), t))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b-12*f(x, t)^4*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2*b+12*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+2*f(x, t)^5*(diff(diff(f(x, t), t), t))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b+16*f(x, t)^5*(diff(diff(f(x, t), t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b+12*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*a+4*f(x, t)^5*(diff(f(x, t), t))*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*b+30*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a+144*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), t))^2*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b+72*f(x, t)^3*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2*b-288*f(x, t)^2*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2*b-384*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3*b+88*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-48*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*b-96*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*b-240*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*a-16*f(x, t)^4*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))*a-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))*b+12*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))^2*b+20*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))^2*a-60*f(x, t)^4*(diff(diff(f(x, t), x), x))^3*a+240*f(x, t)*(diff(f(x, t), x))^6*a-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*f(x, t)^5+4*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*f(x, t)^5-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*f(x, t)^5+8*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))-12*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*f(x, t)^4-8*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(diff(f(x, t), x), x), x))^2+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))*f(x, t)^4-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2*f(x, t)^3+12*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^3+16*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(diff(f(x, t), t), x), x), x))-72*f(x, t)^2*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^5+288*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b = 0
map(int, -8*f(x, t)^4*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+120*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2+8*f(x, t)^3*(diff(f(x, t), t))*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))+96*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))+80*f(x, t)^3*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^2*(diff(diff(diff(f(x, t), x), x), x))-216*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2-96*f(x, t)^2*(diff(f(x, t), t))*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))-288*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3+360*f(x, t)*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)^3*(diff(diff(f(x, t), t), x))^2*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))*b+240*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))*a-720*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4*a-48*f(x, t)^2*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^4*b+240*f(x, t)*(diff(f(x, t), t))^2*(diff(f(x, t), x))^4*b-40*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-4*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))*f(x, t)^4-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))+36*f(x, t)^3*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))^2*b+540*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2*a-60*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a-24*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+8*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*b+8*f(x, t)^5*(diff(diff(diff(f(x, t), t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-4*f(x, t)^4*(diff(f(x, t), t))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b-12*f(x, t)^4*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2*b+12*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+2*f(x, t)^5*(diff(diff(f(x, t), t), t))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b+16*f(x, t)^5*(diff(diff(f(x, t), t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b+12*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*a+4*f(x, t)^5*(diff(f(x, t), t))*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*b+30*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a+144*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), t))^2*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b+72*f(x, t)^3*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2*b-288*f(x, t)^2*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2*b-384*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3*b+88*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-48*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*b-96*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*b-240*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*a-16*f(x, t)^4*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b+2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*f(x, t)^6-4*(diff(diff(f(x, t), t), x))^2*f(x, t)^5-144*(diff(f(x, t), t))*(diff(f(x, t), x))^6-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))*a-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))*b+12*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))^2*b+20*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))^2*a-60*f(x, t)^4*(diff(diff(f(x, t), x), x))^3*a+240*f(x, t)*(diff(f(x, t), x))^6*a-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*f(x, t)^5+4*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*f(x, t)^5-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*f(x, t)^5+8*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))-12*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*f(x, t)^4-8*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(diff(f(x, t), x), x), x))^2+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))*f(x, t)^4-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2*f(x, t)^3+12*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^3+16*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(diff(f(x, t), t), x), x), x))-72*f(x, t)^2*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^5+288*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b = 0, x)
int(2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*f(x, t)^6-4*(diff(diff(f(x, t), t), x))^2*f(x, t)^5-144*(diff(f(x, t), t))*(diff(f(x, t), x))^6-8*f(x, t)^4*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+120*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2+8*f(x, t)^3*(diff(f(x, t), t))*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))+96*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))+80*f(x, t)^3*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^2*(diff(diff(diff(f(x, t), x), x), x))-216*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2-96*f(x, t)^2*(diff(f(x, t), t))*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))-288*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3+360*f(x, t)*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)^3*(diff(diff(f(x, t), t), x))^2*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), t), t), x))*b+240*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(f(x, t), x), x), x))*a-720*f(x, t)^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^4*a-48*f(x, t)^2*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^4*b+240*f(x, t)*(diff(f(x, t), t))^2*(diff(f(x, t), x))^4*b-40*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-4*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))+16*(diff(f(x, t), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), t))*f(x, t)^4-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))-24*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))+36*f(x, t)^3*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))^2*b+540*f(x, t)^3*(diff(diff(f(x, t), x), x))^2*(diff(f(x, t), x))^2*a-60*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a-24*f(x, t)^4*(diff(f(x, t), x))^2*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+8*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x))*b+8*f(x, t)^5*(diff(diff(diff(f(x, t), t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-4*f(x, t)^4*(diff(f(x, t), t))^2*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b-12*f(x, t)^4*(diff(diff(f(x, t), x), x))^2*(diff(diff(f(x, t), t), t))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))^2*b+12*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), t), t), x), x))*b+2*f(x, t)^5*(diff(diff(f(x, t), t), t))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*b+16*f(x, t)^5*(diff(diff(f(x, t), t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b+12*f(x, t)^5*(diff(f(x, t), x))*(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x))*a+4*f(x, t)^5*(diff(f(x, t), t))*(diff(diff(diff(diff(diff(f(x, t), t), x), x), x), x))*b+30*f(x, t)^5*(diff(diff(f(x, t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))*a+144*f(x, t)^3*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(f(x, t), x))^2*b+48*f(x, t)^3*(diff(f(x, t), t))^2*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b+72*f(x, t)^3*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))^2*b-288*f(x, t)^2*(diff(f(x, t), t))^2*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2*b-384*f(x, t)^2*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^3*b+88*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))-48*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*b-96*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(f(x, t), t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-32*f(x, t)^4*(diff(f(x, t), t))*(diff(f(x, t), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))*b-48*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*b-240*f(x, t)^4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*a-16*f(x, t)^4*(diff(diff(f(x, t), t), t))*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), x), x), x))*b-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), x), x), x), x), x), x))*a-2*f(x, t)^6*(diff(diff(diff(diff(diff(diff(f(x, t), t), t), x), x), x), x))*b+12*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))^2*b+20*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))^2*a-60*f(x, t)^4*(diff(diff(f(x, t), x), x))^3*a+240*f(x, t)*(diff(f(x, t), x))^6*a-4*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), t))*f(x, t)^5+4*f(x, t)^5*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(diff(diff(f(x, t), x), x), x), x))-2*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), t))*f(x, t)^5-4*(diff(f(x, t), x))*(diff(diff(diff(f(x, t), t), t), x))*f(x, t)^5+8*f(x, t)^5*(diff(diff(diff(f(x, t), x), x), x))*(diff(diff(diff(diff(f(x, t), t), x), x), x))-12*f(x, t)^4*(diff(diff(diff(f(x, t), t), x), x))*(diff(diff(f(x, t), x), x))^2+4*(diff(diff(f(x, t), x), x))*(diff(f(x, t), t))^2*f(x, t)^4-8*f(x, t)^4*(diff(f(x, t), t))*(diff(diff(diff(f(x, t), x), x), x))^2+4*(diff(f(x, t), x))^2*(diff(diff(f(x, t), t), t))*f(x, t)^4-12*(diff(f(x, t), x))^2*(diff(f(x, t), t))^2*f(x, t)^3+12*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))^3+16*f(x, t)^3*(diff(f(x, t), x))^3*(diff(diff(diff(diff(f(x, t), t), x), x), x))-72*f(x, t)^2*(diff(diff(diff(f(x, t), t), x), x))*(diff(f(x, t), x))^4+144*f(x, t)*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))^5+288*f(x, t)^3*(diff(f(x, t), t))*(diff(diff(f(x, t), x), x))*(diff(diff(f(x, t), t), x))*(diff(f(x, t), x))*b, x) = 0
Download int.mw
I have a set of four equations along with specific parameter values provided in the dataset. I need to create a graph where I can dynamically adjust the values of parameters g2 and y within the specified range given in the sheet.
question_plot_slider.mw
Could you provide a maple code that allows for this flexibility, ideally with interactive controls (like the slider buttons shown in the example figure)
I am working on a problem involving Newton's Law of Cooling in Maple, I want to:
  1. Solve for the cooling constant k,
  2. Find how long it takes for the pizza to cool to 300 F,
Here is the code I am currently using:
T__s := 75;  # Surrounding temperature
ode := diff(T(t), t) = k*(T(t) - T__s);
# General solution
general_solution := dsolve(ode, T(t));
# Initial condition: T(0) = 350
T := t -> 75 + exp(k*t)*c__1;
C := solve(350 = 75 + exp(0)*C__1, C__1);
# Solve for k using T(5) = 340
k := solve(340 = 75 + 275*exp(5*k), k);
k := evalf(k);
# Solve for time to reach T = 300
time_to_reach := solve(300 = 75 + 275*exp(k*t), t);
time_to_reach := evalf(time_to_reach);
# Define T(t) with solved constants
T := t -> 75 + 275*exp(k*t);
# Plot temperature over time
temp := plot(T, t = 0 .. 280, 75 .. 360, title = "Exponential Decay of Pizza Temperature", labels = ["t (minutes)", "T(t) (°F)"], color = blue);
# Plot T__s as a horizontal line
T__sur := plot(T__s, t = 0 .. 280, color = red, linestyle = dash);
# Combine and display plots
display([temp, T__sur]);
The code works, but I am wondering if there is a more efficient or genuine way.
I would greatly appreciate any advice or alternative approaches to solving and visualizing this in Maple.
Thank you in advance for your insights!
loading
First 94 95 96 97 98 99 100 Last Page 96 of 2468
